Some ARM platforms have the ability to program the interrupt controller to
detect various interrupt edges and/or levels. For some platforms, this is
critical to setup correctly, particularly those which the setting is dependent
on the device.
Currently, ARM drivers do (eg) the following:
err = request_irq(irq, ...);
set_irq_type(irq, IRQT_RISING);
However, if the interrupt has previously been programmed to be level sensitive
(for whatever reason) then this will cause an interrupt storm.
Hence, if we combine set_irq_type() with request_irq(), we can then safely set
the type prior to unmasking the interrupt. The unfortunate problem is that in
order to support this, these flags need to be visible outside of the ARM
architecture - drivers such as smc91x need these flags and they're
cross-architecture.
Finally, the SA_TRIGGER_* flag passed to request_irq() should reflect the
property that the device would like. The IRQ controller code should do its
best to select the most appropriate supported mode.
This allows us to eliminate the casts in the drivers, and eventually
remove the use of the device_driver function pointer methods for
platform device drivers.
Convert everyone who uses platform_bus_type to include
linux/platform_device.h.
In PM v1, all devices were called at SUSPEND_DISABLE level. Then
all devices were called at SUSPEND_SAVE_STATE level, and finally
SUSPEND_POWER_DOWN level. However, with PM v2, to maintain
compatibility for platform devices, I arranged for the PM v2
suspend/resume callbacks to call the old PM v1 suspend/resume
callbacks three times with each level in order so that existing
drivers continued to work.
Since this is obsolete infrastructure which is no longer necessary,
we can remove it. Here's an (untested) patch to do exactly that.
Input: convert drivers/input/keyboard to dynamic input_dev allocation
This is required for input_dev sysfs integration
Patch from Richard Purdie
Correct the right shift key entry in the spitz keyboard driver.
Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
Add a input driver for the keyboard found on the Zaurus Cxx00 series (Spitz,
Akita, Borzoi). Its based on corgikbd but there are enough subtle differences
to justify a separate driver.
Signed-Off-by: Richard Purdie <rpurdie@rpsys.net>
Cc: Vojtech Pavlik <vojtech@suse.cz>
