clk_prepare_enable() can fail here and we must check its return value.
Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com>
Instead of being OF-specific, let's switch to using generic device
properties, which will make this code usable on ACPI, device tree and
legacy boards that use property sets.
As part of the change let's rename matrix_keypad_parse_of_params() to
matrix_keypad_parse_properties().
Trivial fix to typo in dev_err message
Static checkers complain about this NULL check because we dereference it
without checking a couple lines later. This function is only called
when "keypad->pdata" is non-NULL so we can just delete the NULL test.
[Dmitry: remove the variable altogether given that it is used just once and
dereference directly.]
Remove some left-over ARM only includes in order to enable building on
ARM64. __raw_{read,write}l were getting implicitly included, so add
linux/io.h include.
Signed-off-by: Rob Herring <robh@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull input subsystem updates from Dmitry Torokhov:
"Two new drivers for Elan hardware (for I2C touchpad and touchscreen
found in several Chromebooks and other devices), a driver for Goodix
touch panel, and small fixes to Cypress I2C trackpad and other input
drivers.
Also we switched to use __maybe_unused instead of gating suspend/
resume code with #ifdef guards to get better compile coverage"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (27 commits)
Input: gpio_keys - fix warning regarding uninitialized 'button' variable
Input: add support for Elan eKTH I2C touchscreens
Input: gpio_keys - fix warning regarding uninitialized 'irq' variable
Input: cyapa - use 'error' for error codes
Input: cyapa - fix resuming the device
Input: gpio_keys - add device tree support for interrupt only keys
Input: amikbd - allocate temporary keymap buffer on the stack
Input: amikbd - fix build if !CONFIG_HW_CONSOLE
Input: lm8323 - missing error check in lm8323_set_disable()
Input: initialize device counter variables with -1
Input: initialize input_no to -1 to avoid subtraction
Input: i8042 - do not try to load on Intel NUC D54250WYK
Input: atkbd - correct MSC_SCAN events for force_release keys
Input: cyapa - switch to using managed resources
Input: lifebook - use "static inline" instead of "inline" in lifebook.h
Input: touchscreen - use __maybe_unused instead of ifdef around suspend/resume
Input: mouse - use __maybe_unused instead of ifdef around suspend/resume
Input: misc - use __maybe_unused instead of ifdef around suspend/resume
Input: cap11xx - support for irq-active-high option
Input: cap11xx - add support for various cap11xx devices
This change switches ithe driver to use devm_* APIs to allocate resources.
This helps to simplify failure path in probe function and module unloading
and does away with remove function.
Signed-off-by: Pramod Gurav <pramod.gurav@smartplayin.com>
A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
The number of columns of pxa27x-keypad used by various boards is not fixed.
When building keymap with call to:
matrix_keypad_build_keymap(keymap_data, NULL,
pdata->matrix_key_rows,
pdata->matrix_key_cols,
keypad->keycodes, input_dev);
it will internally calculate needed row shift and use it to fill the
keymap. Therefore when calculating the "scancode" we should no longer use
constant row shift but also calculate it from number of columns.
Signed-off-by: Chao Xie <chao.xie@marvell.com>
None of these files are actually using any __init type directives
and hence don't need to include <linux/init.h>. Most are just a
left over from __devinit and __cpuinit removal, or simply due to
code getting copied from one driver to the next.
Merge first round of changes for 3.13 merge window.
'of_match_ptr' is defined in linux/of.h. Include it explicitly.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
A NULL pointer dereference exception occurs in the driver probe function when
device tree is used. The pdata pointer will be NULL in this case, but the code
dereferences it in all cases. When device tree is used, a platform data
structure is allocated and initialized, and in all cases this pointer is copied
to the driver's private data, so the variable being tested should be accessed
through the driver's private data structure.
Signed-off-by: Mike Dunn <mikedunn@newsguy.com>
It should not be changed by the driver, so let's make it const pointer.
pxa27x-keypad includes matrix keys. Make use of matrix_keymap
for the matrix keys.
free_irq() expects the same pointer that was passed to request_irq(),
otherwise the IRQ is not freed.
The issue was found using the following coccinelle script:
<smpl>
@r1@
type T;
T devid;
request_irq(..., devid)
@r2@
type r1.T;
T devid;
position p;
free_irq@p(..., devid)
position p != r2.p;
*free_irq@p(...)
</smpl>
Commit 0998d06310 (device-core: Ensure drvdata = NULL when no
driver is bound) removes the need to set driver data field to
NULL.
CONFIG_HOTPLUG is going away as an option so __devexit is no
longer needed.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
CONFIG_HOTPLUG is going away as an option so __devinit is no longer
needed.
Acked-by: Javier Martinez Canillas <javier@dowhile0.org>
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer
needed.
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Bootloader can leave interrupt bit pending, and it confuses driver.
Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com>
Acked-by: Robert Jarzmik <robert.jarzmik@free.fr>
Platform data for device drivers should be defined in
include/linux/platform_data/*.h, not in the architecture
and platform specific directories.
