Removing interrupt key driver as this duplicates the
gpio_keys driver. Desired functionality can be achieve
through the gpio_keys.
Change-Id: I7e5bc18d4b30c64fa08bb64cdceffe2193c43c8f
Reviewed-on: http://git-master/r/92462
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
Some of buttons, like power-on key or onkey, may only generate interrupts
when pressed and not actually be mapped as gpio in the system. Allow
setting gpio to invalid value and specify IRQ instead to support such
keys. The debounce timer is used not to debounce but to ignore new IRQs
coming while button is kept pressed.
Cherry-picked from mainline
d8ee4a1c90529ed06e1aa43d034986649f7b670b
Change-Id: Ibf8e407351082d816dd051d2c69a4a1a7caa70e7
Reviewed-on: http://git-master/r/92321
(cherry picked from commit a16ca23935afc0d72215b139720bd07df3162a9f)
Change-Id: I90ae154a3b124fad0e9320ac5d9d8083175461b5
Reviewed-on: http://git-master/r/92320
request_any_context_irq() should handle the case when using GPIO expanders
that themselves use threaded IRQs, and so the premise of change
7e2ecdf438bb479e2b4667fc16b1a84d6348da04 is incorrect.
(cherry picked from commit 6709c9a5d8c53092cbe89128df4e0a549e93133b)
Change-Id: I0b4267f6493483c2edc9926f48ecda68d863bead
Reviewed-on: http://git-master/r/92319
The platform data should not be altered and therefore should be
accessed through const pointers.
Cherry-picked from
d9080921aa32c70a95476ce387e973787b892591
Change-Id: I5791f831909d4417a5c2732e310630c97c42f4a9
Reviewed-on: http://git-master/r/92318
Use the of_property_read_u32() helper function to retrieve u32 values
from the device tree. Also do not pass the len parameter to
of_get_property if it isn't checked afterwards.
Signed-off-by: Tobias Klauser <tklauser@distanz.ch>
(cherry picked from commit cca84699a079a91b0a0cb4f2da8548e56859376a)
Change-Id: I265e0cdc8b761572d1c78d699d761097be26a4e4
Reviewed-on: http://git-master/r/92317
Maximum power saving is observed by disabling multiple touchscreen
objects. Objects must be saved going into LP0, and restored in
reverse order upon resuming from LP0.
Bug 919435
Change-Id: I42799fbb02efd28e4954b53b3d052ad138537ce9
Signed-off-by: Robert Collins <rcollins@nvidia.com>
Reviewed-on: http://git-master/r/88458
Reviewed-by: Dan Willemsen <dwillemsen@nvidia.com>
Tested-by: Gerrit_Virtual_Submit
The disable_irq_wake() function is getting called more than
enable_irq_wake() and hence creating the inbalance error
for disable irq wake.
Fixing this with same logic for enable_irq_wake().
Change-Id: I32028fde01f1971f94cb75c188f975cbc78e74c5
Reviewed-on: http://git-master/r/86906
Bug 946800
Change-Id: I1c7665002c94f54eb44c6b0715f6bd737a3e1288
Signed-off-by: Johnny Qiu <joqiu@nvidia.com>
Reviewed-on: http://git-master/r/86572
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Reviewed-by: Kerwin Wan <kerwinw@nvidia.com>
Modified driver files to support unified DirectTouch which
can support Kai and Cardhu together. Vendor-supplied source
code update.
Bug 832605
Signed-off-by: Ali Ekici <aekici@nvidia.com>
Change-Id: If0799147b50e9c2cf102d2216103e30b525026e4
Reviewed-on: http://git-master/r/80128
Reviewed-by: Robert Collins <rcollins@nvidia.com>
Tested-by: Robert Collins <rcollins@nvidia.com>
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
(cherry picked from commit 1dfd9d747b8ceb344a435daac60d30f1a6441bcb)
Reviewed-on: http://git-master/r/83568
Bug 937953
Change-Id: I5466fedf6fdcd1f577753736e9eb9b2dbf5b52c0
Reviewed-on: http://git-master/r/83386
Bug 937953
Change-Id: Ieb9a941faaad0945948af806e8bc09a1e51f5772
Reviewed-on: http://git-master/r/83369
Take off the world-write bit from the default permissions for the
mem_access debug node. The init scripts will make it accessible on
engineering builds.
