path: root/drivers/infiniband/core/mad.c
2015-08-30IB/mad: Remove ib_get_dma_mr callsJason Gunthorpe
The pd now has a local_dma_lkey member which completely replaces ib_get_dma_mr, use it instead. Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-08-30IB/core: lock client data with lists_rwsemHaggai Eran
An ib_client callback that is called with the lists_rwsem locked only for read is protected from changes to the IB client lists, but not from ib_unregister_device() freeing its client data. This is because ib_unregister_device() will remove the device from the device list with lists_rwsem locked for write, but perform the rest of the cleanup, including the call to remove() without that lock. Mark client data that is undergoing de-registration with a new going_down flag in the client data context. Lock the client data list with lists_rwsem for write in addition to using the spinlock, so that functions calling the callback would be able to lock only lists_rwsem for read and let callbacks sleep. Since ib_unregister_client() now marks the client data context, no need for remove() to search the context again, so pass the client data directly to remove() callbacks. Reviewed-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Signed-off-by: Haggai Eran <haggaie@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-07-14IB/mad: Fix compare between big endian and cpu endianIra Weiny
The define OPA_LID_PERMISSIVE is big endian and was compared to the cpu endian variable opa_drslid. Problem caught by 0-day build infrastructure. Fixes: 8e4349d13f33 (IB/mad: Add final OPA MAD processing) Signed-off-by: Ira Weiny <ira.weiny@intel.com> Reviewed-by: Mike Marciniszyn <mike.marciniszyn@intel.com> Reviewed-by: John, Jubin <jubin.john@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-07-14IB: Add rdma_cap_ib_switch helper and use where appropriateHal Rosenstock
Persuant to Liran's comments on node_type on linux-rdma mailing list: In an effort to reform the RDMA core and ULPs to minimize use of node_type in struct ib_device, an additional bit is added to struct ib_device for is_switch (IB switch). This is needed to be initialized by any IB switch device driver. This is a NEW requirement on such device drivers which are all "out of tree". In addition, an ib_switch helper was added to ib_verbs.h based on the is_switch device bit rather than node_type (although those should be consistent). The RDMA core (MAD, SMI, agent, sa_query, multicast, sysfs) as well as (IPoIB and SRP) ULPs are updated where appropriate to use this new helper. In some cases, the helper is now used under the covers of using rdma_[start end]_port rather than the open coding previously used. Reviewed-by: Sean Hefty <sean.hefty@intel.com> Reviewed-By: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Reviewed-by: Ira Weiny <ira.weiny@intel.com> Tested-by: Ira Weiny <ira.weiny@intel.com> Signed-off-by: Hal Rosenstock <hal@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-06-12IB/mad: Add final OPA MAD processingIra Weiny
For devices which support OPA MADs 1) Use previously defined SMP support functions. 2) Pass correct base version to ib_create_send_mad when processing OPA MADs. 3) Process out_mad_key_index returned by agents for a response. This is necessary because OPA SMP packets must carry a valid pkey. 4) Carry the correct segment size (OPA vs IBTA) of RMPP messages within ib_mad_recv_wc. 5) Handle variable length OPA MADs by: * Adjusting the 'fake' WC for locally routed SMP's to represent the proper incoming byte_len * out_mad_size is used from the local HCA agents 1) when sending agent responses on the wire 2) when passing responses through the local_completions function NOTE: wc.byte_len includes the GRH length and therefore is different from the in_mad_size specified to the local HCA agents. out_mad_size should _not_ include the GRH length as it is added Signed-off-by: Ira Weiny <ira.weiny@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-06-12IB/mad: Add partial Intel OPA MAD supportIra Weiny
This patch is the first of 3 which adds processing of OPA MADs 1) Add Intel Omni-Path Architecture defines 2) Increase max management version to accommodate OPA 3) update ib_create_send_mad If the device supports OPA MADs and the MAD being sent is the OPA base version alter the MAD size and sg lengths as appropriate Signed-off-by: Ira Weiny <ira.weiny@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-06-12IB/mad: Add support for additional MAD info to/from driversIra Weiny
