The existing user/kernel uverbs API has IB_USER_VERBS_CMD_ALLOC/DEALLOC_MW.
Implement these calls, along with destroying user memory windows during
process cleanup.
Signed-off-by: Haggai Eran <haggaie@mellanox.com>
Signed-off-by: Shani Michaeli <shanim@mellanox.com>
Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com>
Signed-off-by: Roland Dreier <roland@purestorage.com>
both callers of device_get_devnode() are only interested in lower 16bits
and nobody tries to return anything wider than 16bit anyway.
'misc', 'mlx4', 'misc', 'nes', 'qib' and 'xrc' into for-next
Allow processes that share the same XRC domain to open an existing
shareable QP. This permits those processes to receive events on the
shared QP and transfer ownership, so that any process may modify the
QP. The latter allows the creating process to exit, while a remaining
process can still transition it for path migration purposes.
Signed-off-by: Sean Hefty <sean.hefty@intel.com>
XRC TGT QPs are shared resources among multiple processes. Since the
creating process may exit, allow other processes which share the same
XRC domain to open an existing QP. This allows us to transfer
ownership of an XRC TGT QP to another process.
Allow user space to operate on XRC TGT QPs the same way as other types
of QPs, with one notable exception: since XRC TGT QPs may be shared
among multiple processes, the XRC TGT QP is allowed to exist beyond the
lifetime of the creating process.
The process that creates the QP is allowed to destroy it, but if the
process exits without destroying the QP, then the QP will be left bound
to the lifetime of the XRCD.
TGT QPs are not associated with CQs or a PD.
We require additional information to create XRC SRQs than we can
exchange using the existing create SRQ ABI. Provide an enhanced create
ABI for extended SRQ types.
Based on patches by Jack Morgenstein <jackm@dev.mellanox.co.il>
and Roland Dreier <roland@purestorage.com>
Allow user space to create XRC domains. Because XRCDs are expected to
be shared among multiple processes, we use inodes to identify an XRCD.
cmd is unsigned, no need to check for < 0. Found by code inspection.
Commits 71c29bd5c235 ("IB/uverbs: Add devnode method to set path/mode")
and c3af0980ce01 ("IB: Add devnode methods to cm_class and umad_class")
added devnode methods that set the mode.
However, these methods don't check for a NULL mode, and so we get a
crash when unloading modules because devtmpfs_delete_node() calls
device_get_devnode() with mode == NULL.
Add the missing checks.
Signed-off-by: Goldwyn Rodrigues <rgoldwyn@suse.de>
[ Also fix cm.c. - Roland ]
We want udev to create a device node under /dev/infiniband with
permission 0666 for uverbsX devices, so add a devnode method to set the
appropriate info.
Several RDMA user-access drivers have file_operations structures with
no .llseek method set. None of the drivers actually do anything with
f_pos, so this means llseek is essentially a NOP, instead of returning
an error as leaving other file_operations methods unimplemented would
do. This is mostly harmless, except that a NULL .llseek means that
default_llseek() is used, and this function grabs the BKL, which we
would like to avoid.
Since llseek does nothing useful on these files, we would like it to
return an error to userspace instead of silently grabbing the BKL and
succeeding. For nearly all of the file types, we take the
belt-and-suspenders approach of setting the .llseek method to
no_llseek and also calling nonseekable_open(); the exception is the
uverbs_event files, which are created with anon_inode_getfile(), which
already sets f_mode the same way as nonseekable_open() would.
This work is motivated by Arnd Bergmann's bkl-removal tree.
Signed-off-by: Roland Dreier <rolandd@cisco.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Convert some drivers who export a single string as class attribute
to the new class_attr_string functions. This removes redundant
code all over.
Passing the attribute to the low level IO functions allows all kinds
of cleanups, by sharing low level IO code without requiring
an own function for every piece of data.
Also drivers can extend the attributes with own data fields
and use that in the low level function.
This makes the class attributes the same as sysdev_class attributes
and plain attributes.
This will allow further cleanups in drivers.
Full tree sweep converting all users.
