path: root/drivers/infiniband/hw/ipath/ipath_verbs.c
2013-04-16IB/ipath: Correct ipath_verbs_register_sysfs() error handlingMike Marciniszyn
ipath_verbs_register_sysfs() never returned the correct error code from device_create_file and never cleaned up from a failure. Additionally, the caller of ipath_verbs_register_sysfs() doesn't return the correct "ret" value. This patch resolves all of these issues. Reported-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Reviewed-by: Dean Luick <dean.luick@intel.com> Signed-off-by: Mike Marciniszyn <mike.marciniszyn@intel.com> Signed-off-by: Roland Dreier <roland@purestorage.com>
2013-03-22IB/ipath: Silence a static checker warningDan Carpenter
I have a static checker which complains that 0x255 is too high for the "dev->opstats[opcode]" array. It turns out that the hardware has already validated the opcode at this point so it can't actually overflow. However, silencing the warning is good and this matches how the opcode is treated in qib_ib_rcv() as well. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Mike Marciniszyn <mike.marciniszyn@intel.com> Signed-off-by: Roland Dreier <roland@purestorage.com>
2011-10-31infiniband: Fix up module files that need to include module.hPaul Gortmaker
They had been getting it implicitly via device.h but we can't rely on that for the future, due to a pending cleanup so fix it now. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2010-05-21IB/core: Allow device-specific per-port sysfs filesRalph Campbell
Add a new parameter to ib_register_device() so that low-level device drivers can pass in a pointer to a callback function that will be called for each port that is registered in sysfs. This allows low-level device drivers to create files in /sys/class/infiniband/<hca>/ports/<N>/ without having to poke through the internals of the RDMA sysfs handling. There is no need for an unregister function since the kobject reference will go to zero when ib_unregister_device() is called. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-01-17IB: Remove __constant_{endian} usesHarvey Harrison
The base versions handle constant folding just fine, use them directly. The replacements are OK in the include/ files as they are not exported to userspace so we don't need the __ prefixed versions. This patch does not affect code generation at all. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-12-05IB/ipath: Add locking for interrupt use of ipath_pd contexts vs freeDave Olson
Fixes timing race resulting in panic. Not a performance sensitive path. Signed-off-by: Dave Olson <dave.olson@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-09-29IB/ipath: Fix hang on module unloadYannick Cote
Handle the case where posting a send is requested when the link is down. This fixes <https://bugs.openfabrics.org/show_bug.cgi?id=1117>. Signed-off-by: Yannick Cote <yannick.cote@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-07-30IB/ipath: Use unsigned long for irq flagsVegard Nossum
A few functions in the ipath driver incorrectly use unsigned int to hold irq flags for spin_lock_irqsave(). This patch was generated using the Coccinelle framework with the following semantic patch: The semantic patch I used was this: @@ expression lock; identifier flags; expression subclass; @@ - unsigned int flags; + unsigned long flags; ... <+... ( spin_lock_irqsave(lock, flags) | _spin_lock_irqsave(lock) | spin_unlock_irqrestore(lock, flags) | _spin_unlock_irqrestore(lock, flags) | read_lock_irqsave(lock, flags) | _read_lock_irqsave(lock) | read_unlock_irqrestore(lock, flags) | _read_unlock_irqrestore(lock, flags) | write_lock_irqsave(lock, flags) | _write_lock_irqsave(lock) | write_unlock_irqrestore(lock, flags) | _write_unlock_irqrestore(lock, flags) | spin_lock_irqsave_nested(lock, flags, subclass) | _spin_lock_irqsave_nested(lock, subclass) | spin_unlock_irqrestore(lock, flags) | _spin_unlock_irqrestore(lock, flags) | _raw_spin_lock_flags(lock, flags) | __raw_spin_lock_flags(lock, flags) ) ...+> Cc: Ralph Campbell <ralph.campbell@qlogic.com> Cc: Julia Lawall <julia@diku.dk> Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-07-15Merge branch 'core/rcu' into core/rcu-for-linusIngo Molnar
2008-07-14IB/ipath: Use IEEE OUI for vendor_id reported by ibv_query_device()Ralph Campbell
The IB spe. for SubnGet(NodeInfo) and query HCA says that the vendor ID field should be the IEEE OUI assigned to the vendor. The ipath driver was returning the PCI vendor ID instead. This will affect applications which call ibv_query_device(). The old value was 0x001fc1 or 0x001077, the new value is 0x001175. The vendor ID doesn't appear to be exported via /sys so that should reduce possible compatibility issues. I'm only aware of Open MPI as a major application which depends on this change, and they have made necessary adjustments. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-06-16Merge branch 'linus' into core/rcutip-core-rcu-2008-06-16_09.23_MonIngo Molnar
