path: root/drivers/infiniband/hw/ipath/ipath_ud.c
2009-10-11headers: remove sched.h from interrupt.hAlexey Dobriyan
After m68k's task_thread_info() doesn't refer to current, it's possible to remove sched.h from interrupt.h and not break m68k! Many thanks to Heiko Carstens for allowing this. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2009-01-17IB: Remove __constant_{endian} usesHarvey Harrison
The base versions handle constant folding just fine, use them directly. The replacements are OK in the include/ files as they are not exported to userspace so we don't need the __ prefixed versions. This patch does not affect code generation at all. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-12-01IB/ipath: Improve UD loopback performance by allocating temp array only onceRalph Campbell
Receive work queue entries are checked for L_Key validity, and pointers to the memory region structure are saved in an allocated structure. For UD loopback packets, this structure is allocated and freed for each packet. This patch changes that to allocate/free during QP creation and destruction. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-08-15IB/ipath: Fix lost UD send work requestRalph Campbell
If a UD QP has some work requests queued to be sent by the DMA engine followed by a local loopback work request, we have to wait for the previous work requests to finish or the completion for the local loopback work request would be generated out of order. The problem was that the work request queue pointer was already updated so that the request would not be processed when the DMA queue drained. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-07-14RDMA/core: Add memory management extensions supportSteve Wise
This patch adds support for the IB "base memory management extension" (BMME) and the equivalent iWARP operations (which the iWARP verbs mandates all devices must implement). The new operations are: - Allocate an ib_mr for use in fast register work requests. - Allocate/free a physical buffer lists for use in fast register work requests. This allows device drivers to allocate this memory as needed for use in posting send requests (eg via dma_alloc_coherent). - New send queue work requests: * send with remote invalidate * fast register memory region * local invalidate memory region * RDMA read with invalidate local memory region (iWARP only) Consumer interface details: - A new device capability flag IB_DEVICE_MEM_MGT_EXTENSIONS is added to indicate device support for these features. - New send work request opcodes IB_WR_FAST_REG_MR, IB_WR_LOCAL_INV, IB_WR_RDMA_READ_WITH_INV are added. - A new consumer API function, ib_alloc_mr() is added to allocate fast register memory regions. - New consumer API functions, ib_alloc_fast_reg_page_list() and ib_free_fast_reg_page_list() are added to allocate and free device-specific memory for fast registration page lists. - A new consumer API function, ib_update_fast_reg_key(), is added to allow the key portion of the R_Key and L_Key of a fast registration MR to be updated. Consumers call this if desired before posting a IB_WR_FAST_REG_MR work request. Consumers can use this as follows: - MR is allocated with ib_alloc_mr(). - Page list memory is allocated with ib_alloc_fast_reg_page_list(). - MR R_Key/L_Key "key" field is updated with ib_update_fast_reg_key(). - MR made VALID and bound to a specific page list via ib_post_send(IB_WR_FAST_REG_MR) - MR made INVALID via ib_post_send(IB_WR_LOCAL_INV), ib_post_send(IB_WR_RDMA_READ_WITH_INV) or an incoming send with invalidate operation. - MR is deallocated with ib_dereg_mr() - page lists dealloced via ib_free_fast_reg_page_list(). Applications can allocate a fast register MR once, and then can repeatedly bind the MR to different physical block lists (PBLs) via posting work requests to a send queue (SQ). For each outstanding MR-to-PBL binding in the SQ pipe, a fast_reg_page_list needs to be allocated (the fast_reg_page_list is owned by the low-level driver from the consumer posting a work request until the request completes). Thus pipelining can be achieved while still allowing device-specific page_list processing. The 32-bit fast register memory key/STag is composed of a 24-bit index and an 8-bit key. The application can change the key each time it fast registers thus allowing more control over the peer's use of the key/STag (ie it can effectively be changed each time the rkey is rebound to a page list). Signed-off-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-05-13IB/ipath: Fix many locking issues when switching to error stateRalph Campbell