In order to support alternate sized MADs (and variable sized MADs on OPA devices) add in/out MAD size parameters to the process_mad core call. In addition, add an out_mad_pkey_index to communicate the pkey index the driver wishes the MAD stack to use when sending OPA MAD responses. The out MAD size and the out MAD PKey index are required by the MAD stack to generate responses on OPA devices. Furthermore, the in and out MAD parameters are made generic by specifying them as ib_mad_hdr rather than ib_mad. Drivers are modified as needed and are protected by BUG_ON flags if the MAD sizes passed to them is incorrect. Signed-off-by: Ira Weiny <ira.weiny@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-06-12IB/mad: Convert allocations from kmem_cache to kzallocIra Weiny
This patch implements allocating alternate receive MAD buffers within the MAD stack. Support for OPA to send/recv variable sized MADs is implemented later. 1) Convert MAD allocations from kmem_cache to kzalloc kzalloc is more flexible to support devices with different sized MADs and research and testing showed that the current use of kmem_cache does not provide performance benefits over kzalloc. 2) Change struct ib_mad_private to use a flex array for the mad data 3) Allocate ib_mad_private based on the size specified by devices in rdma_max_mad_size. 4) Carry the allocated size in ib_mad_private to be used when processing ib_mad_private objects. 5) Alter DMA mappings based on the mad_size of ib_mad_private. 6) Replace the use of sizeof and static defines as appropriate 7) Add appropriate casts for the MAD data when calling processing functions. Signed-off-by: Ira Weiny <ira.weiny@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-06-12IB/core: Add ability for drivers to report an alternate MAD size.Ira Weiny
Add max MAD size to the device immutable data set and have all drivers that support MADs report the current IB MAD size (IB_MGMT_MAD_SIZE) to the core. Verify MAD size data in both the MAD core and when reading the immutable data. OPA drivers will report alternate MAD sizes in subsequent patches. Signed-off-by: Ira Weiny <ira.weiny@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-06-12IB/mad: Support alternate Base Versions when creating MADsIra Weiny
In preparation to support the new OPA MAD Base version, add a base version parameter to ib_create_send_mad and set it to IB_MGMT_BASE_VERSION for current users. Definition of the new base version and it's processing will occur in later patches. Signed-off-by: Ira Weiny <ira.weiny@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-06-12IB/mad: Split IB SMI handling from MAD Recv handlerIra Weiny
Make a helper function to process Directed Route SMPs to be called by the IB MAD Recv Handler, ib_mad_recv_done_handler. This cleans up the MAD receive handler code a bit and allows for us to better share the SMP processing code between IB and OPA SMPs. IB and OPA SMPs share the same processing algorithm but have different header formats and permissive LID detection. Therefore this and subsequent patches split the common processing code from the IB specific code in anticipation of sharing those algorithms with the OPA code. Signed-off-by: Ira Weiny <ira.weiny@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-06-12IB/mad cleanup: Generalize processing of MAD dataIra Weiny
ib_find_send_mad only needs access to the MAD header not the full IB MAD. Change the local variable to ib_mad_hdr and change the corresponding cast. This allows for clean usage of this function with both IB and OPA MADs because OPA MADs carry the same header as IB MADs. Signed-off-by: Ira Weiny <ira.weiny@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-06-12IB/mad cleanup: Clean up function params -- find_mad_agentIra Weiny
find_mad_agent only needs read only access to the MAD header. Update the ib_mad pointer to be const ib_mad_hdr. Adjust call tree. Signed-off-by: Ira Weiny <ira.weiny@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-06-12IB/core: Change ib_create_cq to use struct ib_cq_init_attrMatan Barak
Currently, ib_create_cq uses cqe and comp_vecotr instead of the extendible ib_cq_init_attr struct. Earlier patches already changed the vendors to work with ib_cq_init_attr. This patch changes the consumers too. Signed-off-by: Matan Barak <matanb@mellanox.com> Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-05-20Merge branches 'bart-srp', 'generic-errors', 'ira-cleanups' and 'mwang-v8' ↵Doug Ledford
