[ Upstream commit 2e4b88f73966adead360e47621df0183586fac32 ]
In remove, the clock is disabled before canceling the
delayed work. This means that the delayed work may be
touching unclocked hardware.
Fix by disabling the clock after the delayed work is
fully canceled. This is consistent with the probe error
path order.
Signed-off-by: Sven Van Asbroeck <TheSven73@gmail.com>
Signed-off-by: Jonathan Cameron <Jonathan.Cameron@huawei.com>
[ Upstream commit 862e4644fd2d7df8998edc65e0963ea2f567bde9 ]
If probe errors out after request_irq(), its error path
does not explicitly cancel the delayed work, which may
have been scheduled by the interrupt handler.
This means the delayed work may still be running when
the core frees the private structure (struct xadc).
This is a potential use-after-free.
Fix by inserting cancel_delayed_work_sync() in the probe
error path.
[ Upstream commit 62039b6aef63380ba7a37c113bbaeee8a55c5342 ]
When cancel_delayed_work() returns, the delayed work may still
be running. This means that the core could potentially free
the private structure (struct xadc) while the delayed work
is still using it. This is a potential use-after-free.
Fix by calling cancel_delayed_work_sync(), which waits for
any residual work to finish before returning.
commit 447ccb4e0834a9f9f0dd5643e421c7f1a1649e6a upstream.
The of_device_id table needs to be registered as module alias in order
for automatic module loading to pick the kernel module based on the
DeviceTree compatible. So add MODULE_DEVICE_TABLE() to make this happen.
Fixes: e13d757279bb ("iio: adc: Add QCOM SPMI PMIC5 ADC driver")
Cc: stable@vger.kernel.org
Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
commit fe2d3df639a7940a125a33d6460529b9689c5406 upstream.
On some laptops, kxcjk1013 is powered off when system enters S3. We need
restore the range regiter during resume. Otherwise, the sensor doesn't
work properly after S3.
Signed-off-by: he, bo <bo.he@intel.com>
Signed-off-by: Chen, Hu <hu1.chen@intel.com>
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
Cc: <Stable@vger.kernel.org>
commit 7f75591fc5a123929a29636834d1bcb8b5c9fee3 upstream.
This fixes a possible circular locking dependency detected warning seen
with:
- CONFIG_PROVE_LOCKING=y
- consumer/provider IIO devices (ex: "voltage-divider" consumer of "adc")
When using the IIO consumer interface, e.g. iio_channel_get(), the consumer
device will likely call iio_read_channel_raw() or similar that rely on
'info_exist_lock' mutex.
typically:
mutex_lock(&chan->indio_dev->info_exist_lock);
if (chan->indio_dev->info == NULL) {
ret = -ENODEV;
goto err_unlock;
ret = do_some_ops()
err_unlock:
mutex_unlock(&chan->indio_dev->info_exist_lock);
return ret;
Same mutex is also hold in iio_device_unregister().
The following deadlock warning happens when:
- the consumer device has called an API like iio_read_channel_raw()
at least once.
- the consumer driver is unregistered, removed (unbind from sysfs)
WARNING: possible circular locking dependency detected
4.19.24 #577 Not tainted
sh/372 is trying to acquire lock:
(kn->count#30){++++}, at: kernfs_remove_by_name_ns+0x3c/0x84
but task is already holding lock:
(&dev->info_exist_lock){+.+.}, at: iio_device_unregister+0x18/0x60
which lock already depends on the new lock.
the existing dependency chain (in reverse order) is:
-> #1 (&dev->info_exist_lock){+.+.}:
__mutex_lock+0x70/0xa3c
mutex_lock_nested+0x1c/0x24
iio_read_channel_raw+0x1c/0x60
iio_read_channel_info+0xa8/0xb0
dev_attr_show+0x1c/0x48
sysfs_kf_seq_show+0x84/0xec
seq_read+0x154/0x528
__vfs_read+0x2c/0x15c
vfs_read+0x8c/0x110
ksys_read+0x4c/0xac
ret_fast_syscall+0x0/0x28
0xbedefb60
-> #0 (kn->count#30){++++}:
lock_acquire+0xd8/0x268
__kernfs_remove+0x288/0x374
remove_files+0x34/0x78
sysfs_remove_group+0x40/0x9c
sysfs_remove_groups+0x24/0x34
device_remove_attrs+0x38/0x64
device_del+0x11c/0x360
cdev_device_del+0x14/0x2c
iio_device_unregister+0x24/0x60
release_nodes+0x1bc/0x200
device_release_driver_internal+0x1a0/0x230
unbind_store+0x80/0x130
kernfs_fop_write+0x100/0x1e4
__vfs_write+0x2c/0x160
vfs_write+0xa4/0x17c
ksys_write+0x4c/0xac
0xbe906840
Possible unsafe locking scenario:
CPU0 CPU1
lock(&dev->info_exist_lock);
lock(kn->count#30);
lock(kn->count#30);
*** DEADLOCK ***
cdev_device_del() can be called without holding the lock. It should be safe
as info_exist_lock prevents kernelspace consumers to use the exported
routines during/after provider removal. cdev_device_del() is for userspace.
Help to reproduce:
See example: Documentation/devicetree/bindings/iio/afe/voltage-divider.txt
sysv {
compatible = "voltage-divider";
io-channels = <&adc 0>;
output-ohms = <22>;
full-ohms = <222>;
First, go to iio:deviceX for the "voltage-divider", do one read:
$ cd /sys/bus/iio/devices/iio:deviceX
$ cat in_voltage0_raw
Then, unbind the consumer driver. It triggers above deadlock warning.