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (52 commits)
init: Open /dev/console from rootfs
mqueue: fix typo "failues" -> "failures"
mqueue: only set error codes if they are really necessary
mqueue: simplify do_open() error handling
mqueue: apply mathematics distributivity on mq_bytes calculation
mqueue: remove unneeded info->messages initialization
mqueue: fix mq_open() file descriptor leak on user-space processes
fix race in d_splice_alias()
set S_DEAD on unlink() and non-directory rename() victims
vfs: add NOFOLLOW flag to umount(2)
get rid of ->mnt_parent in tomoyo/realpath
hppfs can use existing proc_mnt, no need for do_kern_mount() in there
Mirror MS_KERNMOUNT in ->mnt_flags
get rid of useless vfsmount_lock use in put_mnt_ns()
Take vfsmount_lock to fs/internal.h
get rid of insanity with namespace roots in tomoyo
take check for new events in namespace (guts of mounts_poll()) to namespace.c
Don't mess with generic_permission() under ->d_lock in hpfs
sanitize const/signedness for udf
nilfs: sanitize const/signedness in dealing with ->d_name.name
Fix up fairly trivial (famous last words...) conflicts in
drivers/infiniband/core/uverbs_main.c and security/tomoyo/realpath.c
The anon_inodes interface has been split to allow creating a bare
(non-installed) file pointer and also extended to allow specifying
O_RDONLY in the flags. This makes it a suitable replacement for the
private "infinibandeventfs" pseudo-filesystem used by uverbs, and this
replacement saves a small chunk of boilerplate code.
Clean up the errors as shown when 'let c_space_errors=1' is set in vim.
Signed-off-by: Alex Chiang <achiang@hp.com>
Some large systems may support more than IB_UVERBS_MAX_DEVICES
(currently 32).
This change allows us to support more devices in a backwards-compatible
manner. The first IB_UVERBS_MAX_DEVICES keep the same major/minor
device numbers that they've always had.
If there are more than IB_UVERBS_MAX_DEVICES, we then dynamically
request a new major device number (new minors start at 0).
This change increases the maximum number of HCAs to 64 (from 32).
This change is not useful by itself, but sets us up for a future change
that allows us to support more than IB_UVERBS_MAX_DEVICES in a system.
This change is not useful by itself, but it sets us up for a future
change that allows us to dynamically allocate device numbers in case
we have more than IB_UVERBS_MAX_DEVICES in the system.
dev_table's raison d'etre was to associate an inode back to a struct
ib_uverbs_device.
However, now that we've converted ib_uverbs_device to contain an
embedded cdev (instead of a *cdev), we can use the container_of()
macro and cast back to the containing device.
There's no longer any need for dev_table, so get rid of it.
Instead of storing a pointer to a cdev, embed the entire struct cdev.
This change allows us to use the container_of() macro in
ib_uverbs_open() in a future patch.
This change increases the size of struct ib_uverbs_device to 168 bytes
across 3 cachelines from 80 bytes in 2 cachelines. However, we
rearrange the members so that everything fits into the first cacheline
except for the struct cdev. Finally, we don't touch the cdev in any
fastpaths, so this change shouldn't negatively affect performance.
... and have the caller grab both mnt and dentry; kill
leak in infiniband, while we are at it.
Since the original commit 883a99c7 ("[IB] uverbs: Add a mask of device
methods allowed for userspace"), the uverbs core returns EINVAL for
commands not implemented by a specific low-level driver.
This creates a problem that there is no way to tell the difference
between an unimplemented command and an implemented one which is
incorrectly invoked (which also returns EINVAL).
The fix is to have unimplemented commands return ENOSYS.
Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il>
Rather than just defining static spinlock_t variables and then
initializing them later in init functions, simply define them with
DEFINE_SPINLOCK() and remove the calls to spin_lock_init(). This cleans
up the source a tad and also shrinks the compiled code; eg on x86-64:
add/remove: 0/0 grow/shrink: 0/3 up/down: 0/-40 (-40)
function old new delta
ib_uverbs_init 336 326 -10
ib_mad_init_module 147 137 -10
ib_sa_init 123 103 -20
As it is, all instances of ->release() for files that have ->fasync()
need to remember to evict file from fasync lists; forgetting that
creates a hole and we actually have a bunch that *does* forget.
