[ Upstream commit c1545f1a200f4adc4ef8dd534bf33e2f1aa22c2f ]
The retured value from ib_dma_map_sg saved in dma_nents variable. To avoid
future mismatch between types, define dma_nents as an integer instead of
unsigned.
Fixes: 57b26497fabe ("IB/iser: Pass the correct number of entries for dma mapped SGL")
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Reviewed-by: Israel Rukshin <israelr@mellanox.com>
Signed-off-by: Max Gurtovoy <maxg@mellanox.com>
Acked-by: Sagi Grimberg <sagi@grimberg.me>
Reviewed-by: Dan Carpenter <dan.carpenter@oracle.com>
Signed-off-by: Jason Gunthorpe <jgg@mellanox.com>
[ Upstream commit ea174c9573b0e0c8bc1a7a90fe9360ccb7aa9cbb ]
When the rdma device is removed, we must cleanup all
the rdma resources within the DEVICE_REMOVAL event
handler to let the device teardown gracefully. When
this happens with live I/O, some memory regions are
occupied. Thus, track them too and dereg all the mr's.
We are safe with mr access by iscsi_iser_cleanup_task.
Reported-by: Raju Rangoju <rajur@chelsio.com>
Signed-off-by: Sagi Grimberg <sagi@grimberg.me>
Reviewed-by: Max Gurtovoy <maxg@mellanox.com>
Signed-off-by: Doug Ledford <dledford@redhat.com>
Reviewed-by: Sagi Grimberg <sagi@grimberg.me>
Reviewed-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
Reviewed-by: Steve Wise <swise@opengridcomputing.com>
Signed-off-by: Steve Wise <swise@opengridcomputing.com>
Declare that we support remote invalidation in case we are:
1. using fastreg method
2. always registering memory
Detect the invalidated rkey from the work completion info so we
won't invalidate it locally. The spec mandates that we must not rely
on the target remote invalidate our rkey so we must check it upon
a receive (scsi response) completion.
Signed-off-by: Jenny Derzhavetz <jennyf@mellanox.com>
Signed-off-by: Sagi Grimberg <sagig@mellanox.com>
The iser RDMA_CM negotiation protocol is shared by
the initiator and the target, so have a shared header
for the defines and structure. Move relevant items from
the initiator and target headers.
When all the task data is sent as immediate data, we are
allowed to use the local_dma_lkey as it is not sent to
the wire.
We have in iser iser_sg_to_page_vec which has exactly
the same role as ib_sg_to_pages. Customize the page_vec
to hold a fake MR so we can reuse ib_sg_to_pages.
The iser_reg_ops structures are never modified, so declare them as const.
Done with the help of Coccinelle.
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
Acked-by: Sagi Grimberg <sagig@mellanox.com>
drivers/infiniband/ulp/iser/iser_verbs.c
Instead, use the cached copy of the attributes present on the device.
Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com>
Use the new CQ abstraction to simplify completions in the iSER
initiator.
Nicer this way.
We'll need it later with the new CQ abstraction. also switch
login bufs to void pointers.
Remove fastreg page list allocation as the page vector
is now private to the provider. Instead of constructing
the page list and fast_req work request, call ib_map_mr_sg
and construct ib_reg_wr.
Acked-by: Christoph Hellwig <hch@lst.de>
The block layer can reliably guarantee that SG lists won't
contain gaps (page unaligned) if a driver set the queue
virt_boundary.
With this setting the block layer will:
- refuse merges if bios are not aligned to the virtual boundary
- split bios/requests that are not aligned to the virtual boundary
- or, bounce buffer SG_IOs that are not aligned to the virtual boundary
Since iser is working in 4K page size, set the virt_boundary to
4K pages. With this setting, we can now safely remove the bounce
buffering logic in iser.
