[ Upstream commit fbf58026b2256e9cd5f241a4801d79d3b2b7b89d ]
commit 59e8970b3798 ("RDMA/qedr: Return max inline data in QP query
result") changed query_qp max_inline size to return the max roce inline
size. When iwarp was introduced, this should have been modified to return
the max inline size based on protocol. This size is cached in the device
attributes
Fixes: 69ad0e7fe845 ("RDMA/qedr: Add support for iWARP in user space")
Link: https://lore.kernel.org/r/20200902165741.8355-8-michal.kalderon@marvell.com
Signed-off-by: Michal Kalderon <michal.kalderon@marvell.com>
Signed-off-by: Jason Gunthorpe <jgg@nvidia.com>
[ Upstream commit 098e345a1a8faaad6e4e54d138773466cecc45d4 ]
The qedr_qp structure wasn't freed when the protocol was RoCE. kmemleak
output when running basic RoCE scenario.
unreferenced object 0xffff927ad7e22c00 (size 1024):
comm "ib_send_bw", pid 7082, jiffies 4384133693 (age 274.698s)
hex dump (first 32 bytes):
00 b0 cd a2 79 92 ff ff 00 3f a1 a2 79 92 ff ff ....y....?..y...
00 ee 5c dd 80 92 ff ff 00 f6 5c dd 80 92 ff ff ..\.......\.....
backtrace:
[<00000000b2ba0f35>] qedr_create_qp+0xb3/0x6c0 [qedr]
[<00000000e85a43dd>] ib_uverbs_handler_UVERBS_METHOD_QP_CREATE+0x555/0xad0 [ib_uverbs]
[<00000000fee4d029>] ib_uverbs_cmd_verbs+0xa5a/0xb80 [ib_uverbs]
[<000000005d622660>] ib_uverbs_ioctl+0xa4/0x110 [ib_uverbs]
[<00000000eb4cdc71>] ksys_ioctl+0x87/0xc0
[<00000000abe6b23a>] __x64_sys_ioctl+0x16/0x20
[<0000000046e7cef4>] do_syscall_64+0x4d/0x90
[<00000000c6948f76>] entry_SYSCALL_64_after_hwframe+0x44/0xa9
Fixes: 1212767e23bb ("qedr: Add wrapping generic structure for qpidr and adjust idr routines.")
Link: https://lore.kernel.org/r/20200902165741.8355-2-michal.kalderon@marvell.com
[ Upstream commit acca72e2b031b9fbb4184511072bd246a0abcebc ]
QP's with the same SRQ, working on different CQs and running in parallel
on different CPUs could lead to a race when maintaining the SRQ consumer
count, and leads to FW running out of SRQs. Update the consumer
atomically. Make sure the wqe_prod is updated after the sge_prod due to
FW requirements.
Fixes: 3491c9e799fb ("qedr: Add support for kernel mode SRQ's")
Link: https://lore.kernel.org/r/20200708195526.31040-1-ybason@marvell.com
Signed-off-by: Michal Kalderon <mkalderon@marvell.com>
Signed-off-by: Yuval Basson <ybason@marvell.com>
[ Upstream commit 82af6d19d8d9227c22a53ff00b40fb2a4f9fce69 ]
Re-design of the iWARP CM related objects reference counting and
synchronization methods, to ensure operations are synchronized correctly
and that memory allocated for "ep" is properly released. Also makes sure
QP memory is not released before ep is finished accessing it.
Where as the QP object is created/destroyed by external operations, the ep
is created/destroyed by internal operations and represents the tcp
connection associated with the QP.
QP destruction flow:
- needs to wait for ep establishment to complete (either successfully or
with error)
- needs to wait for ep disconnect to be fully posted to avoid a race
condition of disconnect being called after reset.
- both the operations above don't always happen, so we use atomic flags to
indicate whether the qp destruction flow needs to wait for these
completions or not, if the destroy is called before these operations
began, the flows will check the flags and not execute them ( connect /
disconnect).
