path: root/drivers/input/mouse/synaptics.c
2012-01-11Input: synaptics - fix touchpad not working after S2R on Vostro V13Dmitry Torokhov
commit 8521478f67e95ada4e87970c7b41e504c724b2cf upstream. Synaptics touchpads on several Dell laptops, particularly Vostro V13 systems, may not respond properly to PS/2 commands and queries immediately after resuming from suspend to RAM. This leads to unresponsive touchpad after suspend/resume cycle. Adding a 1-second delay after resetting the device allows touchpad to finish initializing (calibrating?) and start reacting properly. Reported-by: Daniel Manrique <daniel.manrique@canonical.com> Tested-by: Daniel Manrique <daniel.manrique@canonical.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Change-Id: I8246905d452b12e1ce535705c746c3ff66660e09 Reviewed-on: http://git-master/r/74172 Reviewed-by: Varun Wadekar <vwadekar@nvidia.com> Tested-by: Varun Wadekar <vwadekar@nvidia.com>
2011-07-09Input: synaptics - set minimum coordinates as reported by firmwareDmitry Torokhov
Newer Synaptics firmware allows to query minimum coordinates reported by the device, let's use this data. Acked-by: Chase Douglas <chase.douglas@canonical.com> Acked-by: Henrik Rydberg <rydberg@euromail.se> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-07-06Input: synaptics - process button bits in AGM packetsDaniel Kurtz
AGM packets contain valid button bits, too. This patch refactors packet processing to parse button bits in AGM packets. However, they aren't actually used or reported. The point is to more completely process AGM packets, and prepare for future patches that may actually use AGM packet button bits. Signed-off-by: Daniel Kurtz <djkurtz@chromium.org> Acked-by: Chase Douglas <chase.douglas@canonical.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-07-06Input: synaptics - rename set_slot to be more descriptiveDaniel Kurtz
2011-07-06Input: synaptics - fuzz position for touchpad with reduced filteringDaniel Kurtz
Synaptics touchpads indicate via a capability bit when they perform reduced filtering on position data. In such a case, use a non-zero fuzz value. Fuzz = 8 was chosen empirically by observing the raw position data reported by a clickpad indicating it had reduced filtering. Signed-off-by: Daniel Kurtz <djkurtz@chromium.org> Acked-by: Chase Douglas <chase.douglas@canonical.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-07-06Input: synaptics - set resolution for MT_POSITION_X/Y axesDaniel Kurtz
Set resolution for MT_POSITION_X and MT_POSITION_Y to match ABS_X and ABS_Y, respectively. Signed-off-by: Daniel Kurtz <djkurtz@chromium.org> Acked-by: Chase Douglas <chase.douglas@canonical.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-03-31Input: synaptics - fix crash in synaptics_module_init()Jan Beulich
'struct dmi_system_id' arrays must always have a terminator to keep dmi_check_system() from looking at data (and possibly crashing) it isn't supposed to look at. The issue went unnoticed until ef8313bb1a22e7d2125d9d758aa8a81f1de91d81, but was introduced about a year earlier with 7705d548cbe33f18ea7713b9a07aa11047aaeca4 (which also similarly changed lifebook.c, but the problem there got eliminated shortly afterwards). The first hunk therefore is a stable candidate back to 2.6.33, while the full change is needed only on 2.6.38. Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: stable@kernel.org Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-01-28Input: synaptics - retry failed resets when reconnectingAlexandre Peixoto Ferreira
On some machines, like Dell Studio XPS 16 (1640), touchpad fails to respond to the standard query after first reset but may start responding later, so let's repeat reset sequence several (3) times. Signed-off-by: Alexandre Peixoto Ferreira <alexandref75@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-01-28Input: synaptics - fix reconnect logic on MT devicesAlexandre Peixoto Ferreira
synaptics_set_advanced_gesture_mode() affect capabilities bits we should perform comparison after calling this function, otherwise they will never match and we will be forced to perform full reconnect. Signed-off-by: Alexandre Peixoto Ferreira <alexandref75@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-12-27Merge branch 'next' of ↵Dmitry Torokhov
git://git.kernel.org/pub/scm/linux/kernel/git/rydberg/input-mt into next
2010-12-23Input: psmouse - disable the synaptics extension on OLPC machinesAndres Salomon
OLPC has switched to a Synaptics touchpad. It turns out that it's pretty useless in absolute mode. This patch looks for an OLPC system (via DMI tables), and refuses to init Synaptics mode in that scenario (falling back to relative mode). Signed-off-by: Andres Salomon <dilinger@queued.net> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-12-23Input: psmouse - fix up Synaptics commentAndres Salomon
