commit c8c16d3bae967f1c7af541e8d016e5c51e4f010a upstream.
Under heavy iser target(scst) start/stop stress during login/logout
on iser intitiator side happened trace call provided below.
The function iscsi_iser_slave_alloc iser_conn pointer could be NULL,
due to the fact that function iscsi_iser_conn_stop can be called before
and free iser connection. Let's protect that flow by introducing global mutex.
BUG: unable to handle kernel paging request at 0000000000001018
IP: [<ffffffffc0426f7e>] iscsi_iser_slave_alloc+0x1e/0x50 [ib_iser]
Call Trace:
? scsi_alloc_sdev+0x242/0x300
scsi_probe_and_add_lun+0x9e1/0xea0
? kfree_const+0x21/0x30
? kobject_set_name_vargs+0x76/0x90
? __pm_runtime_resume+0x5b/0x70
__scsi_scan_target+0xf6/0x250
scsi_scan_target+0xea/0x100
iscsi_user_scan_session.part.13+0x101/0x130 [scsi_transport_iscsi]
? iscsi_user_scan_session.part.13+0x130/0x130 [scsi_transport_iscsi]
iscsi_user_scan_session+0x1e/0x30 [scsi_transport_iscsi]
device_for_each_child+0x50/0x90
iscsi_user_scan+0x44/0x60 [scsi_transport_iscsi]
store_scan+0xa8/0x100
? common_file_perm+0x5d/0x1c0
dev_attr_store+0x18/0x30
sysfs_kf_write+0x37/0x40
kernfs_fop_write+0x12c/0x1c0
__vfs_write+0x18/0x40
vfs_write+0xb5/0x1a0
SyS_write+0x55/0xc0
Fixes: 318d311e8f01 ("iser: Accept arbitrary sg lists mapping if the device supports it")
Signed-off-by: Vladimir Neyelov <vladimirn@mellanox.com>
Signed-off-by: Leon Romanovsky <leon@kernel.org>
Reviewed-by: Sagi Grimberg <sagi@grimbeg.me>
Signed-off-by: Doug Ledford <dledford@redhat.com>
commit 1e5db6c31ade4150c2e2b1a21e39f776c38fea39 upstream.
For devices that can register page list that is bigger than
USHRT_MAX, we actually take the wrong value for sg_tablesize.
E.g: for CX4 max_fast_reg_page_list_len is 65536 (bigger than USHRT_MAX)
so we set sg_tablesize to 0 by mistake. Therefore, each IO that is
bigger than 4k splitted to "< 4k" chunks that cause performance degredation.
Remove wrong sg_tablesize assignment, and use the value that was set during
address resolution handler with the needed casting.
Signed-off-by: Max Gurtovoy <maxg@mellanox.com>
Reviewed-by: Sagi Grimberg <sagi@grimberg.me>
iSER currently has a couple places that set max_sectors in either the host
template or SCSI host, and all of them get it wrong.
This patch instead uses a single assignment that (hopefully) gets it right:
the max_sectors value must be derived from the number of segments in the
FR or FMR structure, but actually be one lower than the page size multiplied
by the number of sectors, as it has to handle the case of non-aligned I/O.
Without this I get trivial to reproduce hangs when running xfstests
(on XFS) over iSER to Linux targets.
Reviewed-by: Max Gurtovoy <maxg@mellanox.com>
Acked-by: Sagi Grimberg <sagi@grimberg.me>
If the device support arbitrary sg list mapping (device cap
IB_DEVICE_SG_GAPS_REG set) we allocate the memory regions with
IB_MR_TYPE_SG_GAPS and allow the block layer to pass us
gaps by skip setting the queue virt_boundary.
Signed-off-by: Sagi Grimberg <sagig@mellanox.com>
Destroy workqueue on transport register error, also
release kmem cache on workqueue allocation error.
Signed-off-by: Roi Dayan <roid@mellanox.com>
Instead, use the cached copy of the attributes present on the device.
Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com>
iser is perfectly capable supporting SG clustering as it translates
the SG list to a page vector. Enabling SG clustering can dramatically
reduce the number of SG elements, which doesn't make much of a difference
at this point, but with arbitrary SG list support, reducing the
number of SG elements can benefit greatly as as it would reduce
the length of the HW descriptors array.
The block layer can reliably guarantee that SG lists won't
contain gaps (page unaligned) if a driver set the queue
virt_boundary.
With this setting the block layer will:
- refuse merges if bios are not aligned to the virtual boundary
- split bios/requests that are not aligned to the virtual boundary
- or, bounce buffer SG_IOs that are not aligned to the virtual boundary
Since iser is working in 4K page size, set the virt_boundary to
4K pages. With this setting, we can now safely remove the bounce
buffering logic in iser.
Detected this by compiling with W=1.
Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com>
Cc: Sagi Grimberg <sagig@mellanox.com>
Just fix a typo in the code comment.
Signed-off-by: Geliang Tang <geliangtang@163.com>
Acked-by: Sagi Grimberg <sagig@mellanox.com>
This module parameter forces memory registration even for
a continuous memory region. It is true by default as sending
an all-physical rkey with remote permissions might be insecure.
Replace all leys with pd->local_dma_lkey. This driver does not support
iWarp, so this is safe.
The insecure use of ib_get_dma_mr is thus isolated to an rkey, and this
looks trivially fixed by forcing the use of registration in a future
patch.
Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
Reviewed-by: Sagi Grimberg <sagig@mellanox.com>
Chaning of send work requests benefits performance by
reducing the send queue lock contention (acquired in
ib_post_send) and saves us HW doorbells which is posted
only once.
Currently, in normal IO flows iser does not chain the CDB send
work request with the registration work request. Also in PI
flows, signature work requests are not chained as well.
Lets chain those and post only once.
iser support up to 512KB data transfer in a single scsi command.
This means that larger IOs will split to different request. While
iser can easily saturate FDR/EDR wires, some arrays are fine tuned
for 1MB (or larger) IO sizes, hence add an option to support larger
transfers (up to 8MB) if the device allows it.
Given that a few target implementations don't support data transfers
of more than 512KB by default and the fact that larger IO sizes require
more resources, we introduce a module parameter to determine the
maximum number of 512B sectors in a single scsi command.
Users that are interested in larger transfers can change this value given
that the target supports larger transfers.
At the moment, iser works in 4K pages granularity, In a later stage
we will get it to work with system page size instead.
IO operations that consists of N pages will need a page vector
of size N+1 in case the first SG element contains an offset. Given
that some devices allocates memory regions in powers of 2, this
means that allocating a region with N+1 pages, will result in
region resources allocation of the next power of 2. Since we don't
want that to happen, in case we are in the limit of IO size supported
and the first SG element has an offset, we align the SG list using a
bounce buffer (which is OK given that this is not likely to happen a lot).
If iser_initialize_task_headers() routine failed before
dma mapping, we should not attempt to unmap in cleanup_task().
Fixes: 7414dde0a6c3a958e (IB/iser: Fix race between iser connection ...)
We don't update those anywhere in the code and they
seem pretty useless (no one seem to care about those).
qp_tx_queue_full: We never should get this
fmr_map_not_avail: We can never get to this
eh_abort_cnt: We don't monitor aborts
Go ahead and remove them.
While we're at it, use permission defines instead
of octal values and rearrange a little bit.
Signed-off-by: Jenny Derzhavetz <jennyf@mellanox.com>
Currently the sg tablesize, which dictates fast register page list
depth to use, does not take into account the limits of the rdma device.
So adjust it once we discover the device fastreg max depth limit. Also
adjust the max_sectors based on the resulting sg tablesize.
Signed-off-by: Steve Wise <swise@opengridcomputing.com>
Following few recent Block integrity updates, we align the iSER data
integrity offload settings with:
- Deprecate pi_guard module param
- Expose support for DIX type 0.
