cxio_flush_sq() was failing to wrap around the software send queue
causing garbage completion entries on a flush operation.
Signed-off-by: Steve Wise <swise@opengridcomputing.com>
Signed-off-by: Roland Dreier <rolandd@cisco.com>
Currently, iw_cxgb3 is severely limited on the amount of userspace
memory that can be registered in in a single memory region, which
causes big problems for applications that expect to be able to
register 100s of MB.
The problem is that the driver uses a single kmalloc()ed buffer to
hold the physical buffer list (PBL) for the entire memory region
during registration, which means that 8 bytes of contiguous memory are
required for each page of memory being registered. For example, a 64
MB registration will require 128 KB of contiguous memory with 4 KB
pages, and it unlikely that such an allocation will succeed on a busy
system.
This is purely a driver problem: the temporary page list buffer is not
needed by the hardware, so we can fix this by writing the PBL to the
hardware in page-sized chunks rather than all at once. We do this by
splitting the memory registration operation up into several steps:
- Allocate PBL space in adapter memory for the full registration
- Copy PBL to adapter memory in chunks
- Allocate STag and enable memory region
This also allows several other cleanups to the __cxio_tpt_op()
interface and related parts of the driver.
This change leaves the reregister memory region and memory window
operations broken, but they already didn't work due to other
longstanding bugs, so fixing them will be left to a later patch.
- Flush the QP only after the HW disables the connection. Currently
we flush the QP when transitioning to CLOSING. This exposes a race
condition where the HW can complete a RECV WR, for instance, -and-
the SW can flush that same WR.
- Only call CQ event handlers on flush IFF we actually flushed something.
Open MPI, Intel MPI and other applications don't respect the iWARP
requirement that the client (active) side of the connection send the
first RDMA message. This class of application connection setup is
called peer-to-peer. Typically once the connection is setup, _both_
sides want to send data.
This patch enables supporting peer-to-peer over the chelsio RNIC by
enforcing this iWARP requirement in the driver itself as part of RDMA
connection setup.
Connection setup is extended, when the peer2peer module option is 1,
such that the MPA initiator will send a 0B Read (the RTR) just after
connection setup. The MPA responder will suspend SQ processing until
the RTR message is received and reply-to.
In the longer term, this will be handled in a standardized way by
enhancing the MPA negotiation so peers can indicate whether they
want/need the RTR and what type of RTR (0B read, 0B write, or 0B send)
should be sent. This will be done by standardizing a few bits of the
private data in order to negotiate all this. However this patch
enables peer-to-peer applications now and allows most of the required
firmware and driver changes to be done and tested now.
Design:
- Add a module option, peer2peer, to enable this mode.
- New firmware support for peer-to-peer mode:
- a new bit in the rdma_init WR to tell it to do peer-2-peer
and what form of RTR message to send or expect.
- process _all_ preposted recvs before moving the connection
into rdma mode.
- passive side: defer completing the rdma_init WR until all
pre-posted recvs are processed. Suspend SQ processing until
the RTR is received.
- active side: expect and process the 0B read WR on offload TX
queue. Defer completing the rdma_init WR until all
the 0B read WR is processed from the offload TX queue.
- If peer2peer is set, driver posts 0B read request on offload TX
queue just after posting the rdma_init WR to the offload TX queue.
- Add CQ poll logic to ignore unsolicitied read responses.
__FUNCTION__ is gcc-specific, use __func__ instead.
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Correctly work around T3A issues by checking "hwtype != T3A" instead of
"hwtype == T3B". This will be needed for new hardware types.
This patch makes most of the generic device layer network
namespace safe. This patch makes dev_base_head a
network namespace variable, and then it picks up
a few associated variables. The functions:
dev_getbyhwaddr
dev_getfirsthwbytype
dev_get_by_flags
dev_get_by_name
__dev_get_by_name
dev_get_by_index
__dev_get_by_index
dev_ioctl
dev_ethtool
dev_load
wireless_process_ioctl
were modified to take a network namespace argument, and
deal with it.
vlan_ioctl_set and brioctl_set were modified so their
hooks will receive a network namespace argument.
