path: root/drivers/iommu/tegra-smmu.c
2015-08-13iommu/tegra-smmu: Parameterize number of TLB linesThierry Reding
The number of TLB lines was increased from 16 on Tegra30 to 32 on Tegra114 and later. Parameterize the value so that the initial default can be set accordingly. On Tegra30, initializing the value to 32 would effectively disable the TLB and hence cause massive latencies for memory accesses translated through the SMMU. This is especially noticeable for isochronuous clients such as display, whose FIFOs would continuously underrun. Fixes: 891846516317 ("memory: Add NVIDIA Tegra memory controller support") Signed-off-by: Thierry Reding <treding@nvidia.com>
2015-08-13iommu/tegra-smmu: Factor out tegra_smmu_set_pde()Russell King
This code is used both when creating a new page directory entry and when tearing it down, with only the PDE value changing between both cases. Factor the code out so that it can be reused. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> [treding@nvidia.com: make commit message more accurate] Signed-off-by: Thierry Reding <treding@nvidia.com>
2015-08-13iommu/tegra-smmu: Extract tegra_smmu_pte_get_use()Russell King
Extract the use count reference accounting into a separate function and separate it from allocating the PTE. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> [treding@nvidia.com: extract and write commit message] Signed-off-by: Thierry Reding <treding@nvidia.com>
2015-08-13iommu/tegra-smmu: Use __GFP_ZERO to allocate zeroed pagesRussell King
Rather than explicitly zeroing pages allocated via alloc_page(), add __GFP_ZERO to the gfp mask to ask the allocator for zeroed pages. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Thierry Reding <treding@nvidia.com>
2015-08-13iommu/tegra-smmu: Remove PageReserved manipulationRussell King
Remove the unnecessary manipulation of the PageReserved flags in the Tegra SMMU driver. None of this is required as the page(s) remain private to the SMMU driver. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Thierry Reding <treding@nvidia.com>
2015-08-13iommu/tegra-smmu: Convert to use DMA APIRussell King
Use the DMA API instead of calling architecture internal functions in the Tegra SMMU driver. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Thierry Reding <treding@nvidia.com>
2015-08-13iommu/tegra-smmu: smmu_flush_ptc() wants device addressesRussell King
Pass smmu_flush_ptc() the device address rather than struct page pointer. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Thierry Reding <treding@nvidia.com>
2015-08-13iommu/tegra-smmu: Split smmu_flush_ptc()Russell King
smmu_flush_ptc() is used in two modes: one is to flush an individual entry, the other is to flush all entries. We know at the call site which we require. Split the function into smmu_flush_ptc_all() and smmu_flush_ptc(). Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Thierry Reding <treding@nvidia.com>
2015-08-13iommu/tegra-smmu: Move flush_dcache to tegra-smmu.cRussell King
Drivers should not be using __cpuc_* functions nor outer_cache_flush() directly. This change partly cleans up tegra-smmu.c. The only difference between cache handling of the tegra variants is Denver, which omits the call to outer_cache_flush(). This is due to Denver being an ARM64 CPU, and the ARM64 architecture does not provide this function. (This, in itself, is a good reason why these should not be used.) Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> [treding@nvidia.com: fix build failure on 64-bit ARM] Signed-off-by: Thierry Reding <treding@nvidia.com>
2015-08-13iommu/tegra-smmu: Use kcalloc() to allocate counter arrayRussell King
Use kcalloc() to allocate the use-counter array for the page directory entries/page tables. Using kcalloc() allows us to be provided with zero-initialised memory from the allocators, rather than initialising it ourselves. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Thierry Reding <treding@nvidia.com>
2015-08-13iommu/tegra-smmu: Store struct page pointer for page tablesRussell King
Store the struct page pointer for the second level page tables, rather than working back from the page directory entry. This is necessary as we want to eliminate the use of physical addresses used with arch-private functions, switching instead to use the streaming DMA API. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Thierry Reding <treding@nvidia.com>
2015-08-13iommu/tegra-smmu: Fix page table lookup in unmap/iova_to_phys methodsRussell King
