path: root/drivers/input/serio/i8042-x86ia64io.h
2011-01-08Input: i8042 - introduce 'notimeout' blacklist for Dell Vostro V13Jiri Kosina
i8042 controller present in Dell Vostro V13 errorneously signals spurious timeouts. Introduce i8042.notimeout parameter for ignoring i8042-signalled timeouts and apply this quirk automatically for Dell Vostro V13, based on DMI match. In addition to that, this machine also needs to be added to nomux blacklist. Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-12-27Input: i8042 - add Acer Aspire 5100 to the Dritek listPali Rohár
This patch adds notebook Acer Aspire 5100 to the list of Dritek HW. Acer Aspire 5100 needs Dritek keyboard extension to support all Fn keys. Signed-off-by: Pali Rohár <pali.rohar@gmail.com> Tested-by: Pali Rohár <pali.rohar@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-11-30Input: i8042 - use pr_<level>, pr_fmt, fix dbg and __FILE__ useJoe Perches
Standardized message logging prefixes. Removed \n from dbg macro, added \n to each dbg call site. Removed direct use of __FILE__ from dbg, converted to pr_fmt(fmt) Added non-debug printf argument verification of dbg calls Removed "i8042.c" from printks, converted to pr_<level> Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-11-04Input: i8042 - add Sony VAIOs to MUX blacklistJesse Barnes
The Sony VPCZ1 doesn't support active multiplexing and trying to enable it causes keyboard to stop working. Since most (all?) VAIOs do not have external PS/2 ports nor they implement active multiplexing properly, and trying to enable MUX usually messes up keyboard/touchpad, let's simply disable MUX probing based on board name (VAIO). Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-07-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: synaptics - relax capability ID checks on newer hardware Input: twl40300-keypad - fix handling of "all ground" rows Input: gamecon - reference correct pad in gc_psx_command() Input: gamecon - reference correct input device in NES mode Input: w90p910_keypad - change platfrom driver name to 'nuc900-kpi' Input: i8042 - add Gigabyte Spring Peak to dmi_noloop_table Input: qt2160 - rename kconfig symbol name
2010-07-19Input: i8042 - add Gigabyte Spring Peak to dmi_noloop_tableKamal Mostafa
Gigabyte "Spring Peak" notebook indicates wrong chassis-type, tripping up i8042 and breaking the touchpad. Add this model to i8042_dmi_noloop_table[] to resolve. BugLink: https://bugs.launchpad.net/bugs/580664 Signed-off-by: Kamal Mostafa <kamal@canonical.com> Cc: stable@kernel.org Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-07-07input: i8042 - add runtime check in x86's i8042_platform_initFeng Tang
Then it will first check x86_platforms's i8042 detection result, then go on with normal probe. Signed-off-by: Feng Tang <feng.tang@intel.com> LKML-Reference: <4c34dd482753bb8f1@agluck-desktop.sc.intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com> Acked-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2010-05-19Input: i8042 - add a PNP entry to the aux device listMatthew Garrett
Windows checks for an ALPS PS/2 device in PNP. Add it on the off-chance that there's a machine that expresses this without also providing a compatibility ID. Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-05-19Input: i8042 - add some extra PNP keyboard typesMatthew Garrett
Some Japanese machines declare their keyboard with a different PNP ID. Add it to the list of probed device IDs. While we're at it, add all the other IDs that Windows binds to - we'll probably never see them in the real world, but it doesn't hurt. Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-03-13Input: i8042 - add ALDI/MEDION netbook E1222 to qurik reset tableChristoph Fritz
ALDI/MEDION netbook E1222 needs to be in the reset quirk list for its touchpad's proper function. Reported-by: Michael Fischer <mifi@gmx.de> Signed-off-by: Christoph Fritz <chf.fritz@googlemail.com> Cc: stable@kernel.org Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-03-09Input: enable remote wakeup for PNP i8042 keyboard portsAlan Stern
This patch (as1355) enables remote wakeup by default on PNP i8042 keyboard ports. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-01-11Input: i8042 - add Dritek quirk for Acer Aspire 5610.Elliott Sales de Andrade
Signed-off-by: Elliott Sales de Andrade <quantum.analyst@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-12-15Input: i8042 - add Gigabyte M1022M to the noloop listDmitry Torokhov
Gigabyte netbook model M1022M requires i8042.noloop, otherwise AUX port will not detected and the touchpad will not work. Unfortunately chassis type in DMI set to "Other" and thus generic laptop entry does not fire on it. Reported-by: Darryl Bond <dbond@nrggos.com.au> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-12-04Input: i8042 - remove identification strings from DMI tablesDmitry Torokhov
The driver does not reference identification strings in DMI tables and since these strings are no longer required by DMI core we can safely remove them and save some memory. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-12-02Input: i8042 - add Dell Vostro 1320, 1520 and 1720 to the reset listAnisse Astier
