path: root/drivers/input
2011-03-19Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (64 commits) Input: tsc2005 - remove 'disable' sysfs attribute Input: tsc2005 - add open/close Input: tsc2005 - handle read errors from SPI layer Input: tsc2005 - do not rearm timer in hardirq handler Input: tsc2005 - don't use work for 'pen up' handling Input: tsc2005 - do not use 0 in place of NULL Input: tsc2005 - use true/false for boolean variables Input: tsc2005 - hide selftest attribute if we can't reset Input: tsc2005 - rework driver initialization code Input: tsc2005 - set up bus type in input device Input: tsc2005 - set up parent device Input: tsc2005 - clear driver data after unbinding Input: tsc2005 - add module description Input: tsc2005 - remove driver banner message Input: tsc2005 - remove incorrect module alias Input: tsc2005 - convert to using dev_pm_ops Input: tsc2005 - use spi_get/set_drvdata() Input: introduce tsc2005 driver Input: xen-kbdfront - move to drivers/input/misc Input: xen-kbdfront - add grant reference for shared page ...
2011-03-18Merge branch 'next' into for-linusDmitry Torokhov
2011-03-17Merge branches 'defcfg', 'drivers' and 'cyberpro-next' of ↵Linus Torvalds
master.kernel.org:/home/rmk/linux-2.6-arm * 'defcfg' of master.kernel.org:/home/rmk/linux-2.6-arm: ARM: 6647/1: add Versatile Express defconfig ARM: 6644/1: mach-ux500: update the U8500 defconfig * 'drivers' of master.kernel.org:/home/rmk/linux-2.6-arm: ARM: 6764/1: pl011: factor out FIFO to TTY code ARM: 6763/1: pl011: add optional RX DMA to PL011 v2 ARM: 6758/1: amba: support pm ops ARM: amba: make amba_driver id_table const ARM: amba: make internal ID table handling const ARM: amba: make probe() functions take const id tables ARM: 6662/1: amba: make amba_bustype non-static ARM: mmci: add dmaengine-based DMA support ARM: mmci: no need for separate host->data_xfered ARM: mmci: avoid unnecessary switch to data available PIO interrupts ARM: mmci: no need to call flush_dcache_page() with sg_miter API ARM: mmci: avoid reporting too many completed bytes on fifo overrun ALSA: AACI: make fifo variables more explanitory ALSA: AACI: no need to call snd_pcm_period_elapsed() for each period ALSA: AACI: use snd_pcm_lib_period_bytes() ALSA: AACI: clean up AACI announcement printk ALSA: AACI: fix channel mask selection ALSA: AACI: fix number of channels for record ALSA: AACI: fix multiple IRQ claiming * 'cyberpro-next' of master.kernel.org:/home/rmk/linux-2.6-arm: VIDEO: cyberpro: remove unused cyber2000fb_get_fb_var() VIDEO: cyberpro: remove useless function extreg pointers VIDEO: cyberpro: update handling of device structures VIDEO: cyberpro: add support for video capture I2C VIDEO: cyberpro: make 'reg_b0_lock' always present VIDEO: cyberpro: add I2C support VIDEO: cyberpro: select lowest multipler/divisor for PLL
2011-03-17Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/epip/linux-2.6-unicore32 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/epip/linux-2.6-unicore32: (40 commits) unicore32: rewrite arch-specific tlb.h to use asm-generic version unicore32: modify io_p2v and io_v2p macros, and adjust PKUNITY_mmio_BASEs unicore32: replace unicore32-specific iomap functions with generic lib implementation unicore32 machine related: add frame buffer driver for pkunity-v3 soc unicore32 machine related files: add i2c bus drivers for pkunity-v3 soc unicore32 io: redefine __REG(x) and re-use readl/writel funcs unicore32 i8042 upgrade and bugfix: adjust resource request region type unicore32 upgrade to v2.6.38-rc5: add one more paramter for pte_alloc_map call unicore32 i8042: adjust io funcs of i8042-unicore32io.h unicore32: rename PKUNITY_IOSPACE_BASE to PKUNITY_MMIO_BASE unicore32: modify function names and parameters for irq_chips unicore32: remove unused lines in arch/unicore32/include/asm/irq.h unicore32 time.c: change calculate method for clock_event_device unicore32: ADD MAINTAINER for unicore32 architecture unicore32 machine related files: ps2 driver unicore32 machine related files: pci bus handling unicore32 machine related files: hardware registers unicore32 machine related files: core files unicore32 additional architecture files: boot process unicore32 additional architecture files: low-level lib: misc ... Acked-by: Arnd Bergmann <arnd@arndb.de>
