[ Upstream commit b448bf9a0df6093dbadac36979a55ce4e012a677 ]
There are some memory allocation calls in hfi1_create_ctxtdata()
that do not use the numa function parameter. This
can cause cache lines to be filled over QPI.
Reviewed-by: Mike Marciniszyn <mike.marciniszyn@intel.com>
Signed-off-by: Sebastian Sanchez <sebastian.sanchez@intel.com>
Signed-off-by: Dennis Dalessandro <dennis.dalessandro@intel.com>
Signed-off-by: Doug Ledford <dledford@redhat.com>
[ Upstream commit 39e2afa8d042a53d855137d4c5a689a6f5492b39 ]
After extended testing, it was found that the previous PCIe Gen
3 recipe, which used adaptive CTLE with Preset 4, could cause an
NMI/Surprise Link Down in about 1 in 100 to 1 in 1000 power cycles on
some platforms. New EV data combined with extensive empirical data
indicates that the new recipe should use static CTLE with Preset 6 for
all integrated silicon SKUs.
Fixes: c3f8de0b334c ("IB/hfi1: Add static PCIe Gen3 CTLE tuning")
Reviewed-by: Dennis Dalessandro <dennis.dalessandro@intel.com>
Signed-off-by: Easwar Hariharan <easwar.hariharan@intel.com>
commit f6aafac184a3e46e919769dd4faa8bf0dc436534 upstream.
aarch64-linux-gcc-7 complains about code it doesn't fully understand:
drivers/infiniband/hw/qib/qib_iba7322.c: In function 'qib_7322_txchk_change':
include/asm-generic/bitops/non-atomic.h:105:35: error: 'shadow' may be used uninitialized in this function [-Werror=maybe-uninitialized]
The code is right, and despite trying hard, I could not come up with a version
that I liked better than just adding a fake initialization here to shut up the
warning.
Fixes: f931551bafe1 ("IB/qib: Add new qib driver for QLogic PCIe InfiniBand adapters")
Acked-by: Ira Weiny <ira.weiny@intel.com>
[ Upstream commit c586071d1dc8227a7182179b8e50ee92cc43f6d2 ]
In order to resolve a situation where a few process delete
the same list element in sequence and cause panic, list_del
is replaced with list_del_init. In this case if the first
process that calls list_del releases the lock before acquiring
it again, other processes who can acquire the lock will call
list_del_init.
Fixes: b63b70d87741 ("IPoIB: Use a private hash table for path lookup")
Signed-off-by: Feras Daoud <ferasda@mellanox.com>
Signed-off-by: Erez Shitrit <erezsh@mellanox.com>
Reviewed-by: Alex Vesker <valex@mellanox.com>
Signed-off-by: Leon Romanovsky <leon@kernel.org>
Reviewed-by: Yuval Shaia <yuval.shaia@oracle.com>
[ Upstream commit 89a3987ab7a923c047c6dec008e60ad6f41fac22 ]
The ipoib_vlan_add function calls rtnl_unlock after free_netdev,
rtnl_unlock not only releases the lock, but also calls netdev_run_todo.
The latter function browses the net_todo_list array and completes the
unregistration of all its net_device instances. If we call free_netdev
before rtnl_unlock, then netdev_run_todo call over the freed device causes
panic.
To fix, move rtnl_unlock call before free_netdev call.
Fixes: 9baa0b036410 ("IB/ipoib: Add rtnl_link_ops support")
Cc: Or Gerlitz <ogerlitz@mellanox.com>
[ Upstream commit 1c3098cdb05207e740715857df7b0998e372f527 ]
This patch fixes Deadlock while executing ipoib_vlan_delete.
The function takes the vlan_rwsem semaphore and calls
unregister_netdevice. The later function calls
ipoib_mcast_stop_thread that cause workqueue flush.
When the queue has one of the ipoib_ib_dev_flush_xxx events,
a deadlock occur because these events also tries to catch the
same vlan_rwsem semaphore.
To fix, unregister_netdevice should be called after releasing
the semaphore.
Fixes: cbbe1efa4972 ("IPoIB: Fix deadlock between ipoib_open() and child interface create")
[ Upstream commit b3a459961014b14c267544c327db033669493295 ]
Avoid that calling check_rkey() for mem->state == RXE_MEM_STATE_FREE
triggers an MR reference leak.
Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com>
Reviewed-by: Andrew Boyer <andrew.boyer@dell.com>
Cc: Moni Shoua <monis@mellanox.com>
[ Upstream commit 642c7cbcaf2ffc1e27f67eda3dc47347ac5aff37 ]
Since index values equal to or above 'range' can trigger memory
corruption, complain if index >= range.
commit 3d318605f5e32ff44fb290d9b67573b34213c4c8 upstream.
The listening endpoint should always be dereferenced at the end of
pass_accept_req().
