This is the 4.14.159 stable release
arch/arm/Kconfig.debug
arch/arm/boot/dts/imx7s.dtsi
arch/arm/mach-imx/cpuidle-imx6sx.c
drivers/crypto/caam/caamalg.c
drivers/crypto/mxs-dcp.c
drivers/dma/imx-sdma.c
drivers/input/keyboard/imx_keypad.c
drivers/net/can/flexcan.c
drivers/net/can/rx-offload.c
drivers/net/wireless/ath/ath10k/pci.c
drivers/pci/dwc/pci-imx6.c
drivers/spi/spi-fsl-lpspi.c
drivers/usb/dwc3/gadget.c
[ Upstream commit bb6bccba390c7d743c1e4427de4ef284c8cc6869 ]
Add a non-NULL check to fix potential NULL pointer dereference
Cleanup code to call function once.
Signed-off-by: Aaron Ma <aaron.ma@canonical.com>
Fixes: 2bf9a0a12749b ('iommu/amd: Add iommu support for ACPI HID devices')
Signed-off-by: Joerg Roedel <jroedel@suse.de>
[ Upstream commit 85c7a0f1ef624ef58173ef52ea77780257bdfe04 ]
In removing the pagetable-wide lock, we gained the possibility of the
vanishingly unlikely case where we have a race between two concurrent
unmappers splitting the same block entry. The logic to handle this is
fairly straightforward - whoever loses the race frees their partial
next-level table and instead dereferences the winner's newly-installed
entry in order to fall back to a regular unmap, which intentionally
echoes the pre-existing case of recursively splitting a 1GB block down
to 4KB pages by installing a full table of 2MB blocks first.
Unfortunately, the chump who implemented that logic failed to update the
condition check for that fallback, meaning that if said race occurs at
the last level (where the loser's unmap_idx is valid) then the unmap
won't actually happen. Fix that to properly account for both the race
and recursive cases.
Fixes: 2c3d273eabe8 ("iommu/io-pgtable-arm: Support lockless operation")
Signed-off-by: Robin Murphy <robin.murphy@arm.com>
[will: re-jig control flow to avoid duplicate cmpxchg test]
[ Upstream commit 0d87308cca2c124f9bce02383f1d9632c9be89c4 ]
In commit 14bd9a607f90 ("iommu/iova: Separate atomic variables
to improve performance") Jinyu Qi identified that the atomic_cmpxchg()
in queue_iova() was causing a performance loss and moved critical fields
so that the false sharing would not impact them.
However, avoiding the false sharing in the first place seems easy.
We should attempt the atomic_cmpxchg() no more than 100 times
per second. Adding an atomic_read() will keep the cache
line mostly shared.
This false sharing came with commit 9a005a800ae8
("iommu/iova: Add flush timer").
Fixes: 9a005a800ae8 ('iommu/iova: Add flush timer')
Cc: Jinyu Qi <jinyuqi@huawei.com>
Cc: Joerg Roedel <jroedel@suse.de>
Acked-by: Robin Murphy <robin.murphy@arm.com>
[ Upstream commit 3d708895325b78506e8daf00ef31549476e8586a ]
When running heavy memory pressure workloads, the system is throwing
endless warnings,
smartpqi 0000:23:00.0: AMD-Vi: IOMMU mapping error in map_sg (io-pages:
5 reason: -12)
Hardware name: HPE ProLiant DL385 Gen10/ProLiant DL385 Gen10, BIOS A40
07/10/2019
swapper/10: page allocation failure: order:0, mode:0xa20(GFP_ATOMIC),
nodemask=(null),cpuset=/,mems_allowed=0,4
Call Trace:
<IRQ>
dump_stack+0x62/0x9a
warn_alloc.cold.43+0x8a/0x148
__alloc_pages_nodemask+0x1a5c/0x1bb0
get_zeroed_page+0x16/0x20
iommu_map_page+0x477/0x540
map_sg+0x1ce/0x2f0
scsi_dma_map+0xc6/0x160
pqi_raid_submit_scsi_cmd_with_io_request+0x1c3/0x470 [smartpqi]
do_IRQ+0x81/0x170
common_interrupt+0xf/0xf
</IRQ>
because the allocation could fail from iommu_map_page(), and the volume
of this call could be huge which may generate a lot of serial console
output and cosumes all CPUs.
Fix it by silencing the warning in this call site, and there is still a
dev_err() later to notify the failure.
Signed-off-by: Qian Cai <cai@lca.pw>
[ Upstream commit 754265bcab78a9014f0f99cd35e0d610fcd7dfa7 ]
After the conversion to lock-less dma-api call the
increase_address_space() function can be called without any
locking. Multiple CPUs could potentially race for increasing
the address space, leading to invalid domain->mode settings
and invalid page-tables. This has been happening in the wild
under high IO load and memory pressure.
Fix the race by locking this operation. The function is
called infrequently so that this does not introduce
a performance regression in the dma-api path again.