$ cd /sys/bus/platform/drivers/iio-rescale/
$ echo sysv > unbind
Note I don't actually expect stable will pick this up all the
way back into IIO being in staging, but if's probably valid that
far back.
Signed-off-by: Fabrice Gasnier <fabrice.gasnier@st.com>
Fixes: ac917a81117c ("staging:iio:core set the iio_dev.info pointer to null on unregister")
commit 09c6bdee51183a575bf7546890c8c137a75a2b44 upstream.
Having a brief look at at91_adc_read_raw() it is obvious that in the case
of a timeout the setting of AT91_ADC_CHDR and AT91_ADC_IDR registers is
omitted. If 2 different channels are queried we can end up with a
situation where two interrupts are enabled, but only one interrupt is
cleared in the interrupt handler. Resulting in a interrupt loop and a
system hang.
Signed-off-by: Georg Ottinger <g.ottinger@abatec.at>
Acked-by: Ludovic Desroches <ludovic.desroches@microchip.com>
commit 20ea39ef9f2f911bd01c69519e7d69cfec79fde3 upstream.
The trialmask is expected to have all bits set to 0 after allocation.
Currently kmalloc_array() is used which does not zero the memory and so
random bits are set. This results in random channels being enabled when
they shouldn't. Replace kmalloc_array() with kcalloc() which has the same
interface but zeros the memory.
Note the fix is actually required earlier than the below fixes tag, but
will require a manual backport due to move from kmalloc to kmalloc_array.
Signed-off-by: Alexandru Ardelean <alexandru.ardelean@analog.com>
Fixes commit 057ac1acdfc4 ("iio: Use kmalloc_array() in iio_scan_mask_set()").
commit 06003531502d06bc89d32528f6ec96bf978790f9 upstream.
When issuing the write DAC register and write eeprom command, the two
powerdown bits (PD0 and PD1) are assumed by the chip to be present in
the bytes sent. Leaving them at 0 implies "powerdown disabled" which is
a different state that the current one. By adding the current state of
the powerdown in the i2c write, the chip will correctly power-on exactly
like as it is at the moment of store_eeprom call.
This is documented in MCP4725's datasheet, FIGURE 6-2: "Write Commands
for DAC Input Register and EEPROM" and MCP4726's datasheet, FIGURE 6-3:
"Write All Memory Command".
Signed-off-by: Jean-Francois Dagenais <jeff.dagenais@gmail.com>
Acked-by: Peter Meerwald-Stadler <pmeerw@pmeerw.net>
commit fccfb9ce70ed4ea7a145f77b86de62e38178517f upstream.
The desired channel has to be selected in order to correctly fill the
buffer with the corresponding data.
The `ad_sd_write_reg()` already does this, but for the
`ad_sd_read_reg_raw()` this was omitted.
Fixes: af3008485ea03 ("iio:adc: Add common code for ADI Sigma Delta devices")
Signed-off-by: Dragos Bogdan <dragos.bogdan@analog.com>
commit 3d02d7082e5823598090530c3988a35f69689943 upstream.
Calculation did not use IIO_DEGREE_TO_RAD and implemented a variant to
avoid precision loss as we aim a nano value. The offset added to avoid
rounding error, though, doesn't give us a close result to the expected
value. E.g.
For 1000dps, the result should be:
(1000 * pi ) / 180 >> 15 ~= 0.000532632218
But with current calculation we get
$ cat scale
0.000547890
Fix the calculation by just doing the maths involved for a nano value
val * pi * 10e12 / (180 * 2^15)
so we get a closer result.
$ cat scale
0.000532632
Fixes: c14dca07a31d ("iio: cros_ec_sensors: add ChromeOS EC Contiguous Sensors driver")
Signed-off-by: Gwendal Grignou <gwendal@chromium.org>
Signed-off-by: Enric Balletbo i Serra <enric.balletbo@collabora.com>
commit 73f3bc6da506711302bb67572440eb84b1ec4a2c upstream.
The SPI interface implementation was completely broken.
When using the SPI interface, there are only 7 address bits, the upper bit
is controlled by a page select register. The core needs access to both
ranges, so implement register read/write for both regions. The regmap
paging functionality didn't agree with a register that needs to be read
and modified, so I implemented a custom paging algorithm.
This fixes that the device wouldn't even probe in SPI mode.
The SPI interface then isn't different from I2C, merged them into the core,
and the I2C/SPI named registers are no longer needed.
Implemented register value caching for the registers to reduce the I2C/SPI
data transfers considerably.
The calibration set reads as all zeroes until some undefined point in time,
and I couldn't determine what makes it valid. The datasheet mentions these
registers but does not provide any hints on when they become valid, and they
aren't even enumerated in the memory map. So check the calibration and
retry reading it from the device after each measurement until it provides
something valid.
Despite the size this is suitable for a stable backport given that
it seems the SPI support never worked.
Signed-off-by: Mike Looijmans <mike.looijmans@topic.nl>
Fixes: 1b3bd8592780 ("iio: chemical: Add support for Bosch BME680 sensor");
commit 9436f45dd53595e21566a8c6627411077dfdb776 upstream.
The standard unit for temperature is millidegrees Celcius. Adapt the
driver to report in millidegrees instead of degrees.
commit 40a7198a4a01037003c7ca714f0d048a61e729ac upstream.