2011-03-17Merge branches 'aaci', 'mmci-dma', 'pl' and 'pl011' into driversRussell King
2011-03-16Merge branch 'tsc2005' into nextDmitry Torokhov
2011-03-16Input: tsc2005 - remove 'disable' sysfs attributeDmitry Torokhov
I believe that enable/disable functionality should not be implemented on the individual driver level but rather in device core, potentially reusing parts of PM framework. Therefore the driver-specific "disable" attribute is removed from the mainline driver. Tested-by: Aaro Koskinen <aaro.koskinen@nokia.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-03-16Input: tsc2005 - add open/closeDmitry Torokhov
Introduce open and close methods for the input device to keep the device powered down when it is not in use. Also rework interaction between interrupt thread and starting/shutting off/resetting the device: instead of taking a mutex in the intterrupt thread and elsewhere disable interrupts before transitioning the device in a new state. The ESD handling is also separated from the IRQ thread; we poll regularly at a given interval and simply skip reads if we see that valid interrupt happened not so long ago. This allows us not cancel and reschedule ESD work from interrupt context all the time. Tested-by: Aaro Koskinen <aaro.koskinen@nokia.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-03-16Input: tsc2005 - handle read errors from SPI layerDmitry Torokhov
2011-03-16Input: tsc2005 - do not rearm timer in hardirq handlerDmitry Torokhov
We will most likely rearm it yet again the IRQ thread so doing it here is pointless. Tested-by: Aaro Koskinen <aaro.koskinen@nokia.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-03-16Input: tsc2005 - don't use work for 'pen up' handlingDmitry Torokhov
We do not need process context to send input events so let's switch to a regular timer. I am going to get rid of taking ts->mutex in tsc2005_irq_thread() later. Tested-by: Aaro Koskinen <aaro.koskinen@nokia.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-03-16Input: tsc2005 - do not use 0 in place of NULLDmitry Torokhov
Sparse in unhappy when people use 0 instead of NULL for pointers so let's rework the way we initialize spi_transfer structure in tsc2005_cmd() and tsc2005_write(). Tested-by: Aaro Koskinen <aaro.koskinen@nokia.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-03-16Input: tsc2005 - use true/false for boolean variablesDmitry Torokhov
2011-03-16Input: tsc2005 - hide selftest attribute if we can't resetDmitry Torokhov
If implementation to perform self-test/reset has not been provided by the platform code hide 'selftest' sysfs attribute instead of returning error when someone tries to use it. Tested-by: Aaro Koskinen <aaro.koskinen@nokia.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-03-16Input: tsc2005 - rework driver initialization codeDmitry Torokhov
We need to make sure we have time/work initialized before requesting and enabling interrupts, otherwise we might start using them way too early. Tested-by: Aaro Koskinen <aaro.koskinen@nokia.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-03-16Input: tsc2005 - set up bus type in input deviceDmitry Torokhov
We know what bus we are residing on (SPI) so let's make this data available to the users. Tested-by: Aaro Koskinen <aaro.koskinen@nokia.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-03-16Input: tsc2005 - set up parent deviceDmitry Torokhov
Set up SPI device as parent of the input device so it gets placed into proper place in sysfs tree. Tested-by: Aaro Koskinen <aaro.koskinen@nokia.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-03-16Input: tsc2005 - clear driver data after unbindingDmitry Torokhov
We should not leave garbage pointers in driver structure after we unbind it from the device or if bind fails. Tested-by: Aaro Koskinen <aaro.koskinen@nokia.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-03-16Input: tsc2005 - add module descriptionDmitry Torokhov
Add proper module description so that it would show in 'modinfo' output. Tested-by: Aaro Koskinen <aaro.koskinen@nokia.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-03-16Input: tsc2005 - remove driver banner messageDmitry Torokhov