- Use scsi_transfer_length for the transfer length
- Get pi_interval, ref_tag, ref_remap, bg_type and
check_mask setting from scsi_cmnd
Signed-off-by: Roland Dreier <roland@purestorage.com>
When closing the connection, we should first terminate the connection
(in case it was not previously terminated) to guarantee the QP is in
error state and we are done with servicing IO. Only then go ahead with
tasks cleanup via iscsi_conn_stop.
In certain scenarios (target kill with live IO) scsi TMFs may race
with iser RDMA teardown, which might cause NULL dereference on iser IB
device handle (which might have been freed). In this case we take a
conditional lock for TMFs and check the connection state (avoid
introducing lock contention in the IO path). This is indeed best
effort approach, but sufficient to survive multi targets sudden death
while heavy IO is inflight.
While we are on it, add a nice kernel-doc style documentation.
Reported-by: Ariel Nahum <arieln@mellanox.com>
If rdma_cm error event comes after ep_poll but before conn_bind, we
should protect against dereferncing the device (which may have been
terminated) in session_create and conn_create (already protected)
callbacks.
Signed-off-by: Ariel Nahum <arieln@mellanox.com>
Re-adjust max CQEs per CQ and max send_wr per QP according
to the resource limits supported by underlying hardware.
Signed-off-by: Minh Tran <minhduc.tran@emulex.com>
Signed-off-by: Jayamohan Kallickal <jayamohan.kallickal@emulex.com>
Drop the now unused reason argument from the ->change_queue_depth method.
Also add a return value to scsi_adjust_queue_depth, and rename it to
scsi_change_queue_depth now that it can be used as the default
->change_queue_depth implementation.
Reviewed-by: Mike Christie <michaelc@cs.wisc.edu>
Reviewed-by: Hannes Reinecke <hare@suse.de>
All drivers use the implementation for ramping the queue up and down, so
instead of overloading the change_queue_depth method call the
implementation diretly if the driver opts into it by setting the
track_queue_depth flag in the host template.
Note that a few drivers validated the new queue depth in their
change_queue_depth method, but as we never go over the queue depth
set during slave_configure or the sysfs file this isn't nessecary
and can safely be removed.
Reviewed-by: Venkatesh Srinivas <venkateshs@google.com>
In the future this will be a per-command parameter so we can lose it,
but in the mean time IP_CSUM is a lot lighter for SW layers to
compute, set it as default.
This patch does not change any functionality.
Match to the debug level of all functions in connect/disconnect flows.
Bailout in case a task cleanup (iscsi_iser_cleanup_task) is called
after the IB device was removed (DEVICE_REMOVAL CM event). We also
call iscsi_conn_stop with a lock taken to prevent DEVICE_REMOVAL and
tasks cleanup from racing.
Previously we didn't need to unbind the iser_conn and iscsi_conn since
we always relied on iscsi daemon to teardown the connection and never
let it finish before we cleanup all that is needed in iser. This is
not the case anymore (for DEVICE_REMOVAL event). So avoid any possible
chance we cause iscsi_conn dereference after iscsi_conn was freed.
We also call iser_conn_terminate (safe to call multiple times) just
for the corner case of iscsi daemon stopping an old connection before
invoking endpoint removal (might happen if it was violently killed).
Notice we are unbinding under a lock - which is required.
Structure that describes the RDMA relates connection objects. Static
member of iser_conn.
Two reasons why we choose to do this:
1. No point today calling struct iser_conn by another name ib_conn
2. In the next patches we will restructure iser control plane representation
- struct iser_conn: connection logical representation
- struct ib_conn: connection RDMA layout representation
We need to fail the bind operation if the iser connection state != UP
(started teardown) and this should be done under the state lock.
Instead of waiting for events and condition changes of the iser
connection state, we wait for explicit completion of connection
establishment and teardown.
