The link state event calls were being generated when the SM told the SMA
to change link states. This works for IB_EVENT_PORT_ACTIVE but not if
the link goes down and stays down. The fix is to generate event calls
from the interrupt handler when the HW link state changes.
Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com>
Signed-off-by: Roland Dreier <rolandd@cisco.com>
ipath_poll() suffered from a couple subtle bugs. Under the right
conditions we could leave recv interrupts enabled on an ipath user
context on close, thereby taking potentially unwanted interrupts on the
next open -- this is fixed by unconditionally turning off recv
interrupts on close. Also, we now use counters rather than set/clear
bits which allows us to make sure we catch all interrupts at the cost of
changing the semantics slightly (it's now give me all events since the
last time I called poll() rather than give me all events since I called
_this_ poll routine). We also added some memory barriers which may help
ensure we get all notifications in a timely manner.
Signed-off-by: Arthur Jones <arthur.jones@qlogic.com>
Different processors have different ordering restrictions for write
combining. By taking advantage of this, we can eliminate some write
barriers when writing to the send buffers.
On some system hardware, we are seeing moderately common cases of the
chip errormask register being overwritten due to a chip bug in iba6120
that is triggered by a vendor-specific PCIe broadcast message. This
patch merely checks periodically, and corrects it if needed (the
overwrite can cause us to not get error and hardware error
interrupts). Also, make dd->ipath_errormask the one, true canonical
source for kr_errormask, and remove references to ipath_ignorederrs as
it is currently unused.
Signed-off-by: Dave Olson <dave.olson@qlogic.com>
Signed-off-by: John Gregor <john.gregor@qlogic.com>
There was confused use of INFINIPATH_S_PIOBUFAVAILUPD (value) and
IPATH_S_PIOBUFAVAILUPD (bit position). Also, some callers of
ipath_cancel_sends() need kr_sendctrl restored, and some want to do it
later.
It has no callers and is completely dead code.
Make some functions that are only used in a single .c file static. In
addition to being a cleanup, this shrinks the generated code. On x86_64:
add/remove: 1/3 grow/shrink: 2/1 up/down: 4777/-4956 (-179)
function old new delta
handle_errors - 3994 +3994
__verbs_timer 42 710 +668
ipath_do_ruc_send 2131 2246 +115
ipath_no_bufs_available 136 - -136
ipath_disarm_senderrbufs 639 - -639
ipath_ib_timer 658 - -658
ipath_intr 5878 2355 -3523
All too often, interrupts do not get enabled for our card due to BIOS
misconfiguration and other issues. This patch checks for that
condition on startup and warns the user. This patch is based on work
(check LID availability) by Robert Walsh.
Clean up some code by removing support for some older pre-production
HTX InfiniPath cards.
We are more careful to be sure that we don't lose information about
changes that occurred while we were in freeze mode, when the chip will
not notify us, and try to avoid false error interrupts while doing
cleanup. Put all of this logic in a new function ipath_clear_freeze().
Now that it's June, it's about time to update
the copyright notices of files that have changed.
Fix ipath_poll and enhance it so we can poll for urgent packets or
regular packets and receive notifications of when a header queue
overflows.
Signed-off-by: Robert Walsh <robert.walsh@qlogic.com>
This centralizes the use of the abort functionality, removes the
unneeded buffer cancel (abort does the same thing), sets up to ignore
launch errors after abort, same as cancel. We need abort on exit from
freeze mode to avoid having buffers stuck in the busy state, if a user
process happened to complete the send while we were in freeze mode
doing the recovery.
We currently track various errors, now we enhance that capability by
logging some of them to EEPROM. We also now log a cumulative "active"
time defined by traffic though the InfiniPath HCA beyond the normal SM
traffic.
Signed-off-by: Michael Albaugh <michael.albaugh@qlogic.com>
The new LED blinking interface adds more contention for the
unprotected GPIO pins that were already shared, though not commonly at
the same time. We add locks to the accesses to these pins so that
Read-Modify-Write is now safe. Some of these locks are added at
interrupt context, so we shadow the registers which drive and inspect
these pins to avoid the mmio read/writes. This mitigates the effects
of the locks and hastens us through the interrupt.