Standard unit for temperature is millidegrees Celcius, whereas this driver
was reporting in degrees. Fix the scale factor in the driver.
commit 409a51e0a4a5f908763191fae2c29008632eb712 upstream.
According to the datasheet, the last bit of CHIP_ID register controls
I2C bus, and the first one is unused. Handle this correctly.
Note that there are chips out there that have a value such that
the id check currently fails.
Signed-off-by: Sergey Larin <cerg2010cerg2010@mail.ru>
[ Upstream commit e0f0ae838a25464179d37f355d763f9ec139fc15 ]
The pm8xxx_get_channel() implementation is unclear, and causes gcc to
suddenly generate odd warnings. The trigger for the warning (at least
for me) was the entirely unrelated commit 79a4e91d1bb2 ("device.h: Add
__cold to dev_<level> logging functions"), which apparently changes gcc
code generation in the caller function enough to cause this:
drivers/iio/adc/qcom-pm8xxx-xoadc.c: In function ‘pm8xxx_xoadc_probe’:
drivers/iio/adc/qcom-pm8xxx-xoadc.c:633:8: warning: ‘ch’ may be used uninitialized in this function [-Wmaybe-uninitialized]
ret = pm8xxx_read_channel_rsv(adc, ch, AMUX_RSV4,
&read_nomux_rsv4, true);
drivers/iio/adc/qcom-pm8xxx-xoadc.c:426:27: note: ‘ch’ was declared here
struct pm8xxx_chan_info *ch;
because gcc for some reason then isn't able to see that the termination
condition for the "for( )" loop in that function is also the condition
for returning NULL.
So it's not _actually_ uninitialized, but the function is admittedly
just unnecessarily oddly written.
Simplify and clarify the function, making gcc also see that it always
returns a valid initialized value.
Cc: Joe Perches <joe@perches.com>
Cc: Andy Gross <andy.gross@linaro.org>
Cc: David Brown <david.brown@linaro.org>
Cc: Jonathan Cameron <jic23@kernel.org>
Cc: Hartmut Knaack <knaack.h@gmx.de>
Cc: Lars-Peter Clausen <lars@metafoo.de>
Cc: Peter Meerwald-Stadler <pmeerw@pmeerw.net>
commit 103cda6a3b8d2c10d5f8cd7abad118e9db8f4776 upstream.
Exynos4212 and Exynos4412 have only four ADC channels so using
"samsung,exynos-adc-v1" compatible (for eight channels ADCv1) on them is
wrong. Add a new compatible for Exynos4x12.
Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
commit 2ea8bab4dd2a9014e723b28091831fa850b82d83 upstream.
Fix NULL pointer exception on device unbind when device tree does not
contain "has-touchscreen" property. In such case the input device is
not registered so it should not be unregistered.
$ echo "12d10000.adc" > /sys/bus/platform/drivers/exynos-adc/unbind
Unable to handle kernel NULL pointer dereference at virtual address 00000474
(input_unregister_device) from [<c0772060>] (exynos_adc_remove+0x20/0x80)
(exynos_adc_remove) from [<c0587d5c>] (platform_drv_remove+0x20/0x40)
(platform_drv_remove) from [<c05860f0>] (device_release_driver_internal+0xdc/0x1ac)
(device_release_driver_internal) from [<c0583ecc>] (unbind_store+0x60/0xd4)
(unbind_store) from [<c031b89c>] (kernfs_fop_write+0x100/0x1e0)
(kernfs_fop_write) from [<c029709c>] (__vfs_write+0x2c/0x17c)
(__vfs_write) from [<c0297374>] (vfs_write+0xa4/0x184)
(vfs_write) from [<c0297594>] (ksys_write+0x4c/0xac)
(ksys_write) from [<c0101000>] (ret_fast_syscall+0x0/0x28)
Fixes: 2bb8ad9b44c5 ("iio: exynos-adc: add experimental touchscreen support")
Cc: <stable@vger.kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-linus
Jonathan writes:
First set of IIO fixes for the 5.0 cycle.
Been a busy month, so these are rather later than they should have been.
* atlas-ph-sensor:
- Temperature scale didn't correspond to the ABI.
* axp288:
- A few different fixes around the TS-pin handling.
* ti-ads8688
- Not enough space in the buffer used to build the scan to allow for
the timestamp.
* tools - iio_generic_buffer
- Make num_loops signed so that we really are running for ever
rather than just a long time when we specify -1.
