Add IB GID change event type. This is needed for IBoE when the HW
driver updates the GID (e.g when new VLANs are added/deleted) table
and the change should be reflected to the IB core cache.
Signed-off-by: Eli Cohen <eli@mellanox.co.il>
Signed-off-by: Or Gerlitz <ogerlitz@mellanox.co.il>
Signed-off-by: Roland Dreier <roland@purestorage.com>
* ib_wq is added, which is used as the common workqueue for infiniband
instead of the system workqueue. All system workqueue usages
including flush_scheduled_work() callers are converted to use and
flush ib_wq.
* cancel_delayed_work() + flush_scheduled_work() converted to
cancel_delayed_work_sync().
* qib_wq is removed and ib_wq is used instead.
This is to prepare for deprecation of flush_scheduled_work().
Signed-off-by: Roland Dreier <rolandd@cisco.com>
They don't get updated by git and so they're worse than useless.
First thing mm.h does is including sched.h solely for can_do_mlock() inline
function which has "current" dereference inside. By dealing with can_do_mlock()
mm.h can be detached from sched.h which is good. See below, why.
This patch
a) removes unconditional inclusion of sched.h from mm.h
b) makes can_do_mlock() normal function in mm/mlock.c
c) exports can_do_mlock() to not break compilation
d) adds sched.h inclusions back to files that were getting it indirectly.
e) adds less bloated headers to some files (asm/signal.h, jiffies.h) that were
getting them indirectly
Net result is:
a) mm.h users would get less code to open, read, preprocess, parse, ... if
they don't need sched.h
b) sched.h stops being dependency for significant number of files:
on x86_64 allmodconfig touching sched.h results in recompile of 4083 files,
after patch it's only 3744 (-8.3%).
Cross-compile tested on
all arm defconfigs, all mips defconfigs, all powerpc defconfigs,
alpha alpha-up
arm
i386 i386-up i386-defconfig i386-allnoconfig
ia64 ia64-up
m68k
mips
parisc parisc-up
powerpc powerpc-up
s390 s390-up
sparc sparc-up
sparc64 sparc64-up
um-x86_64
x86_64 x86_64-up x86_64-defconfig x86_64-allnoconfig
as well as my two usual configs.
After Al Viro (finally) succeeded in removing the sched.h #include in module.h
recently, it makes sense again to remove other superfluous sched.h includes.
There are quite a lot of files which include it but don't actually need
anything defined in there. Presumably these includes were once needed for
macros that used to live in sched.h, but moved to other header files in the
course of cleaning it up.
To ease the pain, this time I did not fiddle with any header files and only
removed #includes from .c-files, which tend to cause less trouble.
Compile tested against 2.6.20-rc2 and 2.6.20-rc2-mm2 (with offsets) on alpha,
arm, i386, ia64, mips, powerpc, and x86_64 with allnoconfig, defconfig,
allmodconfig, and allyesconfig as well as a few randconfigs on x86_64 and all
configs in arch/arm/configs on arm. I also checked that no new warnings were
introduced by the patch (actually, some warnings are removed that were emitted
by unnecessarily included header files).
Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Fix up for make allyesconfig.
Signed-Off-By: David Howells <dhowells@redhat.com>
Modifications to the existing rdma header files, core files, drivers,
and ulp files to support iWARP, including:
- Hook iWARP CM into the build system and use it in rdma_cm.
- Convert enum ib_node_type to enum rdma_node_type, which includes
the possibility of RDMA_NODE_RNIC, and update everything for this.
Signed-off-by: Tom Tucker <tom@opengridcomputing.com>
Signed-off-by: Steve Wise <swise@opengridcomputing.com>
After commit 12bbb2b7be7f5564952ebe0196623e97464b8ac5, when SM LID
change or LID change MAD also has a client reregistration bit set,
only CLIENT_REREGISTER event is generated.
As a result, the sa_query module and the cache module don't update the
port information, and ULPs (e.g. IPoIB) stop working. This is the
regression we observe as compared to 2.6.17.
Rather than generate multiple events (which would have negative
performance impact), let us simply let cache and SA query respond to
reregister event in the same way as to LID and SM change events.
Signed-off-by: Jack Morgenstein <jackm@mellanox.co.il>
Signed-off-by: Michael S. Tsirkin <mst@mellanox.co.il>
Add an LMC cache to struct ib_device, and add a function
ib_get_cached_lmc() to query the cache.
Signed-off-by: Sean Hefty <sean.hefty@intel.com>
When allocating gid_cache, use kmalloc(sizeof *gid_cache, ...) rather
than kmalloc(sizeof *pkey_cache, ...). It doesn't really matter which
one is used, since the size ends up the same either way, but it's much
better to say what we mean.
I recently picked up my older work to remove unnecessary #includes of
sched.h, starting from a patch by Dave Jones to not include sched.h
from module.h. This reduces the number of indirect includes of sched.h
by ~300. Another ~400 pointless direct includes can be removed after
this disentangling (patch to follow later).
However, quite a few indirect includes need to be fixed up for this.
In order to feed the patches through -mm with as little disturbance as
possible, I've split out the fixes I accumulated up to now (complete for
i386 and x86_64, more archs to follow later) and post them before the real
patch. This way this large part of the patch is kept simple with only
adding #includes, and all hunks are independent of each other. So if any
hunk rejects or gets in the way of other patches, just drop it. My scripts
will pick it up again in the next round.
Move the InfiniBand headers from drivers/infiniband/include to include/rdma.
This allows InfiniBand-using code to live elsewhere, and lets us remove the
ugly EXTRA_CFLAGS include path from the InfiniBand Makefiles.
changing CONFIG_LOCALVERSION rebuilds too much, for no appearent reason.
Remove unneeded includes of <linux/version.h>.
Signed-off-by: Olaf Hering <olh@suse.de>
Make some lawyers happy and add copyright notices for people who
forgot to include them when they actually touched the code.
infrastructure for it.
Let it rip!