This moves such data out of the pxa include directories
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Acked-by: Nicolas Pitre <nico@linaro.org>
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
Acked-by: Jeff Garzik <jgarzik@redhat.com>
Acked-by: Paul Parsons <lost.distance@yahoo.com>
Acked-by: Vinod Koul <vinod.koul@linux.intel.com>
Acked-By: Stefan Schmidt <stefan@openezx.org>
Cc: Eric Miao <eric.y.miao@gmail.com>
Cc: Haojian Zhuang <haojian.zhuang@gmail.com>
Cc: Daniel Ribeiro <drwyrm@gmail.com>
Cc: Harald Welte <laforge@openezx.org>
Cc: Philipp Zabel <philipp.zabel@gmail.com>
Cc: Tomas Cech <sleep_walker@suse.cz>
Cc: Sergey Lapin <slapin@ossfans.org>
Cc: Jonathan Cameron <jic23@cam.ac.uk>
Cc: Dan Williams <djbw@fb.com>
Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Chris Ball <cjb@laptop.org>
Cc: Samuel Ortiz <samuel@sortiz.org>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
Cc: Liam Girdwood <lrg@ti.com>
Cc: Jaroslav Kysela <perex@perex.cz>
Cc: Takashi Iwai <tiwai@suse.de>
Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Cc: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
Cc: openezx-devel@lists.openezx.org
Direct keys usage may not start from KP_DKIN0, add a msk option
to configure the specifics for platforms that can skip some keys.
Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com>
KPDK_DK only indicates the pin level of direct key.
So it is related to board, and low level may be active which
indicates that a key is pressed.
When direcct_key_num is 0, the mask should be 0.
When direcct_key_num is 1, the mask should be 0b1.
When the keypad is used as wake up source, the clock can not
be disabled. Or it can not detect key pressing.
If the keypad is used as wake up source, when resume back,
do not enable the clock and configure it again because the
register content is retained.
Commit 940ab88962bc1aff3273a8356d64577a6e386736 introduced a new macro to
save some platform_driver boilerplate code. Use it.
Signed-off-by: JJ Ding <dgdunix@gmail.com>
This flag is a NOOP and can be removed now.
Signed-off-by: Yong Zhang <yong.zhang0@gmail.com>
mach-mmp needs to clear wake event in order to clear the keypad interrupt
Signed-off-by: Mark F. Brown <mark.brown314@gmail.com>
Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
mach-mmp utilizes pxa27x_keypad code so we need to move header to
platform pxa directory.
No need to call input_free_device() after input_unregister_device().
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Due to problems at cam.org, my nico@cam.org email address is no longer
valid. FRom now on, nico@fluxnic.net should be used instead.
Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
Tested-by: Mike Rapoport <mike@compulab.co.il>
Acked-by: Eric Miao <eric.y.miao@gmail.com>
clk_disable() in remove method is not needed since we already
have clk_disable in pxa27x_keypad_close().
Also make sure the driver uses resource_size() and helpers from
include/input/matrix_keypad.h
Where devices only have one consumer, passing a consumer clock ID
has no real benefit. Remove it.
This just leaves include/asm-arm/plat-* to deal with.
There are 43 includes of asm/mach-types.h by files that don't
reference anything from that file. Remove these unnecessary
includes.
drivers/input/mouse/appletouch.c
Signed-off-by: Eric Miao <eric.miao@marvell.com>
1. Set input bits for direct keys codes
2. Set input bits for rotary encoder codes only if rotary
encoder is enabled
3. Enable EV_REL only if rotary encoder is enabled and rel_codes
are set up
Signed-off-by: Antonio Ospite <ao2@openezx.org>
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias
is prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable
"input" platform drivers, to re-enable auto loading.
[dbrownell@users.sourceforge.net: more drivers, registration fixes]
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
We want to mask (key_number - 1), not key_number. The current
implementation works fine for all values but the maximum one,
i.e. 8.
Signed-off-by: Samuel Ortiz <sameo@openedhand.com>
Acked-by: Eric Miao <eric.miao@marvell.com>
Currently, only one debounce_interval is introduced for both direct and
matrix keys. This is true in most cases, although the keypad controller
supports different debounce for direct/matrix keys.
Some platforms do require this to be tuned, instead of the default
reset value of 100ms.
Rotary encoder will always use zero debounce time for now to achieve
certain sensitivity.
1. use ioremap() for registers access, this improves the portability
of the driver (e.g. same IP on different processor with different
I/O memory range), and make it possible to remove those registers
definition in pxa-regs.h as PXA is undergoing a clean-up of that
header file
2. use device specific IRQ instead of hardcoded IRQ_KEYPAD, same
reason as above
3. clean up the error handling path in _probe()
4. remove DRIVER_NAME and use pdev->name when necessary, we don't
actually need a constant string literals
1. Rotary encoder events can be configured either as relative events
as the legacy code does or as any specified key code, this is
useful on some platform which uses the rotary keys as
KEY_{UP/DOWN/LEFT/RIGHT}
2. Add support for direct keys, the corresponding keycodes for each
direct key can now be specified within the platform data
3. Remove the direct/rotary key detection code from the IRQ handler
to dedicated functions to improve readability
Introduce pxa27x_keypad_config() for keypad registers configuration
and remove the reg_kpc, reg_kprec from platform data structure
so that configurations of keypad registers can be centralized to a
single function.
It can also be re-used when resuming.
