git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull input layer fixes from Dmitry Torokhov:
"Fixes for two recent regressions (in Synaptics PS/2 and uinput
drivers) and some more driver fixups"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Revert "Input: synaptics - fix handling of disabling gesture mode"
Input: psmouse - fix data race in __ps2_command
Input: elan_i2c - add all valid ic type for i2c/smbus
Input: zhenhua - ensure we have BITREVERSE
Input: omap4-keypad - fix memory leak
Input: serio - fix blocking of parport
Input: uinput - fix crash when using ABS events
Input: elan_i2c - expand maximum product_id form 0xFF to 0xFFFF
Input: elan_i2c - add ic type 0x03
Input: elan_i2c - don't require known iap version
Input: imx6ul_tsc - fix controller name
Input: imx6ul_tsc - use the preferred method for kzalloc()
Input: imx6ul_tsc - check for negative return value
Input: imx6ul_tsc - propagate the errors
Input: walkera0701 - fix abs() calculations on 64 bit values
Input: mms114 - remove unneded semicolons
Input: pm8941-pwrkey - remove unneded semicolon
Input: fix typo in MT documentation
Input: cyapa - fix address of Gen3 devices in device tree documentation
Commit b6d30968d86c45a7bb599eaca13ff048d3fa576c (Input: uinput - switch to
using for_each_set_bit()) switched driver to use for_each_set_bit().
However during initial write of the uinput structure that contains min/max
data for all possible axes none of them are reflected in dev->absbit yet
and so we were skipping over all of them and were not allocating absinfo
memory which caused crash later when driver tried to sens EV_ABS events:
<1>[ 15.064330] BUG: unable to handle kernel NULL pointer dereference at 0000000000000024
<1>[ 15.064336] IP: [<ffffffff8163f142>] input_handle_event+0x232/0x4e0
<4>[ 15.064343] PGD 0
<4>[ 15.064345] Oops: 0000 [#1] SMP
Fixes: b6d30968d86c45a7bb599eaca13ff048d3fa576c
Cc: stable@vger.kernel.org
Reported-by: Stephen Chandler Paul <cpaul@redhat.com>
Tested-by: Stephen Chandler Paul <cpaul@redhat.com>
It's not needed and is just creating a null statement so remove it.
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
Pull more input updates from Dmitry Torokhov:
"Second round of updates for the input subsystem.
This introduces two brand new touchscreen drivers (Colibri and
imx6ul_tsc), some small driver fixes, and we are no longer report
errors from evdev_flush() as users do not really have a way of
handling errors, error codes that we were returning were not on the
list of errors supposed to be returned by close(), and errors were
causing issues with one of older versions of systemd"
Input: imx_keypad - remove obsolete comment
Input: touchscreen - add imx6ul_tsc driver support
Input: Add touchscreen support for Colibri VF50
Input: i8042 - lower log level for "no controller" message
Input: evdev - do not report errors form flush()
Input: elants_i2c - extend the calibration timeout to 12 seconds
Input: sparcspkr - fix module autoload for OF platform drivers
Input: regulator-haptic - fix module autoload for OF platform driver
Input: pwm-beeper - fix module autoload for OF platform driver
Input: ab8500-ponkey - Fix module autoload for OF platform driver
Input: cyttsp - remove unnecessary MODULE_ALIAS()
Input: elan_i2c - add ACPI ID "ELAN1000"
Prepare second round of input updates for 4.3 merge window.
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip
Pull xen terminology fixes from David Vrabel:
"Use the correct GFN/BFN terms more consistently"
* tag 'for-linus-4.3-rc0b-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip:
xen/xenbus: Rename the variable xen_store_mfn to xen_store_gfn
xen/privcmd: Further s/MFN/GFN/ clean-up
hvc/xen: Further s/MFN/GFN clean-up
video/xen-fbfront: Further s/MFN/GFN clean-up
xen/tmem: Use xen_page_to_gfn rather than pfn_to_gfn
xen: Use correctly the Xen memory terminologies
arm/xen: implement correctly pfn_to_mfn
xen: Make clear that swiotlb and biomerge are dealing with DMA address
Based on include/xen/mm.h [1], Linux is mistakenly using MFN when GFN
is meant, I suspect this is because the first support for Xen was for
PV. This resulted in some misimplementation of helpers on ARM and
confused developers about the expected behavior.