The boot process is noisy as it is and input core already announces all new device so let's get rid of the banner message in the driver. Tested-by: Aaro Koskinen <aaro.koskinen@nokia.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-03-16Input: tsc2005 - remove incorrect module aliasDmitry Torokhov
TSC2005 is not a platform driver so it should not define "platform:tsc2005" module alias. Tested-by: Aaro Koskinen <aaro.koskinen@nokia.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-03-16Input: tsc2005 - convert to using dev_pm_opsDmitry Torokhov
Newer code should not be using legacy suspend/resume methods but rather supply dev_pm_ops structure as it allows better control over power management. Tested-by: Aaro Koskinen <aaro.koskinen@nokia.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-03-16Input: tsc2005 - use spi_get/set_drvdata()Dmitry Torokhov
Instead of peeking into underlying device and using dev_get/set_drvdata(), let's use SPI layer's implementation to access driver-private data (which may be different from driver-core private data). Tested-by: Aaro Koskinen <aaro.koskinen@nokia.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-03-16Input: introduce tsc2005 driverLauri Leukkunen
Discussions: http://www.mail-archive.com/linux-omap@vger.kernel.org/msg26748.html Introduce a driver for the Texas Instruments TSC2005 touchscreen controller (http://focus.ti.com/docs/prod/folders/print/tsc2005.html). The patch is based on a driver by Lauri Leukkunen, with modifications by David Brownell, Phil Carmody, Imre Deak, Hiroshi DOYU, Ari Kauppi, Tony Lindgren, Jarkko Nikula, Eero Nurkkala and Roman Tereshonkov. Signed-off-by: Lauri Leukkunen <lauri.leukkunen@nokia.com> [aaro.koskinen@nokia.com: patch description, rebasing & cleanup] Signed-off-by: Aaro Koskinen <aaro.koskinen@nokia.com> [ext-srikar.1.bhavanarayana@nokia.com: various fixes] Signed-off-by: Srikar <ext-srikar.1.bhavanarayana@nokia.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-03-16Input: xen-kbdfront - move to drivers/input/miscDmitry Torokhov
drivers/input is reserved for input core code and input handlers with drivers belonging to one of the sub-directories. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-03-16Input: xen-kbdfront - add grant reference for shared pageDaniel De Graaf
Without a grant reference, full access to the domain's memory is required to use the shared page. Add an additional parameter in xenstore to allow grant mapping to be used. Signed-off-by: Daniel De Graaf <dgdegra@tycho.nsa.gov> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Acked-by: Ian Campbell <Ian.Campbell@eu.citrix.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-03-16Input: xen-kbdfront - advertise either absolute or relative coordinatesOlaf Hering
A virtualized display device is usually viewed with the vncviewer application, either by 'xm vnc domU' or with vncviewer localhost:port. vncviewer and the RFB protocol provides absolute coordinates to the virtual display. These coordinates are either passed through to a PV guest or converted to relative coordinates for a HVM guest. A PV guest receives these coordinates and passes them to the kernels evdev driver. There it can be picked up by applications such as the xorg-input drivers. Using absolute coordinates avoids issues such as guest mouse pointer not tracking host mouse pointer due to wrong mouse acceleration settings in the guests X display. Advertise either absolute or relative coordinates to the input system and the evdev driver, depending on what dom0 provides. The xorg-input driver prefers relative coordinates even if a devices provides both. Signed-off-by: Olaf Hering <olaf@aepfle.de> Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-03-17unicore32 io: redefine __REG(x) and re-use readl/writel funcsGuanXuetao
-- by advice of Arnd Bergmann Signed-off-by: Guan Xuetao <gxt@mprc.pku.edu.cn> Reviewed-by: Arnd Bergmann <arnd@arndb.de>
2011-03-17unicore32 i8042 upgrade and bugfix: adjust resource request region typeGuanXuetao
2011-03-17unicore32 i8042: adjust io funcs of i8042-unicore32io.hGuanXuetao
