path: root/drivers/infiniband/hw/nes/nes_hw.c
2013-07-30Revert "RDMA/nes: Fix compilation error when nes_debug is enabled"Roland Dreier
This reverts commit bca1935ccdec, which removes variables nes_tcp_state_str and nes_iwarp_state_str, assuming that they aren't defined. However, they are defined within a #ifdef NES_DEBUG statement, which if enabled causes "defined but not used" compiler warning, when the variables are removed. Signed-off-by: Tatyana Nikolova <Tatyana.E.Nikolova@intel.com> Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Roland Dreier <roland@purestorage.com>
2013-04-19net: vlan: add protocol argument to packet tagging functionsPatrick McHardy
Add a protocol argument to the VLAN packet tagging functions. In case of HW tagging, we need that protocol available in the ndo_start_xmit functions, so it is stored in a new field in the skb. The new field fits into a hole (on 64 bit) and doesn't increase the sks's size. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-12-08RDMA/nes: Fix for terminate timer crashTatyana Nikolova
The terminate timer needs to be initialized just once. Signed-off-by: Tatyana Nikolova <Tatyana.E.Nikolova@intel.com> Signed-off-by: Roland Dreier <roland@purestorage.com>
2012-10-02Merge tag 'rdma-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband Pull infiniband updates from Roland Dreier: "First batch of InfiniBand/RDMA changes for the 3.7 merge window: - mlx4 IB support for SR-IOV - A couple of SRP initiator fixes - Batch of nes hardware driver fixes - Fix for long-standing use-after-free crash in IPoIB - Other miscellaneous fixes" This merge also removes a new use of __cancel_delayed_work(), and replaces it with the regular cancel_delayed_work() that is now irq-safe thanks to the workqueue updates. That said, I suspect the sequence in question should probably use "mod_delayed_work()". I just did the minimal "don't use deprecated functions" fixup, though. * tag 'rdma-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (45 commits) IB/qib: Fix local access validation for user MRs mlx4_core: Disable SENSE_PORT for multifunction devices mlx4_core: Clean up enabling of SENSE_PORT for older (ConnectX-1/-2) HCAs mlx4_core: Stash PCI ID driver_data in mlx4_priv structure IB/srp: Avoid having aborted requests hang IB/srp: Fix use-after-free in srp_reset_req() IB/qib: Add a qib driver version RDMA/nes: Fix compilation error when nes_debug is enabled RDMA/nes: Print hardware resource type RDMA/nes: Fix for crash when TX checksum offload is off RDMA/nes: Cosmetic changes RDMA/nes: Fix for incorrect MSS when TSO is on RDMA/nes: Fix incorrect resolving of the loopback MAC address mlx4_core: Fix crash on uninitialized priv->cmd.slave_sem mlx4_core: Trivial cleanups to driver log messages mlx4_core: Trivial readability fix: "0X30" -> "0x30" IB/mlx4: Create paravirt contexts for VFs when master IB driver initializes mlx4: Modify proxy/tunnel QP mechanism so that guests do no calculations mlx4: Paravirtualize Node Guids for slaves mlx4: Activate SR-IOV mode for IB ...
