Since it is not guaranteed that an iommu driver initializes in its
domain_init() function, it must be initialized with NULL to prevent
calling a function in an arbitrary location when iommu fault occurred.
Signed-off-by: KyongHo Cho <pullip.cho@samsung.com>
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
An IOMMU group is a set of devices for which the IOMMU cannot
distinguish transactions. For PCI devices, a group often occurs
when a PCI bridge is involved. Transactions from any device
behind the bridge appear to be sourced from the bridge itself.
We leave it to the IOMMU driver to define the grouping restraints
for their platform.
Using this new interface, the group for a device can be retrieved
using the iommu_device_group() callback. Users will compare the
value returned against the value returned for other devices to
determine whether they are part of the same group. Devices with
no group are not translated by the IOMMU. There should be no
expectations about the group numbers as they may be arbitrarily
assigned by the IOMMU driver and may not be persistent across boots.
We also provide a sysfs interface to the group numbers here so
that userspace can understand IOMMU dependencies between devices
for managing safe, userspace drivers.
[Some code changes by Joerg Roedel <joerg.roedel@amd.com>]
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
include/linux/iommu.h
Change-Id: I524607da569e42730bdc706759c49c4e0783555c
Now that all IOMMU drivers are exporting their supported pgsizes,
we can remove the default pgsize settings in register_iommu().
Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com>
When mapping a memory region, split it to page sizes as supported
by the iommu hardware. Always prefer bigger pages, when possible,
in order to reduce the TLB pressure.
The logic to do that is now added to the IOMMU core, so neither the iommu
drivers themselves nor users of the IOMMU API have to duplicate it.
This allows a more lenient granularity of mappings; traditionally the
IOMMU API took 'order' (of a page) as a mapping size, and directly let
the low level iommu drivers handle the mapping, but now that the IOMMU
core can split arbitrary memory regions into pages, we can remove this
limitation, so users don't have to split those regions by themselves.
Currently the supported page sizes are advertised once and they then
remain static. That works well for OMAP and MSM but it would probably
not fly well with intel's hardware, where the page size capabilities
seem to have the potential to be different between several DMA
remapping devices.
register_iommu() currently sets a default pgsize behavior, so we can convert
the IOMMU drivers in subsequent patches. After all the drivers
are converted, the temporary default settings will be removed.
Mainline users of the IOMMU API (kvm and omap-iovmm) are adopted
to deal with bytes instead of page order.
Many thanks to Joerg Roedel <Joerg.Roedel@amd.com> for significant review!
Cc: David Brown <davidb@codeaurora.org>
Cc: Joerg Roedel <Joerg.Roedel@amd.com>
Cc: Stepan Moskovchenko <stepanm@codeaurora.org>
Cc: KyongHo Cho <pullip.cho@samsung.com>
Cc: Hiroshi DOYU <hdoyu@nvidia.com>
Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Cc: kvm@vger.kernel.org
Express sizes in bytes rather than in page order, to eliminate the
size->order->size conversions we have whenever the IOMMU API is calling
the low level drivers' map/unmap methods.
Adopt all existing drivers.
With all IOMMU drivers being converted to bus_set_iommu the
global iommu_ops are no longer required. The same is true
for the deprecated register_iommu function.
Use the per-bus iommu-ops in the functions of the iommu-api
instead of the global iommu_ops.
With per-bus iommu_ops the iommu_found function needs to
work on a bus_type too. This patch adds a bus_type parameter
to that function and converts all call-places.
The function is also renamed to iommu_present because the
function now checks if an iommu is present for a given bus
and does not check for a global iommu anymore.
This is necessary to store a pointer to the bus-specific
iommu_ops in the iommu-domain structure. It will be used
later to call into bus-specific iommu-ops.
drivers/iommu/iommu.c
Change-Id: Iddbd561739552b663a4be293f1992314eb0f775a
This is the starting point to make the iommu_ops used for
the iommu-api a per-bus-type structure. It is required to
easily implement bus-specific setup in the iommu-layer.
The first user will be the iommu-group attribute in sysfs.
Make report_iommu_fault() return -ENOSYS whenever an iommu fault
handler isn't installed, so IOMMU drivers can then do their own
platform-specific default behavior if they wanted.
Fault handlers can still return -ENOSYS in case they want to elicit the
default behavior of the IOMMU drivers.
commit 4f3f8d9 "iommu/core: Add fault reporting mechanism" added
the public iommu_set_fault_handler() symbol but forgot to export it.
Fix that.
Add iommu fault report mechanism to the IOMMU API, so implementations
could report about mmu faults (translation errors, hardware errors,
etc..).
Fault reports can be used in several ways:
- mere logging
- reset the device that accessed the faulting address (may be necessary
in case the device is a remote processor for example)
- implement dynamic PTE/TLB loading
A dedicated iommu_set_fault_handler() API has been added to allow
users, who are interested to receive such reports, to provide
their handler.
Replace the hard-coded 4kb by PAGE_SIZE to make iommu-api
implementations possible on architectures where
PAGE_SIZE != 4kb.
Replace iommu's alignment checks with the existing IS_ALIGNED macro,
to drop a few lines of code and utilize IS_ALIGNED's type safety.
Create a dedicated folder for iommu drivers, and move the base
iommu implementation over there.
Grouping the various iommu drivers in a single location will help
finding similar problems shared by different platforms, so they
could be solved once, in the iommu framework, instead of solved
differently (or duplicated) in each driver.