These laptops often leave i8042 in a wierd state resulting in non- operational touchpad and keyboard. Signed-off-by: Anisse Astier <anisse@astier.eu> Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-18Input: i8042 - add Sony Vaio VGN-FZ240E to the nomux listDmitry Torokhov
On this model, when KBD is in active multiplexing mode, acknowledgements to reset and get ID commands issued on KBD port sometimes are delivered to AUX3 port (touchpad) which messes up device detection. Legacy KBC mode works fine and since there are no external PS/2 ports on this laptop and no support for docking station we can safely disable active MUX mode. Tested-by: Carlos R. Mafra <crmafra2@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-10-12Input: i8042 - make pnp_data_busted variable boolean instead of intDmitry Torokhov
This small snippet escaped last round of int -> bool conversion. Reported-by: Joe Perches <joe@perches.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-09-13Merge branch 'next' into for-linusDmitry Torokhov
2009-09-10Input: i8042 - use boolean type where it makes senseDmitry Torokhov
2009-09-10Input: i8042 - bypass AUX IRQ delivery test on laptopsDmitry Torokhov
It seems that many laptops do not fully implement AUX LOOP command in their keyboard controllers, causing issues with touchpad detection. We know however that almost every laptop/portable uses a PS/2 pointing device and, even if user disables it in favor of an external mouse, the system will not use IRQ 12 for anything else. Therefore we may bypass AUX IRQ delivery test when running on a laptop and assume that it is routed properly. Just to be safe we require the box to have good PNP data in order to bypass the test. [Jin Dongming <jin.dongming@np.css.fujitsu.com>: fix crash caused by missing terminator in the DMI table] Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-08-26Input: i8042 - add Acer Aspire 5536 to the nomux listDmitry Torokhov
When KBC is in active multiplexing mode, disabling and re-enabling the touchpad with the special key leaves the touchpad dead. Since the laptop does not have any external PS/2 ports disabling MUX mode should be safe. Reported-by: Eugeniy Meshcheryakov <eugen@debian.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-08-05Input: i8042 - add Asus G1S to noloop exception listJory A. Pratt
The synaptic touchpad on the Asus G1S is not properly detected when rebooting machine or on cold boot from time to time. Adding the Asus G1S to the noloop exception table resolves the issue. # dmidecode 2.10 SMBIOS 2.4 present. Handle 0x0001, DMI type 1, 27 bytes System Information Manufacturer: ASUSTeK Computer Inc. Product Name: G1S Version: 1.0 Wake-up Type: Power Switch SKU Number: Family: Signed-off-by: Jory A. Pratt <geekypenguin@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-06-28Input: i8042 - more reset quirks for MSI Wind-clone netbooksYan Li
When testing Moblin on various netbooks, we've got reports that many MSI Wind clones need the i8042 reset quirks for the keyboard and/or touchpad's proper function. Signed-off-by: Yan Li <yan.i.li@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-04-11Input: i8042 - add a DMI table for the i8042.reset optionArjan van de Ven
There are several DMI tables in the i8042 (keyboard) driver already, but not one for the i8042.reset option. This patch adds such an option. Two users for this table are added as well, the MSI Wind U-100 and the LG X110. The MSI Wind also needs to be in the "don't trust the pnp data" for the touchpad to work on my machine. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-04-07Input: i8042 - add HP DV9700 to the noloop listDmitry Torokhov
Reported-by: Kenneth Crudup <kenny@panix.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-01-06Input: i8042 - add Dell Vostro 1510 to nomux listJiri Kosina
Dell Vostro needs 'nomux' quirk, otherwise the touchpad misbehaves. Reported-by: Robert Kiwanuka <robert.kiwanuka@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-12-20Input: i8042 - add Gigabyte M912 netbook to noloop exception tableOzan Çağlayan
Gigabyte M912's touchpad needs i8042.noloop for working. Signed-off-by: Ozan Çağlayan <ozan@pardus.org.tr> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-11-19Input: i8042 - add Compal Hel80 laptop to nomux blacklistDmitry Torokhov
Reported-by: Jaime Cura <jimyx17@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-11-11Input: i8042 - add Dell XPS M1530 to nomux listHerton Ronaldo Krzesinski
Dell XPS M1530 needs i8042.nomux=1 for ALPS touchpad to work as reported on https://qa.mandriva.com/show_bug.cgi?id=43532 It is said that before A08 bios version this isn't needed (I don't have the hardware so can't check), and suppose this will not break with bios versions before A08. Signed-off-by: Herton Ronaldo Krzesinski <herton@mandriva.com.br> Tested-by: Andreas Ericsson <ae@op5.se> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-10-16Input: i8042 - add Blue FB5601 to noloop exception tableStefan Bader
Signed-off-by: Stefan Bader <stefan.bader@canonical.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-10-15Merge branch 'next' into for-linusDmitry Torokhov
2008-10-13Input: i8042 - add Thinkpad R31 to nomux listColin B Macdonald