* tag 'iio-fixes-5.0a' of git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio:
iio: ti-ads8688: Update buffer allocation for timestamps
tools: iio: iio_generic_buffer: make num_loops signed
iio: adc: axp288: Fix TS-pin handling
iio: chemical: atlas-ph-sensor: correct IIO_TEMP values to millicelsius
git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd
Pull MFD updates from Lee Jones:
"New Device Support
- Add support for Power Supply to AXP813
- Add support for GPIO, ADC, AC and Battery Power Supply to AXP803
- Add support for UART to Exynos LPASS
Fix-ups:
- Use supplied MACROS; ti_am335x_tscadc
- Trivial spelling/whitespace/alignment; tmio, axp20x, rave-sp
- Regmap changes; bd9571mwv, wm5110-tables
- Kconfig dependencies; MFD_AT91_USART
- Supply shared data for child-devices; madera-core
- Use new of_node_name_eq() API call; max77620, stmpe
- Use managed resources (devm_*); tps65218
- Comment descriptions; ingenic-tcu
- Coding style; madera-core
Bug Fixes:
- Fix section mismatches; twl-core, db8500-prcmu
- Correct error path related issues; mt6397-core, ab8500-core, mc13xxx-core
- IRQ related fixes; tps6586x
- Ensure proper initialisation sequence; qcom_rpm
- Repair potential memory leak; cros_ec_dev"
* tag 'mfd-next-4.21' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd: (25 commits)
mfd: exynos-lpass: Enable UART module support
mfd: mc13xxx: Fix a missing check of a register-read failure
mfd: cros_ec: Add commands to control codec
mfd: madera: Remove spurious semicolon in while loop
mfd: rave-sp: Fix typo in rave_sp_checksum comment
mfd: ingenic-tcu: Fix bit field description in header
mfd: tps65218: Use devm_regmap_add_irq_chip and clean up error path in probe()
mfd: Use of_node_name_eq() for node name comparisons
mfd: cros_ec_dev: Add missing mfd_remove_devices() call in remove
mfd: axp20x: Add supported cells for AXP803
mfd: axp20x: Re-align MFD cell entries
mfd: axp20x: Add AC power supply cell for AXP813
mfd: wm5110: Add missing ASRC rate register
mfd: qcom_rpm: write fw_version to CTRL_REG
mfd: tps6586x: Handle interrupts on suspend
mfd: madera: Add shared data for accessory detection
mfd: at91-usart: Add platform dependency
mfd: bd9571mwv: Add volatile register to make DVFS work
mfd: ab8500-core: Return zero in get_register_interruptible()
mfd: tmio: Typo s/use use/use/
Per Jonathan Cameron, the buffer needs to allocate room for a
64 bit timestamp as well as the channels. Change the buffer
to allocate this additional space.
Fixes: 2a86487786b5c ("iio: adc: ti-ads8688: add trigger and buffer support")
Signed-off-by: Dan Murphy <dmurphy@ti.com>
Prior to this commit there were 3 issues with our handling of the TS-pin:
1) There are 2 ways how the firmware can disable monitoring of the TS-pin
for designs which do not have a temperature-sensor for the battery:
a) Clearing bit 0 of the AXP20X_ADC_EN1 register
b) Setting bit 2 of the AXP288_ADC_TS_PIN_CTRL monitoring
Prior to this commit we were unconditionally setting both bits to the
value used on devices with a TS. This causes the temperature protection to
kick in on devices without a TS, such as the Jumper ezbook v2, causing
them to not charge under Linux.
This commit fixes this by using regmap_update_bits when updating these 2
registers, leaving the 2 mentioned bits alone.
The next 2 problems are related to our handling of the current-source
for the TS-pin. The current-source used for the battery temp-sensor (TS)
is shared with the GPADC. For proper fuel-gauge and charger operation the
TS current-source needs to be permanently on. But to read the GPADC we
need to temporary switch the TS current-source to ondemand, so that the
GPADC can use it, otherwise we will always read an all 0 value.
2) Problem 2 is we were writing hardcoded values to the ADC TS pin-ctrl
register, overwriting various other unrelated bits. Specifically we were
overwriting the current-source setting for the TS and GPIO0 pins, forcing
it to 80ųA independent of its original setting. On a Chuwi Vi10 tablet
this was causing us to get a too high adc value (due to a too high
current-source) resulting in the following errors being logged:
ACPI Error: AE_ERROR, Returned by Handler for [UserDefinedRegion]
ACPI Error: Method parse/execution failed \_SB.SXP1._TMP, AE_ERROR
This commit fixes this by using regmap_update_bits to change only the
relevant bits.
3) After reading the GPADC channel we were unconditionally enabling the
TS current-source even on devices where the TS-pin is not used and the
current-source thus was off before axp288_adc_read_raw call.
This commit fixes this by making axp288_adc_set_ts a nop on devices where
the ADC is not enabled for the TS-pin.
BugLink: https://bugzilla.redhat.com/show_bug.cgi?id=1610545
Fixes: 3091141d7803 ("iio: adc: axp288: Fix the GPADC pin ...")
IIO_TEMP scale value for temperature was incorrect and not in millicelsius
as required by the ABI documentation.
Signed-off-by: Matt Ranostay <matt.ranostay@konsulko.com>
Fixes: 27dec00ecf2d (iio: chemical: add Atlas pH-SM sensor support)
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
Pull staging/IIO driver updates from Greg KH:
"Here is the big staging and iio driver pull request for 4.21-rc1.
Lots and lots of tiny patches here, nothing major at all. Which is
good, tiny cleanups is nice to see. No new huge driver removal or
addition, this release cycle, although there are lots of good IIO
driver changes, addtions, and movement from staging into the "real"
part of the kernel, which is always great.