So let's keep our lives simple - let __fput() check FASYNC in
file->f_flags and call ->fasync() there if it's been set. And lose that
crap in ->release() instances - leaving it there is still valid, but we
don't have to bother anymore.
Now that device_create() has been audited, rename things back to the
original call to be sane.
Cc: Roland Dreier <rolandd@cisco.com>
Cc: Sean Hefty <sean.hefty@intel.com>
Cc: Hal Rosenstock <hal.rosenstock@gmail.com>
They don't get updated by git and so they're worse than useless.
Remove explicit lock_kernel() calls and document why the code is safe.
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
Be extra-cautious and protect the remaining open() functions.
Commit 1ae5c187 ("IB/uverbs: Don't store struct file * for event
files") changed the way that closed files are handled in the uverbs
code. However, after the conversion, is_closed flag is checked
incorrectly in ib_uverbs_async_handler(). As a result, no async
events are ever passed to applications.
Found by: Ronni Zimmerman <ronniz@mellanox.co.il>
There is a race from when a device is created with device_create() and
then the drvdata is set with a call to dev_set_drvdata() in which a
sysfs file could be open, yet the drvdata will be NULL, causing all
sorts of bad things to happen.
This patch fixes the problem by using the new function,
device_create_drvdata().
Cc: Kay Sievers <kay.sievers@vrfy.org>
Reviewed-by: Roland Dreier <rolandd@cisco.com>
This converts the main ib_device to use struct device instead of struct
class_device as class_device is going away.
Signed-off-by: Tony Jones <tonyj@suse.de>
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Christoph Hellwig wants to unexport get_empty_filp(), which is an ugly
internal interface. Change the modular user in ib_uverbs_alloc_event_file()
to use the better alloc_file() interface; this makes the code cleaner too.
The file member of struct ib_uverbs_event_file was only used to keep
track of whether the file had been closed or not. The only thing we
ever did with the value was check if it was NULL or not. Simplify the
code and get rid of the need to keep track of the struct file * we
allocate by replacing the file member with an is_closed member.
ib_uverbs_release_event_file() is only used in uverbs_main.c, so make it
static to that file. Also move the definition before the first use, so
a forward declaration is not needed.
Export ib_umem_get()/ib_umem_release() and put low-level drivers in
control of when to call ib_umem_get() to pin and DMA map userspace,
rather than always calling it in ib_uverbs_reg_mr() before calling the
low-level driver's reg_user_mr method.
Also move these functions to be in the ib_core module instead of
ib_uverbs, so that driver modules using them do not depend on
ib_uverbs.
This has a number of advantages:
- It is better design from the standpoint of making generic code a
library that can be used or overridden by device-specific code as
the details of specific devices dictate.
- Drivers that do not need to pin userspace memory regions do not
need to take the performance hit of calling ib_mem_get(). For
example, although I have not tried to implement it in this patch,
the ipath driver should be able to avoid pinning memory and just
use copy_{to,from}_user() to access userspace memory regions.
- Buffers that need special mapping treatment can be identified by
the low-level driver. For example, it may be possible to solve
some Altix-specific memory ordering issues with mthca CQs in
userspace by mapping CQ buffers with extra flags.
- Drivers that need to pin and DMA map userspace memory for things
other than memory regions can use ib_umem_get() directly, instead
of hacks using extra parameters to their reg_phys_mr method. For
example, the mlx4 driver that is pending being merged needs to pin
and DMA map QP and CQ buffers, but it does not need to create a
memory key for these buffers. So the cleanest solution is for mlx4
to call ib_umem_get() in the create_qp and create_cq methods.
Add a num_comp_vectors member to struct ib_device and extend
ib_create_cq() to pass in a comp_vector parameter -- this parallels
the userspace libibverbs API. Update all hardware drivers to set
num_comp_vectors to 1 and have all ULPs pass 0 for the comp_vector
value. Pass the value of num_comp_vectors to userspace rather than
hard-coding a value of 1.