2012-09-30RDMA/nes: Fix compilation error when nes_debug is enabledTatyana Nikolova
Removing old variables caused a compile error from nes_debug(). Signed-off-by: Tatyana Nikolova <Tatyana.E.Nikolova@intel.com> Signed-off-by: Roland Dreier <roland@purestorage.com>
2012-08-13workqueue: use mod_delayed_work() instead of cancel + queueTejun Heo
Convert delayed_work users doing cancel_delayed_work() followed by queue_delayed_work() to mod_delayed_work(). Most conversions are straight-forward. Ones worth mentioning are, * drivers/edac/edac_mc.c: edac_mc_workq_setup() converted to always use mod_delayed_work() and cancel loop in edac_mc_reset_delay_period() is dropped. * drivers/platform/x86/thinkpad_acpi.c: No need to remember whether watchdog is active or not. @fan_watchdog_active and related code dropped. * drivers/power/charger-manager.c: Seemingly a lot of delayed_work_pending() abuse going on here. [delayed_]work_pending() are unsynchronized and racy when used like this. I converted one instance in fullbatt_handler(). Please conver the rest so that it invokes workqueue APIs for the intended target state rather than trying to game work item pending state transitions. e.g. if timer should be modified - call mod_delayed_work(), canceled - call cancel_delayed_work[_sync](). * drivers/thermal/thermal_sys.c: thermal_zone_device_set_polling() simplified. Note that round_jiffies() calls in this function are meaningless. round_jiffies() work on absolute jiffies not delta delay used by delayed_work. v2: Tomi pointed out that __cancel_delayed_work() users can't be safely converted to mod_delayed_work(). They could be calling it from irq context and if that happens while delayed_work_timer_fn() is running, it could deadlock. __cancel_delayed_work() users are dropped. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Acked-by: Anton Vorontsov <cbouatmailru@gmail.com> Acked-by: David Howells <dhowells@redhat.com> Cc: Tomi Valkeinen <tomi.valkeinen@ti.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Doug Thompson <dougthompson@xmission.com> Cc: David Airlie <airlied@linux.ie> Cc: Roland Dreier <roland@kernel.org> Cc: "John W. Linville" <linville@tuxdriver.com> Cc: Zhang Rui <rui.zhang@intel.com> Cc: Len Brown <len.brown@intel.com> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Johannes Berg <johannes@sipsolutions.net>
2012-01-30RDMA/nes: Copyright updateTatyana Nikolova
Update copyright information in the source files. Signed-off-by: Tatyana Nikolova <Tatyana.E.Nikolova@intel.com> Signed-off-by: Faisal Latif <Faisal.Latif@intel.com> Signed-off-by: Roland Dreier <roland@purestorage.com>
2012-01-04RDMA/nes: Fix terminate during AETatyana Nikolova
Fix for reset which happens right after sending a terminate message. Terminate timer is not deleted when the connection is closed. Signed-off-by: Tatyana Nikolova <Tatyana.E.Nikolova@intel.com> Signed-off-by: Faisal Latif <Faisal.Latif@intel.com> Signed-off-by: Roland Dreier <roland@purestorage.com>
2012-01-04RDMA/nes: Change MDIO bus clock to 2.5MHzTatyana Nikolova
Change the PHY clock divisor to make the MDIO clock 2.5MHz, instead of 3.5MHz (which is out of spec). Signed-off-by: Tatyana Nikolova <Tatyana.E.Nikolova@intel.com> Signed-off-by: Faisal Latif <Faisal.Latif@intel.com> Signed-off-by: Roland Dreier <roland@purestorage.com>
2011-10-10RDMA/nes: Support for Packed And Unaligned fpdusFaisal Latif
Support for Packed and Unaligned (PAU) FPDUs is needed for interoperability between NES and non-NES nodes. When the NES hardware detects a PAU frame, it will pass it to the driver to process the frame. NES driver creates a new frame for each FPDU and forwards it to the hardware to be sent to its associated qp. Signed-off-by: Tatyana Nikolova <Tatyana.E.Nikolova@intel.com> Signed-off-by: Faisal Latif <Faisal.Latif@intel.com> Signed-off-by: Roland Dreier <roland@purestorage.com>
2011-10-10RDMA/nes: Print IP address for critcal errorsFaisal Latif
Print the IP address of the remote host when a critical asynchronous event is received. Signed-off-by: Tatyana Nikolova <Tatyana.E.Nikolova@intel.com> Signed-off-by: Faisal Latif <Faisal.Latif@intel.com> Signed-off-by: Roland Dreier <roland@purestorage.com>
2011-10-10RDMA/nes: Fix terminate connectionFaisal Latif
Fixes a crash that occurs during close when error async event is received. Terminate message is not sent to the remote node if already processing close. Signed-off-by: Tatyana Nikolova <Tatyana.E.Nikolova@intel.com> Signed-off-by: Faisal Latif <Faisal.Latif@intel.com> Signed-off-by: Roland Dreier <roland@purestorage.com>
2011-07-21nes: do vlan cleanupJiri Pirko