Full details are in the shortlog, and all of these have been in
linux-next for a while with no reported issues"
* tag 'staging-4.21-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (553 commits)
staging: mt7621-mmc: Correct spelling mistakes in comments
staging: wilc1000: fix missing read_write setting when reading data
mt7621-mmc: char * array declaration might be better as static const
mt7621-mmc: return statement in void function unnecessary
mt7621-mmc: Alignment should match open parenthesis
mt7621-mmc: Removed unnecessary blank lines
mt7621-mmc: Fix some coding style issues
staging: android: ashmem: doc: Fix spelling
staging: rtl8188eu: cleanup brace coding style issues
staging: rtl8188eu: add spaces around '&' in rtw_mlme_ext.c
staging: rtl8188eu: change return type of is_basicrate() to bool
staging: rtl8188eu: simplify null array initializations
staging: rtl8188eu: change order of declarations to improve readability
staging: rtl8188eu: make some arrays static in rtw_mlme_ext.c
staging: rtl8188eu: constify some arrays
staging: rtl8188eu: convert unsigned char arrays to u8
staging: rtl8188eu: remove redundant declaration in rtw_mlme_ext.c
staging: rtl8188eu: remove unused arrays WFD_OUI and WMM_INFO_OUI
staging: rtl8188eu: remove unnecessary parentheses in rtw_mlme_ext.c
staging: rtl8188eu: remove unnecessary comments in rtw_mlme_ext.c
git://git.infradead.org/linux-platform-drivers-x86
Pull x86 platform driver updates from Andy Shevchenko:
- The USB Power Delivery discrete components now can be enumerated by
i2c-multi-instantiate driver via several resources under single ACPI
device node (ACPI ID is INT3515).
- Touchscreen support is added for the Mediacom Flexbook Edge 11.
- Mellanox driver got fixed due to updates in their firmware.
- The power management stub driver for AtomISP v2 is fixed in order to
support Intel Baytrail SoCs where same quirk is needed for S0ix to
work.
- Special key handling has been fixed for Favorites hotkey on Thinkpad,
and Screen LOCK on ASUS.
- Ideapad Yoga 2 13 has no HW rfkill switch, thus, driver has been
updated to support this.
- Few cleanups related to debugfs have been made in Intel IPS and Intel
PMC drivers. Besides that Intel PMC has been extended to show more
detailed information about Latency Tolerance
* tag 'platform-drivers-x86-v4.21-1' of git://git.infradead.org/linux-platform-drivers-x86: (41 commits)
platform/x86: mlx-platform: Convert to use SPDX identifier
Documentation/ABI: Add new attribute for mlxreg-io sysfs interfaces
platform/x86: mlx-platform: Allow mlxreg-io driver activation for new systems
platform/x86: mlx-platform: Fix LED configuration
platform/x86: mlx-platform: Fix tachometer registers
platform/x86: mlx-platform: Rename new systems product names
platform/x86: mlx-platform: Add definitions for new registers
platform/x86: intel_telemetry: convert to DEFINE_SHOW_ATTRIBUTE
platform/x86: intel_pmc_core: convert to DEFINE_SHOW_ATTRIBUTE
platform/x86: thinkpad_acpi: Cleanup quirks macros
platform/x86: touchscreen_dmi: Add info for the Mediacom Flexbook Edge 11
platform/x86: Fix config space access for intel_atomisp2_pm
platform/x86: Add the VLV ISP PCI ID to atomisp2_pm
platform/x86: intel_ips: Convert to use DEFINE_SHOW_ATTRIBUTE macro
platform/x86: intel_ips: Remove never happen condition
platform/x86: intel_ips: NULL check before some freeing functions is not needed
platform/x86: intel_ips: remove unnecessary checks in ips_debugfs_init
iio: inv_mpu6050: Use i2c_acpi_get_i2c_resource() helper
ACPI / scan: Create platform device for INT3515 ACPI nodes
platform/x86: i2c-multi-instantiate: Allow to have same slaves
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-next
Jonathan writes:
Second set of IIO new device support, features and cleanups for the 4.21 cycle.
Staging graduation
* ad2s90
- Driver for this resolver to digital chip.
New drivers and device support.
* ad5686
- Add support for ad5310r DAC and associated fix in value read back.
* exynos-adc
- Support for S5PV210 which is slightly different from other parts.
* mcp41010
- Driver supporting MCP41010, MCP41050, MCP41100, MCP42010, MCP42050 and
MCP42100 microchip potentiometers.
New ACPI ids.
* ak8975
- AKM9911 ACPI HID.
* kxcjk-1013
- KXJ2109 ACPI HID.
- KIOX010A ACPI HID.
New features
* ad5933
- Explicit DT binding.
* ad2s90
- Explicit DT binding including dropping spi setup that is done via dt
in favour of verifying the settings form DT.
* adt7316
- Explicit DT binding and support for gpio, irq_flags etc.
* stm32-adc
- Runtime power management.
Minor fixes and cleanups
* core
- Protect against missing info structure.
* ad2s90
- SPDX
- Add documentation fo the mutex.
* ad7280a
- Check allocation failure.
- Fix an accidental replacement of an error return.
* adt7316
- Switch some variables to be local and rename for consistency with other
drivers.
- Revert a false handling of 0 as an error introduced earlier this cycle.
* bmi160
- Use devm functions throughout probe() to avoid need for remove().
* hid-sensor-hub
- White space cleanup.
* hts221
- MAINTAINERS entry.
* lis302
- Use generic name in the DT binding doc.
* Messon-saradc
- Check for allocation error.
- Fix some presented clock names that break clk debugfs.
* qcom-spmi-adc
- A fix for initialization of the prescale property. Came late in the
cycle, so merge window is probably the best route for this.
* st_lsm6dsx
- Allow for variable read length to support wider range of slave devices.