We use completion structure for waiting for the completions mentioned
above.
The QP refcnt was modified to kref object. The EP has a kref added to it
to handle additional worker thread accessing it.
Memory Leaks - https://www.spinics.net/lists/linux-rdma/msg83762.html
Concurrency not managed correctly -
https://www.spinics.net/lists/linux-rdma/msg67949.html
Fixes: de0089e692a9 ("RDMA/qedr: Add iWARP connection management qp related callbacks")
Link: https://lore.kernel.org/r/20191027200451.28187-4-michal.kalderon@marvell.com
Reported-by: Chuck Lever <chuck.lever@oracle.com>
Reported-by: Jason Gunthorpe <jgg@mellanox.com>
Signed-off-by: Ariel Elior <ariel.elior@marvell.com>
Signed-off-by: Jason Gunthorpe <jgg@mellanox.com>
[ Upstream commit 5fdff18b4dc64e2d1e912ad2b90495cd487f791b ]
The qpids xarray isn't accessed from irq context and therefore there
is no need to use the xa_XXX_irq version of the apis.
Remove the _irq.
Fixes: b6014f9e5f39 ("qedr: Convert qpidr to XArray")
Link: https://lore.kernel.org/r/20191027200451.28187-3-michal.kalderon@marvell.com
[ Upstream commit 24e412c1e00ebfe73619e6b88cbc26c2c7d41b85 ]
User QPs pbl's weren't freed properly.
MR pbls weren't freed properly.
Fixes: e0290cce6ac0 ("qedr: Add support for memory registeration verbs")
Link: https://lore.kernel.org/r/20191027200451.28187-5-michal.kalderon@marvell.com
In order to improve readability, add ib_port_phys_state enum to replace
the use of magic numbers.
Signed-off-by: Kamal Heib <kamalheib1@gmail.com>
Reviewed-by: Andrew Boyer <aboyer@tobark.org>
Acked-by: Michal Kalderon <michal.kalderon@marvell.com>
Acked-by: Bernard Metzler <bmt@zurich.ibm.com>
Link: https://lore.kernel.org/r/20190807103138.17219-2-kamalheib1@gmail.com
Signed-off-by: Doug Ledford <dledford@redhat.com>
Fix the below warning reported by coccicheck:
drivers/infiniband/hw/qedr/verbs.c:2454:5-7: Unneeded variable: "rc".
Return "0" on line 2499
Link: https://lore.kernel.org/r/20190716173712.GA12949@hari-Inspiron-1545
Signed-off-by: Hariprasad Kelam <hariprasad.kelam@gmail.com>
Reviewed-by: Jason Gunthorpe <jgg@mellanox.com>
Update ib_umem_release() to behave similarly to kfree() and allow
submitting NULL pointer as safe input to this function.
Fixes: a52c8e2469c3 ("RDMA: Clean destroy CQ in drivers do not return errors")
Signed-off-by: Leon Romanovsky <leonro@mellanox.com>
Ensure that CQ is allocated and freed by IB/core and not by drivers.
Acked-by: Gal Pressman <galpress@amazon.com>
Reviewed-by: Dennis Dalessandro <dennis.dalessandro@intel.com>
Tested-by: Dennis Dalessandro <dennis.dalessandro@intel.com>
Like all other destroy commands, .destroy_cq() call is not supposed
to fail. In all flows, the attempt to return earlier caused to memory
leaks.
This patch converts .destroy_cq() to do not return any errors.
Acked-by: Dennis Dalessandro <dennis.dalessandro@intel.com>
Use the correct enum value introduced in commit 12113a35ada6 ("IB/core:
Add HDR speed enum") Prior to this change a 50Gbps port would show 40Gbps.
This patch also cleaned up the redundant redefiniton of ib speeds for
qedr.