- unify vlan and nonvlan rx path - kill nesvnic->vlan_grp and nes_netdev_vlan_rx_register - allow to turn on/off rx/tx vlan accel via ethtool (set_features) Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-20net: infiniband/hw/nes: convert to hw_featuresMichał Mirosław
Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-03RDMA/nes: Don't generate async events for unregistered devicesMaciej Sosnowski
nes_port_ibevent() should not be called when the nes RDMA device is not registered with the RDMA core. Add missing checks of of_device_registered flag. Signed-off-by: Maciej Sosnowski <maciej.sosnowski@intel.com> Signed-off-by: Roland Dreier <roland@purestorage.com>
2011-01-16RDMA/nes: Fix SFP+ link down detection issue with switch port disableMaciej Sosnowski
In case of SFP+ PHY, link status check at interrupt processing can give false results. For proper link status change detection a delayed recheck is needed to give nes registers time to settle. Add a periodic link status recheck scheduled at interrupt to detect potential delayed registers state changes. Addresses: http://bugs.openfabrics.org/bugzilla/show_bug.cgi?id=2117 Signed-off-by: Maciej Sosnowski <maciej.sosnowski@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2011-01-16RDMA/nes: Generate IB_EVENT_PORT_ERR/PORT_ACTIVE eventsMaciej Sosnowski
Depending on link state change, IB_EVENT_PORT_ERR or IB_EVENT_PORT_ACTIVE should be generated when handling MAC interrupts. Plugging in a cable happens to result in series of interrupts changing driver's link state a number of times before finally staying at link up (e.g. link up, link down, link up, link down, ..., link up). To prevent sending series of redundant IB_EVENT_PORT_ACTIVE and IB_EVENT_PORT_ERR events, we use a timer to debounce them in nes_port_ibevent(). Signed-off-by: Maciej Sosnowski <maciej.sosnowski@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2010-09-08RDMA/nes: Fix hang with modified FIN handling on A0 cardsFaisal Latif
Changing state to CLOSING when FIN is received causes A0 cards to hang. Fix this by checking for A0 cards in FIN handling. Signed-off-by: Faisal Latif <faisal.latif@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2010-09-08RDMA/nes: Change state to closing after FINFaisal Latif
When the driver receives an AE for FIN received, it closes the connection without changing the state of the connection in the hardware to closing. By changing the state to closing, hardware will do a normal close sequence. Signed-off-by: Faisal Latif <faisal.latif@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2010-08-05RDMA/nes: Fix confusing if statement indentationRoland Dreier
Fix confusing indentation that makes a statement look as if it's part of an if statement when in fact it isn't. Reported-by: Julia Lawall <julia@diku.dk> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2010-08-04RDMA/nes: Get rid of "set but not used" variablesRoland Dreier
Delete dead code in various places that is shown by gcc 4.6's new -Wunused-but-set-variable warnings. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2010-07-28RDMA/nes: Fix hangs on ifdownFaisal Latif
When ib_unregister_device() is called from netdev stop during ifdown, it sometimes hangs. Changes made to indicate port_err to ib_dispatch_event() during netdev stop and port_active during netdev open. The ib_unregister_device() is only called during remove of the module. Signed-off-by: Faisal Latif <faisal.latif@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2010-07-14RDMA/nes: Rewrite expression to avoid undefined semanticsRoland Dreier
Change code like x = expr(++x) that assigns to x twice without a sequence point in between to the intended (and well-defined) x = expr(x + 1) Signed-off-by: Roland Dreier <rolandd@cisco.com>
2010-05-25RDMA/nes: Fix incorrect unlock in nes_process_mac_intr()Chien Tung
Commit ce6e74f2 ("RDMA/nes: Make nesadapter->phy_lock usage consistent") introduced a problem where phy_lock was only unlocked within an if statement and so nes_process_mac_intr() could return with phy_lock still held. Fix this. This was discovered because of the sparse warning: drivers/infiniband/hw/nes/nes_hw.c:2643:9: warning: context imbalance in 'nes_process_mac_intr' - different lock contexts for basic block Reported-by: Roland Dreier <rdreier@cisco.com> Signed-off-by: Chien Tung <chien.tin.tung@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2010-05-24RDMA/nes: Async event for closed QP causes crashFaisal Latif
Under abnormal termination, modify_qp() closes the QP, and async event (AE) handling also attempts to close the same QP, causing a crash. Fix this by checking the state of the QP before processing the AE. Signed-off-by: Faisal Latif <faisal.latif@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2010-04-21RDMA/nes: Make unnecessarily global functions staticRoland Dreier
