[ Upstream commit 594e6c5d41ed2471ab0b90f3f0b66cdf618b7ac9 ]
Properly unwind QP counter rebinding in case of failure.
Trying to rebind the counter after unbiding it is not going to work
reliably, move the unbind to the end so it doesn't have to be unwound.
Fixes: b389327df905 ("RDMA/nldev: Allow counter manual mode configration through RDMA netlink")
Link: https://lore.kernel.org/r/20191002115627.16740-1-leon@kernel.org
Reviewed-by: Mark Zhang <markz@mellanox.com>
Signed-off-by: Leon Romanovsky <leonro@mellanox.com>
Reviewed-by: Jason Gunthorpe <jgg@mellanox.com>
Signed-off-by: Jason Gunthorpe <jgg@mellanox.com>
[ Upstream commit 94635c36f3854934a46d9e812e028d4721bbb0e6 ]
In the process of moving the debug counters sysfs entries, the commit
mentioned below eliminated the cm_infiniband sysfs directory.
This sysfs directory was tied to the cm_port object allocated in procedure
cm_add_one().
Before the commit below, this cm_port object was freed via a call to
kobject_put(port->kobj) in procedure cm_remove_port_fs().
Since port no longer uses its kobj, kobject_put(port->kobj) was eliminated.
This, however, meant that kfree was never called for the cm_port buffers.
Fix this by adding explicit kfree(port) calls to functions cm_add_one()
and cm_remove_one().
Note: the kfree call in the first chunk below (in the cm_add_one error
flow) fixes an old, undetected memory leak.
Fixes: c87e65cfb97c ("RDMA/cm: Move debug counters to be under relevant IB device")
Link: https://lore.kernel.org/r/20190916071154.20383-2-leon@kernel.org
Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il>
[ Upstream commit ab59ca3eb4e7059727df85eee68bda169d26c8f8 ]
According to surrounding error paths, it is likely that 'goto err_get;' is
expected here. Otherwise, a call to 'rdma_restrack_put(res);' would be
missing.
Fixes: c5dfe0ea6ffa ("RDMA/nldev: Add resource tracker doit callback")
Link: https://lore.kernel.org/r/20190818091044.8845-1-christophe.jaillet@wanadoo.fr
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
[ Upstream commit b66f31efbdad95ec274345721d99d1d835e6de01 ]
This patch fixes the lock inversion complaint:
WARNING: possible recursive locking detected
5.3.0-rc7-dbg+ #1 Not tainted
kworker/u16:6/171 is trying to acquire lock:
00000000035c6e6c (&id_priv->handler_mutex){+.+.}, at: rdma_destroy_id+0x78/0x4a0 [rdma_cm]
but task is already holding lock:
00000000bc7c307d (&id_priv->handler_mutex){+.+.}, at: iw_conn_req_handler+0x151/0x680 [rdma_cm]
Possible unsafe locking scenario:
CPU0
lock(&id_priv->handler_mutex);
*** DEADLOCK ***
May be due to missing lock nesting notation
3 locks held by kworker/u16:6/171:
#0: 00000000e2eaa773 ((wq_completion)iw_cm_wq){+.+.}, at: process_one_work+0x472/0xac0
#1: 000000001efd357b ((work_completion)(&work->work)#3){+.+.}, at: process_one_work+0x476/0xac0
#2: 00000000bc7c307d (&id_priv->handler_mutex){+.+.}, at: iw_conn_req_handler+0x151/0x680 [rdma_cm]
stack backtrace:
CPU: 3 PID: 171 Comm: kworker/u16:6 Not tainted 5.3.0-rc7-dbg+ #1
Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011
Workqueue: iw_cm_wq cm_work_handler [iw_cm]
Call Trace:
dump_stack+0x8a/0xd6
__lock_acquire.cold+0xe1/0x24d
lock_acquire+0x106/0x240
__mutex_lock+0x12e/0xcb0
mutex_lock_nested+0x1f/0x30
iw_conn_req_handler+0x5c9/0x680 [rdma_cm]
cm_work_handler+0xe62/0x1100 [iw_cm]
process_one_work+0x56d/0xac0
worker_thread+0x7a/0x5d0
kthread+0x1bc/0x210
ret_from_fork+0x24/0x30
This is not a bug as there are actually two lock classes here.
Link: https://lore.kernel.org/r/20190930231707.48259-3-bvanassche@acm.org
Fixes: de910bd92137 ("RDMA/cma: Simplify locking needed for serialization of callbacks")
Signed-off-by: Bart Van Assche <bvanassche@acm.org>
commit 1cbe866cbcb53338de33cf67262e73f9315a9725 upstream.
rdma_for_each_port is already incrementing the iterator's value it
receives therefore, after the first iteration the iterator is increased by
2 which eventually causing wrong queries and possible traces.
Fix the above by removing the old redundant incrementation that was used
before rdma_for_each_port() macro.
Cc: <stable@vger.kernel.org>
Fixes: ea1075edcbab ("RDMA: Add and use rdma_for_each_port")
Link: https://lore.kernel.org/r/20191002122127.17571-1-leon@kernel.org
Signed-off-by: Mohamad Heib <mohamadh@mellanox.com>
Reviewed-by: Erez Alfasi <ereza@mellanox.com>
commit 3eca7fc2d8d1275d9cf0c709f0937becbfcf6d96 upstream.
The cited commit introduced a double-free of the srq buffer in the error
flow of procedure __uverbs_create_xsrq().
The problem is that ib_destroy_srq_user() called in the error flow also
frees the srq buffer.
Thus, if uverbs_response() fails in __uverbs_create_srq(), the srq buffer
will be freed twice.
Fixes: 68e326dea1db ("RDMA: Handle SRQ allocations by IB/core")
Link: https://lore.kernel.org/r/20190916071154.20383-5-leon@kernel.org
[ Upstream commit 77d5bc7e6a6cf8bbeca31aab7f0c5449a5eee762 ]
Julian noted that rt_uses_gateway has a more subtle use than 'is gateway
set':
https://lore.kernel.org/netdev/alpine.LFD.2.21.1909151104060.2546@ja.home.ssi.bg/
Revert that part of the commit referenced in the Fixes tag.
