path: root/drivers/input/mouse/sentelic.c
2015-08-21Input: sentelic - silence some underflow warningsDan Carpenter
I have a static checker that complains when we check for an upper bound but don't have a corresponding check for a lower bound. With this code, the upper bound check seems not really required, so it is not a bug to leave the lower bound check out as well. But let's silence the warning by making these variables unsigned. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2012-12-24Input: sentelic - only report position of first finger as ST coordinatesChristophe TORDEUX
Report only the position of the first finger as absolute non-MT coordinates, instead of reporting both fingers alternatively. Actual MT events are unaffected. This fixes horizontal and improves vertical scrolling with the touchpad. Cc: stable@vger.kernel.org Signed-off-by: Christophe TORDEUX <christophe@tordeux.net> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2012-10-11Merge branch 'next' into for-linusDmitry Torokhov
Prepare second set of updates for 3.7 merge window (Wacom driver update and patches extending number of input minors).
2012-09-19Input: sentelic - filter out erratic movement when lifting fingerTai-hwa Liang
When lifing finger off the surface some versions of touchpad send movement packets with very low coordinates, which cause cursor to jump to the upper left corner of the screen. Let's ignore least significant bits of X and Y coordinates if higher bits are all zeroes and consider finger not touching the pad. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=43197 Reported-and-tested-by: Aleksey Spiridonov <leks13@leks13.ru> Tested-by: Eddie Dunn <eddie.dunn@gmail.com> Tested-by: Jakub Luzny <limoto94@gmail.com> Tested-by: Olivier Goffart <olivier@woboq.com> Signed-off-by: Tai-hwa Liang <avatar@sentelic.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2012-09-19Input: MT - Add flags to input_mt_init_slots()Henrik Rydberg
Preparing to move more repeated code into the mt core, add a flags argument to the input_mt_slots_init() function. Reviewed-and-tested-by: Benjamin Tissoires <benjamin.tissoires@enac.fr> Tested-by: Ping Cheng <pingc@wacom.com> Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Henrik Rydberg <rydberg@euromail.se>
2012-05-10Input: sentelic - report device's production serial numberTai-hwa Liang
Hardware since Cx supports an unique identity (used to identify OEM vendors and released lot number) which is very helpful for diagnostic purpose. This revision tries to make it as a part of driver boot up message. Whilst here, also bumping fsp_drv_ver to acknowledge recent addition of absolute coordinates output. Signed-off-by: Tai-hwa Liang <avatar@sentelic.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2012-04-03Input: sentelic - filter taps in absolute modeOskari Saarenmaa
Taps in absolute positioning single-finger mode are currently reported as physical clicks by the driver. This should be handled by userspace, not the kernel. When a tap occurs, the FSP_PB0_LBTN bit is set, but the FSP_PB0_PHY_BTN is not. We use this to filter out physical clicks from taps. Signed-off-by: Oskari Saarenmaa <os@ohmu.fi> Reviewed-by: Tai-hwa Liang <avatar@sentelic.com> Reviewed-by: Chase Douglas <chase.douglas@canonical.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2012-03-25Input: sentelic - improve packet debugging informationOskari Saarenmaa
Signed-off-by: Oskari Saarenmaa <os@ohmu.fi> Signed-off-by: Tai-hwa Liang <avatar@sentelic.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2012-03-25Input: sentelic - minor code cleanupTai-hwa Liang
Improve code readability by converting yet another magic number into a pre-defined constant. Signed-off-by: Tai-hwa Liang <avatar@sentelic.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2012-03-25Input: sentelic - enabling absolute coordinates output for newer hardwareTai-hwa Liang
- Hooking multi-finger coordinates output with kernel multitouch library; - Enabling absolute coordinates output for Cx+ hardware. The older hardware performs much better in relative mode; thus relative mode related code are preserved. Part of the code is based on the work done by Oskari Saarenmaa <os@ohmu.fi>, which was used to support the clickpad found on ASUS UX21/31 Ultrabook. On the other hand, the FSP found on UX21/31 doesn't have hardware capability register other than PnP ID, which means that we'll have to figure out an alternative approach to identify such pad correctly; otherwise, blindly adding INPUT_PROP_BUTTONPAD property may compatability issues amongst existing FSPs. Signed-off-by: Tai-hwa Liang <avatar@sentelic.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2012-03-25Input: sentelic - refactor code for upcoming new hardware supportTai-hwa Liang