replace inb/outb with readb/writeb in i8042-unicore32io.h and correct typecasting of register and region macros -- by advice with Arnd Bergmann Signed-off-by: Guan Xuetao <gxt@mprc.pku.edu.cn>
2011-03-17unicore32 machine related files: ps2 driverGuanXuetao
This patch implements arch-specific ps2 driver. By reviewed with Dmitry Torokhov: 1. move i8042-ucio.h to drivers/input/serio/i8042-unicore32io.h 2. move puv3_ps2_init() to arch/unicore32/kernel/puv3-core.c 3. remove unused comments. Signed-off-by: Guan Xuetao <gxt@mprc.pku.edu.cn> Acked-by: Dmitry Torokhov <dtor@mail.ru>
2011-03-16Merge branch 'devicetree/next' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'devicetree/next' of git://git.secretlab.ca/git/linux-2.6: (21 commits) tty: serial: altera_jtaguart: Add device tree support tty: serial: altera_uart: Add devicetree support dt: eliminate of_platform_driver shim code dt: Eliminate of_platform_{,un}register_driver dt/serial: Eliminate users of of_platform_{,un}register_driver dt/usb: Eliminate users of of_platform_{,un}register_driver dt/video: Eliminate users of of_platform_{,un}register_driver dt/net: Eliminate users of of_platform_{,un}register_driver dt/sound: Eliminate users of of_platform_{,un}register_driver dt/spi: Eliminate users of of_platform_{,un}register_driver dt: uartlite: merge platform and of_platform driver bindings dt: xilinx_hwicap: merge platform and of_platform driver bindings ipmi: convert OF driver to platform driver leds/leds-gpio: merge platform_driver with of_platform_driver dt/sparc: Eliminate users of of_platform_{,un}register_driver dt/powerpc: Eliminate users of of_platform_{,un}register_driver dt/powerpc: move of_bus_type infrastructure to ibmebus drivercore/dt: add a match table pointer to struct device dt: Typo fix. altera_ps2: Add devicetree support ...
2011-03-16Merge branch 'for-2.6.39' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wqLinus Torvalds
* 'for-2.6.39' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: workqueue: fix build failure introduced by s/freezeable/freezable/ workqueue: add system_freezeable_wq rds/ib: use system_wq instead of rds_ib_fmr_wq net/9p: replace p9_poll_task with a work net/9p: use system_wq instead of p9_mux_wq xfs: convert to alloc_workqueue() reiserfs: make commit_wq use the default concurrency level ocfs2: use system_wq instead of ocfs2_quota_wq ext4: convert to alloc_workqueue() scsi/scsi_tgt_lib: scsi_tgtd isn't used in memory reclaim path scsi/be2iscsi,qla2xxx: convert to alloc_workqueue() misc/iwmc3200top: use system_wq instead of dedicated workqueues i2o: use alloc_workqueue() instead of create_workqueue() acpi: kacpi*_wq don't need WQ_MEM_RECLAIM fs/aio: aio_wq isn't used in memory reclaim path input/tps6507x-ts: use system_wq instead of dedicated workqueue cpufreq: use system_wq instead of dedicated workqueues wireless/ipw2x00: use system_wq instead of dedicated workqueues arm/omap: use system_wq in mailbox workqueue: use WQ_MEM_RECLAIM instead of WQ_RESCUER
2011-03-15Input: tc3589x-keypad - fix 'double const' warningDmitry Torokhov
Also rearrange driver structure initializer a bit. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-03-15Input: tca6416-keypad - suspend/resume wakeup supportMagnus Damm
Extend the tca6416 driver to use enable_irq_wake() and disable_irq_wake() in the suspend/resume hooks. This makes it possible to wake up from suspend-to-ram using a tca6416 key on the sh7372 mackerel board. Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-03-14Input: atmel_mxt_ts - add objects of mXT1386 chipJoonyoung Shim
Atmel mXT1386 chip is operated by atmel_mxt_ts driver and it has some different objects. Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-03-14Input: atmel_mxt_ts - remove firmware version checkJoonyoung Shim
Atmel touchscreen chips have different firmware version with each chip, so we cannot distinguish attribute of chip by firmware version. Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-03-14Input: wm831x-ts - ensure the controller is in a known state on openMark Brown
Explicitly set all the enable bits when opening the device just in case something left the device in an unexpected state. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-03-13Input: add Atmel AT42QT1070 keypad driverBo Shen