2008-05-26IB/ipath: Fix device capability flagsRalph Campbell
The driver supports a few features (RNR NAK, port active event, SRQ resize) that were not reported in the device capability flags. This patch fixes that. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-05-19rcu: split list.h and move rcu-protected lists into rculist.hFranck Bui-Huu
Move rcu-protected lists from list.h into a new header file rculist.h. This is done because list are a very used primitive structure all over the kernel and it's currently impossible to include other header files in this list.h without creating some circular dependencies. For example, list.h implements rcu-protected list and uses rcu_dereference() without including rcupdate.h. It actually compiles because users of rcu_dereference() are macros. Others RCU functions could be used too but aren't probably because of this. Therefore this patch creates rculist.h which includes rcupdates without to many changes/troubles. Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Josh Triplett <josh@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-13IB/ipath: Fix many locking issues when switching to error stateRalph Campbell
The send DMA hardware queue voided a number of prior assumptions about when a send is complete which led to completions being generated out of order. There were also a number of locking issues when switching the QP to the error or reset states, and we implement the IB_QPS_SQD state. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-05-13IB/ipath: Fix RC and UC error handlingRalph Campbell
When errors are detected in RC, the QP should transition to the IB_QPS_ERR state, not the IB_QPS_SQE state. Also, when the error is on the responder side, the receive work completion error was incorrect (remote vs. local). Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-05-07IB/ipath: Only increment SSN if WQE is put on send queueRalph Campbell
If a send work request has immediate errors and is not put on the send queue, we shouldn't update any of the QP state. The increment of the SSN wasn't obeying this. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-04-21IB/ipath: Remove reference to dev->class_dev ↵Roland Dreier
Commit 124b4dcb ("IB/ipath: add calls to new 7220 code and enable in build") inadvertently added core to set dev->class_dev.dev back into ib_ipath. This is completely redundant since commit 1912ffbb ("IB: Set class_dev->dev in core for nice device symlink"), which removed class_dev setting from low-level drivers, and also will break the build when class_dev is removed completely from struct ib_device. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-04-21IB/ipath: Fix module parameter description for disable_smaPaul Bolle
Describe disable_sma parameter with its name rather than the internal ib_ipath_disable_sma variable name, so that the description shows up properly in modinfo. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Acked-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-04-19IB: convert struct class_device to struct deviceTony Jones
This converts the main ib_device to use struct device instead of struct class_device as class_device is going away. Signed-off-by: Tony Jones <tonyj@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Cc: Roland Dreier <rolandd@cisco.com> Cc: Sean Hefty <sean.hefty@intel.com> Cc: Hal Rosenstock <hal.rosenstock@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-16IB/ipath: Update copyright dates for files changed in 2008Ralph Campbell
2008-04-16IB/ipath: add calls to new 7220 code and enable in buildDave Olson
This patch adds the initialization calls into the new 7220 HCA files, changes the Makefile to compile and link the new files, and code to handle send DMA. Signed-off-by: Dave Olson <dave.olson@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-04-16IB/ipath: Make send buffers available for kernel if not allocated to userRalph Campbell
A fixed partitioning of send buffers is determined at driver load time for user processes and kernel use. Since send buffers are a scarce resource, it makes sense to allow the kernel to use the buffers if they are not in use by a user process. Also, eliminate code duplication for ipath_force_pio_avail_update(). Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-04-16IB/ipath: Add code to support multiple link speeds and widthsRalph Campbell
This patch adds code to get/set portinfo to support multiple link speeds and widths. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-04-16IB/ipath: Enable 4KB MTUDave Olson