Currently, there are no u8 holes in 'struct rtable'. There is a 4-byte hole
in the second cacheline which contains the gateway declaration. So move
rt_gw_family down to the gateway declarations since they are always used
together, and then re-use that u8 for rt_uses_gateway. End result is that
rtable size is unchanged.
Fixes: 1550c171935d ("ipv4: Prepare rtable for IPv6 gateway")
Reported-by: Julian Anastasov <ja@ssi.bg>
Signed-off-by: David Ahern <dsahern@gmail.com>
Reviewed-by: Julian Anastasov <ja@ssi.bg>
Signed-off-by: Jakub Kicinski <jakub.kicinski@netronome.com>
In cma_init, if cma_configfs_init fails, need to free the
previously memory and return fail, otherwise will trigger
null-ptr-deref Read in cma_cleanup.
cma_cleanup
cma_configfs_exit
configfs_unregister_subsystem
Fixes: 045959db65c6 ("IB/cma: Add configfs for rdma_cm")
Signed-off-by: zhengbin <zhengbin13@huawei.com>
Reviewed-by: Parav Pandit <parav@mellanox.com>
Link: https://lore.kernel.org/r/1566188859-103051-1-git-send-email-zhengbin13@huawei.com
Signed-off-by: Doug Ledford <dledford@redhat.com>
task_active_pid_ns() is wrong API to check PID namespace because it
posses some restrictions and return PID namespace where the process
was allocated. It created mismatches with current namespace, which
can be different.
Rewrite whole rdma_is_visible_in_pid_ns() logic to provide reliable
results without any relation to allocated PID namespace.
Fixes: 8be565e65fa9 ("RDMA/nldev: Factor out the PID namespace check")
Fixes: 6a6c306a09b5 ("RDMA/restrack: Make is_visible_in_pid_ns() as an API")
Link: https://lore.kernel.org/r/20190815083834.9245-4-leon@kernel.org
"Auto" configuration mode is called for visible in that PID
namespace and it ensures that all counters and QPs are coexist
in the same namespace and belong to same PID.
Fixes: 99fa331dc862 ("RDMA/counter: Add "auto" configuration mode support")
Link: https://lore.kernel.org/r/20190815083834.9245-3-leon@kernel.org
If QP is not visible to the pid, then we try to decrease its reference
count and return from the function before the QP pointer is
initialized. This lead to NULL pointer dereference.
Fix it by pass directly the res to the rdma_restract_put as arg instead of
&qp->res.
This fixes below call trace:
[ 5845.110329] BUG: kernel NULL pointer dereference, address:
00000000000000dc
[ 5845.120482] Oops: 0002 [#1] SMP PTI
[ 5845.129119] RIP: 0010:rdma_restrack_put+0x5/0x30 [ib_core]
[ 5845.169450] Call Trace:
[ 5845.170544] rdma_counter_get_qp+0x5c/0x70 [ib_core]
[ 5845.172074] rdma_counter_bind_qpn_alloc+0x6f/0x1a0 [ib_core]
[ 5845.173731] nldev_stat_set_doit+0x314/0x330 [ib_core]
[ 5845.175279] rdma_nl_rcv_msg+0xeb/0x1d0 [ib_core]
[ 5845.176772] ? __kmalloc_node_track_caller+0x20b/0x2b0
[ 5845.178321] rdma_nl_rcv+0xcb/0x120 [ib_core]
[ 5845.179753] netlink_unicast+0x179/0x220
[ 5845.181066] netlink_sendmsg+0x2d8/0x3d0
[ 5845.182338] sock_sendmsg+0x30/0x40
[ 5845.183544] __sys_sendto+0xdc/0x160
[ 5845.184832] ? syscall_trace_enter+0x1f8/0x2e0
[ 5845.186209] ? __audit_syscall_exit+0x1d9/0x280
[ 5845.187584] __x64_sys_sendto+0x24/0x30
[ 5845.188867] do_syscall_64+0x48/0x120
[ 5845.190097] entry_SYSCALL_64_after_hwframe+0x44/0xa9
Fixes: 1bd8e0a9d0fd1 ("RDMA/counter: Allow manual mode configuration support")
Signed-off-by: Ido Kalir <idok@mellanox.com>
Link: https://lore.kernel.org/r/20190815083834.9245-2-leon@kernel.org
When ODP is enabled with IB_ACCESS_HUGETLB then the required pages
should be calculated based on the extent of the MR, which is rounded
to the nearest huge page alignment.
Fixes: d2183c6f1958 ("RDMA/umem: Move page_shift from ib_umem to ib_odp_umem")
Link: https://lore.kernel.org/r/20190815083834.9245-5-leon@kernel.org
We need to set the error codes on these paths. Currently the only
possible error code is -EMSGSIZE so that's what the patch uses.
Fixes: 83c2c1fcbd08 ("RDMA/nldev: Allow get counter mode through RDMA netlink")
Reviewed-by: Leon Romanovsky <leonro@mellanox.com>
Link: https://lore.kernel.org/r/20190809101311.GA17867@mwanda
In case of rdma_counter_init() fails, counter allocation and QP bind
should not be allowed.
Fixes: 413d3347503b ("RDMA/counter: Add set/clear per-port auto mode support")
Fixes: 1bd8e0a9d0fd ("RDMA/counter: Allow manual mode configuration support")
Signed-off-by: Mark Zhang <markz@mellanox.com>
Link: https://lore.kernel.org/r/20190807101819.7581-1-leon@kernel.org
Once implicit MR is being called to be released by
ib_umem_notifier_release() its leaves were marked as "dying".
However, when dereg_mr()->mlx5_ib_free_implicit_mr()->mr_leaf_free() is
called, it skips running the mr_leaf_free_action (i.e. umem_odp->work)
when those leaves were marked as "dying".
As such ib_umem_release() for the leaves won't be called and their MRs
will be leaked as well.