Bug 906796
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
Reviewed-on: http://git-master/r/79095
(cherry picked from commit a6ba61cc290bebb5dd16e4ad02cd1e8b3b9802b2)
Change-Id: I3e118dd502aa8912ad5fcb8452105c7f5f1c833a
Signed-off-by: Pritesh Raithatha <praithatha@nvidia.com>
Reviewed-on: http://git-master/r/82725
Tested-by: Varun Wadekar <vwadekar@nvidia.com>
Add an ioctl, EVIOCSSUSPENDBLOCK, to enable a wakelock that will block
suspend while the event queue is not empty. This allows userspace code to
process input events while the device appears to be asleep.
The current code holds the wakelock for up 5 seconds for every input
device and client. This can prevent suspend if sensor with a high data
rate is active, even when that sensor is not capable of waking the
device once it is suspended.
(cherry picked from commit 4dc43d7079bdae572212368e1d29abea0177c932 from
android.googlesource.com/common.git)
Signed-off-by: Arve Hjønnevåg <arve@android.com>
Change-Id: I160d2afe77aa76c9d2bbe01cd4b81434201361a9
Reviewed-on: http://git-master/r/78895
If there is no SYN_REPORT event in the buffer the buffer data is invisible
to user-space. The wakelock should not be held in this case.
(cherry picked from commit 7cc846069a8a9116d8c81526c459070eed0e3477 from
Change-Id: I7555b190ff8e4e526291dd353c3c0291b05dfff2
Reviewed-on: http://git-master/r/78894
Enable wake from LP1 on KP interrupt when scan timeout
is set to zero.
Bug 921161
Reviewed-on: http://git-master/r/78146
Change-Id: I6f28f0da971bd159b40412608fca2615a70f6988
Signed-off-by: Ashwini Ghuge <aghuge@nvidia.com>
Reviewed-on: http://git-master/r/78700
This is Synaptics' open source driver except one line
change to accomodate an SPI kernel driver feature
which does not accomodate optional byte-delay. It
will be fully original driver when we add byte-delay
into Tegra SPI kernel drivers.
Bug 912775
Reviewed-on: http://git-master/r/74642
Change-Id: I0f39928c48bc0e633de0d2c1f595bcef47268d52
Signed-off-by: Peter Zu <pzu@nvidia.com>
Reviewed-on: http://git-master/r/77774
Reviewed-on: http://git-master/r/77504
Change-Id: Iafe31126fbcec1bfd01b51e0c122b44d3a71bbda
Reviewed-on: http://git-master/r/77759
Raydium is responsible from pushing this driver
to kernel.org. This driver contains two distinct
drivers, one communicates with Touch IC using SPI
and pushes raw touch data received to a file system,
another driver who is a misc driver receives
processed touch data and initiates touch
input_abs_report touch commands which can only be
issued by a driver.
Changed misc_deregister call from rm31080_spi_exit to
rm31080_spi_remove
Bug 832605
Reviewed-on: http://git-master/r/74432
Change-Id: I8f361130bfe3236cf88ab4348c3d578c84c63ba7
Reviewed-on: http://git-master/r/76820
In evdev_read() the local variable retval is not initialized.
If this variable is not initialized then in case of NONBLOCK READ
retval will have invalid value.
Bug: 922453
Change-Id: I534cbfacf8a0514fcb5bc481a98d0e94a4d73b04
Signed-off-by: Preetham Chandru R <pchandru@nvidia.com>
Reviewed-on: http://git-master/r/74898
Reviewed-by: Sanjay Singh Rawat <srawat@nvidia.com>
Tested-by: Sanjay Singh Rawat <srawat@nvidia.com>
Reviewed-by: Shashank Sharma <shashanks@nvidia.com>
Reviewed-by: Yogish Kulkarni <yogishk@nvidia.com>
Reviewed-by: Kiran Adduri <kadduri@nvidia.com>
commit 8521478f67e95ada4e87970c7b41e504c724b2cf upstream.