Minor comment fixup for typos and grammar. Noticed while adding a separate workaround. Signed-off-by: Andres Salomon <dilinger@queued.net> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-12-22Input: synaptics - ignore bogus mt packetHenrik Rydberg
In multitouch mode, at least one device (fw: 7.4 id: 0x1c0b1) sometimes sends a final main packet with x == 1. Since the normal values are above 1472, this is clearly bogus. At the same time, a two-finger touch is signaled, even though only one finger was on the pad to begin with. This patch ignores the packet altogether, removing the problem. Acked-by: Chris Bagwell <chris@cnpbagwell.com> Acked-by: Chase Douglas <chase.douglas@canonical.com> Acked-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Henrik Rydberg <rydberg@euromail.se>
2010-12-21Input: synaptics - add multi-finger and semi-mt supportHenrik Rydberg
The Synaptics 2.7 series of touchpads support a mode for reporting two sets of X/Y/Pressure data (advanced gesture mode). By default, these devices report only single finger data, depriving userspace of the nowadays ubiquitous two-finger scroll gesture. Enabling advanced gesture mode also enables the multi-finger report, although the device does not claim that capability. Up to three fingers can be reported this way. While two or three fingers are touching, the normal packet is prepended by a reduced finger packet of lower resolution. From the two packets (which do not represent the actual fingers), the bounding rectangle of the individual contacts can be extracted. This information is sufficient to perform scaling gestures and a limited form of rotation gesture. The behavior has been coined semi-mt capability, and is signaled to userspace via the INPUT_PROP_SEMI_MT device property. Work to decode the advanced gesture packet: Takashi Iwai. Cleanup and testing of the original patch: Chase Douglas. Minor cleanup and testing: Chris Bagwell. Finalization and semi-mt support: Henrik Rydberg. Reported-by: Tobyn Bertram Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Chase Douglas <chase.douglas@canonical.com> Signed-off-by: Chris Bagwell <chris@cnpbagwell.com> Acked-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Henrik Rydberg <rydberg@euromail.se>
2010-12-21Input: synaptics - report clickpad propertyHenrik Rydberg
With the new input property interface, it is possible to report the special quirks of a device using ioctl/sysfs. This patch sets up the device as a pointer, and reports the clickpad functionality via the INPUT_PROP_BUTTONPAD property. Acked-by: Chase Douglas <chase.douglas@canonical.com> Signed-off-by: Henrik Rydberg <rydberg@euromail.se>
2010-10-13Input: synaptics - simplify pass-through port handlingDmitry Torokhov
There was too much knowledge about internals if serio in the pass-through handling, clean it up. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-10-13Input: return -ENOMEM in select drivers when memory allocation failsDavidlohr Bueso
Instead of using -1 let's start using proper error codes. Signed-off-by: Davidlohr Bueso <dave@gnu.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-08-10Merge branch 'next' into for-linusDmitry Torokhov
2010-08-02Input: switch to input_abs_*() access functionsDaniel Mack
Change all call sites in drivers/input to not access the ABS axis information directly anymore. Make them use the access helpers instead. Also use input_set_abs_params() when possible. Did some code refactoring as I was on it. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-08-02Merge branch 'next' into for-linusDmitry Torokhov
2010-07-21Input: synaptics - relax capability ID checks on newer hardwareDmitry Torokhov
Older firmwares fixed the middle byte of the Synaptics capabilities query to 0x47, but starting with firmware 7.5 the middle byte represents submodel ID, sometimes also called "dash number". Reported-and-tested-by: Miroslav Šulc <fordfrog@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-07-19Input: synaptics - set min/max for finger widthChris Bagwell
Reporting this will allow GUI config apps to correctly scale width sensitive config values (such as palm detect) to correct range. Current user apps are detecting kernels min/max=0/0 and making an assumption that it means 0/16 or 0/15. Synaptics touchpad interface guides show 4/15 are correct values but driver forces to 0 when no fingers on touchpad. Signed-off-by: Chris Bagwell <chris@cnpbagwell.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-07-19Input: synaptics - only report width on hardware that supports itChris Bagwell