For instance, with pfn_to_mfn, we expect to get an MFN based on the name.
Although, if we look at the implementation on x86, it's returning a GFN.
For clarity and avoid new confusion, replace any reference to mfn with
gfn in any helpers used by PV drivers. The x86 code will still keep some
reference of pfn_to_mfn which may be used by all kind of guests
No changes as been made in the hypercall field, even
though they may be invalid, in order to keep the same as the defintion
in xen repo.
Note that page_to_mfn has been renamed to xen_page_to_gfn to avoid a
name to close to the KVM function gfn_to_page.
Take also the opportunity to simplify simple construction such
as pfn_to_mfn(page_to_pfn(page)) into xen_page_to_gfn. More complex clean up
will come in follow-up patches.
[1] http://xenbits.xen.org/gitweb/?p=xen.git;a=commitdiff;h=e758ed14f390342513405dd766e874934573e6cb
Signed-off-by: Julien Grall <julien.grall@citrix.com>
Reviewed-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Acked-by: Wei Liu <wei.liu2@citrix.com>
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
Pull input subsystem updates from Dmitry Torokhov:
"Drivers, drivers, drivers... No interesting input core changes this
time"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (74 commits)
Input: elan_i2c - use iap_version to get firmware information
Input: max8997_haptic - fix module alias
Input: elan_i2c - fix typos for validpage_count
Input: psmouse - add small delay for IBM trackpoint pass-through mode
Input: elan_i2c - enable ELAN0100 acpi panels
Input: gpio-keys - report error when disabling unsupported key
Input: sur40 - fix error return code
Input: sentelic - silence some underflow warnings
Input: zhenhua - switch to using bitrev8()
Input: cros_ec_keyb - replace KEYBOARD_CROS_EC dependency
Input: cap11xx - add LED support
Input: elants_i2c - fix for devm_gpiod_get API change
Input: elan_i2c - enable asynchronous probing
Input: elants_i2c - enable asynchronous probing
Input: elants_i2c - wire up regulator support
Input: do not emit unneeded EV_SYN when suspending
Input: elants_i2c - disable idle mode before updating firmware
MAINTAINERS: Add maintainer for atmel_mxt_ts
Input: atmel_mxt_ts - remove warning on zero T44 count
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound updates from Takashi Iwai:
"There are little changes in core part, but lots of development are
found in drivers, especially ASoC. The diffstat shows regmap-related
changes for a slight API additions / changes, and that's all.
Looking at the code size statistics, the most significant addition is
for Intel Skylake. (Note that SKL support is still underway, the
codec driver is missing.) Also STI controller driver is a major
addition as well as a few new codec drivers.
In HD-audio side, there are fewer changes than the past. The
noticeable change is the support of ELD notification from i915
graphics driver. Thus this pull request carries a few changes in
drm/i915.
Other than that, USB-audio got a rewrite of runtime PM code. It was
initiated by lockdep warning, but resulted in a good cleanup in the
end.