Reported-by: Qian Cai <cai@lca.pw>
Fixes: 256e4621c21a ('iommu/amd: Make use of the generic IOVA allocator')
[ Upstream commit 36b7200f67dfe75b416b5281ed4ace9927b513bc ]
When devices are attached to the amd_iommu in a kdump kernel, the old device
table entries (DTEs), which were copied from the crashed kernel, will be
overwritten with a new domain number. When the new DTE is written, the IOMMU
is told to flush the DTE from its internal cache--but it is not told to flush
the translation cache entries for the old domain number.
Without this patch, AMD systems using the tg3 network driver fail when kdump
tries to save the vmcore to a network system, showing network timeouts and
(sometimes) IOMMU errors in the kernel log.
This patch will flush IOMMU translation cache entries for the old domain when
a DTE gets overwritten with a new domain number.
Signed-off-by: Stuart Hayes <stuart.w.hayes@gmail.com>
Fixes: 3ac3e5ee5ed5 ('iommu/amd: Copy old trans table from old kernel')
[ Upstream commit ab2cbeb0ed301a9f0460078e91b09f39958212ef ]
Since scatterlist dimensions are all unsigned ints, in the relatively
rare cases where a device's max_segment_size is set to UINT_MAX, then
the "cur_len + s_length <= max_len" check in __finalise_sg() will always
return true. As a result, the corner case of such a device mapping an
excessively large scatterlist which is mergeable to or beyond a total
length of 4GB can lead to overflow and a bogus truncated dma_length in
the resulting segment.
As we already assume that any single segment must be no longer than
max_len to begin with, this can easily be addressed by reshuffling the
comparison.
Fixes: 809eac54cdd6 ("iommu/dma: Implement scatterlist segment merging")
Reported-by: Nicolin Chen <nicoleotsuka@gmail.com>
Tested-by: Nicolin Chen <nicoleotsuka@gmail.com>
commit 24d2c521749d8547765b555b7a85cca179bb2275 upstream.
The function is only called from another __init function, so
it should be moved to .init too.
commit effa467870c7612012885df4e246bdb8ffd8e44c upstream.
Intel VT-d driver was reworked to use common deferred flushing
implementation. Previously there was one global per-cpu flush queue,
afterwards - one per domain.
Before deferring a flush, the queue should be allocated and initialized.
Currently only domains with IOMMU_DOMAIN_DMA type initialize their flush
queue. It's probably worth to init it for static or unmanaged domains
too, but it may be arguable - I'm leaving it to iommu folks.
Prevent queuing an iova flush if the domain doesn't have a queue.
The defensive check seems to be worth to keep even if queue would be
initialized for all kinds of domains. And is easy backportable.
On 4.19.43 stable kernel it has a user-visible effect: previously for
devices in si domain there were crashes, on sata devices:
BUG: spinlock bad magic on CPU#6, swapper/0/1
lock: 0xffff88844f582008, .magic: 00000000, .owner: <none>/-1, .owner_cpu: 0
CPU: 6 PID: 1 Comm: swapper/0 Not tainted 4.19.43 #1
Call Trace:
<IRQ>
dump_stack+0x61/0x7e
spin_bug+0x9d/0xa3
do_raw_spin_lock+0x22/0x8e
_raw_spin_lock_irqsave+0x32/0x3a
queue_iova+0x45/0x115
intel_unmap+0x107/0x113
intel_unmap_sg+0x6b/0x76
__ata_qc_complete+0x7f/0x103
ata_qc_complete+0x9b/0x26a
ata_qc_complete_multiple+0xd0/0xe3
ahci_handle_port_interrupt+0x3ee/0x48a
ahci_handle_port_intr+0x73/0xa9
ahci_single_level_irq_intr+0x40/0x60
__handle_irq_event_percpu+0x7f/0x19a
handle_irq_event_percpu+0x32/0x72
handle_irq_event+0x38/0x56
handle_edge_irq+0x102/0x121
handle_irq+0x147/0x15c
do_IRQ+0x66/0xf2
RIP: 0010:__do_softirq+0x8c/0x2df
The same for usb devices that use ehci-pci:
BUG: spinlock bad magic on CPU#0, swapper/0/1
lock: 0xffff88844f402008, .magic: 00000000, .owner: <none>/-1, .owner_cpu: 0
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.19.43 #4
Call Trace:
<IRQ>
spin_bug+0x9d/0xa3
queue_iova+0x77/0x145
intel_unmap_page+0xe/0x10
usb_hcd_unmap_urb_setup_for_dma+0x53/0x9d
usb_hcd_unmap_urb_for_dma+0x17/0x100
unmap_urb_for_dma+0x22/0x24
__usb_hcd_giveback_urb+0x51/0xc3
usb_giveback_urb_bh+0x97/0xde
tasklet_action_common.isra.4+0x5f/0xa1
tasklet_action+0x2d/0x30
__do_softirq+0x138/0x2df
irq_exit+0x7d/0x8b
smp_apic_timer_interrupt+0x10f/0x151
apic_timer_interrupt+0xf/0x20
</IRQ>
RIP: 0010:_raw_spin_unlock_irqrestore+0x17/0x39
Cc: Joerg Roedel <joro@8bytes.org>
Cc: Lu Baolu <baolu.lu@linux.intel.com>
Cc: iommu@lists.linux-foundation.org
Cc: <stable@vger.kernel.org> # 4.14+
Fixes: 13cf01744608 ("iommu/vt-d: Make use of iova deferred flushing")
Signed-off-by: Dmitry Safonov <dima@arista.com>
Reviewed-by: Lu Baolu <baolu.lu@linux.intel.com>
[v4.14-port notes:
o minor conflict with untrusted IOMMU devices check under if-condition
o setup_timer() near one chunk is timer_setup() in v5.3]
[ Upstream commit ad0834dedaa15c3a176f783c0373f836e44b4700 ]
In case we expand an existing region, we unlink
this latter and insert the larger one. In
that case we should free the original region after
the insertion. Also we can immediately return.
