path: root/drivers/input/evdev.c
2009-10-04headers: remove sched.h from poll.hAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-13Input: fix EVIOCGNAME/JSIOCGNAME regressionDaniel Mack
Commit 3d5cb60e ("Input: simplify name handling for certain input handles") introduced a regression for the EVIOCGNAME/JSIOCGNAME ioctl. Before this, patch, the platform device's name was given back to userspace which was good to identify devices. After this patch, the device is ("event%d", minor) which is not descriptive at all. This fixes the behaviour by taking dev->name. Reported-by: Sven Neumann <s.neumann@raumfeld.com> Signed-off-by: Daniel Mack <daniel@caiaq.de> Reviewed-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-06-19Input: synaptics - add support for reporting x/y resolutionTero Saarni
Synaptics uses anisotropic coordinate system. On some wide touchpads vertical resolution can be twice as high as horizontal which causes unequal sensitivity on x/y directions. Add support for reading the resolution with EVIOCGABS ioctl. Signed-off-by: Tero Saarni <tero.saarni@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-05-11Input: simplify name handling for certain input handlesThadeu Lima de Souza Cascardo
For evdev, joydev and mousedev, instead of having a separate character array holding name of the handle, use struct devce's name which is the same. Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-03-16Rationalize fasync return valuesJonathan Corbet
Most fasync implementations do something like: return fasync_helper(...); But fasync_helper() will return a positive value at times - a feature used in at least one place. Thus, a number of other drivers do: err = fasync_helper(...); if (err < 0) return err; return 0; In the interests of consistency and more concise code, it makes sense to map positive return values onto zero where ->fasync() is called. Cc: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2008-12-20Merge commit 'v2.6.28-rc9' into nextDmitry Torokhov
2008-11-01saner FASYNC handling on file closeAl Viro
As it is, all instances of ->release() for files that have ->fasync() need to remember to evict file from fasync lists; forgetting that creates a hole and we actually have a bunch that *does* forget. So let's keep our lives simple - let __fput() check FASYNC in file->f_flags and call ->fasync() there if it's been set. And lose that crap in ->release() instances - leaving it there is still valid, but we don't have to bother anymore. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-30Input: struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-10-27Input: refactor evdev 32bit compat to be shareable with uinputPhilip Langdale
Currently, evdev has working 32bit compatibility and uinput does not. uinput needs the input_event code that evdev uses, so let's refactor it so it can be shared. [dtor@mail.ru: add fix for force feedback compat issues] Signed-off-by: Philip Langdale <philipl@overt.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-08-19Input: evdev - fix printf() format for sizeofGeert Uytterhoeven
commit f2afa7711f8585ffc088ba538b9a510e0d5dca12 ("Input: paper over a bug in Synaptics X driver") introduced a compiler warning on 64-bit platforms, as sizeof() returns a size_t, not an (unsigned) int: | drivers/input/evdev.c: In function 'handle_eviocgbit': | drivers/input/evdev.c:684: warning: format '%d' expects type 'int', but argument 3 has type 'long unsigned int' Use the proper `z' modifier for size_t, and make the printf() formats for the sizes unsigned while we're at it. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-08-08Input: paper over a bug in Synaptics X driverDmitry Torokhov
2008-08-08Input: evdev - split EVIOCGBIT handlig into a separate functionLinus Torvalds
Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-06-30Input: fix force feedback upload issue in compat modeAdam Dawidowski
Force feedback upload of effects through the event device (ioctl EVIOCSFF) is not working in 32 bit applications running on 64-bit kernel due to the fact that struct ff_effect contains a pointer, resulting in the structure having different sizes in 64 and 32 bit programs and causing difference in ioctl numbers. [dtor@mail.ru: refactor to keep all ugliness in evdev] Signed-off-by: Adam Dawidowski <drake_ster@wp.pl> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-04-01Input: make sure input interfaces pin parent input devicesDmitry Torokhov
Recent driver core change causes references to parent devices being dropped early, at device_del() time, as opposed to when all children are freed. This causes oops in evdev with grabbed devices. Take the reference to the parent input device ourselves to ensure that it stays around long enough. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-03-30evdev: Release eventual input device grabs when getting disconnectedBjörn Steinbrink
When getting disconnected we need to release eventual grabs on the underlying input device as we also release the input device itself. Otherwise, we would try to release the grab when the client that requested it closes its handle, accessing the input device which might already be freed. Signed-off-by: Björn Steinbrink <B.Steinbrink@gmx.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-21Input: Add proper locking when changing device's keymapDmitry Torokhov