The send DMA hardware queue voided a number of prior assumptions about when a send is complete which led to completions being generated out of order. There were also a number of locking issues when switching the QP to the error or reset states, and we implement the IB_QPS_SQD state. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-04-16IB/core: Add support for "send with invalidate" work requestsRoland Dreier
Add a new IB_WR_SEND_WITH_INV send opcode that can be used to mark a "send with invalidate" work request as defined in the iWARP verbs and the InfiniBand base memory management extensions. Also put "imm_data" and a new "invalidate_rkey" member in a new "ex" union in struct ib_send_wr. The invalidate_rkey member can be used to pass in an R_Key/STag to be invalidated. Add this new union to struct ib_uverbs_send_wr. Add code to copy the invalidate_rkey field in ib_uverbs_post_send(). Fix up low-level drivers to deal with the change to struct ib_send_wr, and just remove the imm_data initialization from net/sunrpc/xprtrdma/, since that code never does any send with immediate operations. Also, move the existing IB_DEVICE_SEND_W_INV flag to a new bit, since the iWARP drivers currently in the tree set the bit. The amso1100 driver at least will silently fail to honor the IB_SEND_INVALIDATE bit if passed in as part of userspace send requests (since it does not implement kernel bypass work request queueing). Remove the flag from all existing drivers that set it until we know which ones are OK. The values chosen for the new flag is not consecutive to avoid clashing with flags defined in the XRC patches, which are not merged yet but which are already in use and are likely to be merged soon. This resurrects a patch sent long ago by Mikkel Hagen <mhagen@iol.unh.edu>. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-04-16IB/ipath: Update copyright dates for files changed in 2008Ralph Campbell
2008-04-16IB/ipath: add calls to new 7220 code and enable in buildDave Olson
This patch adds the initialization calls into the new 7220 HCA files, changes the Makefile to compile and link the new files, and code to handle send DMA. Signed-off-by: Dave Olson <dave.olson@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-01-25IB/ipath: Trivial simplification of ipath_make_ud_req()Ralph Campbell
Move the increment of s_hdrwords into the existing if block that tests if we're doing a send with immediate, to save one test of the opcode. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-01-16IB/ipath: Fix receiving UD messages with immediate dataRalph Campbell
This fixes a small bug in ipath_ud_rcv()'s handling of UD messages with immediate data. We need to test whether immediate data is present and update the header size accordingly *before* testing the packet size from the header against the actual received length. Otherwise the wrong header size will be used and all messages with immediate data will be dropped. This bug keeps MVAPICH-UD and HP MPI from working at all on ipath devices. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-10-09IB/ipath: Remove duplicate copy of LMCRalph Campbell
The LMC value was being saved by the SMA in two places. This patch cleans it up so only one copy is kept. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-10-09IB/ipath: Change UD to queue work requests like RC & UCRalph Campbell
The code to post UD sends tried to process work requests at the time ib_post_send() is called without using a WQE queue. This was fine as long as HW resources were available for sending a packet. This patch changes UD to be handled more like RC and UC and shares more code. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-07-09IB/ipath: Add barrier before updating WC head in shared memoryRalph Campbell
Add a barrier to make sure the CPU doesn't reorder writes to memory, since user programs can be polling on the head index update and the entry should be written before that. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-07-09IB/ipath: Update copyright datesJohn Gregor
Now that it's June, it's about time to update the copyright notices of files that have changed. Signed-off-by: John Gregor <john.gregor@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-07-09IB/ipath: Fix possible data corruption if multiple SGEs used for receiveRalph Campbell
The code to copy data from the receive queue buffers to the IB SGEs doesn't check the SGE length, only the memory region/page length when copying data. This could overwrite parts of the user's memory that were not intended to be written. It can only happen if multiple SGEs are used to describe a receive buffer which almost never happens in practice. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-04-18IB/ipath: Check that a UD work request's address handle is validRobert Walsh
Signed-off-by: Bryan O'Sullivan <bryan.osullivan@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-04-18IB/ipath: Fix CQ flushing when QP is modified to error stateBryan O'Sullivan