Below are the highlights:
Common:
- Factoring out of AC'97 reset code from ASoC into the core helper
- A few regmap API extensions (in case it's not pulled yet)
ASoC:
- New drivers for Cirrus CS4349, GTM601, InvenSense ICS43432, Realtek
RT298 and ST STI controllers
- Machine drivers for Rockchip systems with MAX98090 and RT5645 and
RT5650
- Initial driver support for Intel Skylake devices
- Lots of rsnd cleanup and enhancements
- A few DAPM fixes and cleanups
- A large number of cleanups in various drivers (conversion and
standardized to regmap, component) mostly by Lars-Peter and Axel
HD-audio:
- Extended HD-audio core for Intel Skylake controller support
- Quirks for Dell headsets, Alienware 15
- Clean up of pin-based quirk tables for Realtek codecs
- ELD notifier implenetation for Intel HDMI/DP
USB-audio:
- Refactor runtime PM code to make lockdep happier"
* tag 'sound-4.3-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (411 commits)
drm/i915: Add locks around audio component bind/unbind
drm/i915: Drop port_mst_index parameter from pin/eld callback
ALSA: hda - Fix missing inline for dummy snd_hdac_set_codec_wakeup()
ALSA: hda - Wake the codec up on pin/ELD notify events
ALSA: hda - allow codecs to access the i915 pin/ELD callback
drm/i915: Call audio pin/ELD notify function
drm/i915: Add audio pin sense / ELD callback
ASoC: zx296702-i2s: Fix resource leak when unload module
ASoC: sti_uniperif: Ensure component is unregistered when unload module
ASoC: au1x: psc-i2s: Convert to use devm_ioremap_resource
ASoC: sh: dma-sh7760: Convert to devm_snd_soc_register_platform
ASoC: spear_pcm: Use devm_snd_dmaengine_pcm_register to fix resource leak
ALSA: fireworks/bebob/dice/oxfw: fix substreams counting at vmalloc failure
ASoC: Clean up docbook warnings
ASoC: txx9: Convert to devm_snd_soc_register_platform
ASoC: pxa: Convert to devm_snd_soc_register_platform
ASoC: nuc900: Convert to devm_snd_soc_register_platform
ASoC: blackfin: Convert to devm_snd_soc_register_platform
ASoC: au1x: Convert to devm_snd_soc_register_platform
ASoC: qcom: Constify asoc_qcom_lpass_cpu_dai_ops
These platform drivers have a OF device ID table but the OF module
alias information is not created so module autoloading won't work.
Signed-off-by: Luis de Bethencourt <luis@debethencourt.com>
Pull MIPS updates from Ralf Baechle:
"This is the main pull request for 4.3 for MIPS. Here's the summary:
Three fixes that didn't make 4.2-stable:
- a -Os build might compile the kernel using the MIPS16 instruction
set but the R2 optimized inline functions in <uapi/asm/swab.h> are
implemented using 32-bit wide instructions which is invalid.
- a build error in pgtable-bits.h for a particular kernel
configuration.
- accessing registers of the CM GCR might have been compiled to use
64 bit accesses but these registers are onl 32 bit wide.
And also a few new bits:
- move the ATH79 GPIO driver to drivers/gpio
- the definition of IRQCHIP_DECLARE has moved to linux/irqchip.h,
change ATH79 accordingly.
- fix definition of pgprot_writecombine
- add an implementation of dma_map_ops.mmap
- fix alignment of quiet build output for vmlinuz link
- BCM47xx: Use kmemdup rather than duplicating its implementation
- Netlogic: Fix 0x0x prefixes of constants.
- merge Bjorn Helgaas' series to remove most of the weak keywords
from function declarations.
- CP0 and CP1 registers are best considered treated as unsigned
values to avoid large values from becoming negative values.
- improve support for the MIPS GIC timer.
- enable common clock framework for Malta and SEAD3.
- a number of improvments and fixes to dump_tlb().
- document the MIPS TLB dump functionality in Magic SysRq.
- Cavium Octeon CN68XX improvments.
- NetLogic improvments.
- irq: Use access helper irq_data_get_affinity_mask.
- handle MSA unaligned accesses.
- a number of R6-related math-emu fixes.
- support for I6400.
- improvments to MSA support.
- add uprobes support.
- move from deprecated __initcall to arch_initcall.
- remove finish_arch_switch().
- IRQ cleanups by Thomas Gleixner.
- migrate to new 'set-state' interface.
- random small cleanups"
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (148 commits)
MIPS: UAPI: Fix unrecognized opcode WSBH/DSBH/DSHD when using MIPS16.