Synaptics touchpads on several Dell laptops, particularly Vostro V13
systems, may not respond properly to PS/2 commands and queries immediately
after resuming from suspend to RAM. This leads to unresponsive touchpad
after suspend/resume cycle.
Adding a 1-second delay after resetting the device allows touchpad to
finish initializing (calibrating?) and start reacting properly.
Reported-by: Daniel Manrique <daniel.manrique@canonical.com>
Tested-by: Daniel Manrique <daniel.manrique@canonical.com>
Change-Id: I8246905d452b12e1ce535705c746c3ff66660e09
Reviewed-on: http://git-master/r/74172
A flag, disable_ev_rep, is added to enable/disable repeat events
reported from the keyboard driver.
BUG 918758
Change-Id: I65be2f795fd64ebb7d36ad278aa2b24362c1e5ea
Signed-off-by: Nitin Kumbhar <nkumbhar@nvidia.com>
Reviewed-on: http://git-master/r/72952
Added is_open to know whether the clock has been disabled.
Occasionally _close is called before _suspend during LP0 cycles
resulting in a hang as the clock is disabled.
Bug 855753
Change-Id: Ida938ada7d14085e11096b25cf41431fc2d46215
Reviewed-on: http://git-master/r/50218
Reviewed-on: http://git-master/r/64257
Reviewed-by: Simone Willett <swillett@nvidia.com>
Fixes two error cases with slowscan:
1. Disable slowscan without first enabling it.
Leaves TS controller disabled.
2. Enable slowscan twice consecutively.
Leaves TS controller programmed with incorrect values.
Bug 909304
Change-Id: I06db55aaf5935a838953d4f2fcf8f5dc2bb7123b
Reviewed-on: http://git-master/r/67501
(cherry picked from commit bb17439a70c585d35822d38ce5b53ca8368ab3a4)
Reviewed-on: http://git-master/r/70222
The hardware gives you 0 as the pressure even for
valid touches. Pass a default value if you get
pressure value outside limits from the hardware during
a 'press'.
Pass pressure as 0, for a 'release'.
Change-Id: Id858240464474d3c18e4bae9768f41327c5d4124
When 2nd multi touch is removed, release point is (0,0) point.
To correct this, in removing 2nd multi touch,
we send last touched position of 2nd multi touch.
And this removes noise touch event and joystick event also.
Bug 896919
Change-Id: Icccaa3ccc28e613565ce696339b83d60335b344a
Reviewed-on: http://git-master/r/64008
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Rebase-Id: Re3c488cd60c5b02ec43fa8f3e700dc93afbff043
Change-Id: I08eb7b5ad1c70b84ff40ba75a29913b61634d0f0
Signed-off-by: Scott Williams <scwilliams@nvidia.com>
Reviewed-on: http://git-master/r/48786
Reviewed-by: Daniel Willemsen <dwillemsen@nvidia.com>
Rebase-Id: Rc7ac5d5153d845c8be10dbe79f57083fb1919760
In the case where early suspend/resume is enabled, prevent
suspend/resume from being called twice. Removing the
default suspend/resume handlers while early suspend/resume is
enabled prevents the double suspend/resume from occurring.
BUG 843934
Original-Change-Id: I2e014f7a79db524cbe9d5b8b934c8f42216a8ad5
Reviewed-on: http://git-master/r/38576
Tested-by: Krishna Yarlagadda <kyarlagadda@nvidia.com>
Reviewed-by: Robert R Collins <rcollins@nvidia.com>
Tested-by: Robert R Collins <rcollins@nvidia.com>
Rebase-Id: R6c38a345206679eb2ee5ca279d0ffa922c3f8744
Add early suspend/resume functionality to Atmel touch driver.
0W suspend.
Early suspend/resume functions written and provided by
Atmel Corporation.
BUG 826854
Original-Change-Id: I58d5abacff20df9d3027c960021e94298e31b8a6
Reviewed-on: http://git-master/r/35286
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Reviewed-by: Narendra Damahe <ndamahe@nvidia.com>
Rebase-Id: R1364d26f0c95bdb9e650e3231ac254242a9b3349
arch/arm/mach-tegra/Kconfig
arch/arm/mach-tegra/board-ventana.c
drivers/misc/Kconfig
drivers/video/tegra/dc/hdmi.c
Video playback would like to save power by slowing touchscreen
scanning. This change adds a SysFS interface to allow the
scan rate to be programmed by the video display interface.