Synaptics devices report fixed value of 5 for finger/palm widths on devices that do not support capability and driver further hardcodes to 5. Stop reporting this fixed value when its not supported since its not useful. This will aid applications so they can better auto-enable support for multi-touch emulation and palm detection logic using finger width only for devices that support width detection. I can find no applications that currently require existence on ABS_TOOL_WIDTH. Since only synaptics and bcm input devices currently support this tool, it seems they must handle it gracefully. Signed-off-by: Chris Bagwell <chris@cnpbagwell.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-07-14Input: synaptics - fix wrong dimensions checkTakashi Iwai
The commit 83ba9ea8a04b72dfee2515428c15e7414ba4fc61 ommitted the return line for the old synaptics model accidentally. This resulted in a wrong check, namely, the dimensions are checked for the old devices that don't support the query properly. This patch adds the return line back. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-05-19Input: psmouse - small formatting changes to better follow coding styleDmitry Torokhov
2010-05-19Input: synaptics - set dimensions as reported by firmwareDmitry Torokhov
Newer Synaptics firmware allows to query maximim dimensions reported by device, let's use this data. Tested-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-05-05Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: joydev - allow binding to button-only devices Input: elantech - ignore high bits in the position coordinates Input: elantech - allow forcing Elantech protocol Input: elantech - fix firmware version check Input: ati_remote - add some missing devices from lirc_atiusb Input: eeti_ts - cancel pending work when going to suspend Input: Add support of Synaptics Clickpad device Revert "Input: ALPS - add signature for HP Pavilion dm3 laptops" Input: psmouse - ignore parity error for basic protocols
2010-04-20Input: Add support of Synaptics Clickpad deviceTakashi Iwai
The new type of touchpads can be detected via a new query command 0x0c. The clickpad flags are in cap[0]:4 and cap[1]:0 bits. When the device is detected, the driver now reports only the left button as the supported buttons so that X11 driver can detect that the device is Clickpad. A Clickpad device gives the button events only as the middle button. The kernel driver morphs to the left button. The real handling of Clickpad is done rather in X driver side. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-01-07Input: psmouse - fix Synaptics detection when protocol is disabledDaniel Drake
For configurations where Synaptics hardware is present but the Synaptics extensions support is not compiled in, the mouse is reprobed and a new device is allocated on every suspend/resume. During probe, psmouse_switch_protocol() calls psmouse_extensions() with set_properties=1. This calls the dummy synaptics_init() which returns an error code, instructing us not to use the synaptics extensions. During resume, psmouse_reconnect() calls psmouse_extensions() with set_properties=0, in which case call to synaptics_init() is bypassed and PSMOUSE_SYNAPTICS is returned. Since the result is different from previous attempt psmouse_reconnect() fails and full re-probe happens. Fix this by tweaking the set_properties=0 codepath in psmouse_extensions() to be more careful about offering PSMOUSE_SYNAPTICS extensions. Signed-off-by: Daniel Drake <dsd@laptop.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-12-04Input: psmouse - remove identification strings from DMI tablesDmitry Torokhov
The driver does not reference identification strings in DMI tables and since these strings are no longer required by DMI core we can safely remove them and save some memory. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-12-03Input: psmouse - do not carry DMI data aroundDmitry Torokhov
DMI tables use considerable amount of memory. Mark them as __initconst so they will be discarded once module is loaded. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-10-12Input: synaptics - add another Protege M300 to rate blacklistDmitry Torokhov
Apparently some of Toshiba Protege M300 identify themselves as "Portable PC" in DMI so we need to add that to the DMI table as well. We need DMI data so we can automatically lower Synaptics reporting rate from 80 to 40 pps to avoid over-taxing their keyboard controllers. Tested-by: Rod Davison <roddavison@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-09-10Input: psmouse - use boolean typeDmitry Torokhov
2009-06-19Input: synaptics - add support for reporting x/y resolutionTero Saarni
Synaptics uses anisotropic coordinate system. On some wide touchpads vertical resolution can be twice as high as horizontal which causes unequal sensitivity on x/y directions. Add support for reading the resolution with EVIOCGABS ioctl. Signed-off-by: Tero Saarni <tero.saarni@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-02-28Input: synaptics - ensure we reset the device on resumeAndy Whitcroft