Fixes: f86fac79afec ("RDMA/iw_cxgb4: atomic find and reference for listening endpoints")
Signed-off-by: Steve Wise <swise@opengridcomputing.com>
commit 8b1bbf36b7452c4acb20e91948eaa5e225ea6978 upstream.
If a listen create fails, then the server tid (stid) is incorrectly left
in the stid idr table, which can cause a touch-after-free if the stid
is looked up and the already freed endpoint is touched. So make sure
and remove it in the error path.
commit 79e25959403e6a79552db28a87abed34de32a1df upstream.
Commit eea40b8f624f ("infiniband: call ipv6 route lookup via the stub
interface") introduced a regression in address resolution when connecting
to IPv6 destination addresses. The old code called ip6_route_output(),
while the new code calls ipv6_stub->ipv6_dst_lookup(). The two are almost
the same, except that ipv6_dst_lookup() also calls ip6_route_get_saddr()
if the source address is in6addr_any.
This means that the test of ipv6_addr_any(&fl6.saddr) now never succeeds,
and so we never copy the source address out. This ends up causing
rdma_resolve_addr() to fail, because without a resolved source address,
cma_acquire_dev() will fail to find an RDMA device to use. For me, this
causes connecting to an NVMe over Fabrics target via RoCE / IPv6 to fail.
Fix this by copying out fl6.saddr if ipv6_addr_any() is true for the original
source address passed into addr6_resolve(). We can drop our call to
ipv6_dev_get_saddr() because ipv6_dst_lookup() already does that work.
Fixes: eea40b8f624 ("infiniband: call ipv6 route lookup via the stub interface")
Signed-off-by: Roland Dreier <roland@purestorage.com>
Acked-by: Paolo Abeni <pabeni@redhat.com>
Signed-off-by: Raju Rangoju <rajur@chelsio.com>
commit 5b0ef650bd0f820e922fcc42f1985d4621ae19cf upstream.
Section 9.7.7.2.5 of the 1.3 IBTA spec clearly says that receive
credits should never apply to RDMA write.
qib and hfi1 were doing that. The following situation will result
in a QP hang:
- A prior SEND or RDMA_WRITE with immmediate consumed the last
credit for a QP using RC receive buffer credits
- The prior op is acked so there are no more acks
- The peer ULP fails to post receive for some reason
- An RDMA write sees that the credits are exhausted and waits
- The peer ULP posts receive buffers
- The ULP posts a send or RDMA write that will be hung
The fix is to avoid the credit test for the RDMA write operation.
Reviewed-by: Kaike Wan <kaike.wan@intel.com>
Signed-off-by: Mike Marciniszyn <mike.marciniszyn@intel.com>
[ Upstream commit 3bcf96e0183f5c863657cb6ae9adad307a0f6071 ]
Function rx_data(), which handles ingress CPL_RX_DATA messages, was
always sending an RX_DATA_ACK with the goal of updating the credits.
However, if the RDMA connection is moved out of FPDU mode abruptly,
then it is possible for iw_cxgb4 to process queued RX_DATA CPLs after HW
has aborted the connection. These CPLs should not trigger RX_DATA_ACKS.
If they do, HW can see a READ after DELETE of the DB_LE hash entry for
the tid and post a LE_DB HashTblMemCrcError.
[ Upstream commit 10b1c04e92229ebeb38ccd0dcf2b6d3ec73c0575 ]
Demoting simple flow steering rule priority (for DPDK) was achieved by
wrapping FW commands MLX4_QP_FLOW_STEERING_ATTACH/DETACH for the PF
as well, and forcing the priority to MLX4_DOMAIN_NIC in the wrapper
function for the PF and all VFs.
In function mlx4_ib_create_flow(), this change caused the main rule
creation for the PF to be wrapped, while it left the associated
tunnel steering rule creation unwrapped for the PF.
This mismatch caused rule deletion failures in mlx4_ib_destroy_flow()
for the PF when the detach wrapper function did not find the associated
tunnel-steering rule (since creation of that rule for the PF did not
go through the wrapper function).
Fix this by setting MLX4_QP_FLOW_STEERING_ATTACH/DETACH to be "native"
(so that the PF invocation does not go through the wrapper), and perform
the required priority demotion for the PF in the mlx4_ib_create_flow()
code path.
Fixes: 48564135cba8 ("net/mlx4_core: Demote simple multicast and broadcast flow steering rules")
Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il>
Signed-off-by: Tariq Toukan <tariqt@mellanox.com>
commit 5a7a88f1b488e4ee49eb3d5b82612d4d9ffdf2c3 upstream.
The port number is only valid if IB_QP_PORT is set in the mask.
So only check port number if it is valid to prevent modify_qp from
failing due to an invalid port number.