MIPS: Fix alignment of quiet build output for vmlinuz link
MIPS: math-emu: Remove unused handle_dsemul function declaration
MIPS: math-emu: Add support for the MIPS R6 MAX{, A} FPU instruction
MIPS: math-emu: Add support for the MIPS R6 MIN{, A} FPU instruction
MIPS: math-emu: Add support for the MIPS R6 CLASS FPU instruction
MIPS: math-emu: Add support for the MIPS R6 RINT FPU instruction
MIPS: math-emu: Add support for the MIPS R6 MSUBF FPU instruction
MIPS: math-emu: Add support for the MIPS R6 MADDF FPU instruction
MIPS: math-emu: Add support for the MIPS R6 SELNEZ FPU instruction
MIPS: math-emu: Add support for the MIPS R6 SELEQZ FPU instruction
MIPS: math-emu: Add support for the CMP.condn.fmt R6 instruction
MIPS: inst.h: Add new MIPS R6 FPU opcodes
MIPS: Octeon: Fix management port MII address on Kontron S1901
MIPS: BCM47xx: Use kmemdup rather than duplicating its implementation
STAGING: Octeon: Use common helpers for determining interface and port
MIPS: Octeon: Support interfaces 4 and 5
MIPS: Octeon: Set up 1:1 mapping between CN68XX PKO queues and ports
MIPS: Octeon: Initialize CN68XX PKO
STAGING: Octeon: Support CN68XX style WQE
This platform driver has a OF device ID table but the OF module
Prepare first round of input updates for 4.3 merge window.
Currently CONFIG_ARCH_HAVE_CUSTOM_GPIO_H is defined for all MIPS
machines, and each machine type provides its own gpio.h. However
only a handful really implement the GPIO API, most just forward
everythings to gpiolib.
The Alchemy machine is notable as it provides a system to allow
implementing the GPIO API at the board level. But it is not used by
any board currently supported, so it can also be removed.
For most machine types we can just remove the custom gpio.h, as well
as the custom wrappers if some exists. Some of the code found in
the wrappers must be moved to the respective GPIO driver.
A few more fixes are need in some drivers as they rely on linux/gpio.h
to provides some machine specific definitions, or used asm/gpio.h
instead of linux/gpio.h for the gpio API.
Signed-off-by: Alban Bedel <albeu@free.fr>
Cc: linux-mips@linux-mips.org
Cc: Hauke Mehrtens <hauke@hauke-m.de>
Cc: Rafał Miłecki <zajec5@gmail.com>
Cc: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Alexandre Courbot <gnurou@gmail.com>
Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Florian Fainelli <florian@openwrt.org>
Cc: Manuel Lauss <manuel.lauss@gmail.com>
Cc: Joe Perches <joe@perches.com>
Cc: Daniel Walter <dwalter@google.com>
Cc: Sergey Ryazanov <ryazanov.s.a@gmail.com>
Cc: Huacai Chen <chenhc@lemote.com>
Cc: James Hartley <james.hartley@imgtec.com>
Cc: Andrew Bresticker <abrestic@chromium.org>
Cc: Paul Burton <paul.burton@imgtec.com>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Bjorn Helgaas <bhelgaas@google.com>
Cc: Wolfram Sang <wsa@the-dreams.de>
Cc: Randy Dunlap <rdunlap@infradead.org>
Cc: Varka Bhadram <varkabhadram@gmail.com>
Cc: Masanari Iida <standby24x7@gmail.com>
Cc: Tomi Valkeinen <tomi.valkeinen@ti.com>
Cc: Michael Buesch <m@bues.ch>
Cc: abdoulaye berthe <berthe.ab@gmail.com>
Cc: linux-ide@vger.kernel.org
Cc: linux-gpio@vger.kernel.org
Cc: linux-input@vger.kernel.org
Cc: netdev@vger.kernel.org
Patchwork: https://patchwork.linux-mips.org/patch/10828/
'asoc/topic/rl6231', 'asoc/topic/rockchip' and 'asoc/topic/rt286' into asoc-next
'regulator/topic/ltc3589', 'regulator/topic/max77693' and 'regulator/topic/max8973' into regulator-next
The driver is a platform driver and not a I2C driver so its modalias
should be exported with MODULE_DEVICE_TABLE(platform,...) instead of
MODULE_DEVICE_TABLE(i2c,...).
Also, remove the unnecessary MODULE_ALIAS("platform:max8997-haptic")
now that the correct module alias is created.
