The ib_qib driver is taking over support for QLogic PCIe QLE devices,
so remove support for them from ib_ipath. The ib_ipath driver now
supports only the obsolete QLogic Hyper-Transport IB host channel
adapter (model QHT7140).
Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com>
Signed-off-by: Roland Dreier <rolandd@cisco.com>
Let attribute group vectors be declared "const". We'd
like to let most attribute metadata live in read-only
sections... this is a start.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Fixes timing race resulting in panic. Not a performance sensitive path.
Signed-off-by: Dave Olson <dave.olson@qlogic.com>
Implement the ignoring of ibsymbol errors and linkrecover errors while
the link is at less than INIT (long needed), to get accurate counts.
Particularly an issue when doing non-IBTA DDR negotiation with chips
from vendors that do not support IBTA mode negotiation. If the driver
is unloaded, and there is a delta, the adjusted counters are written
back to the chip, so they stay adjusted across driver reload.
Gabriel C <nix.or.die@googlemail.com> pointed out that when the x86
bitops are updated to operate on unsigned long, the code in
sdma_abort_task() will produce warnings:
drivers/infiniband/hw/ipath/ipath_sdma.c: In function 'sdma_abort_task':
drivers/infiniband/hw/ipath/ipath_sdma.c:267: warning: passing argument 2 of 'constant_test_bit' from incompatible pointer type
and so on, because it uses test_bit() to operation on a u64 value
(returned by ipath_read_kref64() for a hardware register).
Fix up these warnings by converting the test_bit() operations to &ing
with appropriate symbolic defines of the bits within the hardware
register. This has the benign side-effect of making the code more
self-documenting as well.
Andrew Morton <akpm@linux-foundation.org> pointed out that bitops
should take an unsigned long * arg. However, the ipath driver was
doing bitops on struct ipath_devdata.ipath_sdma_status, which is u64.
Change this member to unsigned long to avoid tons of warnings when x86
fixes the bitops to take unsigned long * instead of void *.
Also, change the IPATH_SDMA_RUNNING and IPATH_SDMA_SHUTDOWN bit
numbers to 30 and 31 (instead of 62 and 63) so that we're not setting
another booby trap for someone who tries to make ipath work on a
32-bit architecture.
The official reason is "with the presence of pid namespaces in the
kernel using pid_t-s inside one is no longer safe."
But the reason I fix this right now is the following:
About a month ago (when 2.6.25 was not yet released) there still was a
one last caller of a to-be-deprecated-soon function find_pid() - the
kill_proc() function, which in turn was only used by nfs callback
code.
During the last merge window, this last caller was finally eliminated
by some NFS patch(es) and I was about to finally kill this kill_proc()
and find_pid(), but found, that I was late and the kill_proc is now
called from the ipath driver since commit 58411d1c ("IB/ipath: Head of
Line blocking vs forward progress of user apps").
So here's a patch that fixes this code to use struct pid * and (!)
the kill_pid routine.
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
Now that we always use PIO for vl15 on 7220, we could get stuck forever
if we happened to run out of PIO buffers from the verbs code, because
the setup code wouldn't run; the interrupt was also ignored if SDMA was
supported. We also have to reduce the pio update threshold if we have
fewer kernel buffers than the existing threshold.
Clean up the initialization a bit to get ordering safer and more
sensible, and use the existing ipath_chg_kernavail call to do init,
rather than doing it separately.
Drop unnecessary clearing of pio buffer on pio parity error.
Drop incorrect updating of pioavailshadow when exitting freeze mode
(software state may not match chip state if buffer has been allocated
and not yet written).
If we couldn't get a kernel buffer for a while, make sure we are
in sync with hardware, mainly to handle the exitting freeze case.
This converts the main ib_device to use struct device instead of struct
class_device as class_device is going away.
Signed-off-by: Tony Jones <tonyj@suse.de>
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Cc: Roland Dreier <rolandd@cisco.com>
Cc: Sean Hefty <sean.hefty@intel.com>
Cc: Hal Rosenstock <hal.rosenstock@gmail.com>
This patch adds the initialization calls into the new 7220 HCA files,
changes the Makefile to compile and link the new files, and code to
handle send DMA.