Fix the page table lookup in the unmap and iova_to_phys methods. Neither of these methods should allocate a page table; a missing page table should be treated the same as no mapping present. More importantly, using as_get_pte() for an IOVA corresponding with a non-present page table entry increments the use-count for the page table, on the assumption that the caller of as_get_pte() is going to setup a mapping. This is an incorrect assumption. Fix both of these bugs by providing a separate helper which only looks up the page table, but never allocates it. This is akin to pte_offset() for CPU page tables. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Thierry Reding <treding@nvidia.com>
2015-08-13iommu/tegra-smmu: Add iova_pd_index() and iova_pt_index() helpersRussell King
Add a pair of helpers to get the page directory and page table indexes. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Thierry Reding <treding@nvidia.com>
2015-08-13iommu/tegra-smmu: Factor out common PTE settingRussell King
Factor out the common PTE setting code into a separate function. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Thierry Reding <treding@nvidia.com>
2015-08-13iommu/tegra-smmu: Fix unmap() methodRussell King
The Tegra SMMU unmap path has several problems: 1. as_pte_put() can perform a write-after-free 2. tegra_smmu_unmap() can perform cache maintanence on a page we have just freed. 3. when a page table is unmapped, there is no CPU cache maintanence of the write clearing the page directory entry, nor is there any maintanence of the IOMMU to ensure that it sees the page table has gone. Fix this by getting rid of as_pte_put(), and instead coding the PTE unmap separately from the PDE unmap, placing the PDE unmap after the PTE unmap has been completed. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Thierry Reding <treding@nvidia.com>
2015-08-13iommu/tegra-smmu: Fix iova_to_phys() methodRussell King
iova_to_phys() has several problems: (a) iova_to_phys() is supposed to return 0 if there is no entry present for the iova. (b) if as_get_pte() fails, we oops the kernel by dereferencing a NULL pointer. Really, we should not even be trying to allocate a page table at all, but should only be returning the presence of the 2nd level page table. This will be fixed in a subsequent patch. Treat both of these conditions as "no mapping" conditions. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Thierry Reding <treding@nvidia.com>
2015-05-04iommu/tegra-smmu: Add debugfs supportThierry Reding
Provide clients and swgroups files in debugfs. These files show for which clients IOMMU translation is enabled and which ASID is associated with each SWGROUP. Cc: Hiroshi Doyu <hdoyu@nvidia.com> Acked-by: Joerg Roedel <jroedel@suse.de> Signed-off-by: Thierry Reding <treding@nvidia.com>
2015-04-02Merge branches 'iommu/fixes', 'x86/vt-d', 'x86/amd', 'arm/smmu', 'arm/tegra' ↵Joerg Roedel
and 'core' into next Conflicts: drivers/iommu/amd_iommu.c drivers/iommu/tegra-gart.c drivers/iommu/tegra-smmu.c
2015-03-31iommu/tegra: smmu: Compute PFN mask at runtimeThierry Reding
The SMMU on Tegra30 and Tegra114 supports addressing up to 4 GiB of physical memory. On Tegra124 the addressable physical memory was extended to 16 GiB. The page frame number stored in PTEs therefore requires 20 or 22 bits, depending on SoC generation. In order to cope with this, compute the proper value at runtime. Reported-by: Joseph Lo <josephl@nvidia.com> Cc: Hiroshi Doyu <hdoyu@nvidia.com> Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Joerg Roedel <jroedel@suse.de>
2015-03-31iommu/tegra: Setup apertureThierry Reding
Each address space in the Tegra SMMU provides 4 GiB worth of addresses. Cc: Hiroshi Doyu <hdoyu@nvidia.com> Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Joerg Roedel <jroedel@suse.de>
2015-03-31iommu/tegra-smmu: Make use of domain_alloc and domain_freeJoerg Roedel
Implement domain_alloc and domain_free iommu-ops as a replacement for domain_init/domain_destroy. Tested-by: Thierry Reding <treding@nvidia.com> Acked-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Joerg Roedel <jroedel@suse.de>
2014-12-04memory: Add NVIDIA Tegra memory controller supportThierry Reding