into k.o/for-4.2
2015-05-20IB/mad: Add const qualifiers to query only functionsIra Weiny
The following functions only need read access to the data passed to them. ib_mad_kernel_rmpp_agent is_rmpp_data_mad rcv_has_same_gid ib_find_send_mad Clarify with const specifiers Signed-off-by: Ira Weiny <ira.weiny@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-05-20IB/mad: Clean up rcv_has_same_classIra Weiny
rcv_has_same_class only needs access to the MAD header specify WR and Receive WC as const Reviewed-By: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Reviewed-by: Sean Hefty <sean.hefty@intel.com> Signed-off-by: Ira Weiny <ira.weiny@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-05-20IB/mad: Change ib_response_mad signature argumentsIra Weiny
ib_response_mad only needs read access to the MAD header, not write access to the entire mad struct, so replace struct ib_mad with const struct ib_mad_hdr Reviewed-By: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Reviewed-by: Sean Hefty <sean.hefty@intel.com> Signed-off-by: Ira Weiny <ira.weiny@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-05-20IB/mad: Change validate_mad signature argumentsIra Weiny
validate_mad only needs read access to the MAD header, not write access to the entire mad struct, so replace struct ib_mad with const struct ib_mad_hdr Reviewed-By: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Reviewed-by: Sean Hefty <sean.hefty@intel.com> Signed-off-by: Ira Weiny <ira.weiny@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-05-18IB/mad: Rename is_data_mad to is_rmpp_data_madIra Weiny
is_rmpp_data_mad is more descriptive for this function. Reviewed-By: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Reviewed-by: Sean Hefty <sean.hefty@intel.com> Signed-off-by: Ira Weiny <ira.weiny@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-05-18IB/Verbs: Use management helper rdma_cap_ib_smi()Michael Wang
Introduce helper rdma_cap_ib_smi() to help us check if the port of an IB device support Infiniband Subnet Management Interface. Signed-off-by: Michael Wang <yun.wang@profitbricks.com> Reviewed-by: Ira Weiny <ira.weiny@intel.com> Tested-by: Ira Weiny <ira.weiny@intel.com> Reviewed-by: Sean Hefty <sean.hefty@intel.com> Reviewed-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Tested-by: Doug Ledford <dledford@redhat.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-05-18IB/Verbs: Use management helper rdma_cap_ib_mad()Michael Wang
Introduce helper rdma_cap_ib_mad() to help us check if the port of an IB device support Infiniband Management Datagrams. Signed-off-by: Michael Wang <yun.wang@profitbricks.com> Reviewed-by: Ira Weiny <ira.weiny@intel.com> Tested-by: Ira Weiny <ira.weiny@intel.com> Reviewed-by: Sean Hefty <sean.hefty@intel.com> Reviewed-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Tested-by: Doug Ledford <dledford@redhat.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-05-18IB/Verbs: Reform IB-core mad/agent/user_madMichael Wang
Use raw management helpers to reform IB-core mad/agent/user_mad. Signed-off-by: Michael Wang <yun.wang@profitbricks.com> Reviewed-by: Ira Weiny <ira.weiny@intel.com> Tested-by: Ira Weiny <ira.weiny@intel.com> Reviewed-by: Sean Hefty <sean.hefty@intel.com> Reviewed-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Tested-by: Doug Ledford <dledford@redhat.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2014-08-10IB/mad: Add user space RMPP supportIra Weiny
Using the new registration mechanism, define a flag that indicates the user wishes to process RMPP messages in user space rather than have the kernel process them. Signed-off-by: Ira Weiny <ira.weiny@intel.com> Signed-off-by: Roland Dreier <roland@purestorage.com>
2014-08-10IB/mad: add new ioctl to ABI to support new registration optionsIra Weiny
Registrations options are specified through flags. Definitions of flags will be in subsequent patches. Signed-off-by: Ira Weiny <ira.weiny@intel.com> Signed-off-by: Roland Dreier <roland@purestorage.com>
2014-08-10IB/mad: Add dev_notice messages for various umad/mad registration failuresIra Weiny
Registration failures can be difficult to debug from userspace. This gives more visibility. Signed-off-by: Ira Weiny <ira.weiny@intel.com> Signed-off-by: Roland Dreier <roland@purestorage.com>