Fixes: 5ecce4c9b17b("Check port number supplied by user verbs cmds")
Reviewed-by: Steve Wise <swise@opengridcomputing.com>
Signed-off-by: Mustafa Ismail <mustafa.ismail@intel.com>
Tested-by: Mike Marciniszyn <mike.marciniszyn@intel.com>
commit 99975cd4fda52974a767aa44fe0b1a8f74950d9d upstream.
ib_map_mr_sg() can pass an SG-list to .map_mr_sg() that is larger
than what fits into a single MR. .map_mr_sg() must not attempt to
map more SG-list elements than what fits into a single MR.
Hence make sure that mlx5_ib_sg_to_klms() does not write outside
the MR klms[] array.
Fixes: b005d3164713 ("mlx5: Add arbitrary sg list support")
Reviewed-by: Max Gurtovoy <maxg@mellanox.com>
Cc: Sagi Grimberg <sagi@grimberg.me>
Cc: Leon Romanovsky <leonro@mellanox.com>
Cc: Israel Rukshin <israelr@mellanox.com>
Acked-by: Leon Romanovsky <leonro@mellanox.com>
Reviewed-by: Sagi Grimberg <sagi@grimberg.me>
commit a62ab66b13a0f9bcb17b7b761f6670941ed5cd62 upstream.
Initialize the port_num for iWARP in rdma_init_qp_attr.
commit fce50a2fa4e9c6e103915c351b6d4a98661341d6 upstream.
This patch fixes a NULL pointer dereference in isert_login_recv_done()
of isert_conn->cm_id due to isert_cma_handler() -> isert_connect_error()
resetting isert_conn->cm_id = NULL during a failed login attempt.
As per Sagi, we will always see the completion of all recv wrs posted
on the qp (given that we assigned a ->done handler), this is a FLUSH
error completion, we just don't get to verify that because we deref
NULL before.
The issue here, was the assumption that dereferencing the connection
cm_id is always safe, which is not true since:
commit 4a579da2586bd3b79b025947ea24ede2bbfede62
Author: Sagi Grimberg <sagig@mellanox.com>
Date: Sun Mar 29 15:52:04 2015 +0300
iser-target: Fix possible deadlock in RDMA_CM connection error
As I see it, we have a direct reference to the isert_device from
isert_conn which is the one-liner fix that we actually need like
we do in isert_rdma_read_done() and isert_rdma_write_done().
Reported-by: Andrea Righi <righi.andrea@gmail.com>
Tested-by: Andrea Righi <righi.andrea@gmail.com>
commit bebb2a473a43c8f84a8210687d1cbdde503046d7 upstream.
In function addr_resolve() the namespace is a required input parameter
and not an output. It is passed later for searching the routing table
and device addresses. Also, it shouldn't be copied back to the caller.
Fixes: 565edd1d5555 ('IB/addr: Pass network namespace as a parameter')
Signed-off-by: Moni Shoua <monis@mellanox.com>
commit c8c16d3bae967f1c7af541e8d016e5c51e4f010a upstream.
Under heavy iser target(scst) start/stop stress during login/logout
on iser intitiator side happened trace call provided below.
The function iscsi_iser_slave_alloc iser_conn pointer could be NULL,
due to the fact that function iscsi_iser_conn_stop can be called before
and free iser connection. Let's protect that flow by introducing global mutex.
BUG: unable to handle kernel paging request at 0000000000001018
IP: [<ffffffffc0426f7e>] iscsi_iser_slave_alloc+0x1e/0x50 [ib_iser]
Call Trace:
? scsi_alloc_sdev+0x242/0x300
scsi_probe_and_add_lun+0x9e1/0xea0
? kfree_const+0x21/0x30
? kobject_set_name_vargs+0x76/0x90
? __pm_runtime_resume+0x5b/0x70
__scsi_scan_target+0xf6/0x250
scsi_scan_target+0xea/0x100
iscsi_user_scan_session.part.13+0x101/0x130 [scsi_transport_iscsi]
? iscsi_user_scan_session.part.13+0x130/0x130 [scsi_transport_iscsi]
iscsi_user_scan_session+0x1e/0x30 [scsi_transport_iscsi]
device_for_each_child+0x50/0x90
iscsi_user_scan+0x44/0x60 [scsi_transport_iscsi]
store_scan+0xa8/0x100
? common_file_perm+0x5d/0x1c0
dev_attr_store+0x18/0x30
sysfs_kf_write+0x37/0x40
kernfs_fop_write+0x12c/0x1c0
__vfs_write+0x18/0x40
vfs_write+0xb5/0x1a0
SyS_write+0x55/0xc0
Fixes: 318d311e8f01 ("iser: Accept arbitrary sg lists mapping if the device supports it")
Signed-off-by: Vladimir Neyelov <vladimirn@mellanox.com>
Reviewed-by: Sagi Grimberg <sagi@grimbeg.me>
commit 5ecce4c9b17bed4dc9cb58bfb10447307569b77b upstream.