Separate connection establishment wait object from the teardown object
to avoid a situation where racing connection establishment and
teardown may concurrently wakeup each other.
ep_poll will wait for up_completion invoked by
iser_connected_handler() and iser release worker will wait for
flush_completion before releasing the connection.
Bound the completion wait with a 30 seconds timeout for cases where
iscsid (the user space iscsi daemon) is too slow or gone.
The iser connection state lookups and transitions are not fully protected.
Some transitions are protected with a spinlock, and in some cases the
state is accessed unprotected due to specific assumptions of the flow.
Introduce a new mutex to protect the connection state access. We use a
mutex since we need to also include a scheduling operations executed
Each state transition/condition and its corresponding action will be
protected with the state mutex.
The rdma_cm events handler acquires the mutex when handling connection
events. Since iser connection state can transition to DOWN
concurrently during connection establishment, we bailout from
addr/route resolution events when the state is not PENDING.
This addresses a scenario where ep_poll retries expire during CMA
connection establishment. In this case ep_disconnect is invoked while
CMA events keep coming (address/route resolution, connected, etc...).
iser connection needs asynchronous cleanup completions which are
triggered in ep_disconnect. As a result we are keeping the
corresponding iscsi_endpoint structure hanging for no good reason. In
order to avoid that, we seperate iser_conn from iscsi_endpoint storage
space to have their destruction being independent.
iscsi_endpoint will be destroyed at ep_disconnect stage, while the
iser connection will wait for asynchronous completions to be released
in an orderly fashion.
Replace struct sockaddr_in with struct sockaddr which supports both
IPv4 and IPv6, and print using the %pIS format directive.
Logging messages need terminating newlines to avoid possible message
interleaving. Add them.
iSER relies on refcounting to manage iser connections establishment
and teardown.
Following commit 39ff05dbbbdb ("IB/iser: Enhance disconnection logic
for multi-pathing"), iser connection maintain 3 references:
- iscsi_endpoint (at creation stage)
- cma_id (at connection request stage)
- iscsi_conn (at bind stage)
We can avoid taking explicit refcounts by correctly serializing iser
teardown flows (graceful and non-graceful).
Our approach is to trigger a scheduled work to handle ordered teardown
by gracefully waiting for 2 cleanup stages to complete:
1. Cleanup of live pending tasks indicated by iscsi_conn_stop completion
2. Flush errors processing
Each completed stage will notify a waiting worker thread when it is
done to allow teardwon continuation.
Since iSCSI connection establishment may trigger endpoint disconnect
without a successful endpoint connect, we rely on the iscsi <-> iser
binding (.conn_bind) to learn about the teardown policy we should take
wrt cleanup stages.
Since all cleanup worker threads are scheduled (release_wq) in
.ep_disconnect it is safe to assume that when module_exit is called,
all cleanup workers are already scheduled. Thus proper module unload
shall flush all scheduled works before allowing safe exit, to
guarantee no resources got left behind.
Reviewed-by: Roi Dayan <roid@mellanox.com>
Reviewed-by: Or Gerlitz <ogerlitz@mellanox.com>
Update Mellanox copyrights for 2014 on the iser initiator driver.
The iscsi stack has existing mechanisms to link back and forth between
the iscsi connection and the iscsi transport (e.g iser/tcp) connection.
This is done through a dd_data pointer field in struct iscsi_conn
which can be set to point to the transport connection, etc.
The iscsi_iser_conn structure was used to get this linking done in
another way, which is uneeded and adds extra complication to the iser
code, so we just remove it.
After allocating a scsi_host we set protection types and guard type
supported.
Signed-off-by: Alex Tabachnik <alext@mellanox.com>
Once the iSCSI transaction is completed we must implement
check_protection in order to notify on DIF errors that may have
occured.
The routine boils down to calling ib_check_mr_status to get the
signature status of the transaction.
Add logic to initialize protection information entities. Upon each
iSCSI task, we keep the scsi_cmnd in order to query the scsi
protection operations and reference to protection buffers.