Fixes: 6c65fb318e8b ("iommu: iommu_get_group_resv_regions")
Signed-off-by: Eric Auger <eric.auger@redhat.com>
This is the 4.14.126 stable release
drivers/gpio/gpio-vf610.c:
Follow commit 338aa10750ba gpio: vf610: Do not share irq_chip
drivers/gpu/drm/bridge/adv7511/adv7511_drv.c:
Follow commit 67793bd3b394 drm/bridge: adv7511: Fix low refresh rate selection
Use drm_mode_vrefresh(mode) helper
drivers/net/ethernet/freescale/fec_main.c:
Keep downstream file.
drivers/net/wireless/broadcom/brcm80211/brcmfmac/cfg80211.c
Follow commit 46953f97224d brcmfmac: fix missing checks for kmemdup
sound/soc/fsl/Kconfig:
Follow commit ea751227c813 ASoC: imx: fix fiq dependencies
Logical Conflicts:
sound/soc/fsl/fsl_sai.c:
Revert upstream d7325abe29b as downstream fixed it differently
drivers/clk/imx/clk-imx6sl.c
Revert upstream bda9f846ae0 as downstream implemented it differently 68c736e9378
commit 4e4abae311e4b44aaf61f18a826fd7136037f199 upstream.
Apparently, some Qualcomm arm64 platforms which appear to expose their
SMMU global register space are still, in fact, using a hypervisor to
mediate it by trapping and emulating register accesses. Sadly, some
deployed versions of said trapping code have bugs wherein they go
horribly wrong for stores using r31 (i.e. XZR/WZR) as the source
register.
While this can be mitigated for GCC today by tweaking the constraints
for the implementation of writel_relaxed(), to avoid any potential
arms race with future compilers more aggressively optimising register
allocation, the simple way is to just remove all the problematic
constant zeros. For the write-only TLB operations, the actual value is
irrelevant anyway and any old nearby variable will provide a suitable
GPR to encode. The one point at which we really do need a zero to clear
a context bank happens before any of the TLB maintenance where crashes
have been reported, so is apparently not a problem... :/
Reported-by: AngeloGioacchino Del Regno <kholk11@gmail.com>
Tested-by: Marc Gonzalez <marc.w.gonzalez@free.fr>
Signed-off-by: Marc Gonzalez <marc.w.gonzalez@free.fr>
Acked-by: Will Deacon <will.deacon@arm.com>
Cc: stable@vger.kernel.org
[ Upstream commit cf1ec4539a50bdfe688caad4615ca47646884316 ]
The intel_iommu_gfx_mapped flag is exported by the Intel
IOMMU driver to indicate whether an IOMMU is used for the
graphic device. In a virtualized IOMMU environment (e.g.
QEMU), an include-all IOMMU is used for graphic device.
This flag is found to be clear even the IOMMU is used.
Cc: Ashok Raj <ashok.raj@intel.com>
Cc: Jacob Pan <jacob.jun.pan@linux.intel.com>
Cc: Kevin Tian <kevin.tian@intel.com>
Reported-by: Zhenyu Wang <zhenyuw@linux.intel.com>
Fixes: c0771df8d5297 ("intel-iommu: Export a flag indicating that the IOMMU is used for iGFX.")
Suggested-by: Kevin Tian <kevin.tian@intel.com>
Signed-off-by: Lu Baolu <baolu.lu@linux.intel.com>
commit 43a0541e312f7136e081e6bf58f6c8a2e9672688 upstream.
Both Tegra30 and Tegra114 have 4 ASID's and the corresponding bitfield of
the TLB_FLUSH register differs from later Tegra generations that have 128
ASID's.
In a result the PTE's are now flushed correctly from TLB and this fixes
problems with graphics (randomly failing tests) on Tegra30.
Cc: stable <stable@vger.kernel.org>
Signed-off-by: Dmitry Osipenko <digetx@gmail.com>
Acked-by: Thierry Reding <treding@nvidia.com>
[ Upstream commit 3c677d206210f53a4be972211066c0f1cd47fe12 ]
The exlcusion range limit register needs to contain the
base-address of the last page that is part of the range, as
bits 0-11 of this register are treated as 0xfff by the
hardware for comparisons.
