Remove all #inclusions of asm/system.h preparatory to splitting and killing
it. Performed with the following command:
perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *`
In particular, several occurances of funny versions of 'success',
'unknown', 'therefore', 'acknowledge', 'argument', 'achieve', 'address',
'beginning', 'desirable', 'separate' and 'necessary' are fixed.
Signed-off-by: Daniel Mack <daniel@caiaq.de>
Cc: Joe Perches <joe@perches.com>
Cc: Junio C Hamano <gitster@pobox.com>
Always set bad_wr when an immediate error is detected. Do not report
success if an error occurred.
Signed-off-by: Frank Zago <fzago@systemfabricworks.com>
Signed-off-by: Roland Dreier <rolandd@cisco.com>
The driver was reporting CQE flags in the wrong bit positions, causing
consumers to miss incoming immediate data.
Signed-off-by: Joachim Fenkes <fenkes@de.ibm.com>
Commit fe333321 ("powerpc: Change u64/s64 to a long long integer
type") changed u64 from unsigned long to unsigned long long, which
means that printk formats for printing u64 values should use "ll"
instead of "l" to avoid warnings. Fix all the places affected by this
in ehca.
With the latest flush error completion patch we introduced modulus
operation to calculate the next index within a qmap. Based on
comments from other mailing lists we decided to optimize this
operation by using an addition and an if-statement instead of modulus,
even though this is on the error path.
Signed-off-by: Stefan Roscher <stefan.roscher@de.ibm.com>
This fix enables ehca device driver to generate flush work completions
even if the application doesn't request completions for all work
requests. The current implementation of ehca will generate flush work
completions for the wrong work requests if an application uses non
signaled work completions.
When a QP goes into error state, it is required that CQ entries with a
flush error status are delivered to the application for any
outstanding work requests. eHCA does not do this in hardware, so this
patch adds software flush CQE generation to the ehca driver.
Whenever a QP gets into error state, it is added to the QP error list
of its respective CQ. If the error QP list of a CQ is not empty,
poll_cq() generates flush CQEs before polling the actual CQ.
Signed-off-by: Alexander Schmidt <alexs@linux.vnet.ibm.com>
Under rare circumstances, the ehca hardware might erroneously generate
two CQEs for the same WQE, which is not compliant to the IB spec and
will cause unpredictable errors like memory being freed twice. To
avoid this problem, the driver needs to detect the second CQE and
discard it.
For this purpose, introduce an array holding as many elements as the
SQ of the QP, called sq_map. Each sq_map entry stores a "reported"
flag for one WQE in the SQ. When a work request is posted to the SQ,
the respective "reported" flag is set to zero. After the arrival of a
CQE, the flag is set to 1, which allows to detect the occurence of a
second CQE.
The mapping between WQE / CQE and the corresponding sq_map element is
implemented by replacing the lowest 16 Bits of the wr_id with the
index in the queue map. The original 16 Bits are stored in the sq_map
entry and are restored when the CQE is passed to the application.
The idr_find() function may fail when trying to get the QP that is
associated with a CQE, e.g. when a QP has been destroyed between the
generation of a CQE and the poll request for it. In consequence, the
return value of idr_find() must be checked and the CQE must be
discarded when the QP cannot be found.
When the ehca driver detects an invalid opcode in a CQE, it currently
passes the CQE to the application and returns with success. This patch
changes the CQE handling to discard CQEs with invalid opcodes and to
continue reading the next CQE from the CQ.
Rename the "poll_cq_one_read_cqe" goto label to what it actually does,
namely "repoll".
from include/asm-powerpc. This is the result of a
mkdir arch/powerpc/include/asm
git mv include/asm-powerpc/* arch/powerpc/include/asm
Followed by a few documentation/comment fixups and a couple of places
where <asm-powepc/...> was being used explicitly. Of the latter only
one was outside the arch code and it is a driver only built for powerpc.
This patch adds support for the IB "base memory management extension"
(BMME) and the equivalent iWARP operations (which the iWARP verbs
mandates all devices must implement). The new operations are:
- Allocate an ib_mr for use in fast register work requests.