Fixes: 12113a35ada6 ("IB/core: Add HDR speed enum")
Signed-off-by: Sagiv Ozeri <sagiv.ozeri@marvell.com>
Pull rdma updates from Jason Gunthorpe:
"This has been a smaller cycle than normal. One new driver was
accepted, which is unusual, and at least one more driver remains in
review on the list.
Summary:
- Driver fixes for hns, hfi1, nes, rxe, i40iw, mlx5, cxgb4,
vmw_pvrdma
- Many patches from MatthewW converting radix tree and IDR users to
use xarray
- Introduction of tracepoints to the MAD layer
- Build large SGLs at the start for DMA mapping and get the driver to
split them
- Generally clean SGL handling code throughout the subsystem
- Support for restricting RDMA devices to net namespaces for
containers
- Progress to remove object allocation boilerplate code from drivers
- Change in how the mlx5 driver shows representor ports linked to VFs
- mlx5 uapi feature to access the on chip SW ICM memory
- Add a new driver for 'EFA'. This is HW that supports user space
packet processing through QPs in Amazon's cloud"
* tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rdma/rdma: (186 commits)
RDMA/ipoib: Allow user space differentiate between valid dev_port
IB/core, ipoib: Do not overreact to SM LID change event
RDMA/device: Don't fire uevent before device is fully initialized
lib/scatterlist: Remove leftover from sg_page_iter comment
RDMA/efa: Add driver to Kconfig/Makefile
RDMA/efa: Add the efa module
RDMA/efa: Add EFA verbs implementation
RDMA/efa: Add common command handlers
RDMA/efa: Implement functions that submit and complete admin commands
RDMA/efa: Add the ABI definitions
RDMA/efa: Add the com service API definitions
RDMA/efa: Add the efa_com.h file
RDMA/efa: Add the efa.h header file
RDMA/efa: Add EFA device definitions
RDMA: Add EFA related definitions
RDMA/umem: Remove hugetlb flag
RDMA/bnxt_re: Use core helpers to get aligned DMA address
RDMA/i40iw: Use core helpers to get aligned DMA address within a supported page size
RDMA/verbs: Add a DMA iterator to return aligned contiguous memory blocks
RDMA/umem: Add API to find best driver supported page size in an MR
Instead of RoCE drivers figuring out vlan, smac fields while working on
QP/AH, provide a helper routine to read the L2 fields such as vlan_id and
source mac address.
This moves logic from mlx5 driver to core for wider usage for RoCE ports.
This is a preparation patch to allow detaching netdev in subsequent patch.
Signed-off-by: Parav Pandit <parav@mellanox.com>
Convert SRQ allocation from drivers to be in the IB/core
Simplify drivers by ensuring lifetime of ib_ah object. The changes
in .create_ah() go hand in hand with relevant update in .destroy_ah().
We will use this opportunity and convert .destroy_ah() to don't fail, as
it was suggested a long time ago, because there is nothing to do in case
of failure during destroy.
mmiowb() is now implied by spin_unlock() on architectures that require
it, so there is no reason to call it from driver code. This patch was
generated using coccinelle:
@mmiowb@
- mmiowb();
and invoked as:
$ for d in drivers include/linux/qed sound; do \
spatch --include-headers --sp-file mmiowb.cocci --dir $d --in-place; done
NOTE: mmiowb() has only ever guaranteed ordering in conjunction with
spin_unlock(). However, pairing each mmiowb() removal in this patch with
the corresponding call to spin_unlock() is not at all trivial, so there
is a small chance that this change may regress any drivers incorrectly
relying on mmiowb() to order MMIO writes between CPUs using lock-free
synchronisation. If you've ended up bisecting to this commit, you can
reintroduce the mmiowb() calls using wmb() instead, which should restore
the old behaviour on all architectures other than some esoteric ia64
systems.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
In preparation for using coccinelle to remove all mmiowb() instances
from drivers, remove all trailing comments since they won't be picked up
by spatch later on and will end up being preserved in the code.
