path: root/drivers/input
2008-04-17Input: wm97xx-core - only schedule interrupt handler if not already scheduledMark Brown
As well as clarifying the fact that the driver can cope if a second interrupt occurs before the IRQ work is scheduled this also ensures that calls to the machine irq_enable() are balanced, making that easier to implement. Normally this is redundant due to the interrupt disabling but some unusal board configurations can trigger it. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-04-15Input: add Zhen Hua driverMartin Kebert
This is a driver for Zhen Hua PPM-4CH RC transmitter (commonly used in cheap Ready To Fly RC helicopters by Walkera) which using "Zhen Hua 5-byte protocol" for using them as a four axis joystick via serial port. Transmitter connected to serial port (19200 8N1) sending periodically 5 bytes where first byte is for synchronization and next four bytes are values of axis. Signed-off-by: Martin Kebert <gkmarty@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-04-15Input: aiptek - add support for Genius G-PEN 560 tabletGuryanov Dmitry
USBHID driver only supports relative mode with this tablet so let aiptek module handle it. Signed-off-by: Dmitry Guryanov <guryanov@dgap.mipt.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-04-15Input: wacom - implement suspend and autosuspendOliver Neukum
This implements suspend and autosuspend support for wacom devices. It works by using the usb last busy functionality triggered in the completion callback. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Ping Cheng <pingc@wacom.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-04-15Input: xpad - set proper buffer length for outgoing requestsMichael Gruber
The messages for led/rumble are exactly 3 and 8 bytes respectively. Hence set up the transfer_buffer_length accordingly. Signed-off-by: Michael Gruber <lists.mg@googlemail.com> Acked-by: Anssi Hannula <anssi.hannula@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-04-15Input: omap-keypad - fix build warningDavid Brownell
Fix the following build warning: drivers/input/keyboard/omap-keypad.c: In function 'omap_kp_probe': drivers/input/keyboard/omap-keypad.c:418: warning: 'row_idx' is used uninitialized in this function drivers/input/keyboard/omap-keypad.c:421: warning: 'col_idx' is used uninitialized in this function These variables are useful when cpu_is_omap24xx(), and otherwise just for useless cleanup. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-04-15Input: gpio_keys - irq handling cleanupDavid Brownell
Cleanup IRQ handling in gpio_keys: bail after handling the IRQ, and report IRQ_NONE if we never handle it. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-04-15Input: add PS/2 serio driver for AVR32 devicesHans-Christian Egtvedt
Add support for the PSIF peripheral on AVR32 AP7 devices. It is implemented as a serio driver and will behave like a serio 8042 device. The driver has been tested with a Dell keyboard capable of running on 3.3 volts and a Logitech mouse on the STK1000 + STK1002 starter kit. The Logitech mouse was hacked by cutting the cord and using a bi-directional voltage converter to get the required 5 volt I/O level. For more information about the PSIF module, see the datasheet for AT32AP700X at http://www.atmel.com/dyn/products/datasheets.asp?family_id=682 Signed-off-by: Hans-Christian Egtvedt <hcegtvedt@atmel.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-04-14ARM: OMAP: 5912 OSK GPIO updatesDavid Brownell
Start cleaning up GPIO handling for OMAP5912 OSK board: - Initialize GPIOs using the cross-platform calls, not the old OMAP-private ones. - Move touchscreen setup out of ads7846 code into board-specfic setup code, where it belongs. This doesn't depend on the patches to update OMAP to use the gpiolib implementation framework. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-04-04Input: usbtouchscreen - don't use DMA on stackOliver Neukum
DMA on the stack is not allowed. The buffer must be kmalloced. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-04-04Merge branch 'xbox'Dmitry Torokhov
2008-04-03Input: xpad - don't use GFP_ATOMICOliver Neukum
GFP_ATOMIC should not be used when GFP_KERNEL can be used. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-04-03Input: xpad - add support for wireless xbox360 controllersBrian Magnuson
Signed-off-by: Brian Magnuson <bdmagnuson@gmail.com> Signed-off-by: Anssi Hannula <anssi.hannula@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-04-03Input: xpad - drop obsolete driver versioningAnssi Hannula