This patch split up struct ib_send_wr so that all non-trivial verbs
use their own structure which embedds struct ib_send_wr. This dramaticly
shrinks the size of a WR for most common operations:
sizeof(struct ib_send_wr) (old): 96
sizeof(struct ib_send_wr): 48
sizeof(struct ib_rdma_wr): 64
sizeof(struct ib_atomic_wr): 96
sizeof(struct ib_ud_wr): 88
sizeof(struct ib_fast_reg_wr): 88
sizeof(struct ib_bind_mw_wr): 96
sizeof(struct ib_sig_handover_wr): 80
And with Sagi's pending MR rework the fast registration WR will also be
down to a reasonable size:
sizeof(struct ib_fastreg_wr): 64
Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com> [srp, srpt]
Reviewed-by: Chuck Lever <chuck.lever@oracle.com> [sunrpc]
Tested-by: Haggai Eran <haggaie@mellanox.com>
Tested-by: Sagi Grimberg <sagig@mellanox.com>
Tested-by: Steve Wise <swise@opengridcomputing.com>
This module parameter forces memory registration even for
a continuous memory region. It is true by default as sending
an all-physical rkey with remote permissions might be insecure.
Chaning of send work requests benefits performance by
reducing the send queue lock contention (acquired in
ib_post_send) and saves us HW doorbells which is posted
only once.
Currently, in normal IO flows iser does not chain the CDB send
work request with the registration work request. Also in PI
flows, signature work requests are not chained as well.
Lets chain those and post only once.
iser support up to 512KB data transfer in a single scsi command.
This means that larger IOs will split to different request. While
iser can easily saturate FDR/EDR wires, some arrays are fine tuned
for 1MB (or larger) IO sizes, hence add an option to support larger
transfers (up to 8MB) if the device allows it.
Given that a few target implementations don't support data transfers
of more than 512KB by default and the fact that larger IO sizes require
more resources, we introduce a module parameter to determine the
maximum number of 512B sectors in a single scsi command.
Users that are interested in larger transfers can change this value given
that the target supports larger transfers.
At the moment, iser works in 4K pages granularity, In a later stage
we will get it to work with system page size instead.
IO operations that consists of N pages will need a page vector
of size N+1 in case the first SG element contains an offset. Given
that some devices allocates memory regions in powers of 2, this
means that allocating a region with N+1 pages, will result in
region resources allocation of the next power of 2. Since we don't
want that to happen, in case we are in the limit of IO size supported
and the first SG element has an offset, we align the SG list using a
bounce buffer (which is OK given that this is not likely to happen a lot).
Hard coded for now. This will allow to allocate different
sized MRs depending on the IO size needed (and device
capabilities).
This patch does not change any functionality.
iser_reg_rdma_mem_[fastreg|fmr] share a lot of code, and
logically do the same thing other than the buffer registration
method itself (iser_fast_reg_mr vs. iser_fast_reg_fmr).
The DIF logic is not implemented in the FMR flow as there is no
existing device that supports FMRs and Signature feature.
This patch unifies the flow in a single routine iser_reg_rdma_mem
and just split to fmr/frwr for the buffer registration itself.
Also, for symmetry reasons, unify iser_unreg_rdma_mem (which will
call the relevant device specific unreg routine).
Signed-off-by: Adir Lev <adirl@mellanox.com>
As for fmrs we will hold a single registration descriptor
as no need for multiple like in the frwr mode (descriptor
for each task). This change helps unifying the duplicate
registration code paths.
This will allow us to unify the memory registration code path between
the various methods which vary by the device capabilities. This change
will make it easier and less intrusive to remove fmr_pools from the
code when we'd want to.
The reason we use a single descriptor is to avoid taking a
redundant spinlock when working with FMRs.
We also change the signature of iser_reg_page_vec to make it match
iser_fast_reg_mr (and the future indirect registration method).
Instead of having it a part of the connection structure,
have it be under a dedicated (embedded) structure in the
connection. A logical separation of the registration pool
and the connection structure.
Move all the per-device function pointers to an easy
extensible iser_reg_ops structure that contains all
the iser registration operations.
Avoid struct names without iser_ prefix.
Have fast_reg_descriptor hold struct iser_reg_resources
(mr, frpl, valid flag). This will be useful when the
actual buffer registration routines will be passed with
the needed registration resources (i.e. iser_reg_resources)
without being aware of their nature (i.e. data or protection).
In order to achieve this, we remove reg_indicators flags container
and place specific flags (mr_valid) within iser_reg_resources struct.