Now when ib_udata is passed to all the driver's object create/destroy APIs
the ib_udata will carry the ib_ucontext for every user command. There is
no need to also pass the ib_ucontext via the functions prototypes.
Make ib_udata the only argument psssed.
Signed-off-by: Shamir Rabinovitch <shamir.rabinovitch@oracle.com>
Now that we have the udata passed to all the ib_xxx object destroy APIs
and the additional macro 'rdma_udata_to_drv_context' to get the
ib_ucontext from ib_udata stored in uverbs_attr_bundle, we can finally
start to remove the dependency of the drivers in the
ib_xxx->uobject->context.
The uverbs_attr_bundle with the ucontext is sent down to the drivers ib_x
destroy path as ib_udata. The next patch will use the ib_udata to free the
drivers destroy path from the dependency in 'uobject->context' as we
already did for the create path.
Signed-off-by: Matthew Wilcox <willy@infradead.org>
Following the PD conversion patch, do the same for ucontext allocations.
Now when we have the udata passed to all the ib_xxx object creation APIs
Use the for_each_sg_dma_page iterator variant to walk the umem DMA-mapped
SGL and get the page DMA address. This avoids the extra loop to iterate
pages in the SGE when for_each_sg iterator is used.
Additionally, purge umem->page_shift usage in the driver as its only
relevant for ODP MRs. Use system page size and shift instead.
Signed-off-by: Shiraz, Saleem <shiraz.saleem@intel.com>
The PD allocations in IB/core allows us to simplify drivers and their
error flows in their .alloc_pd() paths. The changes in .alloc_pd() go hand
in had with relevant update in .dealloc_pd().
We will use this opportunity and convert .dealloc_pd() to don't fail, as
it was suggested a long time ago, failures are not happening as we have
never seen a WARN_ON print.
Yishai Hadas says:
Enable DEVX asynchronous query commands
This series enables querying a DEVX object in an asynchronous mode.
The userspace application won't block when calling the firmware and it will be
able to get the response back once that it will be ready.
To enable the above functionality:
- DEVX asynchronous command completion FD object was introduced.
- The applicable file operations were implemented to enable using it by
the user application.
- Query asynchronous method was added to the DEVX object, it will call the
firmware asynchronously and manages the response on the given input FD.
- Hot unplug support was added for the FD to work properly upon
unbind/disassociate.
- mlx5 core fence for asynchronous commands was implemented and used to
prevent racing upon unbind/disassociate.
This branch is based on mlx5-next & v5.0-rc2 due to dependencies, from
git://git.kernel.org/pub/scm/linux/kernel/git/mellanox/linux
* branch 'devx-async':
IB/mlx5: Implement DEVX hot unplug for async command FD
IB/mlx5: Implement the file ops of DEVX async command FD
IB/mlx5: Introduce async DEVX obj query API
IB/mlx5: Introduce MLX5_IB_OBJECT_DEVX_ASYNC_CMD_FD
Remove unneeded semicolons.
Signed-off-by: YueHaibing <yuehaibing@huawei.com>
Fixes gcc '-Wunused-but-set-variable' warning:
drivers/infiniband/hw/qedr/verbs.c: In function 'qedr_create_srq':
drivers/infiniband/hw/qedr/verbs.c:1436:22: warning:
variable 'ib_ctx' set but not used [-Wunused-but-set-variable]
drivers/infiniband/hw/qedr/verbs.c: In function 'qedr_create_user_qp':
drivers/infiniband/hw/qedr/verbs.c:1701:22: warning:
Fixes: b0ea0fa5435f ("IB/{core,hw}: Have ib_umem_get extract the ib_ucontext from ib_udata")
The pkey table size is QEDR_ROCE_PKEY_TABLE_LEN, index should be tested
for >= QEDR_ROCE_PKEY_TABLE_LEN instead of > QEDR_ROCE_PKEY_TABLE_LEN.