So correctly set the exclusion range in the hardware to the
last page which is _in_ the range.
Fixes: b2026aa2dce44 ('x86, AMD IOMMU: add functions for programming IOMMU MMIO space')
[ Upstream commit 8aafaaf2212192012f5bae305bb31cdf7681d777 ]
If a device has an exclusion range specified in the IVRS
table, this region needs to be reserved in the iova-domain
of that device. This hasn't happened until now and can cause
data corruption on data transfered with these devices.
Treat exclusion ranges as reserved regions in the iommu-core
to fix the problem.
Fixes: be2a022c0dd0 ('x86, AMD IOMMU: add functions to parse IOMMU memory mapping requirements for devices')
Reviewed-by: Gary R Hook <gary.hook@amd.com>
Signed-off-by: Sasha Levin (Microsoft) <sashal@kernel.org>
[ Upstream commit cffaaf0c816238c45cd2d06913476c83eb50f682 ]
Commit 57384592c433 ("iommu/vt-d: Store bus information in RMRR PCI
device path") changed the type of the path data, however, the change in
path type was not reflected in size calculations. Update to use the
correct type and prevent a buffer overflow.
This bug manifests in systems with deep PCI hierarchies, and can lead to
an overflow of the static allocated buffer (dmar_pci_notify_info_buf),
or can lead to overflow of slab-allocated data.
BUG: KASAN: global-out-of-bounds in dmar_alloc_pci_notify_info+0x1d5/0x2e0
Write of size 1 at addr ffffffff90445d80 by task swapper/0/1
CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 4.14.87-rt49-02406-gd0a0e96 #1
Call Trace:
? dump_stack+0x46/0x59
? print_address_description+0x1df/0x290
? dmar_alloc_pci_notify_info+0x1d5/0x2e0
? kasan_report+0x256/0x340
? e820__memblock_setup+0xb0/0xb0
? dmar_dev_scope_init+0x424/0x48f
? __down_write_common+0x1ec/0x230
? dmar_dev_scope_init+0x48f/0x48f
? dmar_free_unused_resources+0x109/0x109
? cpumask_next+0x16/0x20
? __kmem_cache_create+0x392/0x430
? kmem_cache_create+0x135/0x2f0
? intel_iommu_init+0x170/0x1848
? _raw_spin_unlock_irqrestore+0x32/0x60
? migrate_enable+0x27a/0x5b0
? sched_setattr+0x20/0x20
? migrate_disable+0x1fc/0x380
? task_rq_lock+0x170/0x170
? try_to_run_init_process+0x40/0x40
? locks_remove_file+0x85/0x2f0
? dev_prepare_static_identity_mapping+0x78/0x78
? rt_spin_unlock+0x39/0x50
? lockref_put_or_lock+0x2a/0x40
? dput+0x128/0x2f0
? __rcu_read_unlock+0x66/0x80
? __fput+0x250/0x300
? __rcu_read_lock+0x1b/0x30
? mntput_no_expire+0x38/0x290
? pci_iommu_init+0x25/0x63
? do_one_initcall+0x7e/0x1c0
? initcall_blacklisted+0x120/0x120
? kernel_init_freeable+0x27b/0x307
? rest_init+0xd0/0xd0
? kernel_init+0xf/0x120
? ret_from_fork+0x1f/0x40
The buggy address belongs to the variable:
dmar_pci_notify_info_buf+0x40/0x60
Fixes: 57384592c433 ("iommu/vt-d: Store bus information in RMRR PCI device path")
Signed-off-by: Julia Cartwright <julia@ni.com>
[ Upstream commit 5bb71fc790a88d063507dc5d445ab8b14e845591 ]
The spec states in 10.4.16 that the Protected Memory Enable
Register should be treated as read-only for implementations
not supporting protected memory regions (PLMR and PHMR fields
reported as Clear in the Capability register).
Cc: mark gross <mgross@intel.com>
Suggested-by: Ashok Raj <ashok.raj@intel.com>
Fixes: f8bab73515ca5 ("intel-iommu: PMEN support")
[ Upstream commit 032ebd8548c9d05e8d2bdc7a7ec2fe29454b0ad0 ]
L1 tables are allocated with __get_dma_pages, and therefore already
ignored by kmemleak.
Without this, the kernel would print this error message on boot,
when the first L1 table is allocated:
[ 2.810533] kmemleak: Trying to color unknown object at 0xffffffd652388000 as Black
[ 2.818190] CPU: 5 PID: 39 Comm: kworker/5:0 Tainted: G S 4.19.16 #8
[ 2.831227] Workqueue: events deferred_probe_work_func
[ 2.836353] Call trace:
[ 2.852532] paint_ptr+0xa0/0xa8
[ 2.855750] kmemleak_ignore+0x38/0x6c
[ 2.859490] __arm_v7s_alloc_table+0x168/0x1f4
[ 2.863922] arm_v7s_alloc_pgtable+0x114/0x17c
[ 2.868354] alloc_io_pgtable_ops+0x3c/0x78
Fixes: e5fc9753b1a8314 ("iommu/io-pgtable: Add ARMv7 short descriptor support")
Signed-off-by: Nicolas Boichat <drinkcat@chromium.org>
commit 4e50ce03976fbc8ae995a000c4b10c737467beaa upstream.