SysFS location:
/sys/devices/platform/tegra-i2c.1/i2c-1/1-005a/slowscan_enable
Read functions:
cat slowscan_enable (returns current register status)
Write functions:
0 - Disable slowscan
1 - Enable slowscan
2 N - Program actv_cycle_time with value of N
3 N - Program idle_cycle_time with value of N
4 N - Program actv2idle timeout with value of N (seconds * 10)
Bug 891993
Change-Id: Ib11b544019f3a78290785502e7209b8cbd985852
Reviewed-on: http://git-master/r/65006
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
Rebase-Id: Re4398871d4964d366f0dbdd856a7953600577dea
In order to save system power, we should cut the power to the
touchscreen controller. Older versions of our TS driver did this.
This feature was accidentally removed during a recent driver
update.
Bug 891979
Change-Id: I4bf9333832af65c00b8b10cc8191f4d26aad04e4
Reviewed-on: http://git-master/r/65005
Rebase-Id: R370b26e990a5f129ea0f8e73e9b7178bd85b79e5
Updated to new Atmel touch driver. Added sysfs interface to
allow Config-UI applications to run.
Primary changes:
* Add sysfs interface to allow user applications access to the
touchscreen controller register interface. Required by
Config-UI utility.
* Fixed bug in stop/start functions that would prevent TS
from working with encrypted filesystems.
* Fix logic error that could cause a deadlock condition during
LP0 resume.
Change-Id: If25260e60843e3c3bb3a9818ed9146ea78c39902
Reviewed-on: http://git-master/r/65004
Rebase-Id: R9bde02eeeae3a899e18d17b5ff26cac371729cb0
These changes have no effect if CONFIG_GCOV_KERNEL is not set in
defconfig. It is easier to trigger GCOV for kernel if this patch
is in by only setting the before mentioned flag.
Change-Id: I8aade309da2da62c4b3889bd84e4123ba8f182da
Signed-off-by: Juha Tukkinen <jtukkinen@nvidia.com>
Reviewed-on: http://git-master/r/62999
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Rebase-Id: R4c238f707f1db600f188ae83426336753992b7be
The scan timeout of the continuous mode can be calculated based on
init delay, repeat delay, debounce count and number of active row.
It also depends on how many scan need to be done before kbc change
the mode from continuous to wakeup mode.
Providing mechanism to select the scan count from platform data
and calculating the scan timeout count based on above parameters.
bug 876712
Reviewed-on: http://git-master/r/62591
(cherry picked from commit 3360ed5be86a2afd6716bc5227cc39657efd35b2)
Change-Id: Ib9dc96b1cc201b7af0bd62a3ec7fe9a80791d796
Reviewed-on: http://git-master/r/63229
Tested-by: Laxman Dewangan <ldewangan@nvidia.com>
Rebase-Id: Rbcb685d34c5d00ebf1c79d356eb63e4584075447
-Set only REQUIRED row and column configuration register to
PROPER values to avoid continuously generating KBC input events.
-Use *enable* field in pin_cfg, to check GPIO_x_ROW_EN register
should be set or clear.
bug 889620
Change-Id: I91990156c300605c214e7e393edf14fbced1573d
Reviewed-on: http://git-master/r/59153
Reviewed-by: Shridhar Rasal <srasal@nvidia.com>
Tested-by: Shridhar Rasal <srasal@nvidia.com>
Rebase-Id: R03e9deb839fc21c1ea66fc81ae6601155b8e8d4d
in some situations
BUG 868649
Reviewed-on: http://git-master/r/50598
(cherry picked from commit ad1dbe0eda931f813b20d75400daaa9edf18c82a)
Change-Id: I29f353687c499ff830e98fcf038d8a786dc5608b
Reviewed-on: http://git-master/r/54841
Reviewed-by: Joel Kenny <jkenny@nvidia.com>
Tested-by: Joel Kenny <jkenny@nvidia.com>
Rebase-Id: Rdde94e071f4a27250eccad562c819ca2f537ffcd
This reverts commit baafb435372dd48e3854028aec669effae957c9e.