So basically anthing in the core of the network stack that was
affected to by the change of dev_base was modified to handle
multiple network namespaces. The rest of the network stack was
simply modified to explicitly use &init_net the initial network
namespace. This can be fixed when those components of the network
stack are modified to handle multiple network namespaces.
For now the ifindex generator is left global.
Fundametally ifindex numbers are per namespace, or else
we will have corner case problems with migration when
we get that far.
At the same time there are assumptions in the network stack
that the ifindex of a network device won't change. Making
the ifindex number global seems a good compromise until
the network stack can cope with ifindex changes when
you change namespaces, and the like.
cxgb3 used netdev_priv() and dev->priv for different purposes.
In 2.6.23, netdev_priv() == dev->priv, cxgb3 needs a fix.
This patch is a partial backport of Dave Miller's changes in the
net-2.6.24 git branch.
Without this fix, cxgb3 crashes on 2.6.23.
Signed-off-by: Divy Le Ray <divy@chelsio.com>
Signed-off-by: Jeff Garzik <jeff@garzik.org>
Due to a HW issue, our current scheme to transition the connection from
streaming to rdma mode is broken on the passive side. The firmware
and driver now support a new transition scheme for the passive side:
- driver posts rdma_init_wr (now including the initial receive seqno)
- driver posts last streaming message via TX_DATA message (MPA start
response)
- uP atomically sends the last streaming message and transitions the
tcb to rdma mode.
- driver waits for wr_ack indicating the last streaming message was ACKed.
NOTE: This change also bumps the required firmware version to 4.3.
The semantics defined by the InfiniBand specification say that
completion events are only generated when a completions is added to a
completion queue (CQ) after completion notification is requested. In
other words, this means that the following race is possible:
while (CQ is not empty)
ib_poll_cq(CQ);
// new completion is added after while loop is exited
ib_req_notify_cq(CQ);
// no event is generated for the existing completion
To close this race, the IB spec recommends doing another poll of the
CQ after requesting notification.
However, it is not always possible to arrange code this way (for
example, we have found that NAPI for IPoIB cannot poll after
requesting notification). Also, some hardware (eg Mellanox HCAs)
actually will generate an event for completions added before the call
to ib_req_notify_cq() -- which is allowed by the spec, since there's
no way for any upper-layer consumer to know exactly when a completion
was really added -- so the extra poll of the CQ is just a waste.
Motivated by this, we add a new flag "IB_CQ_REPORT_MISSED_EVENTS" for
ib_req_notify_cq() so that it can return a hint about whether the a
completion may have been added before the request for notification.
The return value of ib_req_notify_cq() is extended so:
< 0 means an error occurred while requesting notification
== 0 means notification was requested successfully, and if
IB_CQ_REPORT_MISSED_EVENTS was passed in, then no
events were missed and it is safe to wait for another
event.
> 0 is only returned if IB_CQ_REPORT_MISSED_EVENTS was
passed in. It means that the consumer must poll the
CQ again to make sure it is empty to avoid the race
described above.
We add a flag to enable this behavior rather than turning it on
unconditionally, because checking for missed events may incur
significant overhead for some low-level drivers, and consumers that
don't care about the results of this test shouldn't be forced to pay
for the test.
This was spotted by the Coverity checker (CID 1554).
cxgb3 uses dma_alloc_coherent() et al. thus needs linux/dma-mapping.h
include in order to build reliably.
Noticed on sparc64.
Acked-by: Steve Wise <swise@opengridcomputing.com>
- don't mark static functions in C files as inline - gcc should know
best whether inlining makes sense
- never compile the unused cxio_dbg.c
- make the following needlessly global functions static:
- cxio_hal.c: cxio_hal_clear_qp_ctx()
- iwch_provider.c: iwch_get_qp()
- remove the following unused global functions:
- cxio_hal.c: cxio_allocate_stag()
- cxio_resource.: cxio_hal_get_rhdl()
- cxio_resource.: cxio_hal_put_rhdl()
Remove the Open Grid Computing copyright. It shouldn't be there.
Add an RDMA/iWARP driver for the Chelsio T3 1GbE and 10GbE adapters.
