This patch implements rumble support for XBox360 Wireless Controllers.
Signed-off-by: Chris Moeller <kode54@gmail.c>
Signed-off-by: Magnus Hörlin <magnus@alefors.se>
Reviewed-by: Christoph Fritz <chf.fritz@googlemail.com>
As pointed out by Oliver Neukum:
xpad->irq_in is currently submitted before xpad->bulk_out is allocated.
That however is a race, because the callback for irq_in can call
xpad360w_process_packet(), which will in turn submit the bulk URB.
This patch moves initialization for xpad->bulk_out earlier, so we can
ensure xpad->bulk_out is initialized before submitting urb.
ixpad can never be NULL here; if it is NULL we would not have been bound to
the interface and then why would we be called?
Properly free the resources in error path by the reverse order of resource
allocation.
In xpad_led_disconnect(), what we really want is to kfree(xpad_led).
In xpad_disconnect(), add a missing kfree(xpad->bdata) to fix the memory leak.
In current implementation, xpad_probe return 0 when
usb_alloc_urb failed for xpad->bulk_out and kzalloc failed for xpad->bdata.
This patch removes the initialization for error variable,
assign the error code at the place the error happens instead.
This patch adds USB Vendor and Product ID for Pelican PL-3601 'TSZ'
Wired Xbox 360 Controller to the device table.
Signed-off-by: Christoph Fritz <chf.fritz@googlemail.com>
Signed-off-by: Chris Merrett <chrisfu@hardc0re.org.uk>
Dance pads don't have any axes/sticks, only buttons for directions. For
example buttons like left+right will get triggered at once, an axis
can't handle this anyway. So this patch adds a module parameter named
"sticks_to_null" for unknown devices. A known dance pad makes use of
it by changing to a new mapping-option named DANCEPAD_MAP_CONFIG. Other
tested devices may follow by adding this mapping-option too.
Some buttons of xpad-devices are addressing mouse-buttons instead of
gamepad-buttons. This gets fixed too.
For more clearance what the functions actually do,
usb_buffer_alloc() is renamed to usb_alloc_coherent()
usb_buffer_free() is renamed to usb_free_coherent()
They should only be used in code which really needs DMA coherency.
All call sites have been changed accordingly, except for staging
drivers.
Signed-off-by: Daniel Mack <daniel@caiaq.de>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Pedro Ribeiro <pedrib@gmail.com>
Signed-off-by: Benjamin Valentin <benpicco@zedat.fu-berlin.de>
xbox_play_effect() is called while holding dev->event_lock with
interrupts disabled and thus may not use GFP_KERNEL when submitting
urbs.
Certain devices implement triggers as buttons rather than axes. In
particular, arcade sticks such as the HORI Real Arcade Pro.EX do not
have analog buttons.
These devices are now setup to present buttons rather than axes for
triggers.
User-space applications often also have problems with
axes-as-buttons. Activating MAP_TRIGGERS_TO_BUTTONS for a device
removes the artificial difference between buttons and triggers.
Signed-off-by: Nicolas Léveillé <nicolas@uucidl.com>
Added two new Xbox 360 devices:
- HORI Real Arcade Pro.EX
- Mad Catz SFIV Fightpad
Add BigBen Interactive XBOX 360 Controller (146b:0601) to xpad driver.
Signed-off-by: Thomas Gruber <kerneldev@tuxpower.org>
Signed-off-by: Anssi Hannula <anssi.hannula@iki.fi>
Signed-off-by: Corbin Simpson <MostAwesomeDude@gmail.com>
This avoids an infinite loop.
Signed-off-by: Michael Gruber <lists.mg@googlemail.com>
USB should not be having it's own printk macros, so remove info() and
use the system-wide standard of dev_info() wherever possible.
Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Signed-off-by: Harley Laue <losinggeneration@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: xpad - fix build failure
If both CONFIG_JOYSTICK_XPAD_FF and CONFIG_JOYSTICK_XPAD_LEDS are unset
xpad_bulk_out is not defined and build fails. Move it out of the #ifdef
block so it is always defined.