- Allocate/free a physical buffer lists for use in fast register work
requests. This allows device drivers to allocate this memory as
needed for use in posting send requests (eg via dma_alloc_coherent).
- New send queue work requests:
* send with remote invalidate
* fast register memory region
* local invalidate memory region
* RDMA read with invalidate local memory region (iWARP only)
Consumer interface details:
- A new device capability flag IB_DEVICE_MEM_MGT_EXTENSIONS is added
to indicate device support for these features.
- New send work request opcodes IB_WR_FAST_REG_MR, IB_WR_LOCAL_INV,
IB_WR_RDMA_READ_WITH_INV are added.
- A new consumer API function, ib_alloc_mr() is added to allocate
fast register memory regions.
- New consumer API functions, ib_alloc_fast_reg_page_list() and
ib_free_fast_reg_page_list() are added to allocate and free
device-specific memory for fast registration page lists.
- A new consumer API function, ib_update_fast_reg_key(), is added to
allow the key portion of the R_Key and L_Key of a fast registration
MR to be updated. Consumers call this if desired before posting
a IB_WR_FAST_REG_MR work request.
Consumers can use this as follows:
- MR is allocated with ib_alloc_mr().
- Page list memory is allocated with ib_alloc_fast_reg_page_list().
- MR R_Key/L_Key "key" field is updated with ib_update_fast_reg_key().
- MR made VALID and bound to a specific page list via
ib_post_send(IB_WR_FAST_REG_MR)
- MR made INVALID via ib_post_send(IB_WR_LOCAL_INV),
ib_post_send(IB_WR_RDMA_READ_WITH_INV) or an incoming send with
invalidate operation.
- MR is deallocated with ib_dereg_mr()
- page lists dealloced via ib_free_fast_reg_page_list().
Applications can allocate a fast register MR once, and then can
repeatedly bind the MR to different physical block lists (PBLs) via
posting work requests to a send queue (SQ). For each outstanding
MR-to-PBL binding in the SQ pipe, a fast_reg_page_list needs to be
allocated (the fast_reg_page_list is owned by the low-level driver
from the consumer posting a work request until the request completes).
Thus pipelining can be achieved while still allowing device-specific
page_list processing.
The 32-bit fast register memory key/STag is composed of a 24-bit index
and an 8-bit key. The application can change the key each time it
fast registers thus allowing more control over the peer's use of the
key/STag (ie it can effectively be changed each time the rkey is
rebound to a page list).
Signed-off-by: Steve Wise <swise@opengridcomputing.com>
...as required by IB Spec, C10-29.
Add a new IB_WR_SEND_WITH_INV send opcode that can be used to mark a
"send with invalidate" work request as defined in the iWARP verbs and
the InfiniBand base memory management extensions. Also put "imm_data"
and a new "invalidate_rkey" member in a new "ex" union in struct
ib_send_wr. The invalidate_rkey member can be used to pass in an
R_Key/STag to be invalidated. Add this new union to struct
ib_uverbs_send_wr. Add code to copy the invalidate_rkey field in
ib_uverbs_post_send().
Fix up low-level drivers to deal with the change to struct ib_send_wr,
and just remove the imm_data initialization from net/sunrpc/xprtrdma/,
since that code never does any send with immediate operations.
Also, move the existing IB_DEVICE_SEND_W_INV flag to a new bit, since
the iWARP drivers currently in the tree set the bit. The amso1100
driver at least will silently fail to honor the IB_SEND_INVALIDATE bit
if passed in as part of userspace send requests (since it does not
implement kernel bypass work request queueing). Remove the flag from
all existing drivers that set it until we know which ones are OK.
The values chosen for the new flag is not consecutive to avoid clashing
with flags defined in the XRC patches, which are not merged yet but
which are already in use and are likely to be merged soon.
This resurrects a patch sent long ago by Mikkel Hagen <mhagen@iol.unh.edu>.
The IB spec doesn't allow packets to QP0 sent on any other VL than VL15.
Hardware doesn't filter those packets on the send side, so we need to do
this in the driver and firmware.