When an application exits/killed without calling dereg_mr we might hit the
above flow.
This fatal scenario is reported by WARN_ON() upon
mlx5_ib_dealloc_ucontext() as ibcontext->per_mm_list is not empty, the
call trace can be seen below.
Originally the "dying" mark as part of ib_umem_notifier_release() was
introduced to prevent pagefault_mr() from returning a success response
once this happened. However, we already have today the completion
mechanism so no need for that in those flows any more. Even in case a
success response will be returned the firmware will not find the pages and
an error will be returned in the following call as a released mm will
cause ib_umem_odp_map_dma_pages() to permanently fail mmget_not_zero().
Fix the above issue by dropping the "dying" from the above flows. The
other flows that are using "dying" are still needed it for their
synchronization purposes.
WARNING: CPU: 1 PID: 7218 at
drivers/infiniband/hw/mlx5/main.c:2004
mlx5_ib_dealloc_ucontext+0x84/0x90 [mlx5_ib]
CPU: 1 PID: 7218 Comm: ibv_rc_pingpong Tainted: G E
5.2.0-rc6+ #13
Call Trace:
uverbs_destroy_ufile_hw+0xb5/0x120 [ib_uverbs]
ib_uverbs_close+0x1f/0x80 [ib_uverbs]
__fput+0xbe/0x250
task_work_run+0x88/0xa0
do_exit+0x2cb/0xc30
? __fput+0x14b/0x250
do_group_exit+0x39/0xb0
get_signal+0x191/0x920
? _raw_spin_unlock_bh+0xa/0x20
? inet_csk_accept+0x229/0x2f0
do_signal+0x36/0x5e0
? put_unused_fd+0x5b/0x70
? __sys_accept4+0x1a6/0x1e0
? inet_hash+0x35/0x40
? release_sock+0x43/0x90
? inet_listen+0x9f/0x120
exit_to_usermode_loop+0x5c/0xc6
do_syscall_64+0x182/0x1b0
Fixes: 81713d3788d2 ("IB/mlx5: Add implicit MR support")
Link: https://lore.kernel.org/r/20190805083010.21777-1-leon@kernel.org
Signed-off-by: Yishai Hadas <yishaih@mellanox.com>
Reviewed-by: Artemy Kovalyov <artemyko@mellanox.com>
We encountered a use-after-free bug when unloading the driver:
[ 3562.116059] BUG: KASAN: use-after-free in ib_mad_post_receive_mads+0xddc/0xed0 [ib_core]
[ 3562.117233] Read of size 4 at addr ffff8882ca5aa868 by task kworker/u13:2/23862
[ 3562.118385]
[ 3562.119519] CPU: 2 PID: 23862 Comm: kworker/u13:2 Tainted: G OE 5.1.0-for-upstream-dbg-2019-05-19_16-44-30-13 #1
[ 3562.121806] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Ubuntu-1.8.2-1ubuntu2 04/01/2014
[ 3562.123075] Workqueue: ib-comp-unb-wq ib_cq_poll_work [ib_core]
[ 3562.124383] Call Trace:
[ 3562.125640] dump_stack+0x9a/0xeb
[ 3562.126911] print_address_description+0xe3/0x2e0
[ 3562.128223] ? ib_mad_post_receive_mads+0xddc/0xed0 [ib_core]
[ 3562.129545] __kasan_report+0x15c/0x1df
[ 3562.130866] ? ib_mad_post_receive_mads+0xddc/0xed0 [ib_core]
[ 3562.132174] kasan_report+0xe/0x20
[ 3562.133514] ib_mad_post_receive_mads+0xddc/0xed0 [ib_core]
[ 3562.134835] ? find_mad_agent+0xa00/0xa00 [ib_core]
[ 3562.136158] ? qlist_free_all+0x51/0xb0
[ 3562.137498] ? mlx4_ib_sqp_comp_worker+0x1970/0x1970 [mlx4_ib]
[ 3562.138833] ? quarantine_reduce+0x1fa/0x270
[ 3562.140171] ? kasan_unpoison_shadow+0x30/0x40
[ 3562.141522] ib_mad_recv_done+0xdf6/0x3000 [ib_core]
[ 3562.142880] ? _raw_spin_unlock_irqrestore+0x46/0x70
[ 3562.144277] ? ib_mad_send_done+0x1810/0x1810 [ib_core]
[ 3562.145649] ? mlx4_ib_destroy_cq+0x2a0/0x2a0 [mlx4_ib]
[ 3562.147008] ? _raw_spin_unlock_irqrestore+0x46/0x70
[ 3562.148380] ? debug_object_deactivate+0x2b9/0x4a0
[ 3562.149814] __ib_process_cq+0xe2/0x1d0 [ib_core]
[ 3562.151195] ib_cq_poll_work+0x45/0xf0 [ib_core]
[ 3562.152577] process_one_work+0x90c/0x1860
[ 3562.153959] ? pwq_dec_nr_in_flight+0x320/0x320
[ 3562.155320] worker_thread+0x87/0xbb0
[ 3562.156687] ? __kthread_parkme+0xb6/0x180
[ 3562.158058] ? process_one_work+0x1860/0x1860
[ 3562.159429] kthread+0x320/0x3e0
[ 3562.161391] ? kthread_park+0x120/0x120
[ 3562.162744] ret_from_fork+0x24/0x30
[ 3562.187615] Freed by task 31682:
[ 3562.188602] save_stack+0x19/0x80
[ 3562.189586] __kasan_slab_free+0x11d/0x160
[ 3562.190571] kfree+0xf5/0x2f0
[ 3562.191552] ib_mad_port_close+0x200/0x380 [ib_core]
[ 3562.192538] ib_mad_remove_device+0xf0/0x230 [ib_core]
[ 3562.193538] remove_client_context+0xa6/0xe0 [ib_core]
[ 3562.194514] disable_device+0x14e/0x260 [ib_core]
[ 3562.195488] __ib_unregister_device+0x79/0x150 [ib_core]
[ 3562.196462] ib_unregister_device+0x21/0x30 [ib_core]
[ 3562.197439] mlx4_ib_remove+0x162/0x690 [mlx4_ib]
[ 3562.198408] mlx4_remove_device+0x204/0x2c0 [mlx4_core]
[ 3562.199381] mlx4_unregister_interface+0x49/0x1d0 [mlx4_core]
[ 3562.200356] mlx4_ib_cleanup+0xc/0x1d [mlx4_ib]
[ 3562.201329] __x64_sys_delete_module+0x2d2/0x400
[ 3562.202288] do_syscall_64+0x95/0x470
[ 3562.203277] entry_SYSCALL_64_after_hwframe+0x49/0xbe
The problem was that the MAD PD was deallocated before the MAD CQ.