The patch adds a number of minor changes to support newer HCAs:
- New send buffer control bits
- New error condition bits
- Locking and initialization changes
- More send buffers
This is part of a patch series to add support for a new HCA. This patch
adds new fields to the header files.
This patch makes chip reset more robust and reduces lock contention
between user and kernel TID register updates.
Newer HCAs support MSI interrupts and also INTx interrupts. Fix the
code so that INTx can be reliably enabled if MSI interrupts are not
working.
Newer HCAs have a threshold counter to reduce the number of DMAs the
chip makes to update the PIO buffer availability status bits. This
patch enables the feature.
Newer HCAs have a HW option to write a sequence number to each receive
queue entry and avoid a separate DMA of the tail register to memory.
This patch adds support for these changes.
This patch makes some white space changes and minor non-functional
changes to more closely match the code in OFED-1.3.
Add support for reading newer card's EEPROMs while continuing to support
older EEPROMs.
Also, add support for the temperature sensor if present.
Signed-off-by: Michael Albaugh <Michael.Albaugh@qlogic.com>
A fixed partitioning of send buffers is determined at driver load time
for user processes and kernel use. Since send buffers are a scarce
resource, it makes sense to allow the kernel to use the buffers if they
are not in use by a user process.
Also, eliminate code duplication for ipath_force_pio_avail_update().
The link can be put in LINKDOWN_DISABLE state either locally or via a
MAD. However, the link-recovery code will take it out of that state as
a side-effect of attempts to clear SerDes/XGXS issues.
We add a flag to indicate "link is down on purpose, leave it alone."
Signed-off-by: Michael Albaugh <michael.albaugh@qlogic.com>
Workaround a QLE7140 problem that in rare cases causes flow control
problems after link recovery by forcing a link retrain after recovery.
A module parameter is provided to control the behavior in case it causes
problems.
This patch adds code to get/set portinfo to support multiple link speeds
and widths.
There's a conflict between our need to quiesce PSM-based applications
to avoid HoL blocking when the IB link goes down and the apps' desire
to remain running so that their quiescence timout mechanism can keep
running.
The compromise is to STOP the processes for a fixed period of time and
then alternate between CONT and STOP until the link is again active.
If there are poor interactions with subnet manager configuration at a
given site, the interval can be adjusted via a module paramter.
Signed-off-by: John Gregor <john.gregor@qlogic.com>
Enable use of 4KB MTU. Since the driver uses more pinned memory for
receive buffers when the 4KB MTU is enabled, whether or not the fabric
supports that MTU, add a "mtu4096" module parameter that can be used to
limit the MTU to 2KB when it is known that 4KB MTUs can't be used
anyway.
Modern I/O buses like PCIe and HT can be configured for multiple speeds
and widths. When an ipath HCA seems to have lower than expected
performance, it is very useful to be able to display what the driver
thinks the bus speed is.
There's no reason for the third parameter of ipath_count_units() to be
a u32 *, so change it to be an int * instead. This fixes the sparse
warning:
drivers/infiniband/hw/ipath/ipath_file_ops.c:1654:47: warning: incorrect type in argument 3 (different signedness)
drivers/infiniband/hw/ipath/ipath_file_ops.c:1654:47: expected unsigned int [usertype] *maxportsp
drivers/infiniband/hw/ipath/ipath_file_ops.c:1654:47: got int *<noident>
Signed-off-by: Arthur Jones <arthur.jones@qlogic.com>
Subnet manager SetPortinfo messages distingush between changing the link
state (DOWN, ARM, ACTIVE) and the link physical state (POLL, SLEEP,
DISABLED). These are somewhat independent commands and affect when link
width and speed changes take effect. Without this patch, a link DOWN
physical state NOP command was causing the link width and speed settings
to take effect which should only happen when the link physical state is
goes down (either by a SMP or some link physical error like link errors
exceeding the threshold).
The IBA7220 uses a count-based triggering mechanism, and therefore
can't use the same bandwidth verification mechanism as older chips.
To support the 7220, allow enabling and disabling armlaunch errors on
application request. Minor robustness improvements as well.
Clean up some unused header fields, minor related cleanup.
