It is now time for the ipath driver to begin to be phased out of the kernel.
This patch moves the ipath driver from the Infiniband sub tree to the staging
area where it will remain until the code is removed from the kernel in a few
releases.
Reviewed-by: Mike Marciniszyn <mike.marciniszyn@intel.com>
Signed-off-by: Dennis Dalessandro <dennis.dalessandro@intel.com>
Signed-off-by: Doug Ledford <dledford@redhat.com>
This patch add the support for Ethernet L2 attributes in the
verbs/cm/cma structures.
When dealing with L2 Ethernet, we should use smac, dmac, vlan ID and priority
in a similar manner that the IB L2 (and the L4 PKEY) attributes are used.
Thus, those attributes were added to the following structures:
* ib_ah_attr - added dmac
* ib_qp_attr - added smac and vlan_id, (sl remains vlan priority)
* ib_wc - added smac, vlan_id
* ib_sa_path_rec - added smac, dmac, vlan_id
* cm_av - added smac and vlan_id
For the path record structure, extra care was taken to avoid the new
fields when packing it into wire format, so we don't break the IB CM
and SA wire protocol.
On the active side, the CM fills. its internal structures from the
path provided by the ULP. We add there taking the ETH L2 attributes
and placing them into the CM Address Handle (struct cm_av).
On the passive side, the CM fills its internal structures from the WC
associated with the REQ message. We add there taking the ETH L2
attributes from the WC.
When the HW driver provides the required ETH L2 attributes in the WC,
they set the IB_WC_WITH_SMAC and IB_WC_WITH_VLAN flags. The IB core
code checks for the presence of these flags, and in their absence does
address resolution from the ib_init_ah_from_wc() helper function.
ib_modify_qp_is_ok is also updated to consider the link layer. Some
parameters are mandatory for Ethernet link layer, while they are
irrelevant for IB. Vendor drivers are modified to support the new
function signature.
Signed-off-by: Matan Barak <matanb@mellanox.com>
Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com>
Signed-off-by: Roland Dreier <roland@purestorage.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
After m68k's task_thread_info() doesn't refer to current,
it's possible to remove sched.h from interrupt.h and not break m68k!
Many thanks to Heiko Carstens for allowing this.
Receive work queue entries are checked for L_Key validity, and
pointers to the memory region structure are saved in an allocated
structure. For UD loopback packets, this structure is allocated and
freed for each packet. This patch changes that to allocate/free
during QP creation and destruction.
Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com>
Signed-off-by: Roland Dreier <rolandd@cisco.com>
The send DMA hardware queue voided a number of prior assumptions about
when a send is complete which led to completions being generated out of
order. There were also a number of locking issues when switching the QP
to the error or reset states, and we implement the IB_QPS_SQD state.
When errors are detected in RC, the QP should transition to the
IB_QPS_ERR state, not the IB_QPS_SQE state. Also, when the error is on
the responder side, the receive work completion error was incorrect
(remote vs. local).
This patch adds the initialization calls into the new 7220 HCA files,
changes the Makefile to compile and link the new files, and code to
handle send DMA.
Signed-off-by: Dave Olson <dave.olson@qlogic.com>
Add a create_flags member to struct ib_qp_init_attr that will allow a
kernel verbs consumer to create a pass special flags when creating a QP.
Add a flag value for telling low-level drivers that a QP will be used
for IPoIB UD LSO. The create_flags member will also be useful for XRC
and ehca low-latency QP support.
Since no create_flags handling is implemented yet, add code to all
low-level drivers to return -EINVAL if create_flags is non-zero.
Signed-off-by: Eli Cohen <eli@mellanox.co.il>
The receive queue number of WRs and SGEs shouldn't be checked if a
SRQ is specified.
Remove useless comment about list removal since locks are held and
the code checks that the QP is on the list before removing it.
Enable use of 4KB MTU. Since the driver uses more pinned memory for
receive buffers when the 4KB MTU is enabled, whether or not the fabric
supports that MTU, add a "mtu4096" module parameter that can be used to
limit the MTU to 2KB when it is known that 4KB MTUs can't be used
anyway.
A work completion entry could be placed on the wrong completion
queue when an RC QP is placed in the error state.
Signed-off-by: Patrick Marchand Latifi <patrick.latifi@qlogic.com>
Acked-by: Ralph Campbell <ralph.campbell@qlogic.com>
This patch fixes the initialization of RC QPs, since we would rely on
the queue pair type (ibqp->qp_type) being set, but this field is only
initialized when we return from ipath_create_qp (it is initialized by
the user-level verbs library).
The fix is to not depend on this field to initialize the send and
the receive state of the RC QP.
There can be a case where the requester's rnr retry counter
(s_rnr_retry) is less than the number of rnr retries allowed per QP
(s_rnr_retry_cnt). This can happen if the s_rnr_retry counter is being
decremented and an ipath_query_qp call is issued during that time frame.
The fix is to always return the number of rnr retries allowed per QP
instead of the requester's rnr counter.
Found by code review.