The ib_uverbs_create_ah() ind ib_uverbs_modify_qp() calls receive
the port number from user input as part of its attributes and assumes
it is valid. Down on the stack, that parameter is used to access kernel
data structures. If the value is invalid, the kernel accesses memory
it should not. To prevent this, verify the port number before using it.
BUG: KASAN: use-after-free in ib_uverbs_create_ah+0x6d5/0x7b0
Read of size 4 at addr ffff880018d67ab8 by task syz-executor/313
BUG: KASAN: slab-out-of-bounds in modify_qp.isra.4+0x19d0/0x1ef0
Read of size 4 at addr ffff88006c40ec58 by task syz-executor/819
Fixes: 67cdb40ca444 ("[IB] uverbs: Implement more commands")
Cc: Yevgeny Kliteynik <kliteyn@mellanox.com>
Cc: Tziporet Koren <tziporet@mellanox.com>
Cc: Alex Polak <alexpo@mellanox.com>
Signed-off-by: Boris Pismenny <borisp@mellanox.com>
commit 5b0ff9a00755d4d9c209033a77f1ed8f3186fe5c upstream.
hns_roce_v1_cq_set_ci() calls roce_set_bit() on an uninitialized field,
which will then change only a few of its bits, causing a warning with
the latest gcc:
infiniband/hw/hns/hns_roce_hw_v1.c: In function 'hns_roce_v1_cq_set_ci':
infiniband/hw/hns/hns_roce_hw_v1.c:1854:23: error: 'doorbell[1]' is used uninitialized in this function [-Werror=uninitialized]
roce_set_bit(doorbell[1], ROCEE_DB_OTHERS_H_ROCEE_DB_OTH_HW_SYNS_S, 1);
The code is actually correct since we always set all bits of the
port_vlan field, but gcc correctly points out that the first
access does contain uninitialized data.
This initializes the field to zero first before setting the
individual bits.
Fixes: 9a4435375cd1 ("IB/hns: Add driver files for hns RoCE driver")
commit de8d6e02efbdb259c67832ccf027d7ace9b91d5d upstream.
The logic was broken as it failed to update the response length for
architectures with PAGE_SIZE larger than 4kB. As a result further
extension of the ucontext response struct would fail.
Fixes: d69e3bcf7976 ('IB/mlx5: Mmap the HCA's core clock register to user-space')
Signed-off-by: Eli Cohen <eli@mellanox.com>
Reviewed-by: Matan Barak <matanb@mellanox.com>
Signed-off-by: Saeed Mahameed <saeedm@mellanox.com>
[ Upstream commit 59e8970b3798e4cbe575ed9cf4d53098760a2a86 ]
Return the maximum supported amount of inline data, not the qp's current
configured inline data size, when filling out the results of a query
qp call.
Signed-off-by: Ram Amrani <Ram.Amrani@cavium.com>
Signed-off-by: Michal Kalderon <Michal.Kalderon@cavium.com>
[ Upstream commit c78c31496111f497b4a03f955c100091185da8b6 ]
It is normal to flush CQEs if the QP is in error state. Hence there's no
use in printing a message per CQE to dmesg.
[ Upstream commit 933e6dcaa0f65eb2f624ad760274020874a1f35e ]
Fail QP state transition from error to reset if SQ/RQ are not empty
and still in the process of flushing out the queued work entries.
[ Upstream commit 9c1e0228ab35e52d30abf4b5629c28350833fbcb ]
Free the PD if no internal resources were available. Move userspace
code under the relevant 'if'.
Signed-off-by: Ariel Elior <Ariel.Elior@cavium.com>
[ Upstream commit f449c7a2d822c2d81b5bcb2c50eec80796766726 ]
Relying on qede to trigger qedr on startup is problematic. When probing
both if qedr loads slowly then qede can assume qedr is missing and not
trigger it. This patch adds a triggering from qedr and protects against
a race via an atomic bit.
commit 1feb40067cf04ae48d65f728d62ca255c9449178 upstream.
The handling of IB_RDMA_WRITE_ONLY_WITH_IMMEDIATE will leak a memory
reference when a buffer cannot be allocated for returning the immediate
data.
The issue is that the rkey validation has already occurred and the RNR
nak fails to release the reference that was fruitlessly gotten. The
the peer will send the identical single packet request when its RNR
timer pops.
The fix is to release the held reference prior to the rnr nak exit.
This is the only sequence the requires both rkey validation and the
buffer allocation on the same packet.
Tested-by: Tadeusz Struk <tadeusz.struk@intel.com>
commit 224d71f910102c966cdcd782c97e096d5e26e4da upstream.
The only context that frees user_exp_rcv data structures is the last
context closed (from a sub-context set). This leaks the allocations
from the other sub-contexts. Separate the common frees from the
specific frees and call them at the appropriate time.
