drivers/input/input.c:1277: warning: 'input_dev_reset' defined but not used
Acked-by: Dmitry Torokhov <dtor@mail.ru>
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: add driver for Atmel AT42QT2160 Sensor Chip
Input: max7359 - use threaded IRQs
Input: add driver for Maxim MAX7359 key switch controller
Input: add driver for ADP5588 QWERTY I2C Keypad
Input: add touchscreen driver for MELFAS MCS-5000 controller
Input: add driver for OpenCores Keyboard Controller
Input: dm355evm_keys - remove dm355evm_keys_hardirq
Input: synaptics_i2c - switch to using __cancel_delayed_work()
Input: ad7879 - add support for AD7889
Input: atkbd - rely on input core to restore state on resume
Input: add generic suspend and resume for input devices
Input: libps2 - additional locking for i8042 ports
This allows subsytems to provide devtmpfs with non-default permissions
for the device node. Instead of the default mode of 0600, null, zero,
random, urandom, full, tty, ptmx now have a mode of 0666, which allows
non-privileged processes to access standard device nodes in case no
other userspace process applies the expected permissions.
This also fixes a wrong assignment in pktcdvd and a checkpatch.pl complain.
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Automatically turn off leds and sound effects as part of suspend
process and restore led state, sounds and repeat rate at resume.
Let attribute group vectors be declared "const". We'd
like to let most attribute metadata live in read-only
sections... this is a start.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
This adds support to the input core to report the proper device name to
userspace for their devices.
Signed-off-by: Jan Blunck <jblunck@suse.de>
There are a few multi-touch devices that support finger tracking
well in hardware, Stantum being the prime example. By exposing the
tracking ID in the MT protocol, evdev bandwidth and cpu usage in
user space can be reduced.
This patch adds the ABS_MT_TRACKING_ID to the MT protocol.
Signed-off-by: Henrik Rydberg <rydberg@euromail.se>
Tested-by: Stéphane Chatty <chatty@enac.fr>
In order to utilize the full power of the new multi-touch devices, a
way to report detailed finger data to user space is needed. This patch
adds a multi-touch (MT) protocol which allows drivers to report details
for an arbitrary number of fingers.
The driver sends a SYN_MT_REPORT event via the input_mt_sync() function
when a complete finger has been reported.
In order to stay compatible with existing applications, the data
reported in a finger packet must not be recognized as single-touch
events. In addition, all finger data must bypass input filtering,
since subsequent events of the same type refer to different fingers.
A set of ABS_MT events with the desired properties are defined. The
events are divided into categories, to allow for partial implementation.
The minimum set consists of ABS_MT_TOUCH_MAJOR, ABS_MT_POSITION_X and
ABS_MT_POSITION_Y, which allows for multiple fingers to be tracked.
If the device supports it, the ABS_MT_WIDTH_MAJOR may be used to provide
the size of the approaching finger. Anisotropy and direction may be
specified with ABS_MT_TOUCH_MINOR, ABS_MT_WIDTH_MINOR and
ABS_MT_ORIENTATION. Devices with more granular information may specify
general shapes as blobs, i.e., as a sequence of rectangular shapes
grouped together by a ABS_MT_BLOB_ID. Finally, the ABS_MT_TOOL_TYPE
may be used to specify whether the touching tool is a finger or a pen.
With the upcoming multi-touch interface as an example, there is
a need to make certain that all reported events actually get passed
to the event handler. This patch equips the input core with the
ability to bypass all filtering for certain EV_ABS events.
There is no need to issue serialize_rcu() after adding a new handle
to the list of handles associated with the device because new events
will "see" the new handle in the list immediately. Remove it so we
can boot a little bit faster.
Setting ->owner as done currently (pde->owner = THIS_MODULE) is racy
as correctly noted at bug #12454. Someone can lookup entry with NULL
->owner, thus not pinning enything, and release it later resulting
in module refcount underflow.
We can keep ->owner and supply it at registration time like ->proc_fops
and ->data.
But this leaves ->owner as easy-manipulative field (just one C assignment)
and somebody will forget to unpin previous/pin current module when
switching ->owner. ->proc_fops is declared as "const" which should give
some thoughts.
->read_proc/->write_proc were just fixed to not require ->owner for
protection.
rmmod'ed directories will be empty and return "." and ".." -- no harm.
And directories with tricky enough readdir and lookup shouldn't be modular.
We definitely don't want such modular code.
Removing ->owner will also make PDE smaller.
So, let's nuke it.
Kudos to Jeff Layton for reminding about this, let's say, oversight.
http://bugzilla.kernel.org/show_bug.cgi?id=12454
Tested-by: Alessio Sangalli <alesan@manoweb.com>
Whenever you press and then release a key, the CPU wakes up
three times:
* press
* release
* autorepeat timer exactly 250ms after press
The autorepeat timer has nothing to do, obviously, since you already
have released the key, so stop it on key release.
[dtor@mail.ru: This changes autorepeat behavior a bit since we now stop
autorepeat even if key that is being released is not the one that is
being auto-repeated, but I believe the new behavior is better.]