Add locking and always use shadows for registers controlling GPIO pins
(ExtCtrl and GPIOout). The use of shadows implies doing less I/O,
which can make I2C operation too fast on some platforms. An explicit
udelay(1) in SCL manipulation fixes that.
When we want to find an InfiniPath HCA in a rack of nodes, it is often
expeditious to blink the status LEDs via a userspace /sys file.
A write-only led_override "file" is published per device. Writes to
this file are interpreted as (string form) numbers, and the resulting
value sent to ipath_set_led_override(). The upper eight bits are
interpretted as a 4.4 fixed-point "frequency in Hertz", and the bottom
two 4-bit values are alternately (D0..3, then D4..7) used by the
board-specific LED-setting function to override the normal state.
Once upon a time, GPIO interrupts were rare. But then a chip bug in
the waldo series forced the use of a GPIO interrupt to signal packet
reception. This greatly increased the frequency of GPIO interrupts
which have the gpio_mask bits set on the waldo chips. Other bits in
the gpio_status register are used for I2C clock and data lines, these
bits are usually on. An "unlikely" annotation leftover from the old
days was improperly applied to these bits, and an unnecessary chip
mmio read was being accessed in the interrupt fast path on waldo.
Remove the stagnant unlikely annotation in the interrupt handler and
keep a shadow copy of the gpio_mask register to avoid the slow mmio
read when testing for interruptable GPIO bits.
Mostly cleanup.
Signed-off-by: Bryan O'Sullivan <bryan.osullivan@qlogic.com>
Some types of packet errors are moderately common with longer IB
cables and large clusters, and are not reported with prints by other
IB HCA drivers. This suppresses those messages unless the new
__IPATH_ERRPKTDBG bit is set in ipath_debug. Reporting of temporarily
disabled frequent error interrupts was also made clearer
We also distinguish between chip errors, and bad packets sent or
received in the wording of the messages.
A recent change was made to allocate memory for a port after CPU
affinity is set. That change didn't account for subports and was
trying to allocate memory for the port twice.
Many struct file_operations in the kernel can be "const". Marking them const
moves these to the .rodata section, which avoids false sharing with potential
dirty data. In addition it'll catch accidental writes at compile time to
these shared resources.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Eric's changes to the htirq infrastructure require corresponding
modifications to the ipath HT driver code so that interrupts are still
delivered properly.
Cc: Eric W. Biederman <ebiederm@xmission.com>
Cc: Roland Dreier <rdreier@cisco.com>
Don't attempt to set up the diagpkt device in the module init code.
Instead, wait until a piece of hardware is initialized. Fixes a
problem when loading the ib_ipath module when no InfiniPath hardware
is present: modprobe would go into the D state and stay there.
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead
of passing regs around manually through all ~1800 interrupt handlers in the
Linux kernel.
The regs pointer is used in few places, but it potentially costs both stack
space and code to pass it around. On the FRV arch, removing the regs parameter
from all the genirq function results in a 20% speed up of the IRQ exit path
(ie: from leaving timer_interrupt() to leaving do_IRQ()).
Where appropriate, an arch may override the generic storage facility and do
something different with the variable. On FRV, for instance, the address is
maintained in GR28 at all times inside the kernel as part of general exception
handling.
Having looked over the code, it appears that the parameter may be handed down
through up to twenty or so layers of functions. Consider a USB character
device attached to a USB hub, attached to a USB controller that posts its
interrupts through a cascaded auxiliary interrupt controller. A character
device driver may want to pass regs to the sysrq handler through the input
layer which adds another few layers of parameter passing.
I've build this code with allyesconfig for x86_64 and i386. I've runtested the
main part of the code on FRV and i386, though I can't test most of the drivers.
I've also done partial conversion for powerpc and MIPS - these at least compile
with minimal configurations.