Fixes: a7efd7773e31 ("qedr: Add support for PD,PKEY and CQ verbs")
Signed-off-by: Gal Pressman <galpress@amazon.com>
ib_umem_get() can only be called in a method callback, which always has a
udata parameter. This allows ib_umem_get() to derive the ucontext pointer
directly from the udata without requiring the drivers to find it in some
way or another.
We already need to zero out memory for dma_alloc_coherent(), as such
using dma_zalloc_coherent() is superflous. Phase it out.
This change was generated with the following Coccinelle SmPL patch:
@ replace_dma_zalloc_coherent @
expression dev, size, data, handle, flags;
-dma_zalloc_coherent(dev, size, handle, flags)
+dma_alloc_coherent(dev, size, handle, flags)
Suggested-by: Christoph Hellwig <hch@lst.de>
Signed-off-by: Luis Chamberlain <mcgrof@kernel.org>
[hch: re-ran the script on the latest tree]
Introduce a 'flags' field to destroy address handle callback and add a
flag that marks whether the callback is executed in an atomic context or
not.
This will allow drivers to wait for completion instead of polling for it
when it is allowed.
Introduce a 'flags' field to create address handle callback and add a flag
that marks whether the callback is executed in an atomic context or not.
when it is allowed.
Drivers should be using udata to determine if a method is invoked from
user space or kernel space. A pd does not necessarily say a different
objects is kernel or user.
Transforming the tests to use udata eliminates a large number of uobject
references from the drivers.
RDMA core layer already make sure port is valid, no need to check it here
again.
For the pkey validation this depends on commit b3ac5742fead ("RDMA/core:
Validate port number in query_pkey verb")
Signed-off-by: Yuval Shaia <yuval.shaia@oracle.com>
Acked-by: Leon Romanovsky <leonro@mellanox.com>
The ll parameter is not used in ib_modify_qp_is_ok(), so remove it.
drivers/infiniband/hw/qedr/verbs.c:1450:24: warning:
variable 'ctx' set but not used [-Wunused-but-set-variable]
Acked-by: Rahul Verma <rahul.verma@cavium.com>
Resolve merge conflicts from the -rc cycle against the rdma.git tree:
drivers/infiniband/core/uverbs_cmd.c
- New ifs added to ib_uverbs_ex_create_flow in -rc and for-next
- Merge removal of file->ucontext in for-next with new code in -rc
drivers/infiniband/core/uverbs_main.c
- for-next removed code from ib_uverbs_write() that was modified
in for-rc
This patch adds support for SRQ's created in user space and update
qedr_affiliated_event to deal with general SRQ events.
Signed-off-by: Michal Kalderon <michal.kalderon@cavium.com>
Signed-off-by: Yuval Bason <yuval.bason@cavium.com>
Implement the SRQ specific verbs and update the poll_cq verb to deal with
SRQ completions.
Today, we are using idr mechanism for QP's only.
This patch prepares the qedr_idr stuctures and the idr routines for
both QP's and SRQ's.
Since neither ib_post_send() nor ib_post_recv() modify the data structure
their second argument points at, declare that argument const. This change
makes it necessary to declare the 'bad_wr' argument const too and also to
modify all ULPs that call ib_post_send(), ib_post_recv() or
ib_post_srq_recv(). This patch does not change any functionality but makes
it possible for the compiler to verify whether the
ib_post_(send|recv|srq_recv) really do not modify the posted work request.
To make this possible, only one cast had to be introduce that casts away
constness, namely in rpcrdma_post_recvs(). The only way I can think of to
avoid that cast is to introduce an additional loop in that function or to
change the data type of bad_wr from struct ib_recv_wr ** into int
(an index that refers to an element in the work request list). However,
both approaches would require even more extensive changes than this
patch.