Take into account that sg->offset can be bigger than PAGE_SIZE when
setting segment sg->dma_address. Otherwise sg->dma_address will point
at diffrent page, what makes DMA not possible with erros like this:
xhci_hcd 0000:38:00.3: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0000 address=0x00000000fdaa70c0 flags=0x0020]
xhci_hcd 0000:38:00.3: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0000 address=0x00000000fdaa7040 flags=0x0020]
xhci_hcd 0000:38:00.3: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0000 address=0x00000000fdaa7080 flags=0x0020]
xhci_hcd 0000:38:00.3: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0000 address=0x00000000fdaa7100 flags=0x0020]
xhci_hcd 0000:38:00.3: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0000 address=0x00000000fdaa7000 flags=0x0020]
Additinally with wrong sg->dma_address unmap_sg will free wrong pages,
what what can cause crashes like this:
Feb 28 19:27:45 kernel: BUG: Bad page state in process cinnamon pfn:39e8b1
Feb 28 19:27:45 kernel: Disabling lock debugging due to kernel taint
Feb 28 19:27:45 kernel: flags: 0x2ffff0000000000()
Feb 28 19:27:45 kernel: raw: 02ffff0000000000 0000000000000000 ffffffff00000301 0000000000000000
Feb 28 19:27:45 kernel: raw: 0000000000000000 0000000000000000 00000001ffffffff 0000000000000000
Feb 28 19:27:45 kernel: page dumped because: nonzero _refcount
Feb 28 19:27:45 kernel: Modules linked in: ccm fuse arc4 nct6775 hwmon_vid amdgpu nls_iso8859_1 nls_cp437 edac_mce_amd vfat fat kvm_amd ccp rng_core kvm mt76x0u mt76x0_common mt76x02_usb irqbypass mt76_usb mt76x02_lib mt76 crct10dif_pclmul crc32_pclmul chash mac80211 amd_iommu_v2 ghash_clmulni_intel gpu_sched i2c_algo_bit ttm wmi_bmof snd_hda_codec_realtek snd_hda_codec_generic drm_kms_helper snd_hda_codec_hdmi snd_hda_intel drm snd_hda_codec aesni_intel snd_hda_core snd_hwdep aes_x86_64 crypto_simd snd_pcm cfg80211 cryptd mousedev snd_timer glue_helper pcspkr r8169 input_leds realtek agpgart libphy rfkill snd syscopyarea sysfillrect sysimgblt fb_sys_fops soundcore sp5100_tco k10temp i2c_piix4 wmi evdev gpio_amdpt pinctrl_amd mac_hid pcc_cpufreq acpi_cpufreq sg ip_tables x_tables ext4(E) crc32c_generic(E) crc16(E) mbcache(E) jbd2(E) fscrypto(E) sd_mod(E) hid_generic(E) usbhid(E) hid(E) dm_mod(E) serio_raw(E) atkbd(E) libps2(E) crc32c_intel(E) ahci(E) libahci(E) libata(E) xhci_pci(E) xhci_hcd(E)
Feb 28 19:27:45 kernel: scsi_mod(E) i8042(E) serio(E) bcache(E) crc64(E)
Feb 28 19:27:45 kernel: CPU: 2 PID: 896 Comm: cinnamon Tainted: G B W E 4.20.12-arch1-1-custom #1
Feb 28 19:27:45 kernel: Hardware name: To Be Filled By O.E.M. To Be Filled By O.E.M./B450M Pro4, BIOS P1.20 06/26/2018
Feb 28 19:27:45 kernel: Call Trace:
Feb 28 19:27:45 kernel: dump_stack+0x5c/0x80
Feb 28 19:27:45 kernel: bad_page.cold.29+0x7f/0xb2
Feb 28 19:27:45 kernel: __free_pages_ok+0x2c0/0x2d0
Feb 28 19:27:45 kernel: skb_release_data+0x96/0x180
Feb 28 19:27:45 kernel: __kfree_skb+0xe/0x20
Feb 28 19:27:45 kernel: tcp_recvmsg+0x894/0xc60
Feb 28 19:27:45 kernel: ? reuse_swap_page+0x120/0x340
Feb 28 19:27:45 kernel: ? ptep_set_access_flags+0x23/0x30
Feb 28 19:27:45 kernel: inet_recvmsg+0x5b/0x100
Feb 28 19:27:45 kernel: __sys_recvfrom+0xc3/0x180
Feb 28 19:27:45 kernel: ? handle_mm_fault+0x10a/0x250
Feb 28 19:27:45 kernel: ? syscall_trace_enter+0x1d3/0x2d0
Feb 28 19:27:45 kernel: ? __audit_syscall_exit+0x22a/0x290
Feb 28 19:27:45 kernel: __x64_sys_recvfrom+0x24/0x30
Feb 28 19:27:45 kernel: do_syscall_64+0x5b/0x170
Feb 28 19:27:45 kernel: entry_SYSCALL_64_after_hwframe+0x44/0xa9
Reported-and-tested-by: Jan Viktorin <jan.viktorin@gmail.com>
Reviewed-by: Alexander Duyck <alexander.h.duyck@linux.intel.com>
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
Fixes: 80187fd39dcb ('iommu/amd: Optimize map_sg and unmap_sg')
[ Upstream commit 9825bd94e3a2baae1f4874767ae3a7d4c049720e ]
When a VM is terminated, the VFIO driver detaches all pass-through
devices from VFIO domain by clearing domain id and page table root
pointer from each device table entry (DTE), and then invalidates
the DTE. Then, the VFIO driver unmap pages and invalidate IOMMU pages.