Modify iser_fast_reg_mr to receive indication whether it is
registering the data or protection buffers.
In addition introduce iser_reg_sig_mr which performs fast registration
work-request for a signature enabled memory region
(IB_WR_REG_SIG_MR). In this routine we set all the protection
relevants for the device to offload protection data-transfer and
verification.
Use modparams to activate protection information support.
pi_enable bool: Based on this parameter iSER will know if it should
support T10-PI. We don't want to do this by default as it requires to
allocate and initialize extra resources. In case pi_enable=N, iSER
won't publish to SCSI midlayer any DIF capabilities.
pi_guard int: Based on this parameter iSER will publish DIX guard type
support to SCSI midlayer. 0 means CRC is allowed to be passed in DIX
buffers, 1 (or non-zero) means IP-CSUM is allowed to be passed in DIX
buffers. Note that over the wire, only CRC is allowed.
In the next phase, it is worth considering passing these parameters
from iscsid via nlmsg. This will allow these parameters to be
connection based rather than global.
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband
Pull main batch of InfiniBand/RDMA changes from Roland Dreier:
- Large ocrdma HW driver update: add "fast register" work requests,
fixes, cleanups
- Add receive flow steering support for raw QPs
- Fix IPoIB neighbour race that leads to crash
- iSER updates including support for using "fast register" memory
registration
- IPv6 support for iWARP
- XRC transport fixes
* tag 'rdma-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (54 commits)
RDMA/ocrdma: Fix compiler warning about int/pointer size mismatch
IB/iser: Fix redundant pointer check in dealloc flow
IB/iser: Fix possible memory leak in iser_create_frwr_pool()
IB/qib: Move COUNTER_MASK definition within qib_mad.h header guards
RDMA/ocrdma: Fix passing wrong opcode to modify_srq
RDMA/ocrdma: Fill PVID in UMC case
RDMA/ocrdma: Add ABI versioning support
RDMA/ocrdma: Consider multiple SGES in case of DPP
RDMA/ocrdma: Fix for displaying proper link speed
RDMA/ocrdma: Increase STAG array size
RDMA/ocrdma: Dont use PD 0 for userpace CQ DB
RDMA/ocrdma: FRMA code cleanup
RDMA/ocrdma: For ERX2 irrespective of Qid, num_posted offset is 24
RDMA/ocrdma: Fix to work with even a single MSI-X vector
RDMA/ocrdma: Remove the MTU check based on Ethernet MTU
RDMA/ocrdma: Add support for fast register work requests (FRWR)
RDMA/ocrdma: Create IRD queue fix
IB/core: Better checking of userspace values for receive flow steering
IB/mlx4: Add receive flow steering support
IB/core: Export ib_create/destroy_flow through uverbs
To run discovery over iSER we need to advertize the CAP_TEXT_NEGO capability
towards user space. Also need to make sure the login RX buffer is posted when
SendTargets TEXT PDUs are sent. For that end, we use a setting of the
ISCSI_PARAM_DISCOVERY_SESS iscsi param as an indication that this is
discovery session.
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
Use cmds_max passed from user space to be the number of PDUs to be
supported for the session instead of hard-coded ISCSI_DEF_XMIT_CMDS_MAX.
This allow controlling the max number of SCSI commands for the session.
Also don't ignore the qdepth passed from user space.
Derive from session->cmds_max the actual number of RX buffers and FMR
pool size to allocate during the connection bind phase.
Since the iser transport connection is established before the iscsi
session/connection are created and bound, we still use one hard-coded
quantity ISER_DEF_XMIT_CMDS_MAX to compute the maximum number of
work-requests to be supported by the RC QP used for the connection.
The above quantity is made to be a power of two between ISCSI_TOTAL_CMDS_MIN
(16) and ISER_DEF_XMIT_CMDS_MAX (512) inclusive.
Signed-off-by: Shlomo Pongratz <shlomop@mellanox.com>