Signed-off-by: Bart Van Assche <bart.vanassche@wdc.com>
Reviewed-by: Chuck Lever <chuck.lever@oracle.com>
When posting a send work request, the work request that is posted is not
modified by any of the RDMA drivers. Make this explicit by constifying
most ib_send_wr pointers in RDMA transport drivers.
Reviewed-by: Sagi Grimberg <sagi@grimberg.me>
Reviewed-by: Steve Wise <swise@opengridcomputing.com>
The internal flag IP_BASED_GIDS was added to a field that was being used
to hold the port Info CapabilityMask without considering the effects this
will have. Since most drivers just use the value from the HW MAD it means
IP_BASED_GIDS will also become set on any HW that sets the IBA flag
IsOtherLocalChangesNoticeSupported - which is not intended.
Fix this by keeping port_cap_flags only for the IBA CapabilityMask value
and store unrelated flags externally. Move the bit definitions for this to
ib_mad.h to make it clear what is happening.
To keep the uAPI unchanged define a new set of flags in the uapi header
that are only used by ib_uverbs_query_port_resp.port_cap_flags which match
the current flags supported in rdma-core, and the values exposed by the
current kernel.
Fixes: b4a26a27287a ("IB: Report using RoCE IP based gids in port caps")
Signed-off-by: Artemy Kovalyov <artemyko@mellanox.com>
Pull rdma fixes from Jason Gunthorpe:
"Here are eight fairly small fixes collected over the last two weeks.
Regression and crashing bug fixes:
- mlx4/5: Fixes for issues found from various checkers
- A resource tracking and uverbs regression in the core code
- qedr: NULL pointer regression found during testing
- rxe: Various small bugs"
IB/rxe: Fix missing completion for mem_reg work requests
RDMA/core: Save kernel caller name when creating CQ using ib_create_cq()
IB/uverbs: Fix ordering of ucontext check in ib_uverbs_write
IB/mlx4: Fix an error handling path in 'mlx4_ib_rereg_user_mr()'
RDMA/qedr: Fix NULL pointer dereference when running over iWARP without RDMA-CM
IB/mlx5: Fix return value check in flow_counters_set_data()
IB/mlx5: Fix memory leak in mlx5_ib_create_flow
IB/rxe: avoid double kfree skb
This patch replaces the ib_device_attr.max_sge with max_send_sge and
max_recv_sge. It allows ulps to take advantage of devices that have very
different send and recv sge depths. For example cxgb4 has a max_recv_sge
of 4, yet a max_send_sge of 16. Splitting out these attributes allows
much more efficient use of the SQ for cxgb4 with ulps that use the RDMA_RW
API. Consider a large RDMA WRITE that has 16 scattergather entries.
With max_sge of 4, the ulp would send 4 WRITE WRs, but with max_sge of
16, it can be done with 1 WRITE WR.
Acked-by: Sagi Grimberg <sagi@grimberg.me>
Acked-by: Christoph Hellwig <hch@lst.de>
Acked-by: Selvin Xavier <selvin.xavier@broadcom.com>
Acked-by: Shiraz Saleem <shiraz.saleem@intel.com>
Signed-off-by: Steve Wise <swise@opengridcomputing.com>
The core code now ensures that all driver callbacks that receive an
rdma_ah_attrs will have a sgid_attr's pointer if there is a GRH present.
Drivers can use this pointer instead of calling a query function with
sgid_index. This simplifies the drivers and also avoids races where a
gid_index lookup may return different data if it is changed.
Introduce AH attribute copy, move and replace APIs to be used by core and
provider drivers.
In CM code flow when ah attribute might be re-initialized twice while
processing incoming request, or initialized once while from path record
while sending out CM requests. Therefore use rdma_move_ah_attr API to
handle such scenarios instead of memcpy().
Provider drivers keeps a copy ah_attr during the lifetime of the ah.
Therefore, use rdma_replace_ah_attr() which conditionally release
reference to old ah_attr and holds reference to new attribute whose
referrence is released when the AH is freed.