The AT42QT1070 QTouch sensor supports up to 7 keys. The driver has been tested on Atmel AT91SAM9M10-G45-EK board, and it should work fine on other platforms. Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-03-12Input: wm831x-ts - default pressure measurements onMark Brown
tslib expects pressure measurements so enable them by default for better compatibility. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-03-12Input: bcm5974 - add support for MacBookPro8Andy Botting
This patch add multitouch support for the MacBookPro8,1 and MacBookPro8,2 models. Cc: stable@kernel.org Signed-off-by: Andy Botting <andy@andybotting.com> Signed-off-by: Henrik Rydberg <rydberg@euromail.se> Acked-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-03-12Input: wacom - support 2FGT in MT formatPing Cheng
Reviewed-by: Henrik Rydberg <rydberg@euromail.se> Reviewed-by: Chris Bagwell <chris@cnpbagwell.com> Signed-off-by: Ping Cheng <pingc@wacom.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-03-12Input: wacom - support one finger touch the touchscreen wayPing Cheng
There are two types of 1FGT devices supported in wacom_wac.c. Changing them to follow the existing touchscreen format, i.e., only report BTN_TOUCH as a valid tool type. Touch data will be ignored if pen is in proximity. This requires a touch up event sent if touch was down when pen comes in. The touch up event should be sent before any pen events are emitted. Otherwise, two pointers would race for the cursor. However, we can not send a touch up inside wacom_tpc_pen since pen and touch are on different logical port. That is why we have to check if touch is up before sending pen events. Reviewed-by: Henrik Rydberg <rydberg@euromail.se> Reviewed-by: Chris Bagwell <chris@cnpbagwell.com> Signed-off-by: Ping Cheng <pingc@wacom.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-03-12Input: wacom - process pen data in its own routinePing Cheng
So it would be easier for patch reviewers to follow the data path. Reviewed-by: Henrik Rydberg <rydberg@euromail.se> Reviewed-by: Chris Bagwell <chris@cnpbagwell.com> Signed-off-by: Ping Cheng <pingc@wacom.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-03-12Input: wacom - do not send 2FGT Tablet PC events in TAP formatPing Cheng
2FGT Tablet PC touch events were processed in _TAP_ format. Remove them so we can change to _MT_ format. Signed-off-by: Ping Cheng <pingc@wacom.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-02-28dt: Eliminate of_platform_{,un}register_driverGrant Likely
Final step to eliminate of_platform_bus_type. They're all just platform drivers now. v2: fix type in pasemi_nand.c (thanks to Stephen Rothwell) Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-02-28dt/sparc: Eliminate users of of_platform_{,un}register_driverGrant Likely
Get rid of old users of of_platform_driver in arch/sparc. Most of_platform_driver users can be converted to use the platform_bus directly. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-02-28Merge commit 'v2.6.38-rc6' into devicetree/nextGrant Likely
Conflicts: drivers/spi/pxa2xx_spi_pci.c
2011-02-27Input: evdev - fix evdev_write return value on partial writesPeter Korsgaard
As was recently brought up on the busybox list (http://lists.busybox.net/pipermail/busybox/2011-January/074565.html), evdev_write doesn't properly check the count argument, which will lead to a return value > count on partial writes if the remaining bytes are accessible - causing userspace confusion. Fix it by only handling each full input_event structure and return -EINVAL if less than 1 struct was written, similar to how it is done in evdev_read. Reported-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk> Acked-by: Henrik Rydberg <rydberg@euromail.se> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-02-27Input: bcm5974 - Report button also for zero fingersHenrik Rydberg
With the current code, pressing the integrated button with an isolating tool does not result in any button report. Fixed with this this patch. Signed-off-by: Henrik Rydberg <rydberg@euromail.se> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