The driver version numbers and changelog have not been updated in a long while to reflect actual changes. Remove the version number and add a notice that later changes can be tracked in SCM. Signed-off-by: Anssi Hannula <anssi.hannula@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-04-03Input: xpad - enable force feedback on xbox 360 controllers onlyAnssi Hannula
Commit 4994cd8dadcf9d484ab3ec19f3c7c7a4e5353c1c introduced a regression which causes xpad to report force feedback cababilities for non-360 controllers too, even while there is no actual support for those. Fix that by adding a check for XTYPE_XBOX360 to xpad_init_ff(). Signed-off-by: Anssi Hannula <anssi.hannula@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-04-03Input: xpad - do not report nonexistent buttons for xbox360Anssi Hannula
The buttons BTN_C and BTN_Z are only used in the original xbox controller, not in xbox360 controller. Therefore only add them to keybit when the controller is a non-360 one. Signed-off-by: Anssi Hannula <anssi.hannula@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-04-03Input: xpad - add more xbox 360 controller idsAnssi Hannula
Add Mad Catz and 0x0e6f xbox360 controllers which are already found in xpad_device[] table in xpad.c into the vendor id list. Also add Logitech into the vendor list for Logitech Chillstream gamepads. Also add the RedOctane Guitar Hero X-plorer. Signed-off-by: Anssi Hannula <anssi.hannula@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-04-03Input: xpad - fix inverted Y and RY axesAnssi Hannula
The commit ae91d10aab2762f81733e9194cb56eff99c8d808 inverted Y and RY axes on xbox360 so that up is positive and down is negative. This is wrong, as axes on game controllers have up as negative per convention. Also, even xpad itself reports HAT0X with up as negative. Fix that by inverting them again. Also, according to http://bugzilla.kernel.org/show_bug.cgi?id=10337 the original xbox controllers also have the Y and RY axes inverted. Fix that by inverting them as well. Cc: Brian Magnuson <bdmagnuson@gmail.com> Signed-off-by: Anssi Hannula <anssi.hannula@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-04-03Input: xpad - fix dpad handling of unknown devicesAnssi Hannula
For devices not specifically listed in xpad.c, xpad->dpad_mapping is initially set to MAP_DPAD_UNKNOWN. In xpad_probe() it gets changed to either MAP_DPAD_TO_BUTTONS or MAP_DPAD_TO_AXES, depending on the module parameter dpad_to_buttons. However, MAP_DPAD_UNKNOWN is defined as -1, while the field is u8. This results in actual value of 255, causing the MAP_DPAD_UNKNOWN check in xpad_probe() to fail. Fix that by defining MAP_DPAD_UNKNOWN as 2 instead. Also, setting module parameter dpad_to_buttons to 1 should obviously map dpad to buttons, while the default behaviour (0) should be to map dpad to axes. However, dpad_to_buttons is directly assigned to xpad->dpad_mapping, and as MAP_DPAD_TO_BUTTONS is 0, the actual behaviour is reversed. Fix that by negating dpad_to_buttons in assignment. Signed-off-by: Anssi Hannula <anssi.hannula@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-04-03Input: xpad - match xbox 360 devices with interface infoAnssi Hannula
Match Xbox 360 controllers using the interface info, i.e. interface class 255 (Vendor specific), subclass 93 and protocol 1, instead of specifying the device ids individually. As the class is vendor-specific, we have to still match against vendor id as well, though. Signed-off-by: Anssi Hannula <anssi.hannula@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-04-02Input: tosakbd - fix suspendDmitry Baryshkov
Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-04-02Input: appletouch - add product IDs for the 4th generation MacBooksTobias Mueller
Signed-off-by: Tobias Mueller <Tobias_Mueller@twam.info> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-04-02Merge branch 'wm97xx'Dmitry Torokhov
2008-04-02Input: WM97xx - add support for streaming mode on MainstoneMark Brown
Signed-off-by: Liam Girdwood <liam.girdwood@wolfsonmicro.com> Signed-off-by: Graeme Gregory <gg@opensource.wolfsonmicro.com> Signed-off-by: Mike Arthur <mike.arthur@wolfsonmicro.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-04-02Input: WM97xx - add chip driver for WM97123 touchscreenMark Brown
Signed-off-by: Liam Girdwood <liam.girdwood@wolfsonmicro.com> Signed-off-by: Graeme Gregory <gg@opensource.wolfsonmicro.com> Signed-off-by: Mike Arthur <mike.arthur@wolfsonmicro.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Lars Munch <lars@segv.dk> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-04-02Input: WM97xx - add chip driver for WM9712 touchscreenMark Brown
2008-04-02Input: WM97xx - add chip driver for WM9705 touchscreenMark Brown
2008-04-02Input: add support for WM97xx familty touchscreensMark Brown
