The dummy touchkit_ps2_detect() for the CONFIG_MOUSE_PS2_TOUCHKIT=n case
shouldn't be a global function.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
The appletouch geyser3 devices found in the Intel Macs (and possibly
some later PPC ones?) send a constant stream of packets after the first
touch. This results in the kernel waking up around once every couple of
milliseconds to process them, making it almost impossible to spend any
significant amount of time in C3 state on a dynamic HZ kernel. Sending
the mode initialization code makes the device shut up until it's touched
again. This patch does so after receiving 10 packets with no interesting
content.
Signed-off-by: Soeren Sonnenburg <kernel@nn7.de>
Signed-off-by: Matthew Garrett <mjg59@srcf.ucam.org>
sysfs is now completely out of driver/module lifetime game. After
deletion, a sysfs node doesn't access anything outside sysfs proper,
so there's no reason to hold onto the attribute owners. Note that
often the wrong modules were accounted for as owners leading to
accessing removed modules.
This patch kills now unnecessary attribute->owner. Note that with
this change, userland holding a sysfs node does not prevent the
backing module from being unloaded.
For more info regarding lifetime rule cleanup, please read the
following message.
http://article.gmane.org/gmane.linux.kernel/510293
(tweaked by Greg to not delete the field just yet, to make it easier to
merge things properly.)
Signed-off-by: Tejun Heo <htejun@gmail.com>
Cc: Cornelia Huck <cornelia.huck@de.ibm.com>
Adds support for simulating a mouse using GPIO lines. The driver
needs an appropriate platform device to be created by architecture
code.
The driver has been tested on AT32AP7000 microprocessor using the
ATSTK1000 development board.
Signed-off-by: Hans-Christian Egtvedt <hcegtvedt@atmel.com>
Cortron PS/2 Trackballs (700-0001A) report the 4th button using the 4th
bit of the first packet (yes, it breaks the standard PS/2 protocol).
This patch adds an extra protocol to generate BTN_SIDE based on the 4th
bit. There's no way to detect those trackballs using any kind of special
sequence, thus the protocol must be activated explicitely by writing
into 'protocol' sysfs attribute:
echo -n "cortps" > /sys/devices/platform/i8042/serio1/protocol
Signed-off-by: Aristeu Rozanski <arozansk@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: reduce raciness when input handlers disconnect
Input: ucb1x00 - do not access input_dev->private directly
Input: logips2pp - fix typo in Kconfig
Input: db9 - do not ignore dev2 module parameter
Signed-off-by: Uwe Bugla <uwe.bugla@gmx.de>
Input: ads7846 - SPI_CPHA mode bugfix
Input: ads7846 - document that it handles tsc2046 too
Input: input-polldev - add module info
Input: ucb1x00-ts - remove commented out code
Input: ucb1400_ts - use sched_setscheduler()
Input: ALPS - force stream mode
Input: iforce - minor clean-ups
Input: iforce - fix force feedback not working
Input: adbhid - do not access input_dev->private directly
Input: logips2pp - add type 72 (PS/2 TrackMan Marble)
ALPS appears to need SETSTREAM command after reset, otherwise it
does not produce any data. Now that we do not request stream mode
by default individual drivers need to take care of it.
[Jason Riedy <ejr@cs.berkeley.edu> - fix oops]
stuff that does select USB should depend on USB_ARCH_HAS_HCD, or we'll
end up with unbuildable configs.
This is purely cosmetic: this is standard 3-button, no wheel or other
such features, so it already _worked_ just fine. This patch suppresses
a warning about the unknown model, and changes the printk from "Mouse"
to "TrackMan".