Take dev->event_lock to make sure that we don't race with input_event() and also force key up event when removing a key from keymap table. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2007-10-19get rid of input BIT* duplicate definesJiri Slaby
get rid of input BIT* duplicate defines use newly global defined macros for input layer. Also remove includes of input.h from non-input sources only for BIT macro definiton. Define the macro temporarily in local manner, all those local definitons will be removed further in this patchset (to not break bisecting). BIT macro will be globally defined (1<<x) Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: <dtor@mail.ru> Acked-by: Jiri Kosina <jkosina@suse.cz> Cc: <lenb@kernel.org> Acked-by: Marcel Holtmann <marcel@holtmann.org> Cc: <perex@suse.cz> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: <vernux@us.ibm.com> Cc: <malattia@linux.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-13Input: use full RCU APIDmitry Torokhov
RT guys alerted me to the fact that in their tree spinlocks are preemptible and it is better to use full RCU API (rcu_read_lock()/rcu_read_unlock()) to be safe. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2007-10-12Merge master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6Dmitry Torokhov
Conflicts: drivers/macintosh/adbhid.c
2007-10-12Input: fix open count handling in input interfacesOliver Neukum
If input_open_device() fails we should not leave interfaces marked as opened. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2007-08-30Input: evdev - implement proper lockingDmitry Torokhov
2007-07-31[MIPS] Fixup secure computing stuff.Ralf Baechle
2007-07-10Input: convert from class devices to standard devicesDmitry Torokhov
2007-06-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: reduce raciness when input handlers disconnect Input: ucb1x00 - do not access input_dev->private directly Input: logips2pp - fix typo in Kconfig Input: db9 - do not ignore dev2 module parameter
2007-06-03Input: reduce raciness when input handlers disconnectDmitry Torokhov
There is a race between input handler's release() and disconnect() methods: when input handler disconnects it wakes up all regular users and then process to walk user list to wake up async. users. While disconnect() walks the list release() removes elements of the same list causing oopses. While this is not a substibute for proper locking we can reduce odds of getting an oops if we wake up normal readers after walking the list. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2007-05-11Input: evdev - fix overflow in compat_ioctlKenichi Nagai
When exporting input device bitmaps via compat_ioctl on BIG_ENDIAN platforms evdev calculates data size incorrectly. This causes buffer overflow if user specifies buffer smaller than maxlen. Signed-off-by: Kenichi Nagai <kenichi3.nagai@toshiba.co.jp> Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Merge master.kernel.org:/pub/scm/linux/kernel/git/dtor/inputLinus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/dtor/input: Input: move USB miscellaneous devices under drivers/input/misc Input: move USB mice under drivers/input/mouse Input: move USB gamepads under drivers/input/joystick Input: move USB touchscreens under drivers/input/touchscreen Input: move USB tablets under drivers/input/tablet Input: i8042 - fix AUX port detection with some chips Input: aaed2000_kbd - convert to use polldev library Input: drivers/usb/input - usb_buffer_free() cleanup Input: synaptics - don't complain about failed resets Input: pull input.h into uinpit.h Input: drivers/usb/input - fix sparse warnings (signedness) Input: evdev - fix some sparse warnings (signedness, shadowing) Input: drivers/joystick - fix various sparse warnings Input: force feedback - make sure effect is present before playing
2007-05-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6Dmitry Torokhov
2007-05-04Merge branch 'for-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of master.kernel.org:/pub/scm/linux/kernel/git/dtor/input: (65 commits) Input: gpio_keys - add support for switches (EV_SW) Input: cobalt_btns - convert to use polldev library Input: add skeleton for simple polled devices Input: update some documentation Input: wistron - fix typo in keymap for Acer TM610 Input: add input_set_capability() helper Input: i8042 - add Fujitsu touchscreen/touchpad PNP IDs Input: i8042 - add Panasonic CF-29 to nomux list Input: lifebook - split into 2 devices Input: lifebook - add signature of Panasonic CF-29 Input: lifebook - activate 6-byte protocol on select models Input: lifebook - work properly on Panasonic CF-18 Input: cobalt buttons - separate device and driver registration Input: ati_remote - make button repeat sensitivity configurable Input: pxa27x - do not use deprecated SA_INTERRUPT flag Input: ucb1400 - make delays configurable Input: misc devices - switch to using input_dev->dev.parent Input: joysticks - switch to using input_dev->dev.parent Input: touchscreens - switch to using input_dev->dev.parent Input: mice - switch to using input_dev->dev.parent ... Fixed up conflicts with core device model removal of "struct subsystem" manually. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-03Input: evdev - fix some sparse warnings (signedness, shadowing)Dmitry Torokhov