Thinkpad R31 needs i8042 nomux quirk. Stops jittery jumping mouse and random keyboard input. Fixes kernel bug #11723. Cherry picked from Ubuntu who have sometimes (on-again-off-again) had a fix in their patched kernels. Signed-off-by: Colin B Macdonald <cbm@m.fsf.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-09-04Input: i8042 - make Lenovo 3000 N100 blacklist entry more specificJiri Kosina
Apparently, there are more different versions of Lenovo 3000 N100, some of them working properly with active mux, and some of them requiring it being switched off. This patch applies 'nomux' only to the specific product name that is reported to behave badly unless 'nomux' is specified. Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-08-06Input: i8042 - Add Dritek quirk for Acer TravelMate 4280Carlos Corbacho
Reported-by: Mattias Jernberg <nostrad@gmail.com> Signed-off-by: Carlos Corbacho <carlos@strangeworlds.co.uk> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-07-19Input: i8042 - add Arima-Rioworks HDAMB board to noloop listDmitry Torokhov
The board does not raise AUX IRQ in response to AUX LOOP command. Reported-by: Guillaume Morin <guillaume@morinfr.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-07-07Input: i8042 - add Dritek quirk for Acer Aspire 5720Carlos Corbacho
The Acer Aspire 5720 series also requires the Dritek quirk to enable the extra scancodes. Signed-off-by: Carlos Corbacho <carlos@strangeworlds.co.uk> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-07-03Input: i8042 - add Medion NAM 2070 to noloop blacklistDmitry Torokhov
AUX LOOP command fails with a timeout although this laptop has a touchpad. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-07-03Input: i8042 - add Gericom Bellagio to nomux blacklistJiri Kosina
Gericom Bellagio needs to be added to nomux blacklist, otherwise its touchpad misbehaves. Reported-by: Roland Kletzing <roland.kletzing@materna.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-07-03Input: i8042 - add Acer Aspire 1360 to nomux blacklistJiri Kosina
Acer Aspire 1360 needs to be added to nomux blacklist, otherwise its touchpad misbehaves. Reported-by: Clark Tompsett <clarkt@cnsp.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-06-17Merge branch 'for-linus' into nextDmitry Torokhov
Conflicts: drivers/input/mouse/appletouch.c
2008-06-06Input: i8042 - add Fujitsu-Siemens Amilo Pro V2030 to nomux tableJiri Kosina
Fujitsu Siemens Amilo Pro V2030 needs nomux table entry, in addition to already existing entry for V2010 model (note that Fujitsu-Siemens changed the capitalization in the DMI data for product). Tested-by: Jiri Mleziva <jmleziva@tiscali.cz> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-05-29Input: i8042 - add Intel D845PESV to nopnp listJiri Kosina
This patch introduces i8042_dmi_nopnp_table to make it possible to perform DMI matches for systems that need 'i8042.nopnp' to work correctly, and introduces such an entry for Intel D845PESV -- this system doesn't detect PS2 mouse reliably without this option, as reported by Robert Lewis. [dtor@mail.ru - make it compile if CONFIG_PNP is off - reported by Randy Dunlap] Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-05-20Input: i8042 - add Dritek quirk for Acer TravelMate 660Bruno Prémont
The Acer TravelMate 660 series also requires the Dritek quirk to enable the extra scancodes. Signed-off-by: Bruno Prémont <bonbons@linux-vserver.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-04-24Input: i8042 - fix incorrect usage of strncpy and strncatRoel Kluin
Fix incorrect length argument for strncpy and strncat by replacing them with strlcpy and strlcat Signed-off-by: Roel Kluin <12o3l@tiscali.nl> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-03-14Input: i8042 - add Lenovo 3000 N100 to nomux blacklistJiri Kosina
Lenovo 3000 N100 needs entry in nomux blacklist. Reported-by: Christopher Desjardins <cddesjardins@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-01-30Input: i8042 - add Fujitsu-Siemens Amilo Pro 2010 to nomux listJiri Kosina
Reported-by: Hans Aschauer <Hans.Aschauer@web.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-01-30Input: i8042 - enable DMI quirks on x86-64Bruce Duncan
If firmware does not implement AUX_LOOP comand in 32 bit mode it is unlikely to implement it in 64 bit mode. Same goes for active multiplexing. See: http://bugzilla.kernel.org/show_bug.cgi?id=9664 Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-01-30Input: i8042 - add Dritek quirk for Acer Aspire 9110Carlos Corbacho
The Acer Aspire 9110 series also requires the Dritek quirk to enable the extra scancodes. Signed-off-by: Carlos Corbacho <carlos@strangeworlds.co.uk> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-01-21Input: i8042 - add Dritek keyboard extension quirkCarlos Corbacho
Some Wistron based laptops need us to explicitly enable the 'Dritek keyboard extension' to make their extra keys start generating scancodes. Originally, this was just confined to older laptops, but a few Acer laptops have turned up in 2007 that also need this again. Signed-off-by: Carlos Corbacho <carlos@strangeworlds.co.uk> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2007-11-21Input: i8042 - add i8042.noloop quirk for MS Virtual MachineJiri Kosina
When booting under Microsoft Virtual Machine, the noloop quirk is needed, otherwise PS/2 mouse is not properly detected. Reported-by: Lawrence Steeger <vendor@russte.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