Add support for the touchscreen controllers provided by Wolfson Microelectronics WM97xx series chips in both polled and streaming modes. These drivers have been maintained out of tree since 2003. During that time the driver the primary maintainer was Liam Girdwood and a number of people have made contributions including Dmitry Baryshkov, Stanley Cai, Rodolfo Giometti, Russell King, Marc Kleine-Budde, Ian Molton, Vincent Sanders, Andrew Zabolotny, Graeme Gregory, Mike Arthur and myself. Apologies to anyone I have omitted. Signed-off-by: Liam Girdwood <liam.girdwood@wolfsonmicro.com> Signed-off-by: Graeme Gregory <gg@opensource.wolfsonmicro.com> Signed-off-by: Mike Arthur <mike.arthur@wolfsonmicro.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-04-02Input: ads7846 - simplify support of external vREF (and ads7843)David Brownell
This updates the ads7846 driver to handle external vREF (required on boards using ads7843 chips) without module parameters, and also removes a needless variable with its associated bogus gcc warning. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-04-02Input: locomokbd - add 'off' button support for Sharp Collie/PoodleHelge Deller
Enables the Sharp Zaurus Collie and Poodle devices to be turned off by pressing the "Cancel" button for a few seconds (as designed by Sharp). Additional small cleanups: - removal of unused #defines and variables - add missing __devinit/__devexit/__devinitconst annotations - reorganized copyright notice Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-04-02Input: remove private member from input_dev structureDmitry Torokhov
Everyone should be using input_{get|set}_drvdata() by now. Alias them to dev_{get|set}_drvdata() and remove ->private. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-04-01Input: make sure input interfaces pin parent input devicesDmitry Torokhov
Recent driver core change causes references to parent devices being dropped early, at device_del() time, as opposed to when all children are freed. This causes oops in evdev with grabbed devices. Take the reference to the parent input device ourselves to ensure that it stays around long enough. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-04-01Merge master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6 into ↵Dmitry Torokhov
for-linus
2008-03-30evdev: Release eventual input device grabs when getting disconnectedBjörn Steinbrink
When getting disconnected we need to release eventual grabs on the underlying input device as we also release the input device itself. Otherwise, we would try to release the grab when the client that requested it closes its handle, accessing the input device which might already be freed. Signed-off-by: Björn Steinbrink <B.Steinbrink@gmx.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-28ixp4xx-beeper: add MODULE_ALIASAlessandro Zummo
The following patch allows ixp4xx-beeper to be loaded by udev automatically when compiled as a module with kernel versions 2.4.24 and greater. This patch is required because 43cc71eed1250755986da4c0f9898f9a635cb3bf ("platform: prefix MODALIAS with "platform:"") changed the modalias string to have the extra prefix. LKG7102D7:~# udevinfo -a -p /sys/devices/platform/ixp4xx-beeper.4 looking at device '/devices/platform/ixp4xx-beeper.4': KERNEL=="ixp4xx-beeper.4" SUBSYSTEM=="platform" DRIVER=="" ATTR{modalias}=="platform:ixp4xx-beeper" udev therefore tries to modprobe platform:ixp4xx-beeper instead of ixp4xx-beeper. LKG7102D7:~# udevtest /sys/devices/platform/ixp4xx-beeper.4 ... import_uevent_var: import into environment: 'PHYSDEVBUS=platform' import_uevent_var: import into environment: 'MODALIAS=platform:ixp4xx-beeper' main: looking at device '/devices/platform/ixp4xx-beeper.4' from subsystem 'platform' wait_for_sysfs: file '/sys/devices/platform/ixp4xx-beeper.4/bus' appeared after 0 loops main: run: 'socket:/org/kernel/udev/monitor' main: run: '/sbin/modprobe --use-blacklist platform:ixp4xx-beeper' With this patch, depmod adds an alias line (see below) to modules.alias which allows modprobe to load the right module. alias platform:ixp4xx-beeper ixp4xx-beeper Signed-off-by: Gordon Farquharson <gordonfarquharson@gmail.com> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: David Brownell <david-b@pacbell.net> Cc: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-24Input: apm-power - fix crash when unloading modulesHelge Deller
Fix a crash in the apm-power driver when an input-device, such as keyboard driver module, is unloaded. Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-03-20Input: pxa27x - fix keypad KPC macrosSamuel Ortiz