Reported-by: Ingo Molnar <mingo@elte.hu>
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (120 commits)
usb: don't update devnum for wusb devices
wusb: make ep0_reinit available for modules
wusb: devices dont use a set address
wusb: teach choose_address() about wireless devices
wusb: add link wusb-usb device
wusb: add authenticathed bit to usb_dev
USB: remove unnecessary type casting of urb->context
usb serial: more fixes and groundwork for tty changes
USB: replace remaining __FUNCTION__ occurrences
USB: usbfs: export the URB_NO_INTERRUPT flag to userspace
USB: fix compile problems in ehci-hcd
USB: ehci: qh_completions cleanup and bugfix
USB: cdc-acm: signedness fix
USB: add documentation about callbacks
USB: don't explicitly reenable root-hub status interrupts
USB: OHCI: turn off RD when remote wakeup is disabled
USB: HCDs use the do_remote_wakeup flag
USB: g_file_storage: ignore bulk-out data after invalid CBW
USB: serial: remove endpoints setting checks from core and header
USB: serial: remove unneeded number endpoints settings
USB is moving to transfering status as a parameter. To ease the transition
urb->status is to be touched only once in a function. The xpad driver has
been overlooked. Dmitry wants this to go through the USB tree.
Signed-off-by: Oliver Neukum <oneukum@suse.de>
The messages for led/rumble are exactly 3 and 8 bytes respectively.
Hence set up the transfer_buffer_length accordingly.
Acked-by: Anssi Hannula <anssi.hannula@gmail.com>
GFP_ATOMIC should not be used when GFP_KERNEL can be used.
Signed-off-by: Brian Magnuson <bdmagnuson@gmail.com>
Signed-off-by: Anssi Hannula <anssi.hannula@gmail.com>
The driver version numbers and changelog have not been updated in a
long while to reflect actual changes. Remove the version number and
add a notice that later changes can be tracked in SCM.
Commit 4994cd8dadcf9d484ab3ec19f3c7c7a4e5353c1c introduced a
regression which causes xpad to report force feedback cababilities
for non-360 controllers too, even while there is no actual support
for those.
Fix that by adding a check for XTYPE_XBOX360 to xpad_init_ff().
The buttons BTN_C and BTN_Z are only used in the original xbox
controller, not in xbox360 controller. Therefore only add them to
keybit when the controller is a non-360 one.
Add Mad Catz and 0x0e6f xbox360 controllers which are already found
in xpad_device[] table in xpad.c into the vendor id list. Also add
Logitech into the vendor list for Logitech Chillstream gamepads.
Also add the RedOctane Guitar Hero X-plorer.
The commit ae91d10aab2762f81733e9194cb56eff99c8d808 inverted Y and RY
axes on xbox360 so that up is positive and down is negative.
This is wrong, as axes on game controllers have up as negative per
convention. Also, even xpad itself reports HAT0X with up as negative.
Fix that by inverting them again.
Also, according to http://bugzilla.kernel.org/show_bug.cgi?id=10337 the
original xbox controllers also have the Y and RY axes inverted.
Fix that by inverting them as well.
Cc: Brian Magnuson <bdmagnuson@gmail.com>
For devices not specifically listed in xpad.c, xpad->dpad_mapping
is initially set to MAP_DPAD_UNKNOWN. In xpad_probe() it gets changed
to either MAP_DPAD_TO_BUTTONS or MAP_DPAD_TO_AXES, depending on the
module parameter dpad_to_buttons.
However, MAP_DPAD_UNKNOWN is defined as -1, while the field is u8.
This results in actual value of 255, causing the MAP_DPAD_UNKNOWN
check in xpad_probe() to fail.
Fix that by defining MAP_DPAD_UNKNOWN as 2 instead.