- Move event bits setup code into a separate function, fsp_set_input_params(), so that we can perform hardware-specific settings in the future; - Take hardware version information into account when activating protocol; - Remove button information from boot message as it's somewhat confusing and is only for internal processing. While there, also move button retrieval code to be a part of protocol activation process. Signed-off-by: Tai-hwa Liang <avatar@sentelic.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2012-03-09Merge commit 'v3.3-rc6' into nextDmitry Torokhov
2012-02-24Input: psmouse - use psmouse_[de]activate() from sentelic and hgpk driversPaul Fox
Make use of psmouse_activate() and psmouse_deactivate() from psmouse-base.c Signed-off-by: Andres Salomon <dilinger@queued.net> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2012-01-08Merge branch 'next' into for-linusDmitry Torokhov
2011-12-29Input: sentelic - fix retrieving number of buttonsTai-hwa Liang
Fixing wrong register offset which is used to retrieve the number of buttons attached to the hardware. Signed-off-by: Tai-hwa Liang <avatar@sentelic.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-12-23Input: sentelic - release mutex upon register write failureTai-hwa Liang
Make sure that mutex is released upon register writing failure. This fixes boot freezing observed on ARM based OLPC (http://dev.laptop.org/ticket/11357). Signed-off-by: Paul Fox <pgf@laptop.org> Signed-off-by: Tai-hwa Liang <avatar@sentelic.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-11-09Input: convert obsolete strict_strtox to kstrtoxJJ Ding
With commit 67d0a0754455f89ef3946946159d8ec9e45ce33a we mark strict_strtox as obsolete. Convert all remaining such uses in drivers/input/. Also change long to appropriate types, and return error conditions from kstrtox separately, as Dmitry sugguests. Signed-off-by: JJ Ding <dgdunix@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-10-10Input: psmouse - switch to using dev_*() for messagesDmitry Torokhov
This will ensure our reporting is consistent with the rest of the system and we do not refer to obsolete source file names. Reviewed-by: Wanlong Gao <gaowanlong@cn.fujitsu.com> Reviewed-by: JJ Ding <dgdunix@gmail.com> Reviewed-by: Daniel Kurtz <djkurtz@chromium.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-06-27Input: remove unneeded version.h includesJesper Juhl
It was pointed out by 'make versioncheck' that some includes of linux/version.h are not needed in drivers/input/. This patch removes them. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-01-13Input: sentelic - fix left/right horizontal scroll mappingTai-hwa Liang
2009-11-20Input: psmouse - rework setting of BTN_MIDDLE capabilityDmitry Torokhov
Do not start protocol detection assuming that middle mouse is present, instead let individual protocols explicitly set this capability. This fixes issue with Synaptics touchpads pretending that they have middle button when hardware clearly reports otherwise. Reported-and-tested-by: Andrey Borzenkov <arvidjaar@mail.ru> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-09-17Input: libps2 - additional locking for i8042 portsDmitry Torokhov
The serio ports on i8042 are not completely isolated; while we provide enough locking to ensure proper serialization when accessing control and data registers AUX and KBD ports can still have an effect on each other on PS/2 protocol level. The most prominent effect is that issuing a command for the device connected to one port may cause abort of the command currently executing by the device connected to another port. Since i8042 nor serio subsystem are not aware of the details of the PS/2 protocol (length of the commands and their replies and so on) the locking should be done on libps2 level by adding special handling when we see that we are dealing with serio port on i8042. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-09-10Input: psmouse - use boolean typeDmitry Torokhov
2009-08-19Input: add new driver for Sentelic Finger Sensing PadTai-hwa Liang
This is the driver for Sentelic Finger Sensing Pad which can be found on MSI WIND Netbook. Signed-off-by: Tai-hwa Liang <avatar@sentelic.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