We want to mask (key_number - 1), not key_number. The current implementation works fine for all values but the maximum one, i.e. 8. Signed-off-by: Samuel Ortiz <sameo@openedhand.com> Acked-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-03-18Input: ALPS - fix forward/back buttons reversed on Acer 5520-5290Laszlo Kajan
ALPS_FW_BK_1 protocol flavor seems to have forward and backward keys reversed. Signed-off-by: Laszlo Kajan <kajla@bioinfo.pl> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-03-18Input: ALPS - put secondary device in proper place in sysfsDmitry Torokhov
Secondary input device did not have parent set up causing it to appear in the root of sysfs device hierarchy. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-03-14Input: wacom - add support for Bamboo1, BambooFun, and Cintiq 12WXPing Cheng
Add support for new wacom tablets - Bamboo1, BambooFun, and Cintiq 12WX Signed-off-by: Ping Cheng <pingc@wacom.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-03-14Input: ads7846 - fix uninitialized var warningAndrew Morton
drivers/input/touchscreen/ads7846.c: In function 'ads7846_read12_ser': drivers/input/touchscreen/ads7846.c:216: warning: 'sample' may be used uninitialized in this function Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-03-14Input: i8042 - add SNI RM supportThomas Bogendoerfer
SNI RM200 don't have the i8042 controller connected to the EISA bus, but have a second address range for onboard devices. This patch handles the two possible address ranges for the i8042 on SNI RMs. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-03-14Input: i8042 - add Lenovo 3000 N100 to nomux blacklistJiri Kosina
Lenovo 3000 N100 needs entry in nomux blacklist. Reported-by: Christopher Desjardins <cddesjardins@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-03-14Input: i8042 - fix warning on non-x86 buildsRoland Dreier
Commit c18bab80 ("Input: i8042 - non-x86 build fix") introduced the following warning on non-x86 builds: drivers/input/serio/i8042.c: In function 'i8042_probe': drivers/input/serio/i8042.c:1154: warning: unused variable 'param' Fix this by moving the parameter variable declaration into the #ifdef too. Signed-off-by: Roland Dreier <rolandd@cisco.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-03-14Input: cobalt_btns - assorted fixesYoichi Yuasa
- fix compile errors (keymap is in bdev, not pdev) - cdev is no more (must use dev.parent) - update copiright notice Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-03-10i8042: use SGI_HAS_I8042 to select SGI i8042 handlinigThomas Bogendoerfer
Use SGI_HAS_I8042 to select SGI i8042 handling Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Cc: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04input: add I2C to config since the driver makes several i2c*() callsRandy Dunlap
Add to help text that the Intel I2C ICH (i801) driver is also needed for this kernel. Add LEDS_CLASS to config since the driver makes les_classdev_*() calls: ERROR: "led_classdev_register" [drivers/input/misc/apanel.ko] undefined! ERROR: "__led_classdev_unregister" [drivers/input/misc/apanel.ko] undefined! Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08mn10300: add the MN10300/AM33 architecture to the kernelDavid Howells
Add architecture support for the MN10300/AM33 CPUs produced by MEI to the kernel. This patch also adds board support for the ASB2303 with the ASB2308 daughter board, and the ASB2305. The only processor supported is the MN103E010, which is an AM33v2 core plus on-chip devices. [akpm@linux-foundation.org: nuke cvs control strings] Signed-off-by: Masakazu Urade <urade.masakazu@jp.panasonic.com> Signed-off-by: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (34 commits) Input: i8042 - non-x86 build fix Input: pxa27x_keypad - also enable on PXA3xx Input: pxa27x_keypad - add debounce_interval to the keypad platform data Input: pxa27x_keypad - use device resources for I/O memory mapping and IRQ Input: pxa27x_keypad - enable rotary encoders and direct keys Input: pxa27x_keypad - introduce pxa27x_keypad_config() Input: pxa27x_keypad - introduce driver structure and use KEY() to define matrix keys Input: pxa27x_keypad - remove pin configuration from the driver Input: pxa27x_keypad - rename the driver (was pxa27x_keyboard) Input: constify function pointer tables (seq_operations) Input: i8042 - add Fujitsu-Siemens Amilo Pro 2010 to nomux list Input: i8042 - enable DMI quirks on x86-64 Input: i8042 - add Dritek quirk for Acer Aspire 9110 Input: add input event to APM event bridge Input: mousedev - use BIT_MASK instead of BIT Input: remove duplicate includes Input: remove cdev from input_dev structure Input: remove duplicated headers in drivers/char/keyboard.c Input: i8042 - add Dritek keyboard extension quirk Input: add Tosa keyboard driver ...
