[ Upstream commit 20bbb312079494a406c10c90932e3c80837c9d94 ]
This is how userspace checks for touchscreen devices most reliably.
Signed-off-by: Martin Kepplinger <martink@posteo.de>
i2c_driver does not need to set an owner because i2c_register_driver()
will set it.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Use __maybe_unused instead of ifdef guards around suspend/resume
functions, in order to increase build coverage and fix build warnings.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Rework dev_pm_qos_add_ancestor_request() so that device PM QoS type
is passed to it as the third argument and make it support the
DEV_PM_QOS_LATENCY_TOLERANCE device PM QoS type (in addition to
DEV_PM_QOS_RESUME_LATENCY).
That will allow the drivers of devices without latency tolerance
hardware support to use their ancestors having it as proxies for
their latency tolerance requirements.
Use the wrapper function for retrieving the platform data instead
of accessing dev->platform_data directly. This is a cosmetic change
to make the code simpler and enhance the readability.
Acked-by: Fugang Duan <B38611@freescale.com>
'of_match_ptr' is defined in linux/of.h. Include it explicitly.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
We add the possibility to hand over a GPIO number for the reset pin.
This way we can remove existing board code that takes care of it and
group this information properly in the platform data or in the device
tree configuration.
Signed-off-by: Bastian Hecht <hechtb+renesas@gmail.com>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Use the devm_* managed functions to allocate resources.
Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
CONFIG_HOTPLUG is going away as an option so __devexit is no
longer needed.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
CONFIG_HOTPLUG is going away as an option so __devinit is no longer
needed.
Acked-by: Javier Martinez Canillas <javier@dowhile0.org>
CONFIG_HOTPLUG is going away as an option so __devinitconst is no
longer needed.
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer
needed.
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Acked-by: Rafael J. Wysocki <rjw@sisk.pl>
Reviewed-by: Simon Horman <horms@verge.net.au>
This patch enables DT support for the st1232 driver
which is primarily used on the sh7372 Mackerel board.
[dtor@mail.ru: chnaged to use CONFIG_OF and of_match_ptr]
Signed-off-by: Magnus Damm <damm@opensource.se>
This patch converts the drivers in drivers/input/* to use the
module_i2c_driver() macro which makes the code smaller and a bit
simpler.
Make the st1232 driver use dev_pm_qos_add_ancestor_request() to
add a device PM QoS latency constraint for the controller it
depends on, so that the controller won't go into an overly deep
low-power state when the touchscreen has to be particularly
responsive (e.g. when the user moves his or her finger on it).
This change is based on a prototype patch from Guennadi Liakhovetski.
This patch introduces support for Sitronix ST1232 integrated capacitive
touchscreen with LCD module. The touchscreen is multitouch capable and
can report coordinates of up to two contact points.
Signed-off-by: Tony SIM <chinyeow.sim.xt@renesas.com>
Reviewed-by: Trilok Soni <tsoni@codeaurora.org>
Acked-by: Henrik Rydberg <rydberg@euromail.se>
