Add logic to wm97xx_read_aux_adc() to retry reading the adc if the
sample failed. This could occur if the previous sample was still in
the return register or the sample timed-out. Also avoid a pathologic
failure mode by disabling the digitizer and returning -EBUSY after 5
retries.
Signed-off-by: Eric Millbrandt <emillbrandt@dekaresearch.com>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Use platform_device_del() instead of platform_device_unregister() in error
handling path.
Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
Acked-by: Mark Brown <broonie@opensoruce.wolfsonmicro.com>
WM97XX_GPIO_HIGH is not a bitmap and should to be treated as such.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6
drivers/power/wm97xx_battery.c
Acked-by: Dmitry Torokhov <dtor@mail.ru>
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
This patch allows tweaking the behaviour of GPIO_STATUS register
shift quirk that's in wm97xx-core. The problem with GPIO_STATUS
register being shifted by one doesn't appear on all hardware it
seems and causes problems with accelerated touchscreen drivers on
Palm hardware. Therefore an accelerated touchscreen driver can select
if the shift is/isn't happening on the hardware.
In the near future, the driver core is going to not allow direct access
to the driver_data pointer in struct device. Instead, the functions
dev_get_drvdata() and dev_set_drvdata() should be used. These functions
have been around since the beginning, so are backwards compatible with
all older kernel versions.
Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Cc: linux-input@vger.kernel.org
The input core will add entropy to the pool so this flag is not
needed.
Android expects BTN_TOUCH events when pen state changes. Add BTN_TOUCH
event reporting to allow use of wm97xx touchscreen controller wiht
Android devices.
Signed-off-by: Mike Rapoport <mike@compulab.co.il>
This updates the email address for Liam Girdwood as my old address is no
longer valid.
Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
If a driver dies not use LINUX_VERSION_CODE nor KERNEL_VERSION
then it does not need to include version.h
Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com>
The chip phy_init() function must be called before the dig_enable() function
but dig_enable() is called when the device is opened and we only call
phy_init() after having reigstered the device, meaning the two can race.
Fix this by doing the phy_init() before we register the input device.
Thanks to Rodolfo Giometti <giometti@enneenne.com> for the report.
Fix driver name - thanks to Guennadi Liakhovetski <g.liakhovetski@gmx.de> for
reporting this.
phys is displayed in diagnostic output like that from evbug so ensure
that it is set to something.
The WM97xx touch screen controllers can be used to generate a wakeup
event when the system is suspended. Provide a new core API call
wm97xx_set_suspend_mode() allowing machine drivers to enable this. If no
suspend_mode is provided then the touch panel will be powered down when
The touchscreen interrupt is driven by human input which can reasonably
be used to provide entropy.
As well as clarifying the fact that the driver can cope if a second
interrupt occurs before the IRQ work is scheduled this also ensures
that calls to the machine irq_enable() are balanced, making that easier
to implement. Normally this is redundant due to the interrupt disabling
but some unusal board configurations can trigger it.
Add support for the touchscreen controllers provided by Wolfson
Microelectronics WM97xx series chips in both polled and streaming
modes.
These drivers have been maintained out of tree since 2003. During
that time the driver the primary maintainer was Liam Girdwood and
a number of people have made contributions including Dmitry Baryshkov,
Stanley Cai, Rodolfo Giometti, Russell King, Marc Kleine-Budde,
Ian Molton, Vincent Sanders, Andrew Zabolotny, Graeme Gregory,
Mike Arthur and myself. Apologies to anyone I have omitted.
Signed-off-by: Liam Girdwood <liam.girdwood@wolfsonmicro.com>
Signed-off-by: Graeme Gregory <gg@opensource.wolfsonmicro.com>
Signed-off-by: Mike Arthur <mike.arthur@wolfsonmicro.com>