* tag 'iio-for-4.21b' of git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio: (37 commits)
iio: adc: qcom-spmi-adc5: Initialize prescale properly
dt-bindings: iio: adc: exynos-adc: Add S5PV210 variant
iio: adc: Allow selection of Exynos ADC on S5PV210
iio: bmi160: use all devm functions in probe
iio: dac: ad5686: fix bit shift read register
iio:dac:ad5686: Add AD5310R support
Revert "Staging: iio: adt7316: Add an extra check for 'ret' equals to 0"
dt-bindings: iio: accel: use a generic node name for lis302
iio: core: check 'info' value before registering the device
staging: iio: adc: ad7280a: fix overwrite of the returned value
staging: iio: adc: ad7280a: check for devm_kasprint() failure
iio: humidity: hts221: add entry in MAINTAINERS file
iio: magnetometer: ak8975: Add the "AKM9911" ACPI HID
staging:iio:ad2s90: Move out of staging
staging:iio:ad2s90: Add comment to device state mutex
staging:iio:ad2s90: Replace license text w/ SPDX identifier
dt-bindings:iio:resolver: Add docs for ad2s90
staging:iio:ad2s90: Add max frequency check at probe
staging:iio:ad2s90: Remove spi setup that should be done via dt
adc5_get_dt_data uses a local, prop, feeds it to adc5_get_dt_channel_data,
and then puts the result into adc->chan_props. The problem is
adc5_get_dt_channel_data may not initialize that structure fully, so a
garbage value is used for prescale if the optional "qcom,pre-scaling" is
not defined in DT. adc5_read_raw then uses this as an array index,
generating a crash that looks like this:
[ 6.683186] Unable to handle kernel paging request at virtual address ffffff90e78c7964
Call trace:
qcom_vadc_scale_code_voltage_factor+0x74/0x104
qcom_vadc_scale_hw_calib_die_temp+0x20/0x60
qcom_adc5_hw_scale+0x78/0xa4
adc5_read_raw+0x3d0/0x65c
iio_channel_read+0x240/0x30c
iio_read_channel_processed+0x10c/0x150
qpnp_tm_get_temp+0xc0/0x40c
of_thermal_get_temp+0x7c/0x98
thermal_zone_get_temp+0xac/0xd8
thermal_zone_device_update+0xc0/0x38c
qpnp_tm_probe+0x624/0x81c
platform_drv_probe+0xe4/0x11c
really_probe+0x188/0x3fc
driver_probe_device+0xb8/0x188
__device_attach_driver+0x114/0x180
bus_for_each_drv+0xd8/0x118
__device_attach+0x180/0x27c
device_initial_probe+0x20/0x2c
bus_probe_device+0x78/0x124
deferred_probe_work_func+0xfc/0x138
process_one_work+0x3d8/0x8b0
process_scheduled_works+0x48/0x6c
worker_thread+0x488/0x7cc
kthread+0x24c/0x264
ret_from_fork+0x10/0x18
Unfortunately, when I went to add the initializer for this and tried to
boot it, my machine shut down immediately, complaining that it was
hotter than the sun. It appears that adc5_chans_pmic and adc5_chans_rev2
were initializing prescale_index as if it were directly a divisor,
rather than the index into adc5_prescale_ratios that it is.
Fix the uninitialized value, and change the static initialization to use
indices into adc5_prescale_ratios.
Signed-off-by: Evan Green <evgreen@chromium.org>
Reviewed-by: Matthias Kaehlcke <mka@chromium.org>
Make it possible to use Exynos ADC driver on S5PV210 based devices.
Signed-off-by: Jonathan Bakker <xc-racer2@live.ca>
Signed-off-by: Paweł Chmiel <pawel.mikolaj.chmiel@gmail.com>
S5PV210's ADC variant is almost the same as v1 except that it has 10
channels and doesn't require the pmu register
Currently, we're using the devm version of some but not all functions.
Switch to the devm version of iio_triggered_buffer_setup and
iio_device_register to simplify the code a bit and decrease the chance of
bugs.
Signed-off-by: Martin Kelly <martin@martingkelly.com>
This patch solves the register readback issue with the bit shift. When the
dac resolution was lower than the register size (ex. 12 bits out of 16
bits) the readback value was not shifted with the difference in bits and
the value was higher. Also a mask is applied on the read value in order to
get the value relative to the actual bit size.
Fixes: 0357e488b8 ("iio:dac:ad5686: Refactor the driver")
Signed-off-by: Mircea Caprioru <mircea.caprioru@analog.com>
The AD5310R is a single channel DAC with 10-bit precision, which is
part of the same family as AD5311R, except that it uses the spi interface
instead of i2c. The device has a built-in 2.5V reference which is enabled
by default.
Another important difference is that the SPI write command operation is
16 bits long. The first four bits represent the command, while the
remaining 12 bits are for data. In the control reg, DB9 and DB10 are used
for power-down modes, while DB8 is the REF bit. In order to accommodate
this change, a new regmap type was defined and checked accordingly.
Because AD5310R does not have a readback register, the read_raw operation
will return "Operation is not supported".
Datasheet:
Link: http://www.analog.com/media/en/technical-documentation/data-sheets/AD5310R_5311R.pdf
Signed-off-by: Stefan Popa <stefan.popa@analog.com>
When the 'info' structure inside indio_dev is left uninitialized,
a segmentation fault occurs.
Check the 'info' value before using it and if it is equal to
NULL, return with -EINVAL.
Signed-off-by: Andi Shyti <andi@etezian.org>
ACPI provides a generic helper to get I2C Serial Bus resources.
Use it instead of open coded variant.
Reviewed-by: Heikki Krogerus <heikki.krogerus@linux.intel.com>
Acked-by: Jonathan Cameron <Jonathan.Cameron@huawei.com>
When performing single ended measurements with TSCADC, its recommended
to set negative input (SEL_INM_SWC_3_0) of ADC step to ADC's VREFN in the
corresponding STEP_CONFIGx register.
