None of these files are actually using any __init type directives
and hence don't need to include <linux/init.h>. Most are just a
left over from __devinit and __cpuinit removal, or simply due to
code getting copied from one driver to the next.
Commit 0998d06310 (device-core: Ensure drvdata = NULL when no
driver is bound) removes the need to set driver data field to
NULL.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
CONFIG_HOTPLUG is going away as an option so __devexit is no
longer needed.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
CONFIG_HOTPLUG is going away as an option so __devinit is no longer
needed.
Acked-by: Javier Martinez Canillas <javier@dowhile0.org>
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer
needed.
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
In preparation for sa11x0 sparse irq conversion, explicitly include
mach/irqs.h as it will not be included for sparse irq.
Commit 940ab88962bc1aff3273a8356d64577a6e386736 introduced a new macro to
save some platform_driver boilerplate code. Use it.
Signed-off-by: JJ Ding <dgdunix@gmail.com>
This flag is a NOOP and can be removed now.
Signed-off-by: Yong Zhang <yong.zhang0@gmail.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
This just leaves include/asm-arm/plat-* to deal with.
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h.
Then, since asm/hardware.h only exists to include asm/arch/hardware.h,
update everything to directly include asm/arch/hardware.h and remove
asm/hardware.h.
... and we have few enough places using the latter to make it
simpler to do search and replace...
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias
is prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable
"input" platform drivers, to re-enable auto loading.
[dbrownell@users.sourceforge.net: more drivers, registration fixes]
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Signed-off-by: Andre Haupt <andre@bitwigglers.org>
Acked-by: Kristoffer Ericson <kristoffer.ericson@gmail.com>
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Send MSC_SCAN events to userspace to ease task of adjusting
keymap.
The driver supports onboard keyboards of HP Jornada 710/720/728
Signed-off-by: Kristoffer Ericson <kristoffer.ericson@gmail.com>