Using KEDR to check for memory leaks we get:
Before test:
[leak_check] Possible leaks: 25
After test:
[leak_check] Possible leaks: 31 (6 leaked data structures)
After patch applied (before and after test have the same value)
Each leak is 192 + 13440 + 6720 = 20352 bytes per sub-context.
Signed-off-by: Michael J. Ruhl <michael.j.ruhl@intel.com>
commit 94679061dcdddbafcf24e3bfb526e54dedcc2f2f upstream.
If the eager buffer allocation fails, it is necessary to return
an error code.
commit eea40b8f624f25cbc02d55f2d93203f60cee9341 upstream.
The infiniband address handle can be triggered to resolve an ipv6
address in response to MAD packets, regardless of the ipv6
module being disabled via the kernel command line argument.
That will cause a call into the ipv6 routing code, which is not
initialized, and a conseguent oops.
This commit addresses the above issue replacing the direct lookup
call with an indirect one via the ipv6 stub, which is properly
initialized according to the ipv6 status (e.g. if ipv6 is
disabled, the routing lookup fails gracefully)
Signed-off-by: Paolo Abeni <pabeni@redhat.com>
commit 0a49f2c31c3efbeb0de3e4b5598764887f629be2 upstream.
In case we got an initial sg_offset, we need to
account for it in the mr length.
Fixes: ff2ba9936591 ("IB/core: Add passing an offset into the SG to ib_map_mr_sg")
Signed-off-by: Sagi Grimberg <sagi@grimberg.me>
Tested-by: Israel Rukshin <israelr@mellanox.com>
commit b6eac931b9bb2bce4db7032c35b41e5e34ec22a5 upstream.
The driver progress routines can call cond_resched() when
a timeslice is exhausted and irqs are enabled.
If the ULP had been holding a spin lock without disabling irqs and
the post send directly called the progress routine, the cond_resched()
could yield allowing another thread from the same ULP to deadlock
on that same lock.
Correct by replacing the current hfi1_do_send() calldown with a unique
one for post send and adding an argument to hfi1_do_send() to indicate
that the send engine is running in a thread. If the routine is not
running in a thread, avoid calling cond_resched().
Fixes: Commit 831464ce4b74 ("IB/hfi1: Don't call cond_resched in atomic mode when sending packets")
commit fb7a91746af18b2ebf596778b38a709cdbc488d3 upstream.
A warning message during SRIOV multicast cleanup should have actually been
a debug level message. The condition generating the warning does no harm
and can fill the message log.
In some cases, during testing, some tests were so intense as to swamp the
message log with these warning messages, causing a stall in the console
message log output task. This stall caused an NMI to be sent to all CPUs
(so that they all dumped their stacks into the message log).
Aside from the message flood causing an NMI, the tests all passed.
Once the message flood which caused the NMI is removed (by reducing the
warning message to debug level), the NMI no longer occurs.
Sample message log (console log) output illustrating the flood and
resultant NMI (snippets with comments and modified with ... instead
of hex digits, to satisfy checkpatch.pl):
<mlx4_ib> _mlx4_ib_mcg_port_cleanup: ... WARNING: group refcount 1!!!...
*** About 4000 almost identical lines in less than one second ***
INFO: rcu_sched detected stalls on CPUs/tasks: { 17} (...)
*** { 17} above indicates that CPU 17 was the one that stalled ***
sending NMI to all CPUs:
NMI backtrace for cpu 17
CPU: 17 PID: 45909 Comm: kworker/17:2
Hardware name: HP ProLiant DL360p Gen8, BIOS P71 09/08/2013
Workqueue: events fb_flashcursor
task: ffff880478...... ti: ffff88064e...... task.ti: ffff88064e......
RIP: 0010:[ffffffff81......] [ffffffff81......] io_serial_in+0x15/0x20
RSP: 0018:ffff88064e257cb0 EFLAGS: 00000002
RAX: 0000000000...... RBX: ffffffff81...... RCX: 0000000000......
RDX: 0000000000...... RSI: 0000000000...... RDI: ffffffff81......
RBP: ffff88064e...... R08: ffffffff81...... R09: 0000000000......
R10: 0000000000...... R11: ffff88064e...... R12: 0000000000......
R13: 0000000000...... R14: ffffffff81...... R15: 0000000000......
FS: 0000000000......(0000) GS:ffff8804af......(0000) knlGS:000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080......
CR2: 00007f2a2f...... CR3: 0000000001...... CR4: 0000000000......
DR0: 0000000000...... DR1: 0000000000...... DR2: 0000000000......
DR3: 0000000000...... DR6: 00000000ff...... DR7: 0000000000......
Stack:
ffff88064e...... ffffffff81...... ffffffff81...... 0000000000......
ffffffff81...... ffff88064e...... ffffffff81...... ffffffff81......
ffffffff81...... ffff88064e...... ffffffff81...... 0000000000......