Pull input subsystem fixes from Dmitry Torokhov:
"Just small ALPS and Elan touchpads, and other driver fixups"
Input: elantech - add special check for fw_version 0x470f01 touchpad
Input: twl4030-vibra - fix ERROR: Bad of_node_put() warning
Input: alps - only Dell laptops have separate button bits for v2 dualpoint sticks
Input: axp20x-pek - add module alias
Input: turbografx - fix potential out of bound access
The max77693 haptic driver supports Maxim 77843 device so remove the
max77843 driver.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
The Maxim 77843 haptic driver differs from 77693 by:
1. Setting the bias.
2. Different configuration register.
3. Not enabling the low-sys DAC.
4. Using same regmap for PMIC and haptic blocks.
Incorporate all differences into max77693 haptic driver so both devices
can be supported.
Prepare the driver for supporting two devices: Maxim 77693 and 77843:
1. Add table of device ids and store current device type for later
usage.
2. Differentiate the haptic device configuration.
Storing a predefined PWM divisor in state container structure is
meaningless. The field, after initialization, is only read so this only
obfuscates the code. Remove the field and use directly enum value.
Fix following:
[ 8.862274] ERROR: Bad of_node_put() on /ocp/i2c@48070000/twl@48/audio
[ 8.869293] CPU: 0 PID: 1003 Comm: modprobe Not tainted 4.2.0-rc2-letux+ #1175
[ 8.876922] Hardware name: Generic OMAP36xx (Flattened Device Tree)
[ 8.883514] [<c00159e0>] (unwind_backtrace) from [<c0012488>] (show_stack+0x10/0x14)
[ 8.891693] [<c0012488>] (show_stack) from [<c05cb810>] (dump_stack+0x78/0x94)
[ 8.899322] [<c05cb810>] (dump_stack) from [<c02cfd5c>] (kobject_release+0x68/0x7c)
[ 8.907409] [<c02cfd5c>] (kobject_release) from [<bf0040c4>] (twl4030_vibra_probe+0x74/0x188 [twl4030_vibra])
[ 8.917877] [<bf0040c4>] (twl4030_vibra_probe [twl4030_vibra]) from [<c03816ac>] (platform_drv_probe+0x48/0x90)
[ 8.928497] [<c03816ac>] (platform_drv_probe) from [<c037feb4>] (really_probe+0xd4/0x238)
[ 8.937103] [<c037feb4>] (really_probe) from [<c0380160>] (driver_probe_device+0x30/0x48)
[ 8.945678] [<c0380160>] (driver_probe_device) from [<c03801e0>] (__driver_attach+0x68/0x8c)
[ 8.954589] [<c03801e0>] (__driver_attach) from [<c037ea60>] (bus_for_each_dev+0x50/0x84)
[ 8.963226] [<c037ea60>] (bus_for_each_dev) from [<c037f828>] (bus_add_driver+0xcc/0x1e4)
[ 8.971832] [<c037f828>] (bus_add_driver) from [<c0380b60>] (driver_register+0x9c/0xe0)
[ 8.980255] [<c0380b60>] (driver_register) from [<c00097e0>] (do_one_initcall+0x100/0x1b8)
[ 8.988983] [<c00097e0>] (do_one_initcall) from [<c00b8008>] (do_init_module+0x58/0x1c0)
[ 8.997497] [<c00b8008>] (do_init_module) from [<c00b8cac>] (SyS_init_module+0x54/0x64)
[ 9.005950] [<c00b8cac>] (SyS_init_module) from [<c000ed20>] (ret_fast_syscall+0x0/0x54)
[ 9.015838] input: twl4030:vibrator as /devices/platform/68000000.ocp/48070000.i2c/i2c-0/0-0048/48070000.i2c:twl@48:audio/input/input2
node passed to of_find_node_by_name is put inside that function and new node
is returned if found. Free returned node not already freed node.
Signed-off-by: Marek Belisko <marek@goldelico.com>
The GPIO subsystem provides dummy GPIO consumer functions if GPIOLIB is
not enabled. Hence drivers that depend on GPIOLIB, but use GPIO consumer
functionality only, can still be compiled if GPIOLIB is not enabled.
Relax the dependency on GPIOLIB if COMPILE_TEST is enabled, where
appropriate.