The memory controller on NVIDIA Tegra exposes various knobs that can be used to tune the behaviour of the clients attached to it. Currently this driver sets up the latency allowance registers to the HW defaults. Eventually an API should be exported by this driver (via a custom API or a generic subsystem) to allow clients to register latency requirements. This driver also registers an IOMMU (SMMU) that's implemented by the memory controller. It is supported on Tegra30, Tegra114 and Tegra124 currently. Tegra20 has a GART instead. The Tegra SMMU operates on memory clients and SWGROUPs. A memory client is a unidirectional, special-purpose DMA master. A SWGROUP represents a set of memory clients that form a logical functional unit corresponding to a single device. Typically a device has two clients: one client for read transactions and one client for write transactions, but there are also devices that have only read clients, but many of them (such as the display controllers). Because there is no 1:1 relationship between memory clients and devices the driver keeps a table of memory clients and the SWGROUPs that they belong to per SoC. Note that this is an exception and due to the fact that the SMMU is tightly integrated with the rest of the Tegra SoC. The use of these tables is discouraged in drivers for generic IOMMU devices such as the ARM SMMU because the same IOMMU could be used in any number of SoCs and keeping such tables for each SoC would not scale. Acked-by: Joerg Roedel <jroedel@suse.de> Signed-off-by: Thierry Reding <treding@nvidia.com>
2014-11-04iommu: Add iommu_map_sg() functionOlav Haugan
Mapping and unmapping are more often than not in the critical path. map_sg allows IOMMU driver implementations to optimize the process of mapping buffers into the IOMMU page tables. Instead of mapping a buffer one page at a time and requiring potentially expensive TLB operations for each page, this function allows the driver to map all pages in one go and defer TLB maintenance until after all pages have been mapped. Additionally, the mapping operation would be faster in general since clients does not have to keep calling map API over and over again for each physically contiguous chunk of memory that needs to be mapped to a virtually contiguous region. Signed-off-by: Olav Haugan <ohaugan@codeaurora.org> Signed-off-by: Joerg Roedel <jroedel@suse.de>
2014-09-25iommu: Make of_device_id array constKiran Padwal
Make of_device_id array const, because all OF functions handle it as const. Signed-off-by: Kiran Padwal <kiran.padwal@smartplayin.com> Signed-off-by: Joerg Roedel <jroedel@suse.de>
2014-09-25iommu/tegra: Convert to iommu_capable() API functionJoerg Roedel
Cc: Hiroshi Doyu <hdoyu@nvidia.com> Signed-off-by: Joerg Roedel <jroedel@suse.de>
2014-08-08Merge tag 'cleanup-for-3.17' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC cleanups from Olof Johansson: "This merge window brings a good size of cleanups on various platforms. Among the bigger ones: - Removal of Samsung s5pc100 and s5p64xx platforms. Both of these have lacked active support for quite a while, and after asking around nobody showed interest in keeping them around. If needed, they could be resurrected in the future but it's more likely that we would prefer reintroduction of them as DT and multiplatform-enabled platforms instead. - OMAP4 controller code register define diet. They defined a lot of registers that were never actually used, etc. - Move of some of the Tegra platform code (PMC, APBIO, fuse, powergate) to drivers/soc so it can be shared with 64-bit code. This also converts them over to traditional driver models where possible. - Removal of legacy gpio-samsung driver, since the last users have been removed (moved to pinctrl) Plus a bunch of smaller changes for various platforms that sort of dissapear in the diffstat for the above. clps711x cleanups, shmobile header file refactoring/moves for multiplatform friendliness, some misc cleanups, etc" * tag 'cleanup-for-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (117 commits) drivers: CCI: Correct use of ! and & video: clcd-versatile: Depend on ARM video: fix up versatile CLCD helper move MAINTAINERS: Add sdhci-st file to ARCH/STI architecture ARM: EXYNOS: Fix build breakge with PM_SLEEP=n MAINTAINERS: Remove Kirkwood ARM: tegra: Convert PMC to a driver soc/tegra: fuse: Set up in early initcall ARM: tegra: Always lock the CPU reset vector ARM: tegra: Setup CPU hotplug in a pure initcall soc/tegra: Implement runtime check for Tegra SoCs soc/tegra: fuse: fix dummy functions soc/tegra: fuse: move APB DMA into Tegra20 fuse driver soc/tegra: Add efuse and apbmisc bindings soc/tegra: Add efuse driver for Tegra ARM: tegra: move fuse exports to soc/tegra/fuse.h ARM: tegra: export apb dma readl/writel ARM: tegra: Use a function to get the chip ID ARM: tegra: Sort includes alphabetically ARM: tegra: Move includes to include/soc/tegra ...