This allows the compiler to do a bit better; on my x86-64 build: add/remove: 0/2 grow/shrink: 1/0 up/down: 2288/-2365 (-77) function old new delta nes_init_phy 273 2561 +2288 nes_init_1g_phy 469 - -469 nes_init_2025_phy 1896 - -1896 Signed-off-by: Roland Dreier <rolandd@cisco.com>
2010-04-21RDMA/nes: Make nesadapter->phy_lock usage consistentChien Tung
nes_{read,write}_1G_phy_reg() are using phy_lock while nes_{read,write}_10G_phy_reg() leave that to the caller. Remove phy_lock from 1G routines and leave the locking to the caller. Add additional phy_lock calls around 1G read/write. Signed-off-by: Chien Tung <chien.tin.tung@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-11RDMA/nes: Clear stall bit before destroying NIC QPChien Tung
Clear the stall bit to drop any incoming packets while destroying NIC QP. This will prevent a chip resource leak. Signed-off-by: Chien Tung <chien.tin.tung@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2010-02-25RDMA/nes: Add support for KR device id 0x0110Chien Tung
Add support for KR device id 0x0110. While at it, cleanup nes_init_phy() by splitting it into nes_init_1g_phy() and nes_init_2025_phy(). Remove support for NES_PHY_TYPE_IRIS, which was used on an XFP board that was only manufactured in small quantities and given out for evals in even smaller quantities. Signed-off-by: Chien Tung <chien.tin.tung@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2010-02-19RDMA/nes: Multiple disconnects cause crash during AE handlingFaisal Latif
There is a double disconnect during AE processing, causing crashes. While fixing the crash, also simplify the AE handling code. Signed-off-by: Faisal Latif <faisal.latif@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-12-09RDMA/nes: Check for zero STagFaisal Latif
STags are generated randomly but the driver does not correctly prevent a zero STag. Using STag zero is privileged and causes a user space application to fail. This change prevents the driver from trying to allocate a zero STag. Signed-off-by: Faisal Latif <faisal.latif@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-12-09RDMA/nes: Update copyright and branding stringChien Tung
Update copyright from Intel-NE, Inc. to Intel Corporation. Use proper branding string in Kconfig and simplify description. Signed-off-by: Chien Tung <chien.tin.tung@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-12-09RDMA/nes: Add max_cqe check to nes_create_cq()Chien Tung
Add a check to nes_create_cq() to return -EINVAL if creating a CQ with depth > max_cqe (32766). Signed-off-by: Chien Tung <chien.tin.tung@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-12-09RDMA/nes: Add additional SFP+ PHY uC status check and PHY resetChien Tung
Add additional PHY uC status check in case PHY firmware is not running properly with heartbeat. Add a hard PHY reset if uC status is 0x0 after initial reset. Signed-off-by: Chien Tung <chien.tin.tung@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-12-09RDMA/nes: Correct fast memory registration implementationChien Tung
Replace alloc_fmr, unmap_fmr, dealloc_fmr and map_phys_fmr with alloc_fast_reg_mr, alloc_fast_reg_page_list, free_fast_reg_page_list. Signed-off-by: Chien Tung <chien.tin.tung@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-09-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1623 commits) netxen: update copyright netxen: fix tx timeout recovery netxen: fix file firmware leak netxen: improve pci memory access netxen: change firmware write size tg3: Fix return ring size breakage netxen: build fix for INET=n cdc-phonet: autoconfigure Phonet address Phonet: back-end for autoconfigured addresses Phonet: fix netlink address dump error handling ipv6: Add IFA_F_DADFAILED flag net: Add DEVTYPE support for Ethernet based devices mv643xx_eth.c: remove unused txq_set_wrr() ucc_geth: Fix hangs after switching from full to half duplex ucc_geth: Rearrange some code to avoid forward declarations phy/marvell: Make non-aneg speed/duplex forcing work for 88E1111 PHYs drivers/net/phy: introduce missing kfree drivers/net/wan: introduce missing kfree net: force bridge module(s) to be GPL Subject: [PATCH] appletalk: Fix skb leak when ipddp interface is not loaded ... Fixed up trivial conflicts: - arch/x86/include/asm/socket.h converted to <asm-generic/socket.h> in the x86 tree. The generic header has the same new #define's, so that works out fine. - drivers/net/tun.c fix conflict between 89f56d1e9 ("tun: reuse struct sock fields") that switched over to using 'tun->socket.sk' instead of the redundantly available (and thus removed) 'tun->sk', and 2b980dbd ("lsm: Add hooks to the TUN driver") which added a new 'tun->sk' use. Noted in 'next' by Stephen Rothwell.
