The IB spe. for SubnGet(NodeInfo) and query HCA says that the vendor
ID field should be the IEEE OUI assigned to the vendor. The ipath
driver was returning the PCI vendor ID instead. This will affect
applications which call ibv_query_device(). The old value was
0x001fc1 or 0x001077, the new value is 0x001175.
The vendor ID doesn't appear to be exported via /sys so that should
reduce possible compatibility issues. I'm only aware of Open MPI as a
major application which depends on this change, and they have made
necessary adjustments.
Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com>
Signed-off-by: Roland Dreier <rolandd@cisco.com>
SM/SMA traps received by the ipath driver should be forwarded to the
SM if it is running on the host. The ib_ipath driver was incorrectly
replying with "bad method."
Raw comparison against jiffies will fail if jiffies wraps, although
since ipath currently only supports 64-bit architectures, this is rather
far-fetched. Still, it's better to use time_after_eq().
The link can be put in LINKDOWN_DISABLE state either locally or via a
MAD. However, the link-recovery code will take it out of that state as
a side-effect of attempts to clear SerDes/XGXS issues.
We add a flag to indicate "link is down on purpose, leave it alone."
Signed-off-by: Michael Albaugh <michael.albaugh@qlogic.com>
This patch adds code to get/set portinfo to support multiple link speeds
and widths.
Enable use of 4KB MTU. Since the driver uses more pinned memory for
receive buffers when the 4KB MTU is enabled, whether or not the fabric
supports that MTU, add a "mtu4096" module parameter that can be used to
limit the MTU to 2KB when it is known that 4KB MTUs can't be used
anyway.
Signed-off-by: Dave Olson <dave.olson@qlogic.com>
Subnet manager SetPortinfo messages distingush between changing the link
state (DOWN, ARM, ACTIVE) and the link physical state (POLL, SLEEP,
DISABLED). These are somewhat independent commands and affect when link
width and speed changes take effect. Without this patch, a link DOWN
physical state NOP command was causing the link width and speed settings
to take effect which should only happen when the link physical state is
goes down (either by a SMP or some link physical error like link errors
exceeding the threshold).
Add support for QLogic HCAs which have hardware performance sampling
registers for PortSamplesControl and PortSamplesResult MADs.
This patch is in response to reviewing a patch to the core MAD
processing which fixes loopback of directed route packets to/from user
level MAD agents. This change enables the core code to work for
ib_ipath by fixing the return code from the ipath process_mad method.
This patch removes some redundant checks when the SMA changes the link
state since the same checks are made in the lower level function that
sets the state.
The link state event calls were being generated when the SM told the SMA
to change link states. This works for IB_EVENT_PORT_ACTIVE but not if
the link goes down and stays down. The fix is to generate event calls
from the interrupt handler when the HW link state changes.
The LMC value was being saved by the SMA in two places. This patch
cleans it up so only one copy is kept.
Return the PortGUID of the correct port when responding to a NodeInfo
query. Returning the SystemImageGUID causes issues when there are
multiple HCAs in a single system.
Signed-off-by: Sean Hefty <sean.hefty@intel.com>
Now that it's June, it's about time to update
the copyright notices of files that have changed.
Signed-off-by: John Gregor <john.gregor@qlogic.com>
Although our chip supports 4K MTUs, our driver doesn't yet support
this feature, so limit the maximum MTU to 2K until we get support for
4K MTUs implemented.
Signed-off-by: Robert Walsh <robert.walsh@qlogic.com>
Respond with an error to the SM if our GUID is 0, and don't allow the
user to set our GUID to 0.
Signed-off-by: Bryan O'Sullivan <bryan.osullivan@qlogic.com>
A lot of ipath layer code was only called in one place. Now that the
ipath_core and ib_ipath drivers are merged, it's more sensible to simply
inline the simple stuff that the layer code was doing.
Remove ips namespace from infinipath drivers. This renames ips_common.h to
ipath_common.h. Definitions, data structures, etc. that were not used by
kernel modules have moved to user-only headers. All names including ips have
been renamed to ipath. Some names have had an ipath prefix added.
Signed-off-by: Christian Bell <christian.bell@qlogic.com>
Cc: "Michael S. Tsirkin" <mst@mellanox.co.il>
Cc: Roland Dreier <rolandd@cisco.com>
The two arrays only had space for 4 units.
Also changed from ipath_set_sps_lid() to ipath_set_lid(); the sps was
leftover.
This patch fixes some problems uncovered during IB compliance testing to
return the right values for error counters returned by the Performance Get
Counters packet.
name
Generate a client reregister event instead of a LID change event when
client reregister bit is set.
Move ipath's struct port_info into <rdma/ib_smi.h>, so that it can be
used by mthca to implement client reregister support.
Remove the __attribute__((packed)) because all the members of the struct
are naturally aligned anyway.
Signed-off-by: Leonid Arsh <leonida@voltaire.com>
Management datagram support, queue pairs, and reliable and unreliable
connections.
Signed-off-by: Bryan O'Sullivan <bos@pathscale.com>