Currently, the IOMMU driver keeps track of which IOMMU and how many
devices are attached to the domain. When invalidate IOMMU pages,
the driver checks if the IOMMU is still attached to the domain before
issuing the invalidate page command.
However, since VFIO has already detached all devices from the domain,
the subsequent INVALIDATE_IOMMU_PAGES commands are being skipped as
there is no IOMMU attached to the domain. This results in data
corruption and could cause the PCI device to end up in indeterministic
state.
Fix this by invalidate IOMMU pages when detach a device, and
before decrementing the per-domain device reference counts.
Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Suggested-by: Joerg Roedel <joro@8bytes.org>
Co-developed-by: Brijesh Singh <brijesh.singh@amd.com>
Signed-off-by: Brijesh Singh <brijesh.singh@amd.com>
Signed-off-by: Suravee Suthikulpanit <suravee.suthikulpanit@amd.com>
Fixes: 6de8ad9b9ee0 ('x86/amd-iommu: Make iommu_flush_pages aware of multiple IOMMUs')
[ Upstream commit f1724c0883bb0ce93b8dcb94b53dcca3b75ac9a7 ]
In the error path of map_sg there is an incorrect if condition
for breaking out of the loop that searches the scatterlist
for mapped pages to unmap. Instead of breaking out of the
loop once all the pages that were mapped have been unmapped,
it will break out of the loop after it has unmapped 1 page.
Fix the condition, so it breaks out of the loop only after
all the mapped pages have been unmapped.
Fixes: 80187fd39dcb ("iommu/amd: Optimize map_sg and unmap_sg")
Signed-off-by: Jerry Snitselaar <jsnitsel@redhat.com>
[ Upstream commit 51d8838d66d3249508940d8f59b07701f2129723 ]
In the error path of map_sg, free_iova_fast is being called with
address instead of the pfn. This results in a bad value getting into
the rcache, and can result in hitting a BUG_ON when
iova_magazine_free_pfns is called.
Cc: Suravee Suthikulpanit <suravee.suthikulpanit@amd.com>
[ Upstream commit a868e8530441286342f90c1fd9c5f24de3aa2880 ]
After removing an entry from a queue (e.g. reading an event in
arm_smmu_evtq_thread()) it is necessary to advance the MMIO consumer
pointer to free the queue slot back to the SMMU. A memory barrier is
required here so that all reads targetting the queue entry have
completed before the consumer pointer is updated.
The implementation of queue_inc_cons() relies on a writel() to complete
the previous reads, but this is incorrect because writel() is only
guaranteed to complete prior writes. This patch replaces the call to
writel() with an mb(); writel_relaxed() sequence, which gives us the
read->write ordering which we require.
Cc: Robin Murphy <robin.murphy@arm.com>
[ Upstream commit 89cddc563743cb1e0068867ac97013b2a5bf86aa ]
qcom,smmu-v2 is an arm,smmu-v2 implementation with specific
clock and power requirements.
On msm8996, multiple cores, viz. mdss, video, etc. use this
smmu. On sdm845, this smmu is used with gpu.
Add bindings for the same.
Signed-off-by: Vivek Gautam <vivek.gautam@codeaurora.org>
Reviewed-by: Rob Herring <robh@kernel.org>
Reviewed-by: Tomasz Figa <tfiga@chromium.org>
Tested-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org>
Reviewed-by: Robin Murphy <robin.murphy@arm.com>
[ Upstream commit c12b08ebbe16f0d3a96a116d86709b04c1ee8e74 ]
The parameter is still there but it's ignored. We need to check its
value before deciding to go into passthrough mode for AMD IOMMU v2
capable device.
We occasionally use this parameter to force v2 capable device into
translation mode to debug memory corruption that we suspect is
caused by DMA writes.
To address the following comment from Joerg Roedel on the first
version, v2 capability of device is completely ignored.
> This breaks the iommu_v2 use-case, as it needs a direct mapping for the
> devices that support it.