Add a proper module alias so the driver can be autoloaded when the
parent axp20x mfd driver registers its cells.
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
Acked-by: Carlo Caione <carlo@caione.org>
The I2C core always reports the MODALIAS uevent as "i2c:<client name"
regardless if the driver was matched using the I2C id_table or the
of_match_table. So the driver needs to export the I2C table and this
be built into the module or udev won't have the necessary information
to auto load the correct module when the device is added.
Using managed input device (via devm_input_allocate_device) simplifies
error handling and driver removal paths and also silences CID# 712569.
Reviewed-by: Joshua Clayton <stillcompiling@gmail.com>
On pm8xxx PMICs, shutdown and restart are signaled to the PMIC via a pin
called PS_HOLD. When this pin goes low, the PMIC performs a configurable
power sequence. Add a .shutdown hook so that we can properly configure this
power sequence for shutdown or restart depending on the system state.
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Reviewed-by: Bjorn Andersson <bjorn.andersson@sonymobile.com>
Sync up with Linux 4.2-rc3 to bring in infrastructure (OF) pieces.
i2c_driver does not need to set an owner because i2c_register_driver()
will set it.
Separate the functionality using sequences of register writes from the
functions that take register defaults. This change renames the arguments
in order to support the extension of reg_sequence to take an optional
delay to be applied after any given register in a sequence is written.
This avoids adding an int to all register defaults, which could
substantially increase memory usage for regmaps with large default tables.
This also updates all the clients of multi_reg_write/register_patch.
Signed-off-by: Nariman Poushin <nariman@opensource.wolfsonmicro.com>
Switch to the same definition of state container as in MAX77693 drivers.
This will allow usage of one regulator driver in both devices: MAX77693
and MAX77843.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski.k@gmail.com>
Acked-by: Lee Jones <lee.jones@linaro.org>
Acked-by: Chanwoo Choi <cw00.choi@samsung.com>
This prepares for merging some of the drivers between max77693 and
max77843 so the child MFD driver can be attached to any parent MFD main
driver.
Move the state container to common header file. Additionally add
consistent 'i2c' prefixes to its members (of 'struct i2c_client' type).
Acked-by: Sebastian Reichel <sre@kernel.org>
Acked-by: Jacek Anaszewski <j.anaszewski@samsung.com>
Use for_each_set_bit to check for set bits in bitmap
as it is more efficient and compact.
Signed-off-by: Anshul Garg <aksgarg1989@gmail.com>
These reg_default tables are not modified after initialized, so make them
const.
Signed-off-by: Axel Lin <axel.lin@ingics.com>
Despite it's name, sign_extend32() is used for 16 bit values aswell.
Signed-off-by: Martin Kepplinger <martink@posteo.de>
Pull second round of input updates from Dmitry Torokhov:
"A new driver for Weida wdt87xx touch controllers, and a bunch of
fixups for other drivers"
Input: wdt87xx_i2c - add a scaling factor for TOUCH_MAJOR event
Input: wdt87xx_i2c - remove stray newline in diagnostic message
Input: arc_ps2 - add HAS_IOMEM dependency
Input: wdt87xx_i2c - fix format warning
Input: improve parsing OF parameters for touchscreens
Input: edt-ft5x06 - mark as direct input device
Input: use for_each_set_bit() where appropriate
Input: add a driver for wdt87xx touchscreen controller
Input: axp20x-pek - fix reporting button state as inverted
Input: xpad - re-send LED command on present event
Input: xpad - set the LEDs properly on XBox Wireless controllers
Input: imx_keypad - check for clk_prepare_enable() error
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull module updates from Rusty Russell:
"Main excitement here is Peter Zijlstra's lockless rbtree optimization
to speed module address lookup. He found some abusers of the module
lock doing that too.
