Use the wrapper functions for getting and setting the driver data using
spi_device instead of using dev_{get|set}_drvdata with &spi->dev, so we
can directly pass a struct spi_device.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
CONFIG_HOTPLUG is going away as an option so __devexit is no
longer needed.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
CONFIG_HOTPLUG is going away as an option so __devinit is no longer
needed.
Acked-by: Javier Martinez Canillas <javier@dowhile0.org>
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer
needed.
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
This patch converts the drivers in drivers/input/* to use the
module_spi_driver() macro which makes the code smaller and a bit
simpler.
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (64 commits)
Input: tc3589x-keypad - add missing kerneldoc
Input: ucb1400-ts - switch to using dev_xxx() for diagnostic messages
Input: ucb1400_ts - convert to threaded IRQ
Input: ucb1400_ts - drop inline annotations
Input: usb1400_ts - add __devinit/__devexit section annotations
Input: ucb1400_ts - set driver owner
Input: ucb1400_ts - convert to use dev_pm_ops
Input: psmouse - make sure we do not use stale methods
Input: evdev - do not block waiting for an event if fd is nonblock
Input: evdev - if no events and non-block, return EAGAIN not 0
Input: evdev - only allow reading events if a full packet is present
Input: add driver for pixcir i2c touchscreens
Input: samsung-keypad - implement runtime power management support
Input: tegra-kbc - report wakeup key for some platforms
Input: tegra-kbc - add device tree bindings
Input: add driver for AUO In-Cell touchscreens using pixcir ICs
Input: mpu3050 - configure the sampling method
Input: mpu3050 - ensure we enable interrupts
Input: mpu3050 - add of_match table for device-tree probing
Input: sentelic - document the latest hardware
Fix up fairly trivial conflicts (device tree matching conflicting with
some independent cleanups) in drivers/input/keyboard/samsung-keypad.c
In ancient times it was necessary to manually initialize the bus field of an
spi_driver to spi_bus_type. These days this is done in spi_driver_register(),
so we can drop the manual assignment.
The patch was generated using the following coccinelle semantic patch:
// <smpl>
identifier _driver;
struct spi_driver _driver = {
.driver = {
- .bus = &spi_bus_type,
// </smpl>
With commit 67d0a0754455f89ef3946946159d8ec9e45ce33a we mark strict_strtox
as obsolete. Convert all remaining such uses in drivers/input/.
Also change long to appropriate types, and return error conditions
from kstrtox separately, as Dmitry sugguests.
Signed-off-by: JJ Ding <dgdunix@gmail.com>
A pending cleanup will mean that module.h won't be implicitly
everywhere anymore. Make sure the modular drivers in input dir
are actually calling out for <module.h> explicitly in advance.
There is a move to deprecate bus-specific PM operations and move to
using dev_pm_ops instead in order to reduce the amount of boilerplate
code in buses and facilitate updates to the PM core. Do this move for
the ad7879 SPI driver.
Acked-by: Michael Hennerich <Michael.Hennerich@analog.com>
Instead of using asynchronous SPI API and then spinning waiting for SPI
transfer to complete when disabling the device, let's use threaded IRQ
model and spi_sync().
Acked-by: Michael Hennerich <michael.hennerich@analog.com>
Tested-by: Michael Hennerich <michael.hennerich@analog.com>
Instead of manually creating one set of attributes or another set up
is_visible method in attribute group structure to control whether
aux3 or gpio3 attribute is presented to userspace.
Suppress events where pressure > pressure_max.
These events come typically along with inaccurate X and Y samples.
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com>
Some input users such as Android or X require BTN_TOUCH events.
Implement EV_KEY:BTN_TOUCH and make sure that the release event
is not erroneous scheduled without a preceding valid touch.
According to the AD7877 datasheet:
Each transfer operation is 16-bit. If multiple read/write operations are
to be performed, CS must be taken high after the end of each read/write
operation before another read/write operation can be performed by
taking CS low again.
Make sure CS toggles after each transfer in the message.
With no word size given in the users platform data, a generic spi host
controller driver will assume a default word size of eight bit. This
causes transmission to be performed bytewise, which will fail on little
endian machines for sure. Failure on big endian depends on usage
of slave select to mark word boundaries.
Anyway, ad7877 is specified to work with 16 bit per word, so
unconditionally set the word size accordingly. Flag an error where 16
bit per word is not available.
Signed-off-by: Oskar Schirmer <os@emlix.com>
Signed-off-by: Daniel Glöckner <dg@emlix.com>
Signed-off-by: Oliver Schneidewind <osw@emlix.com>
With dma based spi transmission, data corruption is observed
occasionally. With dma buffers located right next to msg and
xfer fields, cache lines correctly flushed in preparation for
dma usage may be polluted again when writing to fields in the
same cache line.
Make sure cache fields used with dma do not share cache lines
with fields changed during dma handling. As both fields are part
of a struct that is allocated via kzalloc, thus cache aligned,
moving the fields to the 1st position and insert padding for
alignment does the job.
Signed-off-by: Johannes Weiner <jw@emlix.com>
[dtor@mail.ru - changed to use ___cacheline_aligned as suggested
by akpm]
The time interval between consecutive interrupts depends on a number of
tunables: first_conversion_delay, acquisition_time, averaging and foremost
the pen_down_acc_interval.
Since the mod_timer() action for the PEN UP event happens in the
spi_async() callback function, latencies incurred by the spi bus drivers
also need to be taken into account.
So all in all, give the PEN UP event a bit more wiggle room and increase
timeout to 100ms.
This makes it consistent with other buses (platform, i2c, vio, ...). I'm
not sure why we use the prefixes, but there must be a reason.
This was easy enough to do it, and I did it.
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
Cc: David Brownell <dbrownell@users.sourceforge.net>
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: Jean Delvare <khali@linux-fr.org>
Cc: Ben Dooks <ben-linux@fluff.org>
Cc: Dmitry Torokhov <dtor@mail.ru>
Cc: Samuel Ortiz <sameo@openedhand.com>
Cc: "John W. Linville" <linville@tuxdriver.com>
Acked-by: Mike Frysinger <vapier.adi@gmail.com>
This patch removes depreciated IRQF_SAMPLE_RANDOM flags from
ad7877 and ad7879 touchscreen drivers.
[dtor@mail.ru: locking and other fixups]
Signed-off-by: Bryan Wu <bryan.wu@analog.com>
