We want the fixes in here, and we can resolve a merge issue in
drivers/iio/industrialio-trigger.c
commit 98ad8b41f58dff6b30713d7f09ae3834b8df7ded
("iio: st_sensors: verify interrupt event to status") caused
a regression when reading ST sensors from a HRTimer trigger
rather than the intrinsic interrupts: the HRTimer may
trigger faster than the sensor provides new values, and
as the check against new values available as a cause of
the interrupt trigger was done in the poll function,
this would bail out of the HRTimer interrupt with
IRQ_NONE.
So clearly we need to only check the new values available
from the proper interrupt handler and not from the poll
function, which should rather just read the raw values
from the registers, put them into the buffer and be happy.
To achieve this: switch the ST Sensors over to using a true
threaded interrupt handler.
In the interrupt thread, check if new values are available,
else yield to the (potential) next device on the same
interrupt line to check the registers. If the interrupt
was ours, proceed to poll the values.
Instead of relying on iio_trigger_generic_data_rdy_poll() as
a top half to wake up the thread that polls the sensor for
new data, have the thread call iio_trigger_poll_chained()
after determining that is is the proper source of the
interrupt. This is modelled on drivers/iio/accel/mma8452.c
which is already using a properly threaded interrupt handler.
In order to get the same precision in timestamps as
previously, where samples would be timestamped in the
poll function pf->timestamp when calling
iio_trigger_generic_data_rdy_poll() we introduce a
local timestamp in the sensor data, set it in the top half
(fastpath) of the interrupt handler and provide that to the
core when calling iio_push_to_buffers_with_timestamp().
Additionally: if the active scanmask is not set for the
sensor no IRQs should be enabled and we need to bail out
with IRQ_NONE. This can happen if spurious IRQs fire when
installing the threaded interrupt handler.
Tested with hard interrupt triggers on LIS331DL, then also
tested with hrtimers on the same sensor by creating a 75Hz
HRTimer and using it to poll the sensor.
Cc: Giuseppe Barba <giuseppe.barba@st.com>
Cc: Denis Ciocca <denis.ciocca@st.com>
Reported-by: Crestez Dan Leonard <cdleonard@gmail.com>
Tested-by: Crestez Dan Leonard <cdleonard@gmail.com>
Tested-by: Jonathan Cameron <jic23@kernel.org>
Fixes: 97865fe41322 ("iio: st_sensors: verify interrupt event to status")
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
Ensure failure to enable power regulators is properly handled.
Signed-off-by: Gregor Boirie <gregor.boirie@parrot.com>
This makes all ST sensor drivers check that they actually have
new data available for the requested channel(s) before claiming
an IRQ, by reading the status register (which is conveniently
the same for all ST sensors) and check that the channel has new
data before proceeding to read it and fill the buffer.
This way sensors can share an interrupt line: it can be flaged
as shared and then the sensor that did not fire will return
NO_IRQ, and the sensor that fired will handle the IRQ and
return IRQ_HANDLED.
Most ST MEMS Sensors that support interrupts can also handle sending
an active low interrupt, i.e. going from high to low on data ready
(or other interrupt) and thus triggering on a falling edge to the
interrupt controller.
Set up logic to inspect the interrupt line we get for a sensor: if
it is triggering on rising edge, leave everything alone, but if it
triggers on falling edges, set up active low, and if unsupported
configurations appear: warn with errors and reconfigure the interrupt
to a rising edge, which all interrupt generating sensors support.
Create a local header for st_sensors_core.h to share functions
between the sensor core and the trigger setup code.
This adds a debugfs hook to read/write registers in the ST
sensors using debugfs. Proved to be awesome help when trying
to debug why IRQs do not arrive.
Acked-by: Denis Ciocca <denis.ciocca@st.com>
This adds support for the lsm303agr magnetometer.
Signed-off-by: Giuseppe Barba <giuseppe.barba@st.com>
Add irq trigger handling for magnetometer also
This patch permits to configure the WhoAmI register address
because some device could have not a standard address for
this register.
Reviewed-by: Denis Ciocca <denis.ciocca@st.com>
We want the fixes in here for testing and merge issues.
The LSM303DLH accelerometer/magnetometer has a different
device identification method than using register 0x0f, instead
three registers contain a magic value. We rely on WhoAmI
to be zero for this variant.