There was completion work pending for the CQ when the PD got deallocated.
When the mad completion handling reached procedure
ib_mad_post_receive_mads(), we got a use-after-free bug in the following
line of code in that procedure:
sg_list.lkey = qp_info->port_priv->pd->local_dma_lkey;
(the pd pointer in the above line is no longer valid, because the
pd has been deallocated).
We fix this by allocating the PD before the CQ in procedure
ib_mad_port_open(), and deallocating the PD after freeing the CQ
in procedure ib_mad_port_close().
Since the CQ completion work queue is flushed during ib_free_cq(),
no completions will be pending for that CQ when the PD is later
deallocated.
Note that freeing the CQ before deallocating the PD is the practice
in the ULPs.
Fixes: 4be90bc60df4 ("IB/mad: Remove ib_get_dma_mr calls")
Link: https://lore.kernel.org/r/20190801121449.24973-1-leon@kernel.org
The check for QP type different than XRC has excluded driver QP
types from the resource tracker.
As a result, "rdma resource show" user command would not show opened
driver QPs which does not reflect the real state of the system.
Check QP type explicitly instead of assuming enum values/ordering.
Fixes: 40909f664d27 ("RDMA/efa: Add EFA verbs implementation")
Signed-off-by: Gal Pressman <galpress@amazon.com>
Link: https://lore.kernel.org/r/20190801104354.11417-1-galpress@amazon.com
Due to the complexity of client->remove() callbacks it is desirable to not
hold any locks while calling them. Remove the last one by tracking only
the highest client ID and running backwards from there over the xarray.
Since the only purpose of that lock was to protect the linked list, we can
drop the lock.
Link: https://lore.kernel.org/r/20190731081841.32345-3-leon@kernel.org
lockdep reports:
WARNING: possible circular locking dependency detected
modprobe/302 is trying to acquire lock:
0000000007c8919c ((wq_completion)ib_cm){+.+.}, at: flush_workqueue+0xdf/0x990
000000002d3d2ca9 (&device->client_data_rwsem){++++}, at: remove_client_context+0x79/0xd0 [ib_core]
which lock already depends on the new lock.
the existing dependency chain (in reverse order) is:
-> #2 (&device->client_data_rwsem){++++}:
down_read+0x3f/0x160
ib_get_net_dev_by_params+0xd5/0x200 [ib_core]
cma_ib_req_handler+0x5f6/0x2090 [rdma_cm]
cm_process_work+0x29/0x110 [ib_cm]
cm_req_handler+0x10f5/0x1c00 [ib_cm]
cm_work_handler+0x54c/0x311d [ib_cm]
process_one_work+0x4aa/0xa30
worker_thread+0x62/0x5b0
kthread+0x1ca/0x1f0
-> #1 ((work_completion)(&(&work->work)->work)){+.+.}:
process_one_work+0x45f/0xa30
kthread+0x1ca/0x1f0
-> #0 ((wq_completion)ib_cm){+.+.}:
lock_acquire+0xc8/0x1d0
flush_workqueue+0x102/0x990
cm_remove_one+0x30e/0x3c0 [ib_cm]
remove_client_context+0x94/0xd0 [ib_core]
disable_device+0x10a/0x1f0 [ib_core]
__ib_unregister_device+0x5a/0xe0 [ib_core]
mlx5_ib_stage_ib_reg_cleanup+0x9/0x10 [mlx5_ib]
__mlx5_ib_remove+0x3d/0x70 [mlx5_ib]
mlx5_ib_remove+0x12e/0x140 [mlx5_ib]
mlx5_remove_device+0x144/0x150 [mlx5_core]
mlx5_unregister_interface+0x3f/0xf0 [mlx5_core]
mlx5_ib_cleanup+0x10/0x3a [mlx5_ib]
__x64_sys_delete_module+0x227/0x350
do_syscall_64+0xc3/0x6a4
Which is due to the read side of the client_data_rwsem being obtained
recursively through a work queue flush during cm client removal.
The lock is being held across the remove in remove_client_context() so
that the function is a fence, once it returns the client is removed. This
is required so that the two callers do not proceed with destruction until
the client completes removal.
Instead of using client_data_rwsem use the existing device unregistration
refcount and add a similar client unregistration (client->uses) refcount.
This will fence the two unregistration paths without holding any locks.
Fixes: 921eab1143aa ("RDMA/devices: Re-organize device.c locking")
Link: https://lore.kernel.org/r/20190731081841.32345-2-leon@kernel.org
Some processors may mispredict an array bounds check and
speculatively access memory that they should not. With
a user supplied array index we like to play things safe
by masking the value with the array size before it is
used as an index.
Signed-off-by: Tony Luck <tony.luck@intel.com>
Link: https://lore.kernel.org/r/20190731043957.GA1600@agluck-desk2.amr.corp.intel.com
Port counter objects should be initialized even if alloc_stats is
unsupported, otherwise QP bind operations in user space can trigger a NULL
pointer deference if they try to bind QP on RDMA device which doesn't
support counters.
Fixes: f34a55e497e8 ("RDMA/core: Get sum value of all counters when perform a sysfs stat read")
Link: https://lore.kernel.org/r/20190723065733.4899-11-leon@kernel.org
Signed-off-by: Parav Pandit <parav@mellanox.com>
rdma_counter_init() may fail for a device. In such case while calculating
total sum, ignore NULL hstats.
