This patch allows ports to have different link layers:
IB_LINK_LAYER_INFINIBAND or IB_LINK_LAYER_ETHERNET. This is required
for adding IBoE (InfiniBand-over-Ethernet, aka RoCE) support. For
devices that do not provide an implementation for querying the link
layer property of a port, we return a default value based on the
transport: RMA_TRANSPORT_IB nodes will return IB_LINK_LAYER_INFINIBAND
and RDMA_TRANSPORT_IWARP nodes will return IB_LINK_LAYER_ETHERNET.
Signed-off-by: Eli Cohen <eli@mellanox.co.il>
Signed-off-by: Roland Dreier <rolandd@cisco.com>
Change abbreviated IB_QPT_RAW_ETY to IB_QPT_RAW_ETHERTYPE to make
the special QP type easier to understand.
cf http://www.mail-archive.com/linux-rdma@vger.kernel.org/msg04530.html
Signed-off-by: Aleksey Senin <alekseys@voltaire.com>
I was reviewing the QP state transition diagram in the IB 1.2.1 spec
and the code for qp_state_table[], and noticed that the code allows a
QP to be modified from IB_QPS_RESET to IB_QPS_ERR whereas the notes
for figure 124 (pg 457) specifically says that this transition isn't
allowed. This is a clarification from earlier versions of the IB
spec, which were ambiguous in this area and suggested that the RESET
to ERR transition was allowed.
Fix up the qp_state_table[] to make RESET->ERR not allowed.
Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com>
This patch adds support for the IB "base memory management extension"
(BMME) and the equivalent iWARP operations (which the iWARP verbs
mandates all devices must implement). The new operations are:
- Allocate an ib_mr for use in fast register work requests.
- Allocate/free a physical buffer lists for use in fast register work
requests. This allows device drivers to allocate this memory as
needed for use in posting send requests (eg via dma_alloc_coherent).
- New send queue work requests:
* send with remote invalidate
* fast register memory region
* local invalidate memory region
* RDMA read with invalidate local memory region (iWARP only)
Consumer interface details:
- A new device capability flag IB_DEVICE_MEM_MGT_EXTENSIONS is added
to indicate device support for these features.
- New send work request opcodes IB_WR_FAST_REG_MR, IB_WR_LOCAL_INV,
IB_WR_RDMA_READ_WITH_INV are added.
- A new consumer API function, ib_alloc_mr() is added to allocate
fast register memory regions.
- New consumer API functions, ib_alloc_fast_reg_page_list() and
ib_free_fast_reg_page_list() are added to allocate and free
device-specific memory for fast registration page lists.
- A new consumer API function, ib_update_fast_reg_key(), is added to
allow the key portion of the R_Key and L_Key of a fast registration
MR to be updated. Consumers call this if desired before posting
a IB_WR_FAST_REG_MR work request.
Consumers can use this as follows:
- MR is allocated with ib_alloc_mr().
- Page list memory is allocated with ib_alloc_fast_reg_page_list().
- MR R_Key/L_Key "key" field is updated with ib_update_fast_reg_key().
- MR made VALID and bound to a specific page list via
ib_post_send(IB_WR_FAST_REG_MR)
- MR made INVALID via ib_post_send(IB_WR_LOCAL_INV),
ib_post_send(IB_WR_RDMA_READ_WITH_INV) or an incoming send with
invalidate operation.
- MR is deallocated with ib_dereg_mr()
- page lists dealloced via ib_free_fast_reg_page_list().
Applications can allocate a fast register MR once, and then can
repeatedly bind the MR to different physical block lists (PBLs) via
posting work requests to a send queue (SQ). For each outstanding
MR-to-PBL binding in the SQ pipe, a fast_reg_page_list needs to be
allocated (the fast_reg_page_list is owned by the low-level driver
from the consumer posting a work request until the request completes).
Thus pipelining can be achieved while still allowing device-specific
page_list processing.
The 32-bit fast register memory key/STag is composed of a 24-bit index
and an 8-bit key. The application can change the key each time it
fast registers thus allowing more control over the peer's use of the
key/STag (ie it can effectively be changed each time the rkey is
rebound to a page list).
Signed-off-by: Steve Wise <swise@opengridcomputing.com>
They don't get updated by git and so they're worse than useless.
Add support for modifying CQ parameters for controlling event
generation moderation.
Make sure that a device implements the modify_srq and reg_phys_mr
optional methods before calling them.
Signed-off-by: Dotan Barak <dotanb@dev.mellanox.co.il>
Add a num_comp_vectors member to struct ib_device and extend
ib_create_cq() to pass in a comp_vector parameter -- this parallels
the userspace libibverbs API. Update all hardware drivers to set
num_comp_vectors to 1 and have all ULPs pass 0 for the comp_vector
value. Pass the value of num_comp_vectors to userspace rather than
hard-coding a value of 1.