And from Documentation/admin-guide/kernel-parameters.txt:
This option does not override iommu=pt
Fixes: aafd8ba0ca74 ("iommu/amd: Implement add_device and remove_device")
Signed-off-by: Yu Zhao <yuzhao@google.com>
Normally the iommu pagetable could be in 64bit address space,
but we have one patch to address PCIE driver, 'commit 9e03e5076269
("MLK-15064-2 ARM64: DMA: limit the dma mask to be 32bit")'
The patch restrict swiotlb and iommu dma to be in 32bit address.
So if we allocate pages in highmem, then dma_map_single will return
a 32bit address. Then, we will get "Cannot accommodate DMA
translation for IOMMU page tables", because `dma != virt_to_phys(pages)`.
So we strict the lpae iommu pgtable in DMA area to fix this issue.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
commit 198bc3252ea3a45b0c5d500e6a5b91cfdd08f001 upstream.
Commit 9d3a4de4cb8d ("iommu: Disambiguate MSI region types") changed
the reserved region type in intel_iommu_get_resv_regions() from
IOMMU_RESV_RESERVED to IOMMU_RESV_MSI, but it forgot to also change
the type in intel_iommu_put_resv_regions().
This leads to a memory leak, because now the check in
intel_iommu_put_resv_regions() for IOMMU_RESV_RESERVED will never
be true, and no allocated regions will be freed.
Fix this by changing the region type in intel_iommu_put_resv_regions()
to IOMMU_RESV_MSI, matching the type of the allocated regions.
Fixes: 9d3a4de4cb8d ("iommu: Disambiguate MSI region types")
Cc: <stable@vger.kernel.org> # v4.11+
Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com>
Reviewed-by: Eric Auger <eric.auger@redhat.com>
commit 3569dd07aaad71920c5ea4da2d5cc9a167c1ffd4 upstream.
The Intel IOMMU driver opportunistically skips a few top level page
tables from the domain paging directory while programming the IOMMU
context entry. However there is an implicit assumption in the code that
domain's adjusted guest address width (agaw) would always be greater
than IOMMU's agaw.
The IOMMU capabilities in an upcoming platform cause the domain's agaw
to be lower than IOMMU's agaw. The issue is seen when the IOMMU supports
both 4-level and 5-level paging. The domain builds a 4-level page table
based on agaw of 2. However the IOMMU's agaw is set as 3 (5-level). In
this case the code incorrectly tries to skip page page table levels.
This causes the IOMMU driver to avoid programming the context entry. The
fix handles this case and programs the context entry accordingly.
Fixes: de24e55395698 ("iommu/vt-d: Simplify domain_context_mapping_one")
Reported-by: Ramos Falcon, Ernesto R <ernesto.r.ramos.falcon@intel.com>
Tested-by: Ricardo Neri <ricardo.neri-calderon@linux.intel.com>
Signed-off-by: Sohil Mehta <sohil.mehta@intel.com>
[ Upstream commit 829383e183728dec7ed9150b949cd6de64127809 ]
memunmap() should be used to free the return of memremap(), not
iounmap().
Fixes: dfddb969edf0 ('iommu/vt-d: Switch from ioremap_cache to memremap')
Signed-off-by: Pan Bian <bianpan2016@163.com>
[ Upstream commit ab99be4683d9db33b100497d463274ebd23bd67e ]
This register should have been programmed with the physical address
of the memory location containing the shadow tail pointer for
the guest virtual APIC log instead of the base address.
Fixes: 8bda0cfbdc1a ('iommu/amd: Detect and initialize guest vAPIC log')
Signed-off-by: Filippo Sironi <sironi@amazon.de>
Signed-off-by: Wei Wang <wawei@amazon.de>
[ Upstream commit e5b78f2e349eef5d4fca5dc1cf5a3b4b2cc27abd ]
If iommu_ops.add_device() fails, iommu_ops.domain_free() is still
called, leading to a crash, as the domain was only partially
initialized:
ipmmu-vmsa e67b0000.mmu: Cannot accommodate DMA translation for IOMMU page tables
sata_rcar ee300000.sata: Unable to initialize IPMMU context
iommu: Failed to add device ee300000.sata to group 0: -22
Unable to handle kernel NULL pointer dereference at virtual address 0000000000000038
Call trace:
ipmmu_domain_free+0x1c/0xa0
iommu_group_release+0x48/0x68
kobject_put+0x74/0xe8
kobject_del.part.0+0x3c/0x50
kobject_put+0x60/0xe8
iommu_group_get_for_dev+0xa8/0x1f0
ipmmu_add_device+0x1c/0x40
of_iommu_configure+0x118/0x190
Fix this by checking if the domain's context already exists, before
trying to destroy it.
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Fixes: d25a2a16f0889 ('iommu: Add driver for Renesas VMSA-compatible IPMMU')
[ Upstream commit 19ed3e2dd8549c1a34914e8dad01b64e7837645a ]
When handling page request without pasid event, go to "no_pasid"
branch instead of "bad_req". Otherwise, a NULL pointer deference
will happen there.