This fixes below observed call trace.
BUG: kernel NULL pointer dereference, address: 00000000000000a0
PGD 8000001009b30067 P4D 8000001009b30067 PUD 10549c9067 PMD 0
Oops: 0000 [#1] SMP PTI
CPU: 55 PID: 20887 Comm: cat Kdump: loaded Not tainted 5.2.0-rc6-jdc+ #13
RIP: 0010:rdma_counter_get_hwstat_value+0xf2/0x150 [ib_core]
Call Trace:
show_hw_stats+0x5e/0x130 [ib_core]
dev_attr_show+0x15/0x50
sysfs_kf_seq_show+0xc6/0x1a0
seq_read+0x132/0x370
vfs_read+0x89/0x140
ksys_read+0x5c/0xd0
do_syscall_64+0x5a/0x240
Link: https://lore.kernel.org/r/20190723065733.4899-10-leon@kernel.org
Pull rdma updates from Jason Gunthorpe:
"A smaller cycle this time. Notably we see another new driver, 'Soft
iWarp', and the deletion of an ancient unused driver for nes.
- Revise and simplify the signature offload RDMA MR APIs
- More progress on hoisting object allocation boiler plate code out
of the drivers
- Driver bug fixes and revisions for hns, hfi1, efa, cxgb4, qib,
i40iw
- Tree wide cleanups: struct_size, put_user_page, xarray, rst doc
conversion
- Removal of obsolete ib_ucm chardev and nes driver
- netlink based discovery of chardevs and autoloading of the modules
providing them
- Move more of the rdamvt/hfi1 uapi to include/uapi/rdma
- New driver 'siw' for software based iWarp running on top of netdev,
much like rxe's software RoCE.
- mlx5 feature to report events in their raw devx format to userspace
- Expose per-object counters through rdma tool
- Adaptive interrupt moderation for RDMA (DIM), sharing the DIM core
from netdev"
* tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rdma/rdma: (194 commits)
RMDA/siw: Require a 64 bit arch
RDMA/siw: Mark expected switch fall-throughs
RDMA/core: Fix -Wunused-const-variable warnings
rdma/siw: Remove set but not used variable 's'
rdma/siw: Add missing dependencies on LIBCRC32C and DMA_VIRT_OPS
RDMA/siw: Add missing rtnl_lock around access to ifa
rdma/siw: Use proper enumerated type in map_cqe_status
RDMA/siw: Remove unnecessary kthread create/destroy printouts
IB/rdmavt: Fix variable shadowing issue in rvt_create_cq
RDMA/core: Fix race when resolving IP address
RDMA/core: Make rdma_counter.h compile stand alone
IB/core: Work on the caller socket net namespace in nldev_newlink()
RDMA/rxe: Fill in wc byte_len with IB_WC_RECV_RDMA_WITH_IMM
RDMA/mlx5: Set RDMA DIM to be enabled by default
RDMA/nldev: Added configuration of RDMA dynamic interrupt moderation to netlink
RDMA/core: Provide RDMA DIM support for ULPs
linux/dim: Implement RDMA adaptive moderation (DIM)
IB/mlx5: Report correctly tag matching rendezvous capability
docs: infiniband: add it to the driver-api bookset
IB/mlx5: Implement VHCA tunnel mechanism in DEVX
Patch series "add init_on_alloc/init_on_free boot options", v10.
Provide init_on_alloc and init_on_free boot options.
These are aimed at preventing possible information leaks and making the
control-flow bugs that depend on uninitialized values more deterministic.
Enabling either of the options guarantees that the memory returned by the
page allocator and SL[AU]B is initialized with zeroes. SLOB allocator
isn't supported at the moment, as its emulation of kmem caches complicates
handling of SLAB_TYPESAFE_BY_RCU caches correctly.
Enabling init_on_free also guarantees that pages and heap objects are
initialized right after they're freed, so it won't be possible to access
stale data by using a dangling pointer.
As suggested by Michal Hocko, right now we don't let the heap users to
disable initialization for certain allocations. There's not enough
evidence that doing so can speed up real-life cases, and introducing ways
to opt-out may result in things going out of control.
This patch (of 2):
The new options are needed to prevent possible information leaks and make
This is expected to be on-by-default on Android and Chrome OS. And it
gives the opportunity for anyone else to use it under distros too via the
boot args. (The init_on_free feature is regularly requested by folks
where memory forensics is included in their threat models.)
init_on_alloc=1 makes the kernel initialize newly allocated pages and heap
objects with zeroes. Initialization is done at allocation time at the
places where checks for __GFP_ZERO are performed.
init_on_free=1 makes the kernel initialize freed pages and heap objects
with zeroes upon their deletion. This helps to ensure sensitive data
doesn't leak via use-after-free accesses.
Both init_on_alloc=1 and init_on_free=1 guarantee that the allocator
returns zeroed memory. The two exceptions are slab caches with
constructors and SLAB_TYPESAFE_BY_RCU flag. Those are never
zero-initialized to preserve their semantics.
Both init_on_alloc and init_on_free default to zero, but those defaults
can be overridden with CONFIG_INIT_ON_ALLOC_DEFAULT_ON and
CONFIG_INIT_ON_FREE_DEFAULT_ON.
If either SLUB poisoning or page poisoning is enabled, those options take
precedence over init_on_alloc and init_on_free: initialization is only
applied to unpoisoned allocations.
Slowdown for the new features compared to init_on_free=0, init_on_alloc=0:
hackbench, init_on_free=1: +7.62% sys time (st.err 0.74%)
hackbench, init_on_alloc=1: +7.75% sys time (st.err 2.14%)
Linux build with -j12, init_on_free=1: +8.38% wall time (st.err 0.39%)
Linux build with -j12, init_on_free=1: +24.42% sys time (st.err 0.52%)
Linux build with -j12, init_on_alloc=1: -0.13% wall time (st.err 0.42%)
Linux build with -j12, init_on_alloc=1: +0.57% sys time (st.err 0.40%)
The slowdown for init_on_free=0, init_on_alloc=0 compared to the baseline
is within the standard error.