When resuming from suspend newer Synaptics touchpads do not recover correctly. Analysis of the resume sequence as applied in Linux was compared to that of other operating systems. This indicated that the other OSs were resetting the mouse before attempting to detect it (for all Synaptics touchpads, old and new). Applying this same modification fixes these newer Synaptics touchpads and brings the driver into line with common OS reset behaviour. Signed-off-by: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-11-20Input: synaptics - report multi-taps only if supported by the devicePeter Hutterer
According to Section 2.4.4 of the Synaptics TouchPad Interfacing Guide, bit 2 specifies if multi-finger detection is provided by the touchpad. Thus, only set BTN_TOOL_DOUBLETAP and BTN_TOOL_TRIPLETAP if the device actually supports it. Signed-off-by: Peter Hutterer <peter.hutterer@redhat.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2007-10-09drivers/firmware: const-ify DMI API and internalsJeff Garzik
Three main sets of changes: 1) dmi_get_system_info() return value should have been marked const, since callers should not be changing that data. 2) const-ify DMI internals, since DMI firmware tables should, whenever possible, be marked const to ensure we never ever write to that data area. 3) const-ify DMI API, to enable marking tables const where possible in low-level drivers. And if we're really lucky, this might enable some additional optimizations on the part of the compiler. The bulk of the changes are #2 and #3, which are interrelated. #1 could have been a separate patch, but it was so small compared to the others, it was easier to roll it into this changeset. Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-05-03Input: synaptics - don't complain about failed resetsDmitry Torokhov
On many laptops (Compaq, HP) the touchpad is so slow responding to reset that keyboard controller times out. The device is reset nonetheless and works fine. Kill the "synaptics reset failed" error; if device is not working then other parts of synaptics_query_hardware() will fail anyway. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2007-04-12Input: synaptics - export model bitsDmitry Torokhov
Encode synaptics model in psmouse->model so it will be exported via sysfs as input_dev->id.version and become visible for applications. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2007-03-10Input: psmouse - allow disabing certain protocol extensionsAndres Salomon
Allow ALPS, LOGIPS2PP, LIFEBOOK, TRACKPOINT and TOUCHKIT protocol extensions of psmouse to be disabled during compilation. This will allow users save some memory when they are sure that they will only use a certain type of mice. Signed-off-by: Andres Salomon <dilinger@debian.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2007-02-18Input: psmouse - properly reset mouse on shutdown/suspendDmitry Torokhov
Some people report that they need psmouse module unloaded for suspend to ram/disk to work properly. Let's make port cleanup behave the same way as driver unload. This fixes "bad state" roblem on various HP laptops, such as nx7400. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-10Input: constify psmouse driverHelge Deller
Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-04-02Input: synaptics - limit rate to 40pps on Toshiba Protege M300Richard Thrippleton
Toshiba Protege M300 also requires the same workaround as Satellites and Dynabooks - Synaptics report rate should be lowered to 40pps (from 80), otherwise KBC starts losing keypresses. Signed-off-by: Richard Thrippleton <ret28@cam.ac.uk> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-03-14Input: use kzalloc() throughout the codeEric Sesterhenn
Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-01-14Input: psmouse - attempt to re-synchronize mouse every 5 secondsDmitry Torokhov
This should help driver to deal vith KVMs that reset mice when switching between boxes. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2005-10-28[PATCH] drivers/input/mouse: convert to dynamic input_dev allocationDmitry Torokhov
Input: convert drivers/input/mouse to dynamic input_dev allocation This is required for input_dev sysfs integration Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-07-24Input: synaptics - fix setting packet size on passthrough port.Sergey Vlasov
Synaptics driver used child->type to select either 3-byte or 4-byte packet size for the pass-through port; this gives wrong results for the newer protocols. Change the check to use child->pktsize instead. Signed-off-by: Sergey Vlasov <vsu@altlinux.ru> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2005-07-11Input: synaptics - limit rate to 40pps on Toshiba DynabooksSimon Horman
Toshiba Dynabooks require the same workaround as Satellites - Synaptics report rate should be lowered to 40pps (from 80), otherwise KBC starts losing keypresses. Signed-off-by: Simon Horman <horms@valinux.co.jp> Signed-off-by: Vojtech Pavlik <vojtech@suse.cz> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