2014-08-10IB/mad: Update module to [pr|dev]_* style print messagesIra Weiny
Use dev_* style print when struct device is available. Also combine previously line broken user-visible strings as per Documentation/CodingStyle: "However, never break user-visible strings such as printk messages, because that breaks the ability to grep for them." Signed-off-by: Ira Weiny <ira.weiny@intel.com> [ Remove PFX so the patch actually builds. - Roland ] Signed-off-by: Roland Dreier <roland@purestorage.com>
2014-04-01IB/mad: Check and handle potential DMA mapping errorsYan Burman
Running with DMA_API_DEBUG enabled and not checking for DMA mapping errors triggers a kernel stack trace with "DMA-API: device driver failed to check map error" message. Add these checks to the MAD module, both to be be more robust and also eliminate these false-positive stack traces. Signed-off-by: Yan Burman <yanb@mellanox.com> Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com> Signed-off-by: Roland Dreier <roland@purestorage.com>
2013-07-31IB/core: Create QP1 using the pkey index which contains the default pkeyJack Morgenstein
Currently, QP1 is created using pkey index 0. This patch simply looks for the index containing the default pkey, rather than hard-coding pkey index 0. This change will have no effect in native mode, since QP0 and QP1 are created before the SM configures the port, so pkey table will still be the default table defined by the IB Spec, in C10-123: "If non-volatile storage is not used to hold P_Key Table contents, then if a PM (Partition Manager) is not present, and prior to PM initialization of the P_Key Table, the P_Key Table must act as if it contains a single valid entry, at P_Key_ix = 0, containing the default partition key. All other entries in the P_Key Table must be invalid." Thus, in the native mode case, the driver will find the default pkey at index 0 (so it will be no different than the hard-coding). However, in SR-IOV mode, for VFs, the pkey table may be paravirtualized, so that the VF's pkey index zero may not necessarily be mapped to the real pkey index 0. For VFs, therefore, it is important to find the virtual index which maps to the real default pkey. This commit does the following for QP1 creation: 1. Find the pkey index containing the default pkey, and use that index if found. ib_find_pkey() returns the index of the limited-membership default pkey (0x7FFF) if the full-member default pkey is not in the table. 2. If neither form of the default pkey is found, use pkey index 0 (previous behavior). Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il> Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com> Reviewed-by: Sean Hefty <sean.hefty@intel.com> Signed-off-by: Roland Dreier <roland@purestorage.com>
2012-08-21workqueue: deprecate __cancel_delayed_work()Tejun Heo
Now that cancel_delayed_work() can be safely called from IRQ handlers, there's no reason to use __cancel_delayed_work(). Use cancel_delayed_work() instead of __cancel_delayed_work() and mark the latter deprecated. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Jens Axboe <axboe@kernel.dk> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Roland Dreier <roland@kernel.org> Cc: Tomi Valkeinen <tomi.valkeinen@ti.com>
2012-08-21workqueue: use mod_delayed_work() instead of __cancel + queueTejun Heo
Now that mod_delayed_work() is safe to call from IRQ handlers, __cancel_delayed_work() followed by queue_delayed_work() can be replaced with mod_delayed_work(). Most conversions are straight-forward except for the following. * net/core/link_watch.c: linkwatch_schedule_work() was doing a quite elaborate dancing around its delayed_work. Collapse it such that linkwatch_work is queued for immediate execution if LW_URGENT and existing timer is kept otherwise. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Tomi Valkeinen <tomi.valkeinen@ti.com>
2012-04-24IB/mad: Don't send response for failed MADsJack Morgenstein
Commit 0b307043049f ("IB/mad: Return error response for unsupported MADs") does not failed MADs (eg those that return IB_MAD_RESULT_FAILURE) properly -- these MADs should be silently discarded. (We should not force the lower-layer drivers to return SUCCESS | CONSUMED in this case, since the MAD is NOT successful). Unsupported MADs are not failures -- they return SUCCESS, but with an "unsupported error" status value inside the response MAD. Reviewed-by: Hal Rosenstock <hal@mellanox.com> Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il> Signed-off-by: Roland Dreier <roland@purestorage.com>