Signed-off-by: Peter Samuelson <peter@p12n.org>
This will allow concentrating all input devices in one place
in {menu|x|q}config.
master.kernel.org:/pub/scm/linux/kernel/git/dtor/input
* 'for-linus' of master.kernel.org:/pub/scm/linux/kernel/git/dtor/input: (65 commits)
Input: gpio_keys - add support for switches (EV_SW)
Input: cobalt_btns - convert to use polldev library
Input: add skeleton for simple polled devices
Input: update some documentation
Input: wistron - fix typo in keymap for Acer TM610
Input: add input_set_capability() helper
Input: i8042 - add Fujitsu touchscreen/touchpad PNP IDs
Input: i8042 - add Panasonic CF-29 to nomux list
Input: lifebook - split into 2 devices
Input: lifebook - add signature of Panasonic CF-29
Input: lifebook - activate 6-byte protocol on select models
Input: lifebook - work properly on Panasonic CF-18
Input: cobalt buttons - separate device and driver registration
Input: ati_remote - make button repeat sensitivity configurable
Input: pxa27x - do not use deprecated SA_INTERRUPT flag
Input: ucb1400 - make delays configurable
Input: misc devices - switch to using input_dev->dev.parent
Input: joysticks - switch to using input_dev->dev.parent
Input: touchscreens - switch to using input_dev->dev.parent
Input: mice - switch to using input_dev->dev.parent
Fixed up conflicts with core device model removal of "struct subsystem" manually.
Atari keyboard and mouse support.
(reformating and Kconfig fixes by Roman Zippel)
Signed-off-by: Michael Schmitz <schmitz@debian.org>
Signed-off-by: Roman Zippel <zippel@linux-m68k.org>
On many laptops (Compaq, HP) the touchpad is so slow responding
to reset that keyboard controller times out. The device is reset
nonetheless and works fine. Kill the "synaptics reset failed"
error; if device is not working then other parts of
synaptics_query_hardware() will fail anyway.
Have lifebook protocol register 2 separate input devices -
one for the touchscreen reporting absolute coordinates and
touches and another one for touchpad reporting relative
coordinates and left and right button presses.
It appears that if we turn on 6-byte Lifebook protocol on
Panasonic CF-28 its touchpad is left alone and generates
standard 3-byte PS/2 data stream with relative packets
instead of being converted in 3-byte Lifebook protocol with
absolute coordinates - in other words what get what we need
to distinguish between touchscreen and touchpad.
Panasonic CF18 has an active multiplexing controller with
touchscreen connected to one port and a touchpad to another.
Use "phys" from serio port to activate lifebook protoocol
only on the port that has touchscreen connected to it.
In preparation for struct class_device -> struct device input
core conversion, switch to using input_dev->dev.parent when
specifying device position in sysfs tree.
It turns out I had an old 2-button Logitech mouse that responds
to Logitech's queries with model of 1.
There are mice reporting to logitech's queries with model
of 0. Do not claim that these are Logitech mice.
Encode synaptics model in psmouse->model so it will be
exported via sysfs as input_dev->id.version and become
visible for applications.
When using MS protocol the driver should wait for a byte with
bit 6 set before assuming that it sees beginning of a data packet.
This should allow driver better cope with lost bytes and prevent
spurious left/right button events when serial communication is
disturbed by a CPU-hungry real-time process.
Also fix some formatting.
Signed-off-by: Peter Osterlund <petero2@telia.com>
Allow ALPS, LOGIPS2PP, LIFEBOOK, TRACKPOINT and TOUCHKIT protocol
extensions of psmouse to be disabled during compilation. This will
allow users save some memory when they are sure that they will only
use a certain type of mice.
Signed-off-by: Andres Salomon <dilinger@debian.org>
Forcing stream mode after reset confuses some devices (reported
by Andrea Arcangeli) so let's take it out - spec says that after
reset mouse should already be in stream mode.
Signed-off-by: Helge Deller <deller@gmx.de>
Based on the touchkit USB and lifebook PS/2 touchscreen driver.
The egalax touchsreen controller (PS/2 or USB version) is used in this 7"
device: http://www.cartft.com/catalog/il/449
Signed-off-by: Michal Piotrowski <michal.k.k.piotrowski@gmail.com>
They have been marked as __obsolete_setup() for several years,
it is time for them to go.
Some people report that they need psmouse module unloaded
for suspend to ram/disk to work properly. Let's make port
cleanup behave the same way as driver unload.
This fixes "bad state" roblem on various HP laptops, such
as nx7400.
After Al Viro (finally) succeeded in removing the sched.h #include in module.h
recently, it makes sense again to remove other superfluous sched.h includes.