There are a few places in the ipath driver where a variable is
re-declared within a block where it is already in scope. Most of these
extra declarations can simply be removed, since the variable from the
outer scope is used in a way so that it does not need to keep its
variable across the block with the re-declaration.
Add the work completion error code to the QP error debug output.
This makes it easier to determine the cause of the error.
This patch fixes the code which frees the partially allocated QP
resources if there was an error while creating the QP. In particular,
the QPN wasn't deallocated and the QP wasn't removed from the hash
table.
This patch implements the IB_EVENT_QP_LAST_WQE_REACHED event which is
needed by ib_ipoib to destroy the QP when used in connected mode.
The code to post UD sends tried to process work requests at the time
ib_post_send() is called without using a WQE queue. This was fine as
long as HW resources were available for sending a packet. This patch
changes UD to be handled more like RC and UC and shares more code.
The changeset 3859e39d ("IB/ipath: Support larger IB_QP_MAX_DEST_RD_ATOMIC
and IB_QP_MAX_QP_RD_ATOMIC") added support for larger RD_ATOMIC values,
but it failed to take out the stricter checks that were before these and
hence had no effect. This patch takes out the bogus checks....
Signed-off-by: Arthur Jones <arthur.jones@qlogic.com>
Now that it's June, it's about time to update
the copyright notices of files that have changed.
Signed-off-by: John Gregor <john.gregor@qlogic.com>
Signed-off-by: Robert Walsh <robert.walsh@qlogic.com>
Although our chip supports 4K MTUs, our driver doesn't yet support
this feature, so limit the maximum MTU to 2K until we get support for
4K MTUs implemented.
Fix the pending mmap code so it doesn't corrupt the list of pending
mmaps and crash the machine when pending mmaps are destroyed without
first being mapped. Also, remove an unused variable, and use standard
kernel lists instead of our own homebrewed linked list implementation
to keep the pending mmap list.
Signed-off-by: Bryan O'Sullivan <bryan.osullivan@qlogic.com>
If a receive work request has been removed from the queue but has not
had a CQ entry generated for it and the QP is modified to the error
state, the completion entry generated is incorrect. This patch fixes
the problem.
When switching to the QP error state, the completion queue entries
(error or flush) were not being generated correctly.
ipath_dbg doesn't need the same prefixes that printk does.
This patch adds support for multiple RDMA reads and atomics to be sent
before an ACK is required to be seen by the requester.
struct ib_wc currently only includes the local QP number: this matches
the IB spec, but seems mostly useless. The following patch replaces
this with the pointer to qp itself, and updates all low level drivers
and all users.
This has the following advantages:
- Ability to get a per-qp context through wc->qp->qp_context
- Existing drivers already have the qp pointer ready in poll cq, so
this change actually saves a tiny bit (extra memory read) on data path
(for ehca it would actually be expensive to find the QP pointer when
polling a CQ, but ehca does not support SRQ so we can leave wc->qp as
NULL for ehca)
- Users that need the QP number can still get it through wc->qp->qp_num
Use case:
In IPoIB connected mode code, I have a common CQ shared by multiple
QPs. To track connection usage, I need a way to get at some per-QP
context upon the completion, and I would like to avoid allocating
context object per work request just to stick a QP pointer into it.
With this code, I can just use wc->qp->qp_context.
Signed-off-by: Michael S. Tsirkin <mst@mellanox.co.il>
If the receiver goes into the error state, we need to flush the
posted receive WQEs.
The sender requests an ACK every 1/2 MB to avoid retransmit timeouts that
were causing MVAPICH mod_bw to fail after a predictable number of sends.
When we first submitted a userspace subnet management agent, it was
rejected, so we left it out of the final driver submission. This patch
removes a number of vestigial references to it.
A lot of ipath layer code was only called in one place. Now that the
ipath_core and ib_ipath drivers are merged, it's more sensible to simply
inline the simple stuff that the layer code was doing.
Improve performance of userspace post receive, post SRQ receive, and
poll CQ operations for ipath by allowing userspace to directly mmap()
receive queues and completion queues. This eliminates the copying
between userspace and the kernel in the data path.
Pass a struct ib_udata to the low-level driver's ->modify_srq() and
->modify_qp() methods, so that it can get to the device-specific data
passed in by the userspace driver.
Remove ips namespace from infinipath drivers. This renames ips_common.h to
ipath_common.h. Definitions, data structures, etc. that were not used by
kernel modules have moved to user-only headers. All names including ips have
been renamed to ipath. Some names have had an ipath prefix added.
Signed-off-by: Christian Bell <christian.bell@qlogic.com>
Cc: "Michael S. Tsirkin" <mst@mellanox.co.il>
Cc: Roland Dreier <rolandd@cisco.com>
The receive work queue size should be ignored if the QP is created to use a
shared receive queue according to the IB spec.
This patch separates QP state used for sending and receiving RC packets so the
processing in the receive interrupt handler can be done mostly without locks
being held. ACK packets are now sent without requiring synchronization with
the send tasklet.
These limits are somewhat artificial in that we don't actually have any
device limits. However, the verbs layer expects that such limits exist
and are enforced, so we make up arbitrary (but sensible) limits.