The new features are also going to pave the way for hardware memory
tagging (e.g. arm64's MTE), which will require both on_alloc and on_free
hooks to set the tags for heap objects. With MTE, tagging will have the
same cost as memory initialization.
Although init_on_free is rather costly, there are paranoid use-cases where
in-memory data lifetime is desired to be minimized. There are various
arguments for/against the realism of the associated threat models, but
given that we'll need the infrastructure for MTE anyway, and there are
people who want wipe-on-free behavior no matter what the performance cost,
it seems reasonable to include it in this series.
[glider@google.com: v8]
Link: http://lkml.kernel.org/r/20190626121943.131390-2-glider@google.com
[glider@google.com: v9]
Link: http://lkml.kernel.org/r/20190627130316.254309-2-glider@google.com
[glider@google.com: v10]
Link: http://lkml.kernel.org/r/20190628093131.199499-2-glider@google.com
Link: http://lkml.kernel.org/r/20190617151050.92663-2-glider@google.com
Signed-off-by: Alexander Potapenko <glider@google.com>
Acked-by: Michal Hocko <mhocko@suse.cz> [page and dmapool parts
Acked-by: James Morris <jamorris@linux.microsoft.com>]
Cc: Christoph Lameter <cl@linux.com>
Cc: "Serge E. Hallyn" <serge@hallyn.com>
Cc: Nick Desaulniers <ndesaulniers@google.com>
Cc: Kostya Serebryany <kcc@google.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: Sandeep Patil <sspatil@android.com>
Cc: Laura Abbott <labbott@redhat.com>
Cc: Randy Dunlap <rdunlap@infradead.org>
Cc: Jann Horn <jannh@google.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Marco Elver <elver@google.com>
Pull networking updates from David Miller:
"Some highlights from this development cycle:
1) Big refactoring of ipv6 route and neigh handling to support
nexthop objects configurable as units from userspace. From David
Ahern.
2) Convert explored_states in BPF verifier into a hash table,
significantly decreased state held for programs with bpf2bpf
calls, from Alexei Starovoitov.
3) Implement bpf_send_signal() helper, from Yonghong Song.
4) Various classifier enhancements to mvpp2 driver, from Maxime
Chevallier.
5) Add aRFS support to hns3 driver, from Jian Shen.
6) Fix use after free in inet frags by allocating fqdirs dynamically
and reworking how rhashtable dismantle occurs, from Eric Dumazet.
7) Add act_ctinfo packet classifier action, from Kevin
Darbyshire-Bryant.
8) Add TFO key backup infrastructure, from Jason Baron.
9) Remove several old and unused ISDN drivers, from Arnd Bergmann.
10) Add devlink notifications for flash update status to mlxsw driver,
from Jiri Pirko.
11) Lots of kTLS offload infrastructure fixes, from Jakub Kicinski.
12) Add support for mv88e6250 DSA chips, from Rasmus Villemoes.
13) Various enhancements to ipv6 flow label handling, from Eric
Dumazet and Willem de Bruijn.
14) Support TLS offload in nfp driver, from Jakub Kicinski, Dirk van
der Merwe, and others.
15) Various improvements to axienet driver including converting it to
phylink, from Robert Hancock.
16) Add PTP support to sja1105 DSA driver, from Vladimir Oltean.
17) Add mqprio qdisc offload support to dpaa2-eth, from Ioana
Radulescu.
18) Add devlink health reporting to mlx5, from Moshe Shemesh.
19) Convert stmmac over to phylink, from Jose Abreu.
20) Add PTP PHC (Physical Hardware Clock) support to mlxsw, from
Shalom Toledo.
21) Add nftables SYNPROXY support, from Fernando Fernandez Mancera.
22) Convert tcp_fastopen over to use SipHash, from Ard Biesheuvel.
23) Track spill/fill of constants in BPF verifier, from Alexei
Starovoitov.
24) Support bounded loops in BPF, from Alexei Starovoitov.
25) Various page_pool API fixes and improvements, from Jesper Dangaard
Brouer.
26) Just like ipv4, support ref-countless ipv6 route handling. From
Wei Wang.
27) Support VLAN offloading in aquantia driver, from Igor Russkikh.
28) Add AF_XDP zero-copy support to mlx5, from Maxim Mikityanskiy.
29) Add flower GRE encap/decap support to nfp driver, from Pieter
Jansen van Vuuren.
30) Protect against stack overflow when using act_mirred, from John
Hurley.
31) Allow devmap map lookups from eBPF, from Toke Høiland-Jørgensen.
32) Use page_pool API in netsec driver, Ilias Apalodimas.
33) Add Google gve network driver, from Catherine Sullivan.
34) More indirect call avoidance, from Paolo Abeni.
35) Add kTLS TX HW offload support to mlx5, from Tariq Toukan.
36) Add XDP_REDIRECT support to bnxt_en, from Andy Gospodarek.
37) Add MPLS manipulation actions to TC, from John Hurley.
38) Add sending a packet to connection tracking from TC actions, and
then allow flower classifier matching on conntrack state. From
Paul Blakey.
39) Netfilter hw offload support, from Pablo Neira Ayuso"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (2080 commits)
net/mlx5e: Return in default case statement in tx_post_resync_params
mlx5: Return -EINVAL when WARN_ON_ONCE triggers in mlx5e_tls_resync().
net: dsa: add support for BRIDGE_MROUTER attribute
pkt_sched: Include const.h
net: netsec: remove static declaration for netsec_set_tx_de()
net: netsec: remove superfluous if statement
netfilter: nf_tables: add hardware offload support
net: flow_offload: rename tc_cls_flower_offload to flow_cls_offload
net: flow_offload: add flow_block_cb_is_busy() and use it
net: sched: remove tcf block API
drivers: net: use flow block API
net: sched: use flow block API
net: flow_offload: add flow_block_cb_{priv, incref, decref}()
net: flow_offload: add list handling functions
net: flow_offload: add flow_block_cb_alloc() and flow_block_cb_free()
net: flow_offload: rename TCF_BLOCK_BINDER_TYPE_* to FLOW_BLOCK_BINDER_TYPE_*
net: flow_offload: rename TC_BLOCK_{UN}BIND to FLOW_BLOCK_{UN}BIND
net: flow_offload: add flow_block_cb_setup_simple()
net: hisilicon: Add an tx_desc to adapt HI13X1_GMAC
net: hisilicon: Add an rx_desc to adapt HI13X1_GMAC
The commit below introduced a few compilation warnings.