Call Trace:
[<ffffffff813d099b>] wait_for_xmitr+0x3b/0xa0
[<ffffffff813d0b5c>] serial8250_console_putchar+0x1c/0x30
[<ffffffff813d0b40>] ? serial8250_console_write+0x140/0x140
[<ffffffff813cb5fa>] uart_console_write+0x3a/0x80
[<ffffffff813d0aae>] serial8250_console_write+0xae/0x140
[<ffffffff8107c4d1>] call_console_drivers.constprop.15+0x91/0xf0
[<ffffffff8107d6cf>] console_unlock+0x3bf/0x400
[<ffffffff813503cd>] fb_flashcursor+0x5d/0x140
[<ffffffff81355c30>] ? bit_clear+0x120/0x120
[<ffffffff8109d5fb>] process_one_work+0x17b/0x470
[<ffffffff8109e3cb>] worker_thread+0x11b/0x400
[<ffffffff8109e2b0>] ? rescuer_thread+0x400/0x400
[<ffffffff810a5aef>] kthread+0xcf/0xe0
[<ffffffff810a5a20>] ? kthread_create_on_node+0x140/0x140
[<ffffffff81645858>] ret_from_fork+0x58/0x90
Code: 48 89 e5 d3 e6 48 63 f6 48 03 77 10 8b 06 5d c3 66 0f 1f 44 00 00 66 66 66 6
As indicated in the stack trace above, the console output task got swamped.
Fixes: b9c5d6a64358 ("IB/mlx4: Add multicast group (MCG) paravirtualization for SR-IOV")
commit 99e68909d5aba1861897fe7afc3306c3c81b6de0 upstream.
In mlx4_ib_add, procedure mlx4_ib_alloc_eqs is called to allocate EQs.
However, in the mlx4_ib_add error flow, procedure mlx4_ib_free_eqs is not
called to free the allocated EQs.
Fixes: e605b743f33d ("IB/mlx4: Increase the number of vectors (EQs) available for ULPs")
commit 771a52584096c45e4565e8aabb596eece9d73d61 upstream.
When udev renames the netdev devices, ipoib debugfs entries does not
get renamed. As a result, if subsequent probe of ipoib device reuse the
name then creating a debugfs entry for the new device would fail.
Also, moved ipoib_create_debug_files and ipoib_delete_debug_files as part
of ipoib event handling in order to avoid any race condition between these.
Fixes: 1732b0ef3b3a ([IPoIB] add path record information in debugfs)
Signed-off-by: Vijay Kumar <vijay.ac.kumar@oracle.com>
Signed-off-by: Shamir Rabinovitch <shamir.rabinovitch@oracle.com>
Reviewed-by: Mark Bloch <markb@mellanox.com>
commit 8561eae60ff9417a50fa1fb2b83ae950dc5c1e21 upstream.
The Infiniband spec defines "A multicast address is defined by a
MGID and a MLID" (section 10.5). Currently the MLID value is not
validated.
Add check to verify that the MLID value is in the correct address
range.
Fixes: 0c33aeedb2cf ("[IB] Add checks to multicast attach and detach")
Reviewed-by: Ira Weiny <ira.weiny@intel.com>
Reviewed-by: Dasaratharaman Chandramouli <dasaratharaman.chandramouli@intel.com>
Reviewed-by: Leon Romanovsky <leonro@mellanox.com>
commit b312be3d87e4c80872cbea869e569175c5eb0f9a upstream.
The kernel commit cited below restructured ib device management
so that the device kobject is initialized in ib_alloc_device.
As part of the restructuring, the kobject is now initialized in
procedure ib_alloc_device, and is later added to the device hierarchy
in the ib_register_device call stack, in procedure
ib_device_register_sysfs (which calls device_add).
However, in the ib_device_register_sysfs error flow, if an error
occurs following the call to device_add, the cleanup procedure
device_unregister is called. This call results in the device object
being deleted -- which results in various use-after-free crashes.
The correct cleanup call is device_del -- which undoes device_add
without deleting the device object.
The device object will then (correctly) be deleted in the
ib_register_device caller's error cleanup flow, when the caller invokes
ib_dealloc_device.
Fixes: 55aeed06544f6 ("IB/core: Make ib_alloc_device init the kobject")
commit 45bded2c216da6010184ac5ebe88c27f73439009 upstream.
Make sure that the Q counters are supported by the FW before trying
to allocate/deallocte them, this will avoid driver load failure when
they aren't supported by the FW.
Fixes: 0837e86a7a34 ('IB/mlx5: Add per port counters')
Signed-off-by: Kamal Heib <kamalh@mellanox.com>
commit 0a6fdbdeb1c25e31763c1fb333fa2723a7d2aba6 upstream.