2012-04-24IB/mad: Set 'D' bit in response for unhandled MADsJack Morgenstein
Commit 0b307043049f ("IB/mad: Return error response for unsupported MADs") does not handle directed-route MADs properly -- it fails to set the 'D' bit in the response MAD status field. This is a problem for SmInfo MADs when the receiver does not have an SM running. Reviewed-by: Hal Rosenstock <hal@mellanox.com> Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il> Signed-off-by: Roland Dreier <roland@purestorage.com>
2012-02-25IB/mad: Return error response for unsupported MADsSwapna Thete
Set up a response with appropriate error status and send it for MADs that are not supported by a specific class/version. Reviewed-by: Hal Rosenstock <hal@mellanox.com> Signed-off-by: Swapna Thete <swapna.thete@qlogic.com> Signed-off-by: Roland Dreier <roland@purestorage.com>
2011-11-06Merge branch 'modsplit-Oct31_2011' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux * 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits) Revert "tracing: Include module.h in define_trace.h" irq: don't put module.h into irq.h for tracking irqgen modules. bluetooth: macroize two small inlines to avoid module.h ip_vs.h: fix implicit use of module_get/module_put from module.h nf_conntrack.h: fix up fallout from implicit moduleparam.h presence include: replace linux/module.h with "struct module" wherever possible include: convert various register fcns to macros to avoid include chaining crypto.h: remove unused crypto_tfm_alg_modname() inline uwb.h: fix implicit use of asm/page.h for PAGE_SIZE pm_runtime.h: explicitly requires notifier.h linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h miscdevice.h: fix up implicit use of lists and types stop_machine.h: fix implicit use of smp.h for smp_processor_id of: fix implicit use of errno.h in include/linux/of.h of_platform.h: delete needless include <linux/module.h> acpi: remove module.h include from platform/aclinux.h miscdevice.h: delete unnecessary inclusion of module.h device_cgroup.h: delete needless include <linux/module.h> net: sch_generic remove redundant use of <linux/module.h> net: inet_timewait_sock doesnt need <linux/module.h> ... Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in - drivers/media/dvb/frontends/dibx000_common.c - drivers/media/video/{mt9m111.c,ov6650.c} - drivers/mfd/ab3550-core.c - include/linux/dmaengine.h
2011-10-31infiniband: Fix up module files that need to include module.hPaul Gortmaker
They had been getting it implicitly via device.h but we can't rely on that for the future, due to a pending cleanup so fix it now. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-06IB/mad: Verify mgmt class in received MADsHefty, Sean
If a received MAD contains an invalid or reserved mgmt class, we will attempt to access method_table outside of its range. Add a check to ensure that mgmt class falls within the handled range. Found by code inspection. Signed-off-by: Sean Hefty <sean.hefty@intel.com> Signed-off-by: Roland Dreier <roland@purestorage.com>
2011-05-23IB/mad: Return EPROTONOSUPPORT when an RDMA device lacks the QP requiredIra Weiny
We had a script which was looping through the devices returned from ibstat and attempted to register a SMI agent on an ethernet device. This caused a kernel panic for IBoE devices that don't have QP0. Fix this by checking if the QP exists before using it. Signed-off-by: Ira Weiny <weiny2@llnl.gov> Acked-by: Sean Hefty <sean.hefty@intel.com> Signed-off-by: Roland Dreier <roland@purestorage.com>
2010-10-13IB/mad: IBoE supports only QP1 (no QP0)Eli Cohen
Since IBoE is using Ethernet as its link layer, there is no central management entity so there is need for QP0. QP1 is still needed since it handles communications between CM agents. This patch will skip QP0 and create only QP1 for IBoE ports. Signed-off-by: Eli Cohen <eli@mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2010-05-23IB/mad: Make needlessly global mad_sendq_size/mad_recvq_size staticRoland Dreier
2010-05-15IB/core: Use kmemdup() instead of kmalloc()+memcpy()Julia Lawall