Also, the positive(SEL_RFP_SWC_2_0) and negative(SEL_RFM_SWC_1_0)
reference voltage for ADC step needs to be set to VREFP and VREFN
respectively in STEP_CONFIGx register.
Without these changes, there may be variation of as much as ~2% in the
ADC's digital output which is bad for precise measurement.
Signed-off-by: Vignesh R <vigneshr@ti.com>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
We need the staging fixes in here as well.
This HID is used on the ASUS MeMO Pad 7 (ME176C) tablet.
Signed-off-by: Stephan Gerhold <stephan@gerhold.net>
Move ad2s90 resolver driver out of staging to the main tree.
Signed-off-by: Matheus Tavares <matheus.bernardino@usp.br>
Signed-off-by: Victor Colombo <victorcolombo@gmail.com>
Acked-by: Alexandru Ardelean <alexandru.ardelean@analog.com>
Generalize st_lsm6dsx_shub_read_oneshot in order to not use a fixed
read length and take into account iio channel realbits for single
read operations
Signed-off-by: Lorenzo Bianconi <lorenzo.bianconi@redhat.com>
The statement is indented too much by one level, fix this by
removing the extraneous tab.
Switch off ADC when going to low power mode, in case it has been left
running in buffer mode. Then re-enable it when resuming.
Add support for runtime PM & sleep. Move all regulator and clock management
to dedicated HW start/stop routines. Then rely on (runtime) PM OPS to
call them.
Move self-calibration routine to prepare routine.
- This is precursor patch to ease power management handling.
- This also allow to factorize few error cases (error handling).
Various 2-in-1's use KIOX010A and KIOX020A as HIDs for 2 KXCJ91008
accelerometers. The KIOX010A HID is for the one in the base and the
KIOX020A for the accelerometer in the keyboard.
Since userspace does not have a way yet to deal with (or ignore) the
accelerometer in the keyboard, this commit just adds the KIOX010A HID
for now so that display rotation will work.
Related: https://github.com/hadess/iio-sensor-proxy/issues/166
This patch adds driver support for the Microchip MCP41xxx/42xxx family
of digital potentiometers:
DEVICE Wipers Positions Resistance (kOhm)
MCP41010 1 256 10
MCP41050 1 256 50
MCP41100 1 256 100
MCP42010 2 256 10
MCP42050 2 256 50
MCP42100 2 256 100
Datasheet: http://ww1.microchip.com/downloads/en/devicedoc/11195c.pdf
Signed-off-by: Chris Coffey <cmc@babblebit.net>
Before this patch we are registering the internal clocks (for example on
Meson8b, where the SAR ADC IP block implements the divider and gate
clocks) with the following names:
- /soc/cbus@c1100000/adc@8680#adc_div
- /soc/cbus@c1100000/adc@8680#adc_en
This is bad because the common clock framework uses the clock to create
a directory in <debugfs>/clk. With such name, the directory creation
(silently) fails and the debugfs entry ends up being created at the
debugfs root.
With this change, the new clock names are:
- c1108680.adc#adc_div
- c1108680.adc#adc_en
This matches the clock naming scheme used in the PWM, Ethernet and MMC
drivers. It also fixes the problem with debugfs.
The idea is shamelessly taken from commit b96e9eb62841c5 ("pwm: meson:
Fix mux clock names").
Fixes: 3921db46a8c5bc ("iio: Convert to using %pOF instead of full_name")
Signed-off-by: Martin Blumenstingl <martin.blumenstingl@googlemail.com>
devm_kasprintf() may return NULL on failure of internal allocation thus
the assignments to init.name are not safe if not checked. On error
meson_sar_adc_clk_init() returns negative values so -ENOMEM in the
(unlikely) failure case of devm_kasprintf() should be fine here.
Signed-off-by: Nicholas Mc Guire <hofrat@osadl.org>
Fixes: 3adbf3427330 ("iio: adc: add a driver for the SAR ADC found in Amlogic Meson SoCs")
Acked-by: Martin Blumenstingl <martin.blumenstingl@googlemail.com>
Tested-by: Martin Blumenstingl <martin.blumenstingl@googlemail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-testing
Jonathan writes:
First set of new device support, features and cleanups for IIO in the 4.21 cycle
Along with the headline feature of 5 new drivers, we have the
substantial addition of auxilliary sensor support on the lsm6sdx
parts for ST. There has also been a good set of staging cleanup
in this period with more underway.
An ever increasing number of devices supported with just a new
ID which is a good sign that at least some manufacturers are
continuing to stabilise their interfaces.
New device support,
* ad7124
- New driver supporting Analog Devices' ad7124-4 and ad7124-8 parts
with the inevitable DT binding.
* ad7949
- New driver supporting Analog Devices' ad7949, AD7682 and AD7689 ADCs.
* rm3100
- New driver supporting PNIs RM3100 magnometer with bindings and
vendor prefix.
* ti-dac7311
- New driver supporting DAC7311, DAC6311 and DAC5311 TI DACs, with
DT bindings.
* vcnl5035
- New driver supporting the light sensor part of the VCNL4035, with
DT bindings
Features,
* bindings
- Add a generic ADC channel binding as we keep reinventing this
wheel.
* adc128s052
- Add IDs for additional pin compatible parts.
- Add APCI ID seen on E3940 UP squared boards.
* ad_sigma_delta
- Allow for custom data register overiding default.