2007-05-02remove "struct subsystem" as it is no longer neededGreg Kroah-Hartman
We need to work on cleaning up the relationship between kobjects, ksets and ktypes. The removal of 'struct subsystem' is the first step of this, especially as it is not really needed at all. Thanks to Kay for fixing the bugs in this patch. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-12Input: handlers - handle errors from input_open_device()Dmitry Torokhov
2007-04-12Input: handlers - rename 'list' to 'client'Dmitry Torokhov
The naming convention in input handlers was very confusing - client stuctures were called lists, regular lists were also called lists making anyone looking at the code go mad. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2007-04-12Input: rework handle creation codeDmitry Torokhov
- consolidate code for binding handlers to a device - return error codes from handlers connect() methods back to input core and log failures Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2007-03-14Input: add getkeycode and setkeycode methodsMarvin Raaijmakers
Allow drivers to implement their own get and set keycode methods. This will allow drivers to change their keymaps without allocating huge tables covering entire range of possible scancodes. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-09-14Input: make input_register_handler() return error codesDmitry Torokhov
2006-09-14Input: constify input coreDmitry Torokhov
2006-07-19Input: implement new force feedback interfaceAnssi Hannula
Implement a new force feedback interface, in which all non-driver-specific operations are separated to a common module. This includes handling effect type validations, locking, etc. The effects are now file descriptor specific instead of the previous strange half-process half-fd specific behaviour. The effect memory of devices is not emptied if the root user opens and closes the device while another user is using effects. This is a minor change and most likely no force feedback aware programs are affected by this negatively. Otherwise the userspace interface is left unaltered. Signed-off-by: Anssi Hannula <anssi.hannula@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-07-06Input: introduce input_inject_event() functionDmitry Torokhov
Create input_inject_event() function which is to be used by input handlers as opposed to input_event() which is reserved for drivers implementing input devices. The difference is that if device is "grabbed" by some process input_inject_event() will ignore events unless sent from the handle that is currently owns the device. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-07-06Input: remove accept method from input_devDmitry Torokhov
This method used to enforce exclusive access to iforce devices, but presenlty there are no known users of this method. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-06-26Input: fix formatting to better follow CodingStyleDmitry Torokhov
2006-06-23[PATCH] vfs: add lock owner argument to flush operationMiklos Szeredi
Pass the POSIX lock owner ID to the flush operation. This is useful for filesystems which don't want to store any locking state in inode->i_flock but want to handle locking/unlocking POSIX locks internally. FUSE is one such filesystem but I think it possible that some network filesystems would need this also. Also add a flag to indicate that a POSIX locking request was generated by close(), so filesystems using the above feature won't send an extra locking request in this case. Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-29Input: ressurect EVIOCGREP and EVIOCSREPDmitry Torokhov
While writing to an event device allows to set repeat rate for an individual input device there is no way to retrieve current settings so we need to ressurect EVIOCGREP. Also ressurect EVIOCSREP so we have a symmetrical interface. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-03-14Input: use kzalloc() throughout the codeEric Sesterhenn
Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-01-12[PATCH] ia64: task_pt_regs()Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-11[PATCH] x86_64: Implement is_compat_task the right wayAndi Kleen
By setting a flag during a 32bit system call only Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/dtor/inputLinus Torvalds
2006-01-06[PATCH] s390: cleanup KconfigMartin Schwidefsky
Sanitize some s390 Kconfig options. We have ARCH_S390, ARCH_S390X, ARCH_S390_31, 64BIT, S390_SUPPORT and COMPAT. Replace these 6 options by S390, 64BIT and COMPAT. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-11Input: evdev - consolidate compat and regular codeDmitry Torokhov
Compat and normal code mirror each other and are hard to maintain. When EV_SW was added compat_ioctl case was missed. Here is my attempt at consolidating the code. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