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
Use proc_create()/proc_create_data() to make sure that ->proc_fops and ->data
be setup before gluing PDE to main tree.
Signed-off-by: Denis V. Lunev <den@openvz.org>
Cc: Greg Kroah-Hartman <gregkh@suse.de>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Peter Osterlund <petero2@telia.com>
Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
Cc: Dmitry Torokhov <dtor@mail.ru>
Cc: Neil Brown <neilb@suse.de>
Cc: Mauro Carvalho Chehab <mchehab@infradead.org>
Cc: Bjorn Helgaas <bjorn.helgaas@hp.com>
Cc: Alessandro Zummo <a.zummo@towertech.it>
Remove proc_bus export and variable itself. Using pathnames works fine
and is slightly more understandable and greppable.
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de>
Cdev field was obsolete and provided only for backward compatibility
since conversion of input core from class devices to regular devices.
It is time to remove it.
Take dev->event_lock to make sure that we don't race with input_event() and
also force key up event when removing a key from keymap table.
input_handle_event() used to pass EV_PWR events to event handlers
but no longer does so in 2.6.23. Modules to trigger power management
events based on input power events exist but rely on the EV_PWR events
being passed to the input event handlers.
Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com>
get rid of input BIT* duplicate defines
use newly global defined macros for input layer. Also remove includes of
input.h from non-input sources only for BIT macro definiton. Define the
macro temporarily in local manner, all those local definitons will be
removed further in this patchset (to not break bisecting).
BIT macro will be globally defined (1<<x)
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
Cc: <dtor@mail.ru>
Acked-by: Jiri Kosina <jkosina@suse.cz>
Cc: <lenb@kernel.org>
Acked-by: Marcel Holtmann <marcel@holtmann.org>
Cc: <perex@suse.cz>
Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Cc: <vernux@us.ibm.com>
Cc: <malattia@linux.it>
RT guys alerted me to the fact that in their tree spinlocks
are preemptible and it is better to use full RCU API
(rcu_read_lock()/rcu_read_unlock()) to be safe.
drivers/macintosh/adbhid.c
This changes the uevent buffer functions to use a struct instead of a
long list of parameters. It does no longer require the caller to do the
proper buffer termination and size accounting, which is currently wrong
in some places. It fixes a known bug where parts of the uevent
environment are overwritten because of wrong index calculations.
Many thanks to Mathieu Desnoyers for finding bugs and improving the
error handling.
Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca>
Cc: Cornelia Huck <cornelia.huck@de.ibm.com>
Also add some kerneldoc documentation to input.h
This is essentially just a renaming of the existing functions
as copies of seq_list_start() and seq_list_next() already existed
in the input.c.
Signed-off-by: Pavel Emelianov <xemul@openvz.org>
Remove includes of <linux/smp_lock.h> where it is not used/needed.
Suggested by Al Viro.
Builds cleanly on x86_64, i386, alpha, ia64, powerpc, sparc,
sparc64, and arm (all 59 defconfigs).
Add input_set_capability() helper used to indicate that an input
device supports a certain event without need to manipulate bitmaps
directly.
In preparation to switching to struct device and class device
going away provide an alias to allow drivers that create devices
to use either input_dev->cdev.dev or input_dev->dev.parent to
put them into sysfs tree. The former will go away once conversion
to struct device is complete.
- consolidate code for binding handlers to a device
- return error codes from handlers connect() methods back to input
core and log failures
Now that sysfs attributes that were marked for deletion can't access
their devices we do not need to set name, phys and uniq to NULL.
Allow drivers to implement their own get and set keycode methods. This
will allow drivers to change their keymaps without allocating huge
tables covering entire range of possible scancodes.
Rely on device core to create attribute groups for input devices
instead of open-coding it.
Now that sysfs attributes return -ENODEV once driver requests their
removal we do not need to handle scenario when data is deleted from
under our feet and can simplify the code.
After Al Viro (finally) succeeded in removing the sched.h #include in module.h
recently, it makes sense again to remove other superfluous sched.h includes.
There are quite a lot of files which include it but don't actually need
anything defined in there. Presumably these includes were once needed for
macros that used to live in sched.h, but moved to other header files in the
course of cleaning it up.
To ease the pain, this time I did not fiddle with any header files and only
removed #includes from .c-files, which tend to cause less trouble.
Compile tested against 2.6.20-rc2 and 2.6.20-rc2-mm2 (with offsets) on alpha,
arm, i386, ia64, mips, powerpc, and x86_64 with allnoconfig, defconfig,
allmodconfig, and allyesconfig as well as a few randconfigs on x86_64 and all
configs in arch/arm/configs on arm. I also checked that no new warnings were
introduced by the patch (actually, some warnings are removed that were emitted
by unnecessarily included header files).
Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Many struct file_operations in the kernel can be "const". Marking them const
moves these to the .rodata section, which avoids false sharing with potential
dirty data. In addition it'll catch accidental writes at compile time to
these shared resources.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Hopefully this will stop people from using input_free_device()
incorrectly.
Now that input_free_device is basically an alias for input_put_device
we need to acquire a reference to input module right when we allocate
device because input_dev_release releases reference to input module
unconditionally.