We want multiple CQ event vector support (via MSI-X or similar for
adapters that can generate multiple interrupts), but it's not clear
how many vectors we want, or how we want to deal with policy issues
such as how to decide which vector to use or how to set up interrupt
affinity. This patch is useful for experimenting, since no core
changes will be necessary when updating a driver to support multiple
vectors, and we know that we want to make at least these changes
anyway.
Signed-off-by: Michael S. Tsirkin <mst@dev.mellanox.co.il>
The hop_limit value in the ah_attr should be 0xFF, not the value read
from the received GRH (which should be 0). See 13.5.4.4 in the 1.2 IB
spec.
Signed-off-by: Sean Hefty <sean.hefty@intel.com>
Modifications to the existing rdma header files, core files, drivers,
and ulp files to support iWARP, including:
- Hook iWARP CM into the build system and use it in rdma_cm.
- Convert enum ib_node_type to enum rdma_node_type, which includes
the possibility of RDMA_NODE_RNIC, and update everything for this.
Signed-off-by: Tom Tucker <tom@opengridcomputing.com>
Pass a struct ib_udata to the low-level driver's ->modify_srq() and
->modify_qp() methods, so that it can get to the device-specific data
passed in by the userspace driver.
Add a function to initialize address handle attributes from a work
completion. This functionality is duplicated by both verbs and the CM.
Push translation of static rate to HCA format into low-level drivers,
where it belongs. For static rate encoding, use encoding of rate
field from IB standard PathRecord, with addition of value 0, for
backwards compatibility with current usage. The changes are:
- Add enum ib_rate to midlayer includes.
- Get rid of static rate translation in IPoIB; just use static rate
directly from Path and MulticastGroup records.
- Update mthca driver to translate absolute static rate into the
format used by hardware. This also fixes mthca's static rate
handling for HCAs that are capable of 4X DDR.
Signed-off-by: Jack Morgenstein <jackm@mellanox.co.il>
According to the IB spec version 1.2, section 11.2.4.2, the current
table has a couple of mistakes where it allows the current QP state
(IB_QP_CUR_STATE) attribute. For the transitions:
RTS -> RTS: IB_QP_CUR_STATE should be allowed for all transports
SQD -> SQD: IB_QP_CUR_STATE should never be allowed
Signed-off-by: Dotan Barak <dotanb@mellanox.co.il>
Remove trailing whitespace and fix indentation that with spaces
instead of tabs.
The in-kernel mthca driver contains a table of which attributes are
valid for each queue pair state transition. It turns out that both
other IB drivers -- ipath and ehca -- which are being prepared for
merging have copied this table, errors and all.
To forestall this code duplication, move this table and the code to
check parameters against it into a midlayer library function,
ib_modify_qp_is_ok().
Add support to uverbs to handle resizing userspace CQs (completion
queues), including adding an ABI for marshalling requests and
responses. The kernel midlayer already has ib_resize_cq().
ib_create_ah_from_wc() doesn't create the correct return address (AH)
when there is a GRH present (source & dest GIDs need to be swapped).
Signed-off-by: Ralph Campbell <ralphc@pathscale.com>
master.kernel.org:/pub/scm/linux/kernel/git/roland/infiniband
Change the struct ib_device.resize_cq() method to take a plain integer
that holds the new CQ size, rather than a pointer to an integer that
it uses to return the new size. This makes the interface match the
exported ib_resize_cq() signature, and allows the low-level driver to
update the CQ size with proper locking if necessary.
No in-tree drivers are exporting this method yet.
Fix more include file problems that surfaced since I submitted the previous
fix-missing-includes.patch. This should now allow not to include sched.h
from module.h, which is done by a followup patch.
Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de>
Add checks so that we only allow multicast attach/detach with
a valid multicast GID and the correct QP type.
Move the InfiniBand headers from drivers/infiniband/include to include/rdma.
This allows InfiniBand-using code to live elsewhere, and lets us remove the
ugly EXTRA_CFLAGS include path from the InfiniBand Makefiles.
Make the required core API additions and changes for
shared receive queues (SRQs).
Make some lawyers happy and add copyright notices for people who
forgot to include them when they actually touched the code.
Replace be32_to_cpup with be32_to_cpu and fix bug referencing pointer rather
than value in ib_create_ah_from_wc().
Signed-off-by: Tom Duffy <tduffy@sun.com>
Signed-off-by: Hal Rosenstock <halr@voltaire.com>
Cc: Roland Dreier <rolandd@cisco.com>
Added new call: ib_create_ah_from_wc. Call will allocate an address handle
given work completion information, including any received GRH.
Update kernel InfiniBand midlayer to compile against the updated API for
low-level drivers. This just amounts to passing NULL for all
userspace-related parameters, and setting userspace-related structure members
to NULL.
infrastructure for it.
Let it rip!