As eHCA doesn't support QP0, we can just filter out all traffic going to
QP0, regardless of SL or VL.
Some HW revisions of eHCA2 may cause an RC connection to break if they
received RDMA Reads over that connection before. This can be
prevented by assuring that, after the first RDMA Read, the QP receives
a new RDMA Read every few million link packets.
Include code into the driver that inserts an empty (size 0) RDMA Read
into the message stream every now and then if the consumer doesn't
post them frequently enough.
...because -12 is easier to read than FFFFFFF4.
Run the existing ehca code through checkpatch.pl and clean up the
worst of the coding style violations.
Kick the hardware before unlocking the send/receive queue to overlap
processing a little more.
Also add two unlikely() statements.
- Rename all spinlock flags to "flags", matching the vast majority of kernel
code.
- Move hcall_lock into the only file it's used in.
- Replaced spin_lock_init() and friends with static initializers for
global variables.
Support SRQs on eHCA2. Since an SRQ is a QP for eHCA2, a lot of code
(structures, create, destroy, post_recv) can be shared between QP and SRQ.
Refactor the ehca changes from commit ed23a727 ("IB: Return "maybe
missed event" hint from ib_req_notify_cq()") so the queue arithmetic
is done in slightly fewer lines. Also, move the spinlock flags into
the block they're used in.
The semantics defined by the InfiniBand specification say that
completion events are only generated when a completions is added to a
completion queue (CQ) after completion notification is requested. In
other words, this means that the following race is possible:
while (CQ is not empty)
ib_poll_cq(CQ);
// new completion is added after while loop is exited
ib_req_notify_cq(CQ);
// no event is generated for the existing completion
To close this race, the IB spec recommends doing another poll of the
CQ after requesting notification.
However, it is not always possible to arrange code this way (for
example, we have found that NAPI for IPoIB cannot poll after
requesting notification). Also, some hardware (eg Mellanox HCAs)
actually will generate an event for completions added before the call
to ib_req_notify_cq() -- which is allowed by the spec, since there's
no way for any upper-layer consumer to know exactly when a completion
was really added -- so the extra poll of the CQ is just a waste.
Motivated by this, we add a new flag "IB_CQ_REPORT_MISSED_EVENTS" for
ib_req_notify_cq() so that it can return a hint about whether the a
completion may have been added before the request for notification.
The return value of ib_req_notify_cq() is extended so:
< 0 means an error occurred while requesting notification
== 0 means notification was requested successfully, and if
IB_CQ_REPORT_MISSED_EVENTS was passed in, then no
events were missed and it is safe to wait for another
event.
> 0 is only returned if IB_CQ_REPORT_MISSED_EVENTS was
passed in. It means that the consumer must poll the
CQ again to make sure it is empty to avoid the race
described above.
We add a flag to enable this behavior rather than turning it on
unconditionally, because checking for missed events may incur
significant overhead for some low-level drivers, and consumers that
don't care about the results of this test shouldn't be forced to pay
for the test.
struct ib_wc currently only includes the local QP number: this matches
the IB spec, but seems mostly useless. The following patch replaces
this with the pointer to qp itself, and updates all low level drivers
and all users.
This has the following advantages:
- Ability to get a per-qp context through wc->qp->qp_context
- Existing drivers already have the qp pointer ready in poll cq, so
this change actually saves a tiny bit (extra memory read) on data path
(for ehca it would actually be expensive to find the QP pointer when
polling a CQ, but ehca does not support SRQ so we can leave wc->qp as
NULL for ehca)
- Users that need the QP number can still get it through wc->qp->qp_num
Use case:
In IPoIB connected mode code, I have a common CQ shared by multiple
QPs. To track connection usage, I need a way to get at some per-QP
context upon the completion, and I would like to avoid allocating
context object per work request just to stick a QP pointer into it.
With this code, I can just use wc->qp->qp_context.
Signed-off-by: Michael S. Tsirkin <mst@mellanox.co.il>
Add a driver for IBM GX bus InfiniBand adapters, which are usable with
some pSeries/System p systems.
Signed-off-by: Heiko J Schick <schickhj.ibm.com>