2009-09-05RDMA/nes: Use flush mechanism to set status for wqe in errorDon Wood
When an asynchronous event occurs that requires a terminate, it is sometimes possible to identify the wqe in error. This change uses flush to get this information to the poll routine. The flush operation puts the status into the cqe. If this information is not available, it continues to use the more generic flush code as before. Signed-off-by: Don Wood <donald.e.wood@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-09-05RDMA/nes: Implement Terminate PacketDon Wood
Implement the sending and receiving of Terminate packets. Signed-off-by: Don Wood <donald.e.wood@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-09-05RDMA/nes: Add CQ error handlingDon Wood
CQ errors are not being handled correctly. Put in the the upcall for CQ errors. Signed-off-by: Don Wood <donald.e.wood@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-09-02drivers: Kill now superfluous ->last_rx storesEric Dumazet
The generic packet receive code takes care of setting netdev->last_rx when necessary, for the sake of the bonding ARP monitor. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Neil Horman <nhorman@txudriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-15RDMA/nes: Fix off-by-one bugs in reset_adapter_ne020() and init_serdes()Roel Kluin
With a postfix increment, i is incremented one past 10K/5K before the loop ends, so the error messages will be displayed too soon if the test succeeds on the last iteration. Fix the comparisons to be > instead of >=. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-04-27RDMA/nes: Set trace length to 1 inch for SFP_DChien Tung
With updated PHY firmware for SFP_D, setting the trace length to 1 inch for SFP_D provides a more stable link. Signed-off-by: Chien Tung <chien.tin.tung@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-04-27RDMA/nes: Enable repause timer for port 1Chien Tung
Enable repause timer for port 1. Without this setting, under stress, the chip may misbehave. Signed-off-by: Chien Tung <chien.tin.tung@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-04-27RDMA/nes: Correct CDR loop filter setting for port 1Chien Tung
In commit 1b949324 ("RDMA/nes: Fix SFP+ PHY initialization") there is a mistake in the clean up code that removed port 1 CDR loop filter settings for 10G cards other than CX4. Put the correct setting back for appropriate PHY types. Signed-off-by: Chien Tung <chien.tin.tung@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-04-27RDMA/nes: Modify thermo mitigation to flip SerDes1 ref clk to internalChien Tung
Change thermo mitigation code to flip the SerDes1 reference clock to internal, to match the change in commit a4849fc1 ("RDMA/nes: Add wide_ppm_offset parm for switch compatibility"). Signed-off-by: Chien Tung <chien.tin.tung@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-04-08RDMA/nes: Add support for new SFP+ PHYChien Tung
Add new register settings for new SFP+ PHY/firmware. Add new PHY to to nes_netdev_get/set_settings. Signed-off-by: Chien Tung <chien.tin.tung@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-04-08RDMA/nes: Add wide_ppm_offset parm for switch compatibilityChien Tung
We have observed unstable link with a new BNT switch. Add wide_ppm_offset parameter to allow the user to control the clock ppm offset on the CX4 interface for better compatibility. Default is 100ppm, setting it to 1 will increase it to 300ppm. Change default SerDes1 reference clock to external source. Signed-off-by: Chien Tung <chien.tin.tung@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-04-08RDMA/nes: Fix SFP+ PHY initializationChien Tung
SFP+ PHY initialization has very long delays, incorrect settings for direct attach copper cables, and inconsistent link detection. Adjust delays to the minimum required by the PHY. Worst case is now less than 4 seconds. Add new register settings for direct attach cables. Change link detection logic to use two new registers for more consistent link state detection. Reorganize code to shorten line length. Signed-off-by: Chien Tung <chien.tin.tung@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