IBA7220 includes many more configurable IB settings. Getting/setting
these is now grouped into a pair of chip specific functions accessed via
function pointers. Provide sysfs access to these settings.
This adds the new (sometimes empty) chip-specific functions to the older
chips, and makes the initialization and related functions consistent across
all 3 chips.
This code has been unused for some time, but still had leftovers
from when it was used.
Different chips have different width interrupt status registers, so add
a flag and accessor function to decide which width register read to use.
The 6110 had a bug that caused some registers to be swapped; it was
fixed for the 7220 (and didn't affect the 6120 because it had fewer
registers). This adds a flag and related code to handle that, and
includes some minor cleanups in the same area.
The number of configured ports for the 7220 changes the number of eager
TIDs available per port, for all but port 0 (kernel port) which remains
constant, so add a field to give port0 count separate from the portdata
structure.
User registers have different alignments on different chips (4KB on
older, 64KB on 7220). Allow mapping the user registers on kernels with
page sizes up to 64K.
Various hardware counters are exported via the ipath file system (since
it is binary data). The old file format was very dependent on the HW
offsets for these registers. Newer HCA chips can have different
counters at different offsets. This patch adds a level of indirection
to make the file format consistent across HCAs.
Add support for QLogic HCAs which have hardware performance sampling
registers for PortSamplesControl and PortSamplesResult MADs.
This patch moves some arrays that were defined per-device to be
variables defined in the per context data structure, thus avoiding extra
kzalloc() calls.
In preparation for upcoming chips that have different values for
INFINIPATH_R_PORTENABLE_SHIFT, INFINIPATH_R_INTRAVAIL_SHIFT,
INFINIPATH_R_TAILUPD_SHIFT, and portcfg_shift, remove the shared
#defines and use device-specific variables instead.
kreceive is now portdata * instead of devdata * and other kreceive
related cleanups....
Code review pointed out that the locking around uses of ipath_sendctrl
and kr_sendctrl were, in several places, incorrect and/or inconsistent.
At one point in time there was code to allow a user process to
wait for a send buffer if none were available. This feature was
never used and most of the code was removed. This removes
some missed unused code.
Signed-off-by: Matthias Kaehlcke <matthias.kaehlcke@gmail.com>
Acked-by: Michael Albaugh <Michael.Albaugh@qlogic.com>
Tested-by: Arthur Jones <arthur.jones@qlogic.com>
Make the ipath driver use the new driver functions so that it does not
touch the sysfs portion of the driver structure.
We also remove the redundant symlink from the device back to the driver,
as it is already in the sysfs tree. Any userspace tools should be using
the standard symlink, not some driver specific one.
Cc: Roland Dreier <rdreier@cisco.com>
Cc: Bryan O'Sullivan <bryan.osullivan@qlogic.com>
Cc: Arthur Jones <arthur.jones@qlogic.com>
Cc: Cornelia Huck <cornelia.huck@de.ibm.com>
The link state event calls were being generated when the SM told the SMA
to change link states. This works for IB_EVENT_PORT_ACTIVE but not if
the link goes down and stays down. The fix is to generate event calls
from the interrupt handler when the HW link state changes.
ipath_poll() suffered from a couple subtle bugs. Under the right
conditions we could leave recv interrupts enabled on an ipath user
context on close, thereby taking potentially unwanted interrupts on the
next open -- this is fixed by unconditionally turning off recv
interrupts on close. Also, we now use counters rather than set/clear
bits which allows us to make sure we catch all interrupts at the cost of
changing the semantics slightly (it's now give me all events since the
last time I called poll() rather than give me all events since I called
_this_ poll routine). We also added some memory barriers which may help
ensure we get all notifications in a timely manner.
Different processors have different ordering restrictions for write
combining. By taking advantage of this, we can eliminate some write
barriers when writing to the send buffers.
On some system hardware, we are seeing moderately common cases of the
chip errormask register being overwritten due to a chip bug in iba6120
that is triggered by a vendor-specific PCIe broadcast message. This
patch merely checks periodically, and corrects it if needed (the
overwrite can cause us to not get error and hardware error
interrupts). Also, make dd->ipath_errormask the one, true canonical
source for kr_errormask, and remove references to ipath_ignorederrs as
it is currently unused.