2014-07-17ARM: tegra: Move includes to include/soc/tegraThierry Reding
In order to not clutter the include/linux directory with SoC specific headers, move the Tegra-specific headers out into a separate directory. Signed-off-by: Thierry Reding <treding@nvidia.com>
2014-07-07iommu: Constify struct iommu_opsThierry Reding
This structure is read-only data and should never be modified. Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Joerg Roedel <jroedel@suse.de>
2013-11-01iommu/tegra-smmu: Staticize tegra_smmu_pm_opsSachin Kamat
'tegra_smmu_pm_ops' is used only in this file. Make it static. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Acked-by: Hiroshi Doyu <hdoyu@nvidia.com> Signed-off-by: Joerg Roedel <joro@8bytes.org>
2013-09-24iommu/tegra: Print phys_addr_t using %paThierry Reding
When enabling LPAE on ARM, phys_addr_t becomes 64 bits wide and printing a variable of that type using a simple %x format specifier causes the compiler to complain. Change the format specifier to %pa, which is used specifically for variables of type phys_addr_t. Signed-off-by: Thierry Reding <treding@nvidia.com> Acked-by: Olof Johansson <olof@lixom.net> Signed-off-by: Joerg Roedel <joro@8bytes.org>
2013-08-15tegra: simplify use of devm_ioremap_resourceJulia Lawall
Remove unneeded error handling on the result of a call to platform_get_resource when the value is passed to devm_ioremap_resource. A simplified version of the semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression pdev,res,n,e,e1; expression ret != 0; identifier l; @@ - res = platform_get_resource(pdev, IORESOURCE_MEM, n); ... when != res - if (res == NULL) { ... \(goto l;\|return ret;\) } ... when != res + res = platform_get_resource(pdev, IORESOURCE_MEM, n); e = devm_ioremap_resource(e1, res); // </smpl> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2013-05-02Merge branches 'iommu/fixes', 'x86/vt-d', 'x86/amd', 'ppc/pamu', 'core' and ↵Joerg Roedel
'arm/tegra' into next
2013-05-02iommu/tegra: Fix printk formats for dma_addr_tVarun Sethi
Fix printk formats for dma_addr_t: drivers/iommu/tegra-smmu.c: In function 'smmu_iommu_iova_to_phys': >> drivers/iommu/tegra-smmu.c:774:2: warning: format '%lx' expects argument of type 'long unsigned int', but argument 4 has type 'dma_addr_t' [-Wformat] -- drivers/iommu/tegra-gart.c: In function 'gart_iommu_iova_to_phys': >> drivers/iommu/tegra-gart.c:298:3: warning: format '%lx' expects argument of type 'long unsigned int', but argument 3 has type 'dma_addr_t' [-Wformat] Signed-off-by: Varun Sethi <Varun.Sethi@freescale.com> Signed-off-by: Joerg Roedel <joro@8bytes.org>
2013-04-02iommu/fsl: Make iova dma_addr_t in the iommu_iova_to_phys API.Varun Sethi
This is required in case of PAMU, as it can support a window size of up to 64G (even on 32bit). Signed-off-by: Varun Sethi <Varun.Sethi@freescale.com> Signed-off-by: Joerg Roedel <joro@8bytes.org>
2013-02-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile (part one) from Al Viro: "Assorted stuff - cleaning namei.c up a bit, fixing ->d_name/->d_parent locking violations, etc. The most visible changes here are death of FS_REVAL_DOT (replaced with "has ->d_weak_revalidate()") and a new helper getting from struct file to inode. Some bits of preparation to xattr method interface changes. Misc patches by various people sent this cycle *and* ocfs2 fixes from several cycles ago that should've been upstream right then. PS: the next vfs pile will be xattr stuff." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (46 commits) saner proc_get_inode() calling conventions proc: avoid extra pde_put() in proc_fill_super() fs: change return values from -EACCES to -EPERM fs/exec.c: make bprm_mm_init() static ocfs2/dlm: use GFP_ATOMIC inside a spin_lock ocfs2: fix possible use-after-free with AIO ocfs2: Fix oops in ocfs2_fast_symlink_readpage() code path get_empty_filp()/alloc_file() leave both ->f_pos and ->f_version zero target: writev() on single-element vector is pointless export kernel_write(), convert open-coded instances fs: encode_fh: return FILEID_INVALID if invalid fid_type kill f_vfsmnt vfs: kill FS_REVAL_DOT by adding a d_weak_revalidate dentry op nfsd: handle vfs_getattr errors in acl protocol switch vfs_getattr() to struct path default SET_PERSONALITY() in linux/elf.h ceph: prepopulate inodes only when request is aborted d_hash_and_lookup(): export, switch open-coded instances 9p: switch v9fs_set_create_acl() to inode+fid, do it before d_instantiate() 9p: split dropping the acls from v9fs_set_create_acl() ...