Enable use of 4KB MTU. Since the driver uses more pinned memory for receive buffers when the 4KB MTU is enabled, whether or not the fabric supports that MTU, add a "mtu4096" module parameter that can be used to limit the MTU to 2KB when it is known that 4KB MTUs can't be used anyway. Signed-off-by: Dave Olson <dave.olson@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-01-25IB/ipath: Add mappings from HW register to PortInfo port physical stateRalph Campbell
Add new mappings from port physical state (a HW register value) to the IB SubnGet(PortInfo) port physical state. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-01-25IB/ipath: Clean up some commentsDave Olson
2008-01-25IB/ipath: MAD performance sampling registers supportRalph Campbell
Add support for QLogic HCAs which have hardware performance sampling registers for PortSamplesControl and PortSamplesResult MADs. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-11-20IB/ipath: Normalize error return codes for posting work requestsRalph Campbell
The error codes for ib_post_send(), ib_post_recv(), and ib_post_srq_recv() were inconsistent. Use EINVAL for too many SGEs and ENOMEM for too many WRs. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-10-09IB/ipath: Fix IB_EVENT_PORT_ERR eventRalph Campbell
The link state event calls were being generated when the SM told the SMA to change link states. This works for IB_EVENT_PORT_ACTIVE but not if the link goes down and stays down. The fix is to generate event calls from the interrupt handler when the HW link state changes. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-10-09IB/ipath: Remove duplicate copy of LMCRalph Campbell
The LMC value was being saved by the SMA in two places. This patch cleans it up so only one copy is kept. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-10-09IB/ipath: Generate flush CQE when QP is in error stateRalph Campbell
Follow the IB spec. (C10-96) for post send which states that a flushed completion event should be generated for work requests posted when a QP is in the error state. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-10-09IB/ipath: Change UD to queue work requests like RC & UCRalph Campbell
The code to post UD sends tried to process work requests at the time ib_post_send() is called without using a WQE queue. This was fine as long as HW resources were available for sending a packet. This patch changes UD to be handled more like RC and UC and shares more code. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-10-09IB/ipath: Performance optimization for CPU differencesRalph Campbell
Different processors have different ordering restrictions for write combining. By taking advantage of this, we can eliminate some write barriers when writing to the send buffers. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-07-17IB/ipath: Make a few functions staticRoland Dreier
Make some functions that are only used in a single .c file static. In addition to being a cleanup, this shrinks the generated code. On x86_64: add/remove: 1/3 grow/shrink: 2/1 up/down: 4777/-4956 (-179) function old new delta handle_errors - 3994 +3994 __verbs_timer 42 710 +668 ipath_do_ruc_send 2131 2246 +115 ipath_no_bufs_available 136 - -136 ipath_disarm_senderrbufs 639 - -639 ipath_ib_timer 658 - -658 ipath_intr 5878 2355 -3523 Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-07-09IB/ipath: Remove support for preproduction HTX InfiniPath cardsRalph Campbell
Clean up some code by removing support for some older pre-production HTX InfiniPath cards. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com>
2007-07-09IB/ipath: Add barrier before updating WC head in shared memoryRalph Campbell
Add a barrier to make sure the CPU doesn't reorder writes to memory, since user programs can be polling on the head index update and the entry should be written before that. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-07-09IB/ipath: Update copyright datesJohn Gregor
Now that it's June, it's about time to update the copyright notices of files that have changed. Signed-off-by: John Gregor <john.gregor@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-07-09IB/ipath: Fix possible data corruption if multiple SGEs used for receiveRalph Campbell
The code to copy data from the receive queue buffers to the IB SGEs doesn't check the SGE length, only the memory region/page length when copying data. This could overwrite parts of the user's memory that were not intended to be written. It can only happen if multiple SGEs are used to describe a receive buffer which almost never happens in practice. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-07-09IB/ipath: Wait for PIO available interruptRalph Campbell