Also, setting module parameter dpad_to_buttons to 1 should obviously
map dpad to buttons, while the default behaviour (0) should be to map
dpad to axes. However, dpad_to_buttons is directly assigned to
xpad->dpad_mapping, and as MAP_DPAD_TO_BUTTONS is 0, the actual
behaviour is reversed.
Fix that by negating dpad_to_buttons in assignment.
Match Xbox 360 controllers using the interface info, i.e. interface
class 255 (Vendor specific), subclass 93 and protocol 1, instead of
specifying the device ids individually. As the class is vendor-specific,
we have to still match against vendor id as well, though.
Drop #include <linux/moduleparam.h> in files that also include
linux/module.h, since module.h includes moduleparam.h already.
Add USB IDs of Mad Catz Wired Xbox 360 Controller and
Pelican 'TSZ' Wired Xbox 360 Controller.
Signed-off-by: Joshua J Bowman <bowmanj@augsburg.edu>
get rid of input BIT* duplicate defines
use newly global defined macros for input layer. Also remove includes of
input.h from non-input sources only for BIT macro definiton. Define the
macro temporarily in local manner, all those local definitons will be
removed further in this patchset (to not break bisecting).
BIT macro will be globally defined (1<<x)
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
Cc: <dtor@mail.ru>
Acked-by: Jiri Kosina <jkosina@suse.cz>
Cc: <lenb@kernel.org>
Acked-by: Marcel Holtmann <marcel@holtmann.org>
Cc: <perex@suse.cz>
Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Cc: <vernux@us.ibm.com>
Cc: <malattia@linux.it>
Use avaliable functions instead of doing it all manually.
Export LEDs on Xbox360 pad via led subsystem as a single device in
/sys/class/leds/xpad[0-9]+.
Xbox360 pad has four leds, which form a circle. Unfortunately the leds
can't be controlled independently and can only display a predefined
set of patterns (for example one is turned on wile others are off or
a rotating pattern - 1-2-3-4). To activate a pattern one needs to send
a specific command to the device (see http://www.free60.org/wiki/Gamepad).
Led subsystem allows us to set brightness, but there is nothing like
brightness on this device. So brightness is actually interpreted as
the command (only values between 0 and 14 are accepted).
Signed-off-by: Jan Kratochvil <honza@jikos.cz>
Make the driver report Y/RY up as positive value and down as negative. Also
make DPAD mapping the same as classic xpad.
Reported-by: Brian Magnuson <bdmagnuson@gmail.com>
Tested-by: Jan Kratochvil <honza@jikos.cz>
xpad_play_effect() does not need to be global.
Implementation is using force feedback support for memoryless devices.
Xbox 360 gamepad is slightly different then the previous model so it has
its own version of process_packet method. Detection of this new device
relies on USB_DEVICE_INTERFACE_PROTOCOL macro. This device got vendor
specific subclass so it can't be matched with USB_INTERFACE_INFO and
we need only one interface protocol from four availaible. It means
USB_DEVICE can't be used either.
Added xpad360_btn structure with additional buttons for x360 gamepad.
Added xtype into xpad_device structure to distinguish between different
types of xbox devices.
* master.kernel.org:/pub/scm/linux/kernel/git/dtor/input:
Input: move USB miscellaneous devices under drivers/input/misc
Input: move USB mice under drivers/input/mouse
Input: move USB gamepads under drivers/input/joystick
Input: move USB touchscreens under drivers/input/touchscreen
Input: move USB tablets under drivers/input/tablet
Input: i8042 - fix AUX port detection with some chips
Input: aaed2000_kbd - convert to use polldev library
Input: drivers/usb/input - usb_buffer_free() cleanup
Input: synaptics - don't complain about failed resets
Input: pull input.h into uinpit.h
Input: drivers/usb/input - fix sparse warnings (signedness)
Input: evdev - fix some sparse warnings (signedness, shadowing)
Input: drivers/joystick - fix various sparse warnings
Input: force feedback - make sure effect is present before playing