If a receive work request has been removed from the queue but has not had a CQ entry generated for it and the QP is modified to the error state, the completion entry generated is incorrect. This patch fixes the problem. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Bryan O'Sullivan <bryan.osullivan@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-04-18IB/ipath: Support larger IB_QP_MAX_DEST_RD_ATOMIC and IB_QP_MAX_QP_RD_ATOMICRalph Campbell
This patch adds support for multiple RDMA reads and atomics to be sent before an ACK is required to be seen by the requester. Signed-off-by: Bryan O'Sullivan <bryan.osullivan@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-02-04IB: Return qp pointer as part of ib_wcMichael S. Tsirkin
struct ib_wc currently only includes the local QP number: this matches the IB spec, but seems mostly useless. The following patch replaces this with the pointer to qp itself, and updates all low level drivers and all users. This has the following advantages: - Ability to get a per-qp context through wc->qp->qp_context - Existing drivers already have the qp pointer ready in poll cq, so this change actually saves a tiny bit (extra memory read) on data path (for ehca it would actually be expensive to find the QP pointer when polling a CQ, but ehca does not support SRQ so we can leave wc->qp as NULL for ehca) - Users that need the QP number can still get it through wc->qp->qp_num Use case: In IPoIB connected mode code, I have a common CQ shared by multiple QPs. To track connection usage, I need a way to get at some per-QP context upon the completion, and I would like to avoid allocating context object per work request just to stick a QP pointer into it. With this code, I can just use wc->qp->qp_context. Signed-off-by: Michael S. Tsirkin <mst@mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-09-28IB/ipath: Ensure that PD of MR matches PD of QP checking the RkeyBryan O'Sullivan
2006-09-22IB/ipath: simplify layering codeBryan O'Sullivan
A lot of ipath layer code was only called in one place. Now that the ipath_core and ib_ipath drivers are merged, it's more sensible to simply inline the simple stuff that the layer code was doing. Signed-off-by: Bryan O'Sullivan <bryan.osullivan@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-09-22IB/ipath: Performance improvements via mmap of queuesRalph Campbell
Improve performance of userspace post receive, post SRQ receive, and poll CQ operations for ipath by allowing userspace to directly mmap() receive queues and completion queues. This eliminates the copying between userspace and the kernel in the data path. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-07-01[PATCH] IB/ipath: namespace cleanup: replace ips with ipathBryan O'Sullivan
Remove ips namespace from infinipath drivers. This renames ips_common.h to ipath_common.h. Definitions, data structures, etc. that were not used by kernel modules have moved to user-only headers. All names including ips have been renamed to ipath. Some names have had an ipath prefix added. Signed-off-by: Christian Bell <christian.bell@qlogic.com> Signed-off-by: Bryan O'Sullivan <bryan.osullivan@qlogic.com> Cc: "Michael S. Tsirkin" <mst@mellanox.co.il> Cc: Roland Dreier <rolandd@cisco.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-01[PATCH] IB/ipath: fixes to performance get counters for IB complianceBryan O'Sullivan
This patch fixes some problems uncovered during IB compliance testing to return the right values for error counters returned by the Performance Get Counters packet. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Bryan O'Sullivan <bryan.osullivan@qlogic.com> Cc: "Michael S. Tsirkin" <mst@mellanox.co.il> Cc: Roland Dreier <rolandd@cisco.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-01[PATCH] IB/ipath: disallow send of invalid packet sizes over UDBryan O'Sullivan
2006-07-01[PATCH] IB/ipath: update copyrights and other strings to reflect new company ↵Bryan O'Sullivan
name Signed-off-by: Bryan O'Sullivan <bryan.osullivan@qlogic.com> Cc: "Michael S. Tsirkin" <mst@mellanox.co.il> Cc: Roland Dreier <rolandd@cisco.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-01IB/ipath: tidy up white space in a few filesBryan O'Sullivan
Signed-off-by: Bryan O'Sullivan <bos@pathscale.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-04-19IB/ipath: Make more names staticRoland Dreier
Make symbols that are only used in a single source file static. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-03-31IB/ipath: infiniband UC and UD protocol supportBryan O'Sullivan
These files implement the Infiniband UC ("unreliable connection") and UD ("unreliable datagram") protocols. Signed-off-by: Bryan O'Sullivan <bos@pathscale.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