There are quite a lot of files which include it but don't actually need
anything defined in there. Presumably these includes were once needed for
macros that used to live in sched.h, but moved to other header files in the
course of cleaning it up.
To ease the pain, this time I did not fiddle with any header files and only
removed #includes from .c-files, which tend to cause less trouble.
Compile tested against 2.6.20-rc2 and 2.6.20-rc2-mm2 (with offsets) on alpha,
arm, i386, ia64, mips, powerpc, and x86_64 with allnoconfig, defconfig,
allmodconfig, and allyesconfig as well as a few randconfigs on x86_64 and all
configs in arch/arm/configs on arm. I also checked that no new warnings were
introduced by the patch (actually, some warnings are removed that were emitted
by unnecessarily included header files).
Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Change the apparently incorrect check for CONFIG_INPUT_ATIXL
in a source file to be consistent with the kernel config
option CONFIG_MOUSE_ATIXL.
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com>
The driver should return -ENODEV rather than -ENOENT when it
detects a PCI device in the box.
drivers/usb/input/hid.h
Fix up for make allyesconfig.
Signed-Off-By: David Howells <dhowells@redhat.com>
psmouse_show_int_attr() and psmouse_set_int_attr() were accessing
unsigned int fields as unsigned long, which gave garbage on x86_64.
Signed-off-by: Sergey Vlasov <vsu@altlinux.ru>
Signed-off-by: Jeff Garzik <jeff@garzik.org>
Also use kzalloc instead of kcalloc since we are allocating single object.
This adds another DMI detected touchscreen. It is exactly the same
driver as the existing ones, but this allows it to be detected on the
Hitachi Flora-IE 55mi tablet. The original Midori drivers are "abeo
antiquus". This should allow new life for these machines.
Enable HIL configuration options on HP300
Signed-off-by: Kars de Jong <jongk@linux-m68k.org>
Signed-off-by: Matthew Wilcox <matthew@wil.cx>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead
of passing regs around manually through all ~1800 interrupt handlers in the
Linux kernel.
The regs pointer is used in few places, but it potentially costs both stack
space and code to pass it around. On the FRV arch, removing the regs parameter
from all the genirq function results in a 20% speed up of the IRQ exit path
(ie: from leaving timer_interrupt() to leaving do_IRQ()).
Where appropriate, an arch may override the generic storage facility and do
something different with the variable. On FRV, for instance, the address is
maintained in GR28 at all times inside the kernel as part of general exception
handling.
Having looked over the code, it appears that the parameter may be handed down
through up to twenty or so layers of functions. Consider a USB character
device attached to a USB hub, attached to a USB controller that posts its
interrupts through a cascaded auxiliary interrupt controller. A character
device driver may want to pass regs to the sysrq handler through the input
layer which adds another few layers of parameter passing.
I've build this code with allyesconfig for x86_64 and i386. I've runtested the
main part of the code on FRV and i386, though I can't test most of the drivers.
I've also done partial conversion for powerpc and MIPS - these at least compile
with minimal configurations.
This will affect all archs. Mostly the changes should be relatively easy.
Take do_IRQ(), store the regs pointer at the beginning, saving the old one:
struct pt_regs *old_regs = set_irq_regs(regs);
And put the old one back at the end:
set_irq_regs(old_regs);
Don't pass regs through to generic_handle_irq() or __do_IRQ().
In timer_interrupt(), this sort of change will be necessary:
- update_process_times(user_mode(regs));
- profile_tick(CPU_PROFILING, regs);
+ update_process_times(user_mode(get_irq_regs()));
+ profile_tick(CPU_PROFILING);
I'd like to move update_process_times()'s use of get_irq_regs() into itself,
except that i386, alone of the archs, uses something other than user_mode().
Some notes on the interrupt handling in the drivers:
(*) input_dev() is now gone entirely. The regs pointer is no longer stored in
the input_dev struct.
(*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does
something different depending on whether it's been supplied with a regs
pointer or not.
(*) Various IRQ handler function pointers have been moved to type
irq_handler_t.
(cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