Use kmemdup when some other buffer is immediately copied into the allocated region. A simplified version of the semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression from,to,size,flag; statement S; @@ - to = \(kmalloc\|kzalloc\)(size,flag); + to = kmemdup(from,size,flag); if (to==NULL || ...) S - memcpy(to, from, size); // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Roland Dreier <rolandd@cisco.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-11IB/mad: Ignore iWARP devices on device removalSteve Wise
When an iWARP device is unloaded, the ib_mad module logs errors. It should be ignoring iWARP devices on device removal just like it does on device add. Signed-off-by: Steve Wise <swise@opengridcomputing.com> Acked-by: Sean Hefty <sean.hefty@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2010-03-06infiniband: use for_each_set_bit()Akinobu Mita
Replace open-coded loop with for_each_set_bit(). Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Roland Dreier <rolandd@cisco.com> Cc: Sean Hefty <sean.hefty@intel.com> Cc: Hal Rosenstock <hal.rosenstock@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-10Merge branch 'mad' into for-linusRoland Dreier
Conflicts: drivers/infiniband/core/mad.c
2009-09-07IB/mad: Allow tuning of QP0 and QP1 sizesHal Rosenstock
MADs are UD and can be dropped if there are no receives posted, so allow receive queue size to be set with a module parameter in case the queue needs to be lengthened. Send side tuning is done for symmetry with receive. Signed-off-by: Hal Rosenstock <hal.rosenstock@gmail.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-09-07IB/mad: Fix possible lock-lock-timer deadlockRoland Dreier
Lockdep reported a possible deadlock with cm_id_priv->lock, mad_agent_priv->lock and mad_agent_priv->timed_work.timer; this happens because the mad module does cancel_delayed_work(&mad_agent_priv->timed_work); while holding mad_agent_priv->lock. cancel_delayed_work() internally does del_timer_sync(&mad_agent_priv->timed_work.timer). This can turn into a deadlock because mad_agent_priv->lock is taken inside cm_id_priv->lock, so we can get the following set of contexts that deadlock each other: A: holding cm_id_priv->lock, waiting for mad_agent_priv->lock B: holding mad_agent_priv->lock, waiting for del_timer_sync() C: interrupt during mad_agent_priv->timed_work.timer that takes cm_id_priv->lock Fix this by using the new __cancel_delayed_work() interface (which internally does del_timer() instead of del_timer_sync()) in all the places where we are holding a lock. Addresses: http://bugzilla.kernel.org/show_bug.cgi?id=13757 Reported-by: Bart Van Assche <bart.vanassche@gmail.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-09-05IB: Use DEFINE_SPINLOCK() for static spinlocksRoland Dreier
Rather than just defining static spinlock_t variables and then initializing them later in init functions, simply define them with DEFINE_SPINLOCK() and remove the calls to spin_lock_init(). This cleans up the source a tad and also shrinks the compiled code; eg on x86-64: add/remove: 0/0 grow/shrink: 0/3 up/down: 0/-40 (-40) function old new delta ib_uverbs_init 336 326 -10 ib_mad_init_module 147 137 -10 ib_sa_init 123 103 -20 Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-03-03IB/mad: Fix ib_post_send_mad() returning 0 with no generate send compRalph Campbell
If ib_post_send_mad() returns 0, the API guarantees that there will be a callback to send_buf->mad_agent->send_handler() so that the sender can call ib_free_send_mad(). Otherwise, the ib_mad_send_buf will be leaked and the mad_agent reference count will never go to zero and the IB device module cannot be unloaded. The above can happen without this patch if process_mad() returns (IB_MAD_RESULT_SUCCESS | IB_MAD_RESULT_CONSUMED). If process_mad() returns IB_MAD_RESULT_SUCCESS and there is no agent registered to receive the mad being sent, handle_outgoing_dr_smp() returns zero which causes a MAD packet which is at the end of the directed route to be incorrectly sent on the wire but doesn't cause a hang since the HCA generates a send completion. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-02-27IB/mad: initialize mad_agent_priv before putting on listsRalph Campbell
There is a potential race in ib_register_mad_agent() where the struct ib_mad_agent_private is not fully initialized before it is added to the list of agents per IB port. This means the ib_mad_agent_private could be seen before the refcount, spin locks, and linked lists are initialized. The fix is to initialize the structure earlier. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