In SPI mode the transfer buffer is locked with a mutex. However this
mutex is only initilized after the probe, but some transfer needs to
be done in the probe.
To fix this bug we move the mutex initialization at the beginning of
the device probe.
Signed-off-by: Alban Bedel <alban.bedel@avionic-design.de>
Cc: <Stable@vger.kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-next
Jonathan writes:
First round of new drivers, features and cleanups for IIO in the 3.19 cycle.
New drivers / supported parts
* rockchip - rk3066-tsadc variant
* si7020 humidity and temperature sensor
* mcp320x - add mcp3001, mcp3002, mcp3004, mcp3008, mcp3201, mcp3202
* bmp280 pressure and temperature sensor
* Qualcomm SPMI PMIC current ADC driver
* Exynos_adc - support exynos7
New features
* vf610-adc - add temperature sensor support
* Documentation of current attributes, scaled pressure, offset and
scaled humidity, RGBC intensity gain factor and scale applied to
differential voltage channels.
* Bring iio_event_monitor up to date with newer modifiers.
* Add of_xlate function to allow for complex channel mappings from the
device tree.
* Add -g parameter to generic_buffer example to allow for devices with
directly fed (no trigger) buffers.
* Move exynos driver over to syscon for PMU register access.
Cleanups, fixes for new drivers
* lis3l02dq drop an unneeded else.
* st sensors - renam st_sensors to st_sensor_settings (for clarity)
* st sensors - drop an unused parameter from all the probe utility
functions.
* vf610 better error handling and tidy up.
* si7020 - cleanups following merge
* as3935 - drop some unnecessary semicolons.
* bmp280 - fix the pressure calculation.
Signed-off-by: Denis Ciocca <denis.ciocca@st.com>
This patch change structure name and related variables names.
This patch fix gains values. The first driver was designed using
engineering samples, in mass production the values are changed.
Cc: Stable@vger.kernel.org
support.
This allows in kernel client drivers to access this
Reviewed-by: Hartmut Knaack <knaack.h@gmx.de>
Currently the pressure sensor has code to retrieve and enable two
regulators for Vdd and Vdd IO, but actually these voltage inputs
are found on all of these ST sensors, so move the regulator
handling to the core and make sure all the ST sensors call these
functions on probe() and remove() to enable/disable power.
Here also mover over to obtaining the regulator from the *parent*
device of the IIO device, as the IIO device is created on-the-fly
in this very subsystem it very unlikely evert have any regulators
attached to it whatsoever. It is much more likely that the parent
is a platform device, possibly instantiated from a device tree,
which in turn have Vdd and Vdd IO supplied assigned to it.
Cc: Lee Jones <lee.jones@linaro.org>
Cc: Denis CIOCCA <denis.ciocca@st.com>
It is pretty helpful to know already from dmesg that a certain
device is successfully registered, instead of having to browse
sysfs to see if it's actually there.
We want the staging fixes in this branch as well.
This patch fix buffer registration that allows to use generic IIO trigger.
Reduce the amount of those unnecessary goto calls, as in most cases
we can simply return immediately. We also only call for the IRQ number
once and use that value throughout.
Signed-off-by: Lee Jones <lee.jones@linaro.org>
Using devm_iio_device_alloc makes code simpler.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
This patch add support to redirect the DRDY interrupt on INT1 or INT2
on accelerometer and pressure sensors.
struct and added support on one-shot sysfs reads to 3 byte channel
This patch introduce num_data_channels variable on st_sensors struct
to manage different type of channels (size or number) in
st_sensors_get_buffer_element function.
Removed ST_SENSORS_NUMBER_DATA_CHANNELS and ST_SENSORS_BYTE_FOR_CHANNEL
and used struct iio_chan_spec const *ch to catch data.
Added 3 byte channel data support on one-shot reads.
Partly a case of removing unused headers and partly a case
of ifdefing out the iio_trigger_ops structures. This has
come about because of an 'unusual' separation of code in this
driver.
Reported-by: Randy Dunlap <rdunlap@infradead.org>
This patch adds a generic magnetometer driver for STMicroelectronics
magnetometers, currently it supports:
LSM303DLHC, LSM303DLM, LIS3MDL.