We want multiple CQ event vector support (via MSI-X or similar for
adapters that can generate multiple interrupts), but it's not clear
how many vectors we want, or how we want to deal with policy issues
such as how to decide which vector to use or how to set up interrupt
affinity. This patch is useful for experimenting, since no core
changes will be necessary when updating a driver to support multiple
vectors, and we know that we want to make at least these changes
anyway.
Signed-off-by: Michael S. Tsirkin <mst@dev.mellanox.co.il>
Many struct file_operations in the kernel can be "const". Marking them const
moves these to the .rodata section, which avoids false sharing with potential
dirty data. In addition it'll catch accidental writes at compile time to
these shared resources.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Signed-off-by: Josef Sipek <jsipek@fsl.cs.sunysb.edu>
Wait until all users have closed their device context before allowing
device unregistration to complete. This prevents a crash caused by
referring to stale data structures.
A better solution would be to have a way to revoke contexts rather
than waiting for userspace to close the context, but that's a much
bigger change that will have to wait. For now let's at least avoid
the crash.
Signed-off-by: Jack Morgenstein <jackm@mellanox.co.il>
Signed-off-by: Michael S. Tsirkin <mst@mellanox.co.il>
master.kernel.org:/pub/scm/linux/kernel/git/roland/infiniband
* 'for-linus' of master.kernel.org:/pub/scm/linux/kernel/git/roland/infiniband:
IB/iser: iSER Kconfig and Makefile
IB/iser: iSER handling of memory for RDMA
IB/iser: iSER RDMA CM (CMA) and IB verbs interaction
IB/iser: iSER initiator iSCSI PDU and TX/RX
IB/iser: iSCSI iSER transport provider high level code
IB/iser: iSCSI iSER transport provider header file
IB/uverbs: Remove unnecessary list_del()s
IB/uverbs: Don't free wr list when it's known to be empty
Extend the get_sb() filesystem operation to take an extra argument that
permits the VFS to pass in the target vfsmount that defines the mountpoint.
The filesystem is then required to manually set the superblock and root dentry
pointers. For most filesystems, this should be done with simple_set_mnt()
which will set the superblock pointer and then set the root dentry to the
superblock's s_root (as per the old default behaviour).
The get_sb() op now returns an integer as there's now no need to return the
superblock pointer.
This patch permits a superblock to be implicitly shared amongst several mount
points, such as can be done with NFS to avoid potential inode aliasing. In
such a case, simple_set_mnt() would not be called, and instead the mnt_root
and mnt_sb would be set directly.
The patch also makes the following changes:
(*) the get_sb_*() convenience functions in the core kernel now take a vfsmount
pointer argument and return an integer, so most filesystems have to change
very little.
(*) If one of the convenience function is not used, then get_sb() should
normally call simple_set_mnt() to instantiate the vfsmount. This will
always return 0, and so can be tail-called from get_sb().
(*) generic_shutdown_super() now calls shrink_dcache_sb() to clean up the
dcache upon superblock destruction rather than shrink_dcache_anon().
This is required because the superblock may now have multiple trees that
aren't actually bound to s_root, but that still need to be cleaned up. The
currently called functions assume that the whole tree is rooted at s_root,
and that anonymous dentries are not the roots of trees which results in
dentries being left unculled.
However, with the way NFS superblock sharing are currently set to be
implemented, these assumptions are violated: the root of the filesystem is
simply a dummy dentry and inode (the real inode for '/' may well be
inaccessible), and all the vfsmounts are rooted on anonymous[*] dentries
with child trees.
[*] Anonymous until discovered from another tree.
(*) The documentation has been adjusted, including the additional bit of
changing ext2_* into foo_* in the documentation.
[akpm@osdl.org: convert ipath_fs, do other stuff]
Acked-by: Al Viro <viro@zeniv.linux.org.uk>
Cc: Nathan Scott <nathans@sgi.com>