Avoid that srp_process_rsp() overwrites the status information
in ch if the SRP target response timed out and processing of
another task management function has already started. Avoid that
issuing multiple task management functions concurrently triggers
list corruption. This patch prevents that the following stack
trace appears in the system log:
WARNING: CPU: 8 PID: 9269 at lib/list_debug.c:52 __list_del_entry_valid+0xbc/0xc0
list_del corruption. prev->next should be ffffc90004bb7b00, but was ffff8804052ecc68
CPU: 8 PID: 9269 Comm: sg_reset Tainted: G W 4.10.0-rc7-dbg+ #3
Call Trace:
dump_stack+0x68/0x93
__warn+0xc6/0xe0
warn_slowpath_fmt+0x4a/0x50
wait_for_completion_timeout+0x12e/0x170
srp_send_tsk_mgmt+0x1ef/0x2d0 [ib_srp]
srp_reset_device+0x5b/0x110 [ib_srp]
scsi_ioctl_reset+0x1c7/0x290
scsi_ioctl+0x12a/0x420
sd_ioctl+0x9d/0x100
blkdev_ioctl+0x51e/0x9f0
block_ioctl+0x38/0x40
do_vfs_ioctl+0x8f/0x700
SyS_ioctl+0x3c/0x70
entry_SYSCALL_64_fastpath+0x18/0xad
Cc: Max Gurtovoy <maxg@mellanox.com>
Cc: Laurence Oberman <loberman@redhat.com>
Cc: Steve Feeley <Steve.Feeley@sandisk.com>
commit 6cb72bc1b40bb2c1750ee7a5ebade93bed49a5fb upstream.
After srp_process_rsp() returns there is a short time during which
the scsi_host_find_tag() call will return a pointer to the SCSI
command that is being completed. If during that time a duplicate
response is received, avoid that the following call stack appears:
BUG: unable to handle kernel NULL pointer dereference at (null)
IP: srp_recv_done+0x450/0x6b0 [ib_srp]
Oops: 0000 [#1] SMP
CPU: 10 PID: 0 Comm: swapper/10 Not tainted 4.10.0-rc7-dbg+ #1
Call Trace:
<IRQ>
__ib_process_cq+0x4b/0xd0 [ib_core]
ib_poll_handler+0x1d/0x70 [ib_core]
irq_poll_softirq+0xba/0x120
__do_softirq+0xba/0x4c0
irq_exit+0xbe/0xd0
smp_apic_timer_interrupt+0x38/0x50
apic_timer_interrupt+0x90/0xa0
</IRQ>
RIP: srp_recv_done+0x450/0x6b0 [ib_srp] RSP: ffff88046f483e20
commit d6c58dc40fec35ff6cdb350b53bce0fcf9143709 upstream.
Tests have shown that the following error message is reported when
using SG-GAPS registration with an mlx5 adapter:
scsi host1: ib_srp: failed RECV status WR flushed (5) for CQE ffff880bd4270eb0
00000000 00000000 00000000 00000000
00000000 0f007806 2500002a ad9fafd1
scsi host1: ib_srp: reconnect succeeded
mlx5_0:dump_cqe:262:(pid 7369): dump error cqe
00000000 0f007806 25000032 00105dd0
scsi host1: ib_srp: failed FAST REG status memory management operation error (6) for CQE ffff880b92860138
Hence avoid using SG-GAPS memory registrations. Additionally,
always configure the blk_queue_virt_boundary() to avoid to trigger
a mapping failure when using adapters that support SG-GAPS (e.g.
mlx5).
Fixes: commit ad8e66b4a801 ("IB/srp: fix mr allocation when the device supports sg gaps")
Fixes: commit 509c5f33f4f6 ("IB/srp: Prevent mapping failures")
Reported-by: Laurence Oberman <loberman@redhat.com>
Cc: Mark Bloch <markb@mellanox.com>
Cc: Yuval Shaia <yuval.shaia@oracle.com>
commit 0fd27a88c2e4f548937fd7d93fc6e65c4ad7c278 upstream.
When we initialize buffer to create SRQ in kernel,
the number of pages was less than actually used in
following mlx5_fill_page_array().
Fixes: e126ba97dba9 ("mlx5: Add driver for Mellanox Connect-IB adapters")
Signed-off-by: Leon Romanovsky <leonro@mellanox.com>
Reviewed-by: Eli Cohen <eli@mellanox.com>
commit 2b0841766a898aba84630fb723989a77a9d3b4e6 upstream.
When sending packet to destination that was not resolved yet
via path query, the driver keeps the skb and tries to re-send it
again when the path is resolved.
But when re-sending via dev_queue_xmit the kernel doesn't call
to dev_hard_header, so IPoIB needs to keep 20 bytes in the skb
and to put the destination address inside them.
In that way the dev_start_xmit will have the correct destination,
and the driver won't take the destination from the skb->data, while
nothing exists there, which causes to packet be be dropped.