* kxcjk1013
- Add KIOX0009 ACPI ID as seen on the Acer One 10.
* lsm6dsx
- Rework leading to...
- External sensor support using the built in I2C master.
- Initial support for a slave lis2mdl magnetometer.
* meson-saradc
- Add temperature sensor support and bindings.
* st_magn
- New ID for lsm9dsl_magn with bindings
- New ID for lis3de accelerometer
* tpl0102
- Add supprot for IIO_AVAIL_RANGE to report the range available
from this device to userspace and in kernel users.
Cleanups and minor fixes
* tools
- Allow outside specification of CFLAGS
* ad2s90
- Handle and spi_read error.
- Handle spi_setup failure
- Drop a pointless assignment.
- Prevent a potentail race by moving device registration to after
all other setup.
- Add missing scale attribute.
- Add a sanity check on channel type before trying to read it.
* ad2s1210
- Move to modern gpio descriptors.
- Drop a gpioin flag which made no sense as far as we can tell.
- Add dt table (bindings doc to follow when this is ready for
moving out of staging).
* ad5933
- Drop camel-case naming of ext_clk_hz.
- White space fixes.
* ad7150
- Local variable to shorten overly long line.
- Alignment and line break fixes.
* ad7280a
- Handle an error path that was previously ignored.
- Use crc8.h to build the crc table replacing custom code.
- Avoid unecessary cast.
- Power down the device if an error happens in probe
- Use devm routines to simplify probe and remove.
* ad7606
- Alignment fixes.
* ad7780
- This worked as long as by coincidence an uninitialized value
was 0. Lets not rely on that.
- Ensure gain update is only used with the ad778x chips that
actually support it.
- Tidy up pattern mask generation.
- Read regulator when scale is requested (which should be infrequent)
as it might have changed from initialization.
* ad7816
- Don't use a busy_pin for ad7818 as there isn't one.
- Ensure RD/WR and CONVST pins are outputs (previously they
were brought up as inputs which doesn't seem to make any sense)
- DT id table.
* adc128s052
- SPDX
* adt7316
- Alignment fix.
- Fix data reading. When using I2C the driver never actually
used the value read. This has been broken a very long time
hence no rush to fix it now + the driver is undergoing a lot
of cleanup.
- Sanity check that the i2c read didn't fail to actually read
anything.
* dpot-dac
- Mark a switch full through with slightly different text so that
gcc doesn't warn on it.
* gyro-adc
- Fix a wrong file in the MAINTAINERS entry and add binding doc to the
listed files.
* ina2xx
- Add some early returns to clarify error paths in switch.
* lsm6dsx
* max11100
- SPDX
* max9611
- SPDX
* mcp4131
- use of_device_get_match_data in preference to spi_get_device_id
approach.
* rcar-adc
- SPDX
* sc27xx
- Add ADC conversion timeout support to avoid possible fault.
* ssp_sensors
- Don't free managed resources manually.
* st-magn
- Add a comment to avoid future confusion over when to use -magn
postfix (on multi chip in package parts)
- Add BDU register for LIS3MDL where it seems to have been missed.
* st-sensors
- Minor spelling, grammar etc fixes.
* tpl0102
- Use a pointer rather than an index of an array to improve conciseness.
* tag 'iio-for-4.21a' of git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio: (80 commits)
Staging: iio: adt7316: Fix i2c data reading, set the data field
dt-bindings: iio: adc: Add docs for ad7124
iio: adc: Add ad7124 support
dt-bindings: iio: adc: Add common ADCs properties to a separate file
iio: ad_sigma_delta: Allow to provide custom data register address
staging: iio: ad7816: Add device tree table.
iio: imu: st_lsm6dsx: add entry in MAINTAINERS file
iio: potentiometer: mcp4131: use of_device_get_match_data()
staging: iio: adc: ad7280a: use devm_* APIs
staging: iio: adc: ad7280a: power down the device on error in probe
dt-bindings: iio: imu: st_lsm6dsx: add support to i2c pullup resistors
iio: imu: st_lsm6dsx: add hw FIFO support to i2c controller
iio: imu: st_lsm6dsx: add st_lsm6dsx_push_tagged_data routine
iio: imu: st_lsm6dsx: add i2c embedded controller support
iio: imu: st_lsm6dsx: introduce st_lsm6dsx_sensor_set_enable routine
iio: imu: st_lsm6dsx: introduce ST_LSM6DSX_ID_EXT sensor ids
iio: imu: st_lsm6dsx: remove static from st_lsm6dsx_set_watermark
iio: imu: st_lsm6dsx: reload trimming parameter at bootstrap
iio: imu: st_lsm6dsx: introduce locked read/write utility routines
The ad7124-4 and ad7124-8 are a family of 4 and 8 channel sigma-delta ADCs
with 24-bit precision and reference.
Three power modes are available which in turn affect the output data rate:
* Full power: 9.38 SPS to 19,200 SPS
* Mid power: 2.34 SPS to 4800 SPS
* Low power: 1.17 SPS to 2400 SPS
The ad7124-4 can be configured to have four differential inputs, while
ad7124-8 can have 8. Moreover, ad7124 also supports per channel
configuration. Each configuration consists of gain, reference source,
output data rate and bipolar/unipolar configuration.
Datasheets:
Link: http://www.analog.com/media/en/technical-documentation/data-sheets/AD7124-4.pdf
Link: http://www.analog.com/media/en/technical-documentation/data-sheets/ad7124-8.pdf
