path: root/drivers/infiniband/hw/ipath/ipath_sdma.c
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-01-17IB: Remove __constant_{endian} usesHarvey Harrison
The base versions handle constant folding just fine, use them directly. The replacements are OK in the include/ files as they are not exported to userspace so we don't need the __ prefixed versions. This patch does not affect code generation at all. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-12-05IB/ipath: Check return value of dma_map_single()Ralph Campbell
This fixes an obvious oversight where the return value is not checked for error. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-07-26dma-mapping: add the device argument to dma_mapping_error()FUJITA Tomonori
Add per-device dma_mapping_ops support for CONFIG_X86_64 as POWER architecture does: This enables us to cleanly fix the Calgary IOMMU issue that some devices are not behind the IOMMU (http://lkml.org/lkml/2008/5/8/423). I think that per-device dma_mapping_ops support would be also helpful for KVM people to support PCI passthrough but Andi thinks that this makes it difficult to support the PCI passthrough (see the above thread). So I CC'ed this to KVM camp. Comments are appreciated. A pointer to dma_mapping_ops to struct dev_archdata is added. If the pointer is non NULL, DMA operations in asm/dma-mapping.h use it. If it's NULL, the system-wide dma_ops pointer is used as before. If it's useful for KVM people, I plan to implement a mechanism to register a hook called when a new pci (or dma capable) device is created (it works with hot plugging). It enables IOMMUs to set up an appropriate dma_mapping_ops per device. The major obstacle is that dma_mapping_error doesn't take a pointer to the device unlike other DMA operations. So x86 can't have dma_mapping_ops per device. Note all the POWER IOMMUs use the same dma_mapping_error function so this is not a problem for POWER but x86 IOMMUs use different dma_mapping_error functions. The first patch adds the device argument to dma_mapping_error. The patch is trivial but large since it touches lots of drivers and dma-mapping.h in all the architecture. This patch: dma_mapping_error() doesn't take a pointer to the device unlike other DMA operations. So we can't have dma_mapping_ops per device. Note that POWER already has dma_mapping_ops per device but all the POWER IOMMUs use the same dma_mapping_error function. x86 IOMMUs use device argument. [akpm@linux-foundation.org: fix sge] [akpm@linux-foundation.org: fix svc_rdma] [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: fix bnx2x] [akpm@linux-foundation.org: fix s2io] [akpm@linux-foundation.org: fix pasemi_mac] [akpm@linux-foundation.org: fix sdhci] [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: fix sparc] [akpm@linux-foundation.org: fix ibmvscsi] Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Muli Ben-Yehuda <muli@il.ibm.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Avi Kivity <avi@qumranet.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-26IB/ipath: Avoid test_bit() on u64 SDMA status valueRoland Dreier
Gabriel C <nix.or.die@googlemail.com> pointed out that when the x86 bitops are updated to operate on unsigned long, the code in sdma_abort_task() will produce warnings: drivers/infiniband/hw/ipath/ipath_sdma.c: In function 'sdma_abort_task': drivers/infiniband/hw/ipath/ipath_sdma.c:267: warning: passing argument 2 of 'constant_test_bit' from incompatible pointer type and so on, because it uses test_bit() to operation on a u64 value (returned by ipath_read_kref64() for a hardware register). Fix up these warnings by converting the test_bit() operations to &ing with appropriate symbolic defines of the bits within the hardware register. This has the benign side-effect of making the code more self-documenting as well. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-05-15IB/ipath: Fix printk format for ipath_sdma_statusRoland Dreier
Commit f018c7e1 ("IB/ipath: Change ipath_devdata.ipath_sdma_status to be unsigned long") changed ipath_sdma_status to be unsigned long, but left a few debug messages that printed it out with a %016llx format, which generates the warnings drivers/infiniband/hw/ipath/ipath_sdma.c:348: warning: format '%016llx' expects type 'long long unsigned int', but argument 3 has type 'long unsigned int' drivers/infiniband/hw/ipath/ipath_sdma.c:618: warning: format '%016llx' expects type 'long long unsigned int', but argument 3 has type 'long unsigned int' Fix this by changing the format used to print out the value to %08lx (8 hex digits are now sufficient, because the highest bit used is 31). Warnings reported by Randy Dunlap <randy.dunlap@oracle.com>. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-05-07IB/ipath: Fix SDMA error recovery in absence of link status changeJohn Gregor
What's fixed: in ipath_cancel_sends() We need to unconditionally set ABORTING. So, swap the tests so the set_bit() isn't shadowed by the &&. If we've disarmed the piobufs, then we need to unconditionally set DISARMED. So, move it out from the overly protective if at the bottom. in sdma_abort_task() Abort_task was written knowing that the SDMA engine would always be reset (and restarted) on error. A recent change broke that fundamental assumption by taking the restart portion and making it conditional on a link status change. But, SDMA can go boom without a link status change in some conditions. Signed-off-by: John Gregor <john.gregor@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-05-07IB/ipath: Need to always request and handle PIO avail interruptsDave Olson
Now that we always use PIO for vl15 on 7220, we could get stuck forever if we happened to run out of PIO buffers from the verbs code, because the setup code wouldn't run; the interrupt was also ignored if SDMA was supported. We also have to reduce the pio update threshold if we have fewer kernel buffers than the existing threshold. Clean up the initialization a bit to get ordering safer and more sensible, and use the existing ipath_chg_kernavail call to do init, rather than doing it separately. Drop unnecessary clearing of pio buffer on pio parity error. Drop incorrect updating of pioavailshadow when exitting freeze mode (software state may not match chip state if buffer has been allocated and not yet written). If we couldn't get a kernel buffer for a while, make sure we are in sync with hardware, mainly to handle the exitting freeze case. Signed-off-by: Dave Olson <dave.olson@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-04-16IB/ipath: add calls to new 7220 code and enable in buildDave Olson
This patch adds the initialization calls into the new 7220 HCA files, changes the Makefile to compile and link the new files, and code to handle send DMA. Signed-off-by: Dave Olson <dave.olson@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-04-16IB/ipath: Add code for IBA7220 send DMAJohn Gregor
The IBA7220 HCA has a new feature to DMA data to the on chip send buffers instead of or in addition to the host CPU doing the data transfer. This patch adds code to support the send DMA queue. Signed-off-by: John Gregor <john.gregor@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