In file included from ./include/rdma/ib_verbs.h:64,
from ./include/linux/mlx5/device.h:37,
from ./include/linux/mlx5/driver.h:51,
from drivers/net/ethernet/mellanox/mlx5/core/uar.c:36:
./include/linux/dim.h:378:1: warning: 'rdma_dim_prof' defined but not
used [-Wunused-const-variable=]
rdma_dim_prof[RDMA_DIM_PARAMS_NUM_PROFILES] = {
from
drivers/net/ethernet/mellanox/mlx5/core/pagealloc.c:37:
Since only ib_cq_rdma_dim_work() in drivers/infiniband/core/cq.c uses it,
just move the definition over there.
Fixes: f4915455dcf0 ("linux/dim: Implement RDMA adaptive moderation (DIM)")
Signed-off-by: Qian Cai <cai@lca.pw>
Use the neighbour lock when copying the MAC address from the neighbour
data struct in dst_fetch_ha.
When not using the lock, it is possible for the function to race with
neigh_update(), causing it to copy an torn MAC address:
rdma_resolve_addr()
rdma_resolve_ip()
addr_resolve()
addr_resolve_neigh()
fetch_ha()
dst_fetch_ha()
memcpy(dev_addr->dst_dev_addr, n->ha, MAX_ADDR_LEN)
and
net_ioctl()
arp_ioctl()
arp_rec_delete()
arp_invalidate()
neigh_update()
__neigh_update()
memcpy(&neigh->ha, lladdr, dev->addr_len)
It is possible to provoke this error by calling rdma_resolve_addr() in a
tight loop, while deleting the corresponding ARP entry in another tight
loop.
Fixes: 51d45974515c ("infiniband: addr: Consolidate code to fetch neighbour hardware address from dst.")
Signed-off-by: Dag Moxnes <dag.moxnes@oracle.com>
Signed-off-by: Håkon Bugge <haakon.bugge@oracle.com>
git://git.kernel.org/pub/scm/linux/kernel/git/zohar/linux-integrity
Pull integrity updates from Mimi Zohar:
"Bug fixes, code clean up, and new features:
- IMA policy rules can be defined in terms of LSM labels, making the
IMA policy dependent on LSM policy label changes, in particular LSM
label deletions. The new environment, in which IMA-appraisal is
being used, frequently updates the LSM policy and permits LSM label
deletions.
- Prevent an mmap'ed shared file opened for write from also being
mmap'ed execute. In the long term, making this and other similar
changes at the VFS layer would be preferable.
- The IMA per policy rule template format support is needed for a
couple of new/proposed features (eg. kexec boot command line
measurement, appended signatures, and VFS provided file hashes).
- Other than the "boot-aggregate" record in the IMA measuremeent
list, all other measurements are of file data. Measuring and
storing the kexec boot command line in the IMA measurement list is
the first buffer based measurement included in the measurement
list"
* 'next-integrity' of git://git.kernel.org/pub/scm/linux/kernel/git/zohar/linux-integrity:
integrity: Introduce struct evm_xattr
ima: Update MAX_TEMPLATE_NAME_LEN to fit largest reasonable definition
KEXEC: Call ima_kexec_cmdline to measure the boot command line args
IMA: Define a new template field buf
IMA: Define a new hook to measure the kexec boot command line arguments
IMA: support for per policy rule template formats
integrity: Fix __integrity_init_keyring() section mismatch
ima: Use designated initializers for struct ima_event_data
ima: use the lsm policy update notifier
LSM: switch to blocking policy update notifiers
x86/ima: fix the Kconfig dependency for IMA_ARCH_POLICY
ima: Make arch_policy_entry static
ima: prevent a file already mmap'ed write to be mmap'ed execute
x86/ima: check EFI SetupMode too
While creating new RDMA devices based on netdevice name, consider the net
namespace of the caller skb's socket similar to rest of the doit()
callbacks and nldev_dellink() which deletes the RDMA device created using
nldev_newlink().
Fixes: 3856ec4b93c94 ("RDMA/core: Add RDMA_NLDEV_CMD_NEWLINK/DELLINK support")
Added parameter in ib_device for enabling dynamic interrupt moderation so
that it can be configured in userspace using rdma tool.
In order to set adaptive-moderation for an ib device the command is:
rdma dev set [DEV] adaptive-moderation [on|off]
Please set on/off.
rdma dev show
0: mlx5_0: node_type ca fw 16.26.0055 node_guid 248a:0703:00a5:29d0
sys_image_guid 248a:0703:00a5:29d0 adaptive-moderation on
rdma resource show cq
dev mlx5_0 cqn 0 cqe 1023 users 4 poll-ctx UNBOUND_WORKQUEUE
adaptive-moderation off comm [ib_core]
Signed-off-by: Yamin Friedman <yaminf@mellanox.com>
Reviewed-by: Sagi Grimberg <sagi@grimberg.me>
Added the interface in the infiniband driver that applies the rdma_dim
adaptive moderation. There is now a special function for allocating an
ib_cq that uses rdma_dim.