The send function is called when posting new send work requests. There is no point in trying to send a packet if the QP is already waiting for a HW send buffer so don't clear the busy bit until the buffer available interrupt happens. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-07-09IB/ipath: Fill in some missing FMR-related fields in query_deviceRobert Walsh
In ipath_query_device(), some of the struct ib_device_attr fields were not being initialized. Signed-off-by: Robert Walsh <robert.walsh@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-07-09IB/ipath: Fix maximum MTU reportingRobert Walsh
Although our chip supports 4K MTUs, our driver doesn't yet support this feature, so limit the maximum MTU to 2K until we get support for 4K MTUs implemented. Signed-off-by: Robert Walsh <robert.walsh@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-05-14IB/ipath: Shadow the gpio_mask registerArthur Jones
Once upon a time, GPIO interrupts were rare. But then a chip bug in the waldo series forced the use of a GPIO interrupt to signal packet reception. This greatly increased the frequency of GPIO interrupts which have the gpio_mask bits set on the waldo chips. Other bits in the gpio_status register are used for I2C clock and data lines, these bits are usually on. An "unlikely" annotation leftover from the old days was improperly applied to these bits, and an unnecessary chip mmio read was being accessed in the interrupt fast path on waldo. Remove the stagnant unlikely annotation in the interrupt handler and keep a shadow copy of the gpio_mask register to avoid the slow mmio read when testing for interruptable GPIO bits. Signed-off-by: Arthur Jones <arthur.jones@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-05-06IB: Add CQ comp_vector supportMichael S. Tsirkin
Add a num_comp_vectors member to struct ib_device and extend ib_create_cq() to pass in a comp_vector parameter -- this parallels the userspace libibverbs API. Update all hardware drivers to set num_comp_vectors to 1 and have all ULPs pass 0 for the comp_vector value. Pass the value of num_comp_vectors to userspace rather than hard-coding a value of 1. We want multiple CQ event vector support (via MSI-X or similar for adapters that can generate multiple interrupts), but it's not clear how many vectors we want, or how we want to deal with policy issues such as how to decide which vector to use or how to set up interrupt affinity. This patch is useful for experimenting, since no core changes will be necessary when updating a driver to support multiple vectors, and we know that we want to make at least these changes anyway. Signed-off-by: Michael S. Tsirkin <mst@dev.mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-04-30IB/ipath: Don't corrupt pending mmap list when unmapped objects are freedRobert Walsh
Fix the pending mmap code so it doesn't corrupt the list of pending mmaps and crash the machine when pending mmaps are destroyed without first being mapped. Also, remove an unused variable, and use standard kernel lists instead of our own homebrewed linked list implementation to keep the pending mmap list. Signed-off-by: Robert Walsh <robert.walsh@qlogic.com> Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-04-24IB: Set class_dev->dev in core for nice device symlinkJoachim Fenkes
All RDMA drivers except ehca set class_dev->dev to their dma_device value (ehca leaves this unset). dma_device is the only value that makes any sense, so move this assignment to core/sysfs.c. This reduce the duplicated code in the rest of the drivers and gives ehca a nice /sys/class/infiniband/ehcaX/device symlink. Signed-off-by: Joachim Fenkes <fenkes@de.ibm.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-04-18IB/ipath: Discard multicast packets without a GRHBryan O'Sullivan
This patch fixes a bug where multicast packets without a GRH were not being dropped as per the IB spec. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Bryan O'Sullivan <bryan.osullivan@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-04-18IB/ipath: Support larger IB_QP_MAX_DEST_RD_ATOMIC and IB_QP_MAX_QP_RD_ATOMICRalph Campbell
This patch adds support for multiple RDMA reads and atomics to be sent before an ACK is required to be seen by the requester. Signed-off-by: Bryan O'Sullivan <bryan.osullivan@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-12-12IB/ipath: Implement new verbs DMA mapping functionsRalph Campbell
This patch implements the interposing DMA mapping functions to allow support for IOMMUs and remove the dependence on phys_to_virt() and bus_to_virt(). Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-11-29IB/ipath: Fix typo in pma_counter_select subscriptRoland Dreier
The array has only 5 entries, so [5] should have been [4]. Signed-off-by: Roland Dreier <rolandd@cisco.com>