Rebase-Id: Re9bd7135ad63df297876341431cad65fa12a838a
Prevents touchscreen hangs during initial TS boot, and TS resume.
BUG 847725
BUG 845156
BUG 846711
Original-Change-Id: Ia853574e4b2422eb9368fe37eaf7457bd4022df8
Reviewed-on: http://git-master/r/40261
Rebase-Id: Rc1de4685a4e85d761097142b39f2a672846b8c44
* Fix suspend/resume bug to prevent unecessary i2cinterrupts when suspended.
* Change input device name to match NVDA IDC name.
* Add I2C address defines.
* Change "printk" to "dev_info" function calls.
BUG 826854
Original-Change-Id: Ic1b25bc469b86d8a26e876e80973597d9f6fb107
Reviewed-on: http://git-master/r/35285
Rebase-Id: Rcba51c79d3c004372c0be18538f14f56a2249bc0
Integrate changes made by Atmel. These changes are in addition to
mainline driver.
NOTE: Driver will compile as a stand-alone.
BUG 826854
Original-Change-Id: If13688d90d97b71718576f3fb756496f57a965d7
Reviewed-on: http://git-master/r/35280
Rebase-Id: Reb8ae14299d248c0ce69e52b26a8816d1a0ee057
For the key connected directly to interrupt keys, there is continuous
interrupt from key pressed. The generation of interrupt stops only
when key is released.
To handle this case, reporting the key press in first interrupt and key
release event if there is no interrupt for sometime. This time is configurable
from platform data.
bug 814005
Original-Change-Id: I56345ca68bd227e48cf31b1f54a0deac43bf900c
Reviewed-on: http://git-master/r/28065
Reviewed-by: Ramachandrudu Kandhala <rkandhala@nvidia.com>
Original-Change-Id: I83d04992fe29c9a472a79e900b8083475c1ddf40
Rebase-Id: R62a01548c16a78033337dcfe35d391210412c3f2
Original-Change-Id: I2ffeaf6f8dfeb279b40ca6f69f6c9157401a746a
Rebase-Id: R056056997b4913133216474f863fc17c7f69878b
Adding keys support which are directly connected to interrupt lines.
Original-Change-Id: Ib26c06b170b82f4745e758be80b3e04122ad1d6c
Reviewed-on: http://git-master/r/22069
Original-Change-Id: I3921cc88f32558282654fbd36243b4b0b3574133
Rebase-Id: Rd7954ff7c2e0167a6a4765ff2f08494b9d0eba14
During resume, gpio-keys does not get updated state of gpios which
fails to report wakeup key event. Update resume routine to report
key event based on wakeup source.
BUG 745149
Original-Change-Id: Iff7a9b431f9da8d226c8d3cd522725c3049fef07
Reviewed-on: http://git-master/r/17455
Tested-by: Nitin Kumbhar <nkumbhar@nvidia.com>
Rebase-Id: Rde589cdb4f74683e9ea46933c7f949da16c5f884
Reports Scroll keys:
- Press
- Scrollup
- Scrolldown
Original-Change-Id: I47f6ca3d7b5bed4aa7441634850881df7066fce7
Reviewed-on: http://git-master/r/13618
Rebase-Id: R7c42f5468e8a89fb4881abd7ef7d314740f99144
Change-Id: I1adc2bb646269f17480718a7efb3dc14e6325fbc
Signed-off-by: Gary King <gking@nvidia.com>
arch/arm/mm/cache-l2x0.c
drivers/misc/Makefile
Change-Id: I29ccb32e795c5c3e4c51c3d3a209f5b55dfd7d94
Signed-off-by: Dima Zavin <dima@android.com>
If there is a full packet in the buffer, and we overflow that buffer
right after checking for that condition, it would have been possible
for us to block indefinitely (rather, until the next full packet) even if
the file was marked as O_NONBLOCK.
Change-Id: Icd0f59f8cc98392be4c4d13bd45b5cf94317eb5a