2013-02-26Merge tag 'iommu-updates-v3.9' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu Pull IOMMU Updates from Joerg Roedel: "Besides some fixes and cleanups in the code there are three more important changes to point out this time: * New IOMMU driver for the ARM SHMOBILE platform * An IOMMU-API extension for non-paging IOMMUs (required for upcoming PAMU driver) * Rework of the way the Tegra IOMMU driver accesses its registetrs - register windows are easier to extend now. There are also a few changes to non-iommu code, but that is acked by the respective maintainers." * tag 'iommu-updates-v3.9' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: (23 commits) iommu/tegra: assume CONFIG_OF in SMMU driver iommu/tegra: assume CONFIG_OF in gart driver iommu/amd: Remove redundant NULL check before dma_ops_domain_free(). iommu/amd: Initialize device table after dma_ops iommu/vt-d: Zero out allocated memory in dmar_enable_qi iommu/tegra: smmu: Fix incorrect mask for regbase iommu/exynos: Make exynos_sysmmu_disable static ARM: mach-shmobile: r8a7740: Add IPMMU device ARM: mach-shmobile: sh73a0: Add IPMMU device ARM: mach-shmobile: sh7372: Add IPMMU device iommu/shmobile: Add iommu driver for Renesas IPMMU modules iommu: Add DOMAIN_ATTR_WINDOWS domain attribute iommu: Add domain window handling functions iommu: Implement DOMAIN_ATTR_PAGING attribute iommu: Check for valid pgsize_bitmap in iommu_map/unmap iommu: Make sure DOMAIN_ATTR_MAX is really the maximum iommu/tegra: smmu: Change SMMU's dependency on ARCH_TEGRA iommu/tegra: smmu: Use helper function to check for valid register offset iommu/tegra: smmu: Support variable MMIO ranges/blocks iommu/tegra: Add missing spinlock initialization ...
2013-02-26tegra: don't wank with d_find_alias()Al Viro
2013-02-22new helper: file_inode(file)Al Viro
2013-02-19iommu/tegra: assume CONFIG_OF in SMMU driverStephen Warren
Tegra only supports, and always enables, device tree. Remove all ifdefs for DT support from the driver. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Joerg Roedel <joro@8bytes.org>
2013-02-07iommu/tegra: smmu: Fix incorrect mask for regbaseHiroshi Doyu
This fixes kernel crash because of BUG() in register address validation. Signed-off-by: Hiroshi Doyu <hdoyu@nvidia.com> Signed-off-by: Joerg Roedel <joro@8bytes.org>
2013-02-05iommu/tegra: smmu: Use helper function to check for valid register offsetJoerg Roedel
Do not repeat the checking loop in the read and write functions. Use a single helper function for that check and call it in both accessors. Signed-off-by: Joerg Roedel <joro@8bytes.org>
2013-02-05iommu/tegra: smmu: Support variable MMIO ranges/blocksHiroshi Doyu
Presently SMMU registers are located in discontiguous 3 blocks. They are interleaved by MC registers. Ideally SMMU register blocks should be in an independent one block, but it is too late to change this H/W design. In the future Tegra chips over some generations, it is expected that some of register block "size" can be extended towards the end and also more new register blocks will be added at most a few blocks. The starting address of each existing block won't change. This patch allocates multiple number of register blocks dynamically based on the info passed from DT. Those ranges are verified in the accessors{read,write}. This may sacrifice some performance because a new accessors prevents compiler optimization of a fixed size register offset calculation. Since SMMU register accesses are not so frequent, this would be acceptable. This patch is necessary to unify "tegra-smmu.ko" over some Tegra SoC generations. Signed-off-by: Hiroshi Doyu <hdoyu@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Joerg Roedel <joro@8bytes.org>
2013-02-04iommu/tegra: Add missing spinlock initializationSami Liedes
Fix tegra_smmu_probe() to initialize client_lock spinlocks in per-address-space structures. Signed-off-by: Sami Liedes <sliedes@nvidia.com> Signed-off-by: Joerg Roedel <joro@8bytes.org>
2013-01-25iommu: Convert to devm_ioremap_resource()Thierry Reding
