Set the return variable to an error code as done elsewhere in the function.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
if@p1 (\(ret < 0\|ret != 0\))
{ ... return ret; }
ret@p1 = 0
... when != ret = e1
when != &ret
*if(...)
... when != ret = e2
when forall
return ret;
// </smpl>
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
Signed-off-by: Roland Dreier <roland@purestorage.com>
CONFIG_HOTPLUG is going away as an option. As a result, the __dev*
markings need to be removed.
This change removes the use of __devinit, __devexit_p, __devinitdata,
and __devexit from these drivers.
Based on patches originally written by Bill Pemberton, but redone by me
in order to handle some of the coding style issues better, by hand.
Cc: Bill Pemberton <wfp5p@virginia.edu>
Cc: Tom Tucker <tom@opengridcomputing.com>
Cc: Steve Wise <swise@opengridcomputing.com>
Cc: Roland Dreier <roland@kernel.org>
Cc: Sean Hefty <sean.hefty@intel.com>
Cc: Hal Rosenstock <hal.rosenstock@gmail.com>
Cc: Hoang-Nam Nguyen <hnguyen@de.ibm.com>
Cc: Christoph Raisch <raisch@de.ibm.com>
Cc: Mike Marciniszyn <infinipath@intel.com>
Cc: Faisal Latif <faisal.latif@intel.com>
Correct spelling typos in comments in drivers/infiniband.
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Signed-off-by: Roland Dreier <rolandd@cisco.com>
The DMA API is preferred; no functional change.
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
- Change the IB_DEVICE_ZERO_STAG flag to the transport-neutral name
IB_DEVICE_LOCAL_DMA_LKEY, which is used by iWARP RNICs to indicate 0
STag support and IB HCAs to indicate reserved L_Key support.
- Add a u32 local_dma_lkey member to struct ib_device. Drivers fill
this in with the appropriate local DMA L_Key (if they support it).
- Fix up the drivers using this flag.
Signed-off-by: Steve Wise <swise@opengridcomputing.com>
In 2.6.26, we added some support for send with invalidate work
requests, including a device capability flag to indicate whether a
device supports such requests. However, the support was incomplete:
the completion structure was not extended with a field for the key
contained in incoming send with invalidate requests.
Full support for memory management extensions (send with invalidate,
local invalidate, fast register through a send queue, etc) is planned
for 2.6.27. Since send with invalidate is not very useful by itself,
just remove the IB_DEVICE_SEND_W_INV bit before the 2.6.26 final
release; we will add an IB_DEVICE_MEM_MGT_EXTENSIONS bit in 2.6.27,
which makes things simpler for applications, since they will not have
quite as confusing an array of fine-grained bits to check.
Handle IB_WR_SEND_WITH_INV work requests.
This resurrects a patch sent long ago by Mikkel Hagen <mhagen@iol.unh.edu>.
Add a new IB_WR_SEND_WITH_INV send opcode that can be used to mark a
"send with invalidate" work request as defined in the iWARP verbs and
the InfiniBand base memory management extensions. Also put "imm_data"
and a new "invalidate_rkey" member in a new "ex" union in struct
ib_send_wr. The invalidate_rkey member can be used to pass in an
R_Key/STag to be invalidated. Add this new union to struct
ib_uverbs_send_wr. Add code to copy the invalidate_rkey field in
ib_uverbs_post_send().
Fix up low-level drivers to deal with the change to struct ib_send_wr,
and just remove the imm_data initialization from net/sunrpc/xprtrdma/,
since that code never does any send with immediate operations.
Also, move the existing IB_DEVICE_SEND_W_INV flag to a new bit, since
the iWARP drivers currently in the tree set the bit. The amso1100
driver at least will silently fail to honor the IB_SEND_INVALIDATE bit
if passed in as part of userspace send requests (since it does not
implement kernel bypass work request queueing). Remove the flag from
all existing drivers that set it until we know which ones are OK.
The values chosen for the new flag is not consecutive to avoid clashing
with flags defined in the XRC patches, which are not merged yet but
which are already in use and are likely to be merged soon.
__FUNCTION__ is gcc-specific, use __func__ instead.
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Acked-by: Steve Wise <swise@opengridcomputing.com>
The amso1100 driver was missing a couple of __devinit/__devexit
annotations for init/cleanup functions that are called from
__devinit/__devexit functions.
Reported by Randy Dunlap <randy.dunlap@oracle.com>.
Fix the AMSO1100 firmware version computation, which was broken
due to "&&" being used where "&" should have.
pr_debug() was printing the wrong stuff.
The Ammasso driver needs to use dma_alloc_coherent() for
allocating memory that will be used by the HW for dma.
This patch fixes a NULL dereference spotted by the Coverity checker.
Acked-by: Tom Tucker <tom@opengridcomputing.com>
Make sure all 64-bit quantities are cast to unsigned long long
when printed with "%ll" printk formats.
indirect chains of includes are arch-specific and can't
be relied upon... (hell, even attempt to build it for
itanic would trigger vmalloc.h ones; err.h triggers
on e.g. alpha).
Add a driver for the Ammasso 1100 gigabit ethernet RNIC.
Signed-off-by: Tom Tucker <tom@opengridcomputing.com>