We also place the sig_mr_valid and sig_protcted flags in iser_pi_context.
This patch also modifies iser_fast_reg_mr to receive the
reg_resources instead of the fast_reg_descriptor and a data/protection
indicator.
If iser_initialize_task_headers() routine failed before
dma mapping, we should not attempt to unmap in cleanup_task().
Fixes: 7414dde0a6c3a958e (IB/iser: Fix race between iser connection ...)
In some rare cases, IO operations may be not aligned to page
boundaries. This prevents iser from performing fast memory
registration. In order to overcome that iser uses a bounce
buffer to carry the transaction. We basically allocate a buffer
in the size of the transaction and perform a copy.
The buffer allocation using kmalloc is too restrictive since it
requires higher order (atomic) allocations for large transactions
(which may result in memory exhaustion fairly fast for some workloads).
We rewrite the bounce buffer code path to allocate scattered pages
and perform a copy between the transaction sg and the bounce sg.
Reported-by: Alex Lyakas <alex@zadarastorage.com>
No need to keep lkey, va, len variables, we can keep
them as struct ib_sge. This will help when we change the
memory registration logic.
Instead of open-coding connection fastreg pool get/put,
we introduce iser_reg_desc[get|put] helpers.
We aren't setting these static as this will be a per-device
routine later on. Also, cleanup iser_unreg_rdma_mem_fastreg
a bit.
This struct members other than struct iser_mem_reg are unused,
so remove it altogether.
As memory registration/de-registration methods, lets
move them to their natural location. While we're at it,
make iser_reg_page_vec routine static.
No need to keep two iser_data_buf structures just in case we use
mem copy. We can avoid that just by adding a pointer to the original
sg. So keep only two iser_data_buf per command (data and protection)
and pass the relevant data_buf to bounce buffer routine.
We always unmap SGs with the same direction instead of unmapping
with the direction the mapping was done, fix that.
Fixes: 9a8b08fad2ef ("IB/iser: Generalize iser_unmap_task_data and [...]")
Signed-off-by: Roi Dayan <roid@mellanox.com>
Signed-off-by: Roland Dreier <roland@purestorage.com>
And fix a checkpatch warning.
No reason to settle with four, can use the min between device max comp
vectors and number of cores.
It is enough to check mem_h pointer assignment, mem_h == NULL will
indicate that buffer is not registered using mr.
Fix a regression was introduced in commit 6df5a128f0fd ("IB/iser:
Suppress scsi command send completions").
The sig_count was wrongly set to be static variable, thus it is
possible that we won't reach to (sig_count % ISER_SIGNAL_BATCH) == 0
condition (due to races) and the send queue will be overflowed.
Instead keep sig_count per connection. We don't need it to be atomic
as we are safe under the iscsi session frwd_lock taken by libiscsi on
the queuecommand path.
Fixes: 6df5a128f0fd ("IB/iser: Suppress scsi command send completions")
Re-adjust max CQEs per CQ and max send_wr per QP according
to the resource limits supported by underlying hardware.
Signed-off-by: Minh Tran <minhduc.tran@emulex.com>
Signed-off-by: Jayamohan Kallickal <jayamohan.kallickal@emulex.com>
Update the driver version and add Sagi Grimberg as maintainer
- iser_hdr
- iser_data_buf
- iser_mem_reg
- iser_regd_buf
- iser_tx_desc
- iser_rx_desc
- iser_device
- iser_pi_context
- iser_conn
- ib_conn
- iser_comp
- iscsi_iser_task
- iser_global
While we're at it, change nit alignments in this file
Change logging: "iser:XXXX" to "iser: XXXX"
Singal completion of every 32 scsi commands and suppress all the rest.
We don't do anything upon getting the completion so no need to "just
consume" it. Cleanup of scsi command is done in cleanup_task callback.
Still keep dataout and control send completions as we may need to
cleanup there. This helps reducing the amount of interrupts/completions
in the IO path.
Poll in batch of 16. Since we don't want it on the stack, keep under
iser completion context (iser_comp).
Avoid post_send counting (atomic) in the IO path just to keep track of
how many completions we need to consume. Use a beacon post to indicate
that all prior posts completed.