Convert all uses of devm_request_and_ioremap() to the newly introduced devm_ioremap_resource() which provides more consistent error handling. devm_ioremap_resource() provides its own error messages so all explicit error messages can be removed from the failure code paths. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Cc: Joerg Roedel <joro@8bytes.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-03Drivers: iommu: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Joerg Roedel <joro@8bytes.org> Cc: Ohad Ben-Cohen <ohad@wizery.com> Cc: Tony Lindgren <tony@atomide.com> Cc: Omar Ramirez Luna <omar.luna@linaro.org> Cc: Mauro Carvalho Chehab <mchehab@redhat.com> Cc: Hiroshi Doyu <hdoyu@nvidia.com> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Bharat Nihalani <bnihalani@nvidia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-20Merge tag 'iommu-updates-v3.8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu Pull IOMMU updates from Joerg Roedel: "A few new features this merge-window. The most important one is probably, that dma-debug now warns if a dma-handle is not checked with dma_mapping_error by the device driver. This requires minor changes to some architectures which make use of dma-debug. Most of these changes have the respective Acks by the Arch-Maintainers. Besides that there are updates to the AMD IOMMU driver for refactor the IOMMU-Groups support and to make sure it does not trigger a hardware erratum. The OMAP changes (for which I pulled in a branch from Tony Lindgren's tree) have a conflict in linux-next with the arm-soc tree. The conflict is in the file arch/arm/mach-omap2/clock44xx_data.c which is deleted in the arm-soc tree. It is safe to delete the file too so solve the conflict. Similar changes are done in the arm-soc tree in the common clock framework migration. A missing hunk from the patch in the IOMMU tree will be submitted as a seperate patch when the merge-window is closed." * tag 'iommu-updates-v3.8' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: (29 commits) ARM: dma-mapping: support debug_dma_mapping_error ARM: OMAP4: hwmod data: ipu and dsp to use parent clocks instead of leaf clocks iommu/omap: Adapt to runtime pm iommu/omap: Migrate to hwmod framework iommu/omap: Keep mmu enabled when requested iommu/omap: Remove redundant clock handling on ISR iommu/amd: Remove obsolete comment iommu/amd: Don't use 512GB pages iommu/tegra: smmu: Move bus_set_iommu after probe for multi arch iommu/tegra: gart: Move bus_set_iommu after probe for multi arch iommu/tegra: smmu: Remove unnecessary PTC/TLB flush all tile: dma_debug: add debug_dma_mapping_error support sh: dma_debug: add debug_dma_mapping_error support powerpc: dma_debug: add debug_dma_mapping_error support mips: dma_debug: add debug_dma_mapping_error support microblaze: dma-mapping: support debug_dma_mapping_error ia64: dma_debug: add debug_dma_mapping_error support c6x: dma_debug: add debug_dma_mapping_error support ARM64: dma_debug: add debug_dma_mapping_error support intel-iommu: Prevent devices with RMRRs from being placed into SI Domain ...
2012-11-28iommu/tegra: smmu: Move bus_set_iommu after probe for multi archHiroshi Doyu
For a single image to support multiple SoCs(GART/SMMU). Reported-by: Arto Merilainen <amerilainen@nvidia.com> Signed-off-by: Hiroshi Doyu <hdoyu@nvidia.com> Signed-off-by: Joerg Roedel <joro@8bytes.org>
2012-11-28iommu/tegra: smmu: Remove unnecessary PTC/TLB flush allHiroshi Doyu
smmu_flush_regs() does TLB/PTC flush all when freeing a second level page table. This isn't necessay at all since each pte entry has been already maintained by address in the above flush_ptc_and_tlb(). Signed-off-by: Hiroshi Doyu <hdoyu@nvidia.com> Signed-off-by: Joerg Roedel <joro@8bytes.org>
2012-11-25Merge tag 'v3.7-rc7' into next/cleanupOlof Johansson
Merging in mainline back to next/cleanup since it has collected a few conflicts between fixes going upstream and some of the cleanup patches. Git doesn't auto-resolve some of them, and they're mostly noise so let's take care of it locally. Conflicts are in: arch/arm/mach-omap2/omap_hwmod_44xx_data.c arch/arm/plat-omap/i2c.c drivers/video/omap2/dss/dss.c Signed-off-by: Olof Johansson <olof@lixom.net>
2012-11-17iommu/tegra-smmu.c: fix dentry reference leak in smmu_debugfs_stats_show().Cyril Roelandt
Call to d_find_alias() needs a corresponding dput(). Signed-off-by: Cyril Roelandt <tipecaml@gmail.com> Signed-off-by: Joerg Roedel <joro@8bytes.org>