The test flow is:
1. Run the SM on remote node,
2. Restart the driver.
4. Ping some destination,
3. Observe that first ICMP request will be dropped.
Fixes: fc791b633515 ("IB/ipoib: move back IB LL address into the hard header")
Signed-off-by: Noa Osherovich <noaos@mellanox.com>
Tested-by: Yuval Shaia <yuval.shaia@oracle.com>
commit 0a0007f28304cb9fc87809c86abb80ec71317f20 upstream.
When calling set_mode from sys/fs, the call flow locks the sys/fs lock
first and then tries to lock rtnl_lock (when calling ipoib_set_mod).
On the other hand, the rmmod call flow takes the rtnl_lock first
(when calling unregister_netdev) and then tries to take the sys/fs
lock. Deadlock a->b, b->a.
The problem starts when ipoib_set_mod frees it's rtnl_lck and tries
to get it after that.
set_mod:
[<ffffffff8104f2bd>] ? check_preempt_curr+0x6d/0x90
[<ffffffff814fee8e>] __mutex_lock_slowpath+0x13e/0x180
[<ffffffff81448655>] ? __rtnl_unlock+0x15/0x20
[<ffffffff814fed2b>] mutex_lock+0x2b/0x50
[<ffffffff81448675>] rtnl_lock+0x15/0x20
[<ffffffffa02ad807>] ipoib_set_mode+0x97/0x160 [ib_ipoib]
[<ffffffffa02b5f5b>] set_mode+0x3b/0x80 [ib_ipoib]
[<ffffffff8134b840>] dev_attr_store+0x20/0x30
[<ffffffff811f0fe5>] sysfs_write_file+0xe5/0x170
[<ffffffff8117b068>] vfs_write+0xb8/0x1a0
[<ffffffff8117ba81>] sys_write+0x51/0x90
[<ffffffff8100b0f2>] system_call_fastpath+0x16/0x1b
rmmod:
[<ffffffff81279ffc>] ? put_dec+0x10c/0x110
[<ffffffff8127a2ee>] ? number+0x2ee/0x320
[<ffffffff814fe6a5>] schedule_timeout+0x215/0x2e0
[<ffffffff8127cc04>] ? vsnprintf+0x484/0x5f0
[<ffffffff8127b550>] ? string+0x40/0x100
[<ffffffff814fe323>] wait_for_common+0x123/0x180
[<ffffffff81060250>] ? default_wake_function+0x0/0x20
[<ffffffff8119661e>] ? ifind_fast+0x5e/0xb0
[<ffffffff814fe43d>] wait_for_completion+0x1d/0x20
[<ffffffff811f2e68>] sysfs_addrm_finish+0x228/0x270
[<ffffffff811f2fb3>] sysfs_remove_dir+0xa3/0xf0
[<ffffffff81273f66>] kobject_del+0x16/0x40
[<ffffffff8134cd14>] device_del+0x184/0x1e0
[<ffffffff8144e59b>] netdev_unregister_kobject+0xab/0xc0
[<ffffffff8143c05e>] rollback_registered+0xae/0x130
[<ffffffff8143c102>] unregister_netdevice+0x22/0x70
[<ffffffff8143c16e>] unregister_netdev+0x1e/0x30
[<ffffffffa02a91b0>] ipoib_remove_one+0xe0/0x120 [ib_ipoib]
[<ffffffffa01ed95f>] ib_unregister_device+0x4f/0x100 [ib_core]
[<ffffffffa021f5e1>] mlx4_ib_remove+0x41/0x180 [mlx4_ib]
[<ffffffffa01ab771>] mlx4_remove_device+0x71/0x90 [mlx4_core]
Fixes: 862096a8bbf8 ("IB/ipoib: Add more rtnl_link_ops callbacks")
commit f2625f7db4dd0bbd16a9c7d2950e7621f9aa57ad upstream.
cma_accept_iw() needs to return an error if conn_params is NULL.
Since this is coming from user space, we can crash.
Reported-by: Shaobo He <shaobo@cs.utah.edu>
Acked-by: Sean Hefty <sean.hefty@intel.com>
commit 647bf3d8a8e5777319da92af672289b2a6c4dc66 upstream.
Update the range check to avoid integer-overflow in edge case.
Resolves CVE 2016-8636.
Signed-off-by: Eyal Itkin <eyal.itkin@gmail.com>
commit 628f07d33c1f2e7bf31e0a4a988bb07914bd5e73 upstream.
Update the response's resid field when larger than MTU, instead of only
updating the local resid variable.
Fixes: 8700e3e7c485 ("Soft RoCE driver")
commit b414fa01c31318383ae29d9d23cb9ca4184bbd86 upstream.
The current QP FetchBurstMax value is 256B, which
is incorrect since a WR can exceed that value. The
result being a partial WR fetched by hardware, and
a fatal "bad WR" error posted by the SGE.
So bump the FetchBurstMax to 512B.
