2011-11-30 | input: keyreset: Only print message for default handler | Colin Cross | |
Change-Id: I68e5451fef2e6f08bf1035077ea999e34a619f87 Signed-off-by: Colin Cross <ccross@android.com> | |||
2011-11-30 | input: keyreset: Allow reset function to be overriden | Colin Cross | |
Change-Id: Ibb3dda05772b2e89d7b2646689944d309cb1f74e Signed-off-by: Colin Cross <ccross@android.com> | |||
2011-11-30 | input: Add keyreset driver. | Arve Hjønnevåg | |
Add a platform device in the board file to specify a reset key-combo. The first time the key-combo is detected a work function that syncs the filesystems is scheduled. If all the keys are released and then pressed again, it calls panic. Reboot on panic should be set for this to work. Change-Id: I9d54283ca1fba45e4b1ae1a407524cdda8171143 Signed-off-by: Arve Hjønnevåg <arve@android.com> |