A little bit of parameter work here too; including Dan Streetman's
breaking up the big param mutex so writing a parameter can load
another module (yeah, really). Unfortunately that broke the usual
suspects, !CONFIG_MODULES and !CONFIG_SYSFS, so those fixes were
appended too"
* tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (26 commits)
modules: only use mod->param_lock if CONFIG_MODULES
param: fix module param locks when !CONFIG_SYSFS.
rcu: merge fix for Convert ACCESS_ONCE() to READ_ONCE() and WRITE_ONCE()
module: add per-module param_lock
module: make perm const
params: suppress unused variable error, warn once just in case code changes.
modules: clarify CONFIG_MODULE_COMPRESS help, suggest 'N'.
kernel/module.c: avoid ifdefs for sig_enforce declaration
kernel/workqueue.c: remove ifdefs over wq_power_efficient
kernel/params.c: export param_ops_bool_enable_only
kernel/params.c: generalize bool_enable_only
kernel/module.c: use generic module param operaters for sig_enforce
kernel/params: constify struct kernel_param_ops uses
sysfs: tightened sysfs permission checks
module: Rework module_addr_{min,max}
module: Use __module_address() for module_address_lookup()
module: Make the mod_tree stuff conditional on PERF_EVENTS || TRACING
module: Optimize __module_address() using a latched RB-tree
rbtree: Implement generic latch_tree
seqlock: Introduce raw_read_seqcount_latch()
Currently we are reporting the button state as inverted on all boards with
an axp209 pmic, tested on a ba10-tvbox, bananapi, bananapro, cubietruck and
utoo-p66 tablet.
The axp209 datasheet clearly states that the power button must be connected
between the PWRON key and ground. Which means that on a press we will get
a falling edge (dbf) irq not a rising one, and likewise on release we will
get a rising edge (dbr) irq, not a falling one.
This commit swaps the check for the 2 irqs fixing the inverted reporting of
the power button state.
Acked-by: Chen-Yu Tsai <wens@csie.org>
Since 39b2bbe3d715 (gpio: add flags argument to gpiod_get*() functions)
which appeared in v3.17-rc1, the gpiod_get* functions take an additional
parameter that allows to specify direction and initial value for
output. Simplify drivers accordingly.
Note that in the case of the drv260x driver error checking is more
strict now because -ENOSYS is reported to the caller now. But this
should only be returned if GPIOLIB is disabled which shouldn't happen as
the driver depends on GPIOLIB.
This adds OnKey driver support for DA9063.
Signed-off-by: Steve Twiss <stwiss.opensource@diasemi.com>
Most code already uses consts for the struct kernel_param_ops,
sweep the kernel for the last offending stragglers. Other than
include/linux/moduleparam.h and kernel/params.c all other changes
were generated with the following Coccinelle SmPL patch. Merge
conflicts between trees can be handled with Coccinelle.
In the future git could get Coccinelle merge support to deal with
patch --> fail --> grammar --> Coccinelle --> new patch conflicts
automatically for us on patches where the grammar is available and
the patch is of high confidence. Consider this a feature request.
Test compiled on x86_64 against:
* allnoconfig
* allmodconfig
* allyesconfig
@ const_found @
identifier ops;
const struct kernel_param_ops ops = {
@ const_not_found depends on !const_found @
identifier ops;
-struct kernel_param_ops ops = {
+const struct kernel_param_ops ops = {
Generated-by: Coccinelle SmPL
Cc: Junio C Hamano <gitster@pobox.com>
Cc: cocci@systeme.lip6.fr
Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
The I2C subsystem can match devices without explicit OF support based on
the part of their compatible property after the comma. However, this
mechanism uses the first compatible value only. For adxl34x OF device
nodes the compatible property will contain the more specific
"adi,adxl345" or "adi,adxl346" value first. This prevents the device
node from being matched with the adxl34x driver.
Fix this by adding an OF match table with an "adi,adxl345" compatible
entry. There's no need to add the "adi,adxl346" entry as the ADXL346 is
backward-compatible with the ADXL345 with differences handled by runtime
detection of the device model.
Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
Reviewed-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Since commit 1c6c69525b40eb76de8adf039409722015927dc3 ("genirq: Reject
bogus threaded irq requests") threaded IRQs without a primary handler
need to be requested with IRQF_ONESHOT, otherwise the request will fail.
So pass the IRQF_ONESHOT flag in this case.
The semantic patch that makes this change is available
in scripts/coccinelle/misc/irqf_oneshot.cocci.
Remove duplicated include for acpi.h.
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