Performance improvement (ConnectX-5 100GbE, x86) running FIO benchmark over
NVMf between two equal end-hosts with 56 cores across a Mellanox switch
using null_blk device:
READS without DIM:
blk size | BW | IOPS | 99th percentile latency | 99.99th latency
512B | 3.8GiB/s | 7.7M | 1401 usec | 2442 usec
4k | 7.0GiB/s | 1.8M | 4817 usec | 6587 usec
64k | 10.7GiB/s| 175k | 9896 usec | 10028 usec
IO WRITES without DIM:
512B | 3.6GiB/s | 7.5M | 1434 usec | 2474 usec
4k | 6.3GiB/s | 1.6M | 938 usec | 1221 usec
64k | 10.7GiB/s| 175k | 8979 usec | 12780 usec
IO READS with DIM:
512B | 4GiB/s | 8.2M | 816 usec | 889 usec
4k | 10.1GiB/s| 2.65M| 3359 usec | 5080 usec
IO WRITES with DIM:
512B | 3.9GiB/s | 8.1M | 799 usec | 922 usec
4k | 9.6GiB/s | 2.5M | 717 usec | 1004 usec
64k | 10.7GiB/s| 176k | 8586 usec | 12256 usec
The rdma_dim algorithm was designed to measure the effectiveness of
moderation on the flow in a general way and thus should be appropriate
for all RDMA storage protocols.
rdma_dim is configured to be the default option based on performance
improvement seen after extensive tests.
Reviewed-by: Max Gurtovoy <maxg@mellanox.com>
Signed-off-by: Saeed Mahameed <saeedm@mellanox.com>
This patch adds the ability to return the hwstats of per-port default
counters (which can also be queried through sysfs nodes).
Provide an option to get current counter mode through RDMA netlink.
Reviewed-by: Majd Dibbiny <majd@mellanox.com>
Provide an option to allow users to manually bind a qp with a counter
through RDMA netlink. Limit it to users with ADMIN capability only.
In manual mode a QP is bound to a counter manually. If counter is not
specified then a new one will be allocated.
Manual mode is enabled when user binds a QP, and disabled when the last
manually bound QP is unbound.
When auto-mode is turned off and there are counters left, manual mode is
enabled so that the user is able to access these counters.
Since a QP can only be bound to one counter, then if it is bound to a
separate counter, for backward compatibility purpose, the statistic value
must be:
* stat of default counter
+ stat of all running allocated counters
+ stat of all deallocated counters (history stats)
This patch adds the ability to return all available counters together with
their properties and hwstats.
Provide an option to enable/disable per-port counter auto mode through
In auto mode all QPs belong to one category are bind automatically to a
single counter set. Currently only "qp type" is supported.
In this mode the qp counter is set in RST2INIT modification, and when a qp
is destroyed the counter is unbound.
Add an API to support set/clear per-port auto mode.
Remove is_visible_in_pid_ns() from nldev.c and make it as a restrack API,
so that it can be taken advantage by other parts like counter.
Add rdma_restrack_attach_task() which is able to attach a task other then
"current" to a resource.
Introduce statistic counter as a new resource. It allows a user to monitor
specific objects (e.g., QPs) by binding to a counter.
In some cases a user counter resource is created with task other then
"current", because its creation is done as part of rdmatool call.
The variable ret is being initialized with a value that is never read and
it is being updated later with a new value. The initialization is
redundant and can be removed.
Addresses-Coverity: ("Unused value")
For dependencies in next patches.
Resolve conflicts:
- Use uverbs_get_cleared_udata() with new cq allocation flow
- Continue to delete nes despite SPDX conflict
- Resolve list appends in mlx5_command_str()
- Use u16 for vport_rule stuff
- Resolve list appends in struct ib_client
For all string attributes for which we don't currently accept the element
as input, we only use it as output, set the string length to
RDMA_NLDEV_ATTR_EMPTY_STRING which is defined as 1. That way we will only
accept a null string for that element. This will prevent someone from
writing a new input routine that uses the element without also updating
the policy to have a valid value.
Also while there, make sure the existing entries that are valid have the
correct policy, if not, correct the policy. Remove unnecessary checks
for nla_strlcpy() overflow once the policy has been set correctly.
The InfiniBand docs are plain text with no markups. So, all we needed to
do were to add the title markups and some markup sequences in order to
properly parse tables, lists and literal blocks.
At its new index.rst, let's add a :orphan: while this is not linked to the
main index.rst file, in order to avoid build warnings.
Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
Replace the old signature handover API with the new one. The new API
simplifes PI handover code complexity for ULPs and improve performance.
For RW API it will reduce the maximum number of work requests per task
and the need of dealing with multiple MRs (and their registrations and
invalidations) per task. All the mappings and registration of the data
and the protection buffers is done by the LLD using a single WR and a
special MR type (IB_MR_TYPE_INTEGRITY) for the PI handover operation.
The setup of the tested benchmark (using iSER ULP):
- 2 servers with 24 cores (1 initiator and 1 target)
- ConnectX-4/ConnectX-5 adapters
- 24 target sessions with 1 LUN each
- ramdisk backstore
- PI active
Performance results running fio (24 jobs, 128 iodepth) using
write_generate=1 and read_verify=1 (w/w.o patch):
bs IOPS(read) IOPS(write)
512 1243.3K/1182.3K 1725.1K/1680.2K
4k 571233/528835 743293/748259
32k 72388/71086 71789/93573
Using write_generate=0 and read_verify=0 (w/w.o patch):
512 1572.1K/1427.2K 1823.5K/1724.3K
4k 921992/916194 753772/768267
32k 75052/73960 73180/95484
There is a performance degradation when writing big block sizes.
Degradation is caused by the complexity of combining multiple
indirections and perform RDMA READ operation from it. This will be
fixed in the following patches by reducing the indirections if
possible.
Signed-off-by: Israel Rukshin <israelr@mellanox.com>
This is a preparation for adding new signature API to the rw-API.
Suggested-by: Christoph Hellwig <hch@lst.de>
Protect the case that a ULP tries to allocate a QP with signature
enabled flag while the LLD doesn't support this feature.
While we're here, also move integrity_en attribute from mlx5_qp to
ib_qp as a preparation for adding new integrity API to the rw-API
(that is part of ib_core module).
Signed-off-by: Max Gurtovoy <maxg@mellanox.com>