This will affect all archs. Mostly the changes should be relatively easy.
Take do_IRQ(), store the regs pointer at the beginning, saving the old one:
struct pt_regs *old_regs = set_irq_regs(regs);
And put the old one back at the end:
set_irq_regs(old_regs);
Don't pass regs through to generic_handle_irq() or __do_IRQ().
In timer_interrupt(), this sort of change will be necessary:
- update_process_times(user_mode(regs));
- profile_tick(CPU_PROFILING, regs);
+ update_process_times(user_mode(get_irq_regs()));
+ profile_tick(CPU_PROFILING);
I'd like to move update_process_times()'s use of get_irq_regs() into itself,
except that i386, alone of the archs, uses something other than user_mode().
Some notes on the interrupt handling in the drivers:
(*) input_dev() is now gone entirely. The regs pointer is no longer stored in
the input_dev struct.
(*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does
something different depending on whether it's been supplied with a regs
pointer or not.
(*) Various IRQ handler function pointers have been moved to type
irq_handler_t.
Signed-Off-By: David Howells <dhowells@redhat.com>
(cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
We can sometimes trigger parity errors due to processor speculative
reads to our write-combined memory (mostly seen on Woodcrest). Add a
stats counter for these.
Factored out the sendbuffererror buffer cancellation code so it can be
used in the new handling; suppress likely subsequent error messages if
within two jiffies of the cancellation.
Also restore 2 dropped TXE lines on hwe_bitsextant noticed while
debugging.
We were passing 0 for base and length, which worked on older kernels,
but it doesn't seem to any longer.
Prior to this change, the driver was not able to support a HT and PCIE
card simultaneously present in the same machine.
This also entailed a little GPIO-interrupt general cleanup.
This allows multiple userspace processes to share a single hardware
context in a master/slave arrangement. It is backwards binary compatible
with existing userspace.
This patch only renames files, fixes product names, and updates
comments.
When we first submitted a userspace subnet management agent, it was
rejected, so we left it out of the final driver submission. This patch
removes a number of vestigial references to it.
A lot of ipath layer code was only called in one place. Now that the
ipath_core and ib_ipath drivers are merged, it's more sensible to simply
inline the simple stuff that the layer code was doing.
There is little point in keeping the two drivers separate, so we are
merging them.
via DMA
We can't tell for sure if any packets are in the infinipath receive buffer
when we shut down a chip port. Normally this is taken care of by orderly
shutdown, but when processes are terminated, or sending process has a bug, we
can continue to receive packets. So rather than writing zero to the address
registers for the closing port, we point it at a dummy memory.
Cc: "Michael S. Tsirkin" <mst@mellanox.co.il>
Cc: Roland Dreier <rolandd@cisco.com>
We do a few more explicit checks for specific models, and now also support the
old PathScale serial number style, or new QLogic style.
This is backwards compatible with previous versions of software and hardware.
That is, older software will see a plausible serial number and correct GUID
when used with a new board, while newer software will correctly handle an
older board.
Signed-off-by: Mike Albaugh <mike.albaugh@qlogic.com>
This patch fixes some problems uncovered during IB compliance testing to
return the right values for error counters returned by the Performance Get
Counters packet.
Made in-memory rcvhdrq tail update be in dma_alloc'ed memory, not random user
or special kernel (needed for ppc, also "just the right thing to do").
Some cleanups to make unexpected link transitions less likely to produce
complaints about packet errors, and also to not leave SMA packets stuck and
unable to go out.
A few other random debug and comment cleanups.
Always init rcvhdrq head/tail registers to 0, to avoid race conditions (should
have been that way some time ago).
This is not a DMA target, so no need to use dma_alloc_coherent on it.
There is no longer a /dev/ipath_diag file; instead, there's
/dev/ipath_diag0, 1, etc.
It's still not possible to have diags run on more than one unit at a time,
but that's easy to fix at some point.
name
This is required for even semi-decent performance on OpenIB.
Signed-off-by: Bryan O'Sullivan <bos@pathscale.com>