Cc: Sohil Mehta <sohil.mehta@intel.com>
Fixes: a222a7f0bb6c9 'iommu/vt-d: Implement page request handling'
commit 7d321bd3542500caf125249f44dc37cb4e738013 upstream.
The IO-pgtable code relies on the driver TLB invalidation callbacks to
ensure that all page-table updates are visible to the IOMMU page-table
walker.
In the case that the page-table walker is cache-coherent, we cannot rely
on an implicit DSB from the DMA-mapping code, so we must ensure that we
execute a DSB in our tlb_add_flush() callback prior to triggering the
invalidation.
Fixes: 2df7a25ce4a7 ("iommu/arm-smmu: Clean up DMA API usage")
[ Upstream commit 5ebb1bc2d63d90dd204169e21fd7a0b4bb8c776e ]
ACPI HID devices do not actually have an alias for
them in the IVRS. But dev_data->alias is still used
for indexing into the IOMMU device table for devices
being handled by the IOMMU. So for ACPI HID devices,
we simply return the corresponding devid as an alias,
as parsed from IVRS table.
Signed-off-by: Arindam Nath <arindam.nath@amd.com>
Fixes: 2bf9a0a12749 ('iommu/amd: Add iommu support for ACPI HID devices')
commit b3e9b515b08e407ab3a026dc2e4d935c48d05f69 upstream.
Boris Ostrovsky reported a memory leak with device passthrough when SME
is active.
The VFIO driver uses iommu_iova_to_phys() to get the physical address for
an iova. This physical address is later passed into vfio_unmap_unpin() to
unpin the memory. The vfio_unmap_unpin() uses pfn_valid() before unpinning
the memory. The pfn_valid() check was failing because encryption mask was
part of the physical address returned. This resulted in the memory not
being unpinned and therefore leaked after the guest terminates.
The memory encryption mask must be cleared from the physical address in
iommu_iova_to_phys().
Fixes: 2543a786aa25 ("iommu/amd: Allow the AMD IOMMU to work with memory encryption")
Reported-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: Tom Lendacky <thomas.lendacky@amd.com>
Cc: <iommu@lists.linux-foundation.org>
Cc: Borislav Petkov <bp@suse.de>
Cc: Radim Krčmář <rkrcmar@redhat.com>
Cc: kvm@vger.kernel.org
[ Upstream commit 379521462e4add27f3514da8e4ab1fd7a54fe1c7 ]
Fixes the following splat during boot:
BUG: sleeping function called from invalid context at kernel/locking/mutex.c:747
in_atomic(): 1, irqs_disabled(): 128, pid: 77, name: kworker/2:1
4 locks held by kworker/2:1/77:
#0: (ptrval) ((wq_completion)"events"){+.+.}, at: process_one_work+0x1fc/0x8fc
#1: (ptrval) (deferred_probe_work){+.+.}, at: process_one_work+0x1fc/0x8fc
#2: (ptrval) (&dev->mutex){....}, at: __device_attach+0x40/0x178
#3: (ptrval) (msm_iommu_lock){....}, at: msm_iommu_add_device+0x28/0xcc
irq event stamp: 348
hardirqs last enabled at (347): [<c049dc18>] kfree+0xe0/0x3c0
hardirqs last disabled at (348): [<c0c35cac>] _raw_spin_lock_irqsave+0x2c/0x68
softirqs last enabled at (0): [<c0322fd8>] copy_process.part.5+0x280/0x1a68
softirqs last disabled at (0): [<00000000>] (null)
Preemption disabled at:
[<00000000>] (null)
CPU: 2 PID: 77 Comm: kworker/2:1 Not tainted 4.17.0-rc5-wt-ath-01075-gaca0516bb4cf #239
Hardware name: Generic DT based system
[<c0314e00>] (unwind_backtrace) from [<c030fc70>] (show_stack+0x20/0x24)
[<c030fc70>] (show_stack) from [<c0c16ad8>] (dump_stack+0xa0/0xcc)
[<c0c16ad8>] (dump_stack) from [<c035a978>] (___might_sleep+0x1f8/0x2d4)
ath10k_sdio mmc2:0001:1: Direct firmware load for ath10k/QCA9377/hw1.0/board-2.bin failed with error -2
[<c035a978>] (___might_sleep) from [<c035aac4>] (__might_sleep+0x70/0xa8)
[<c035aac4>] (__might_sleep) from [<c0c3066c>] (__mutex_lock+0x50/0xb28)
[<c0c3066c>] (__mutex_lock) from [<c0c31170>] (mutex_lock_nested+0x2c/0x34)
ath10k_sdio mmc2:0001:1: board_file api 1 bmi_id N/A crc32 544289f7
[<c0c31170>] (mutex_lock_nested) from [<c052d798>] (kernfs_find_and_get_ns+0x30/0x5c)
[<c052d798>] (kernfs_find_and_get_ns) from [<c0531cc8>] (sysfs_add_link_to_group+0x28/0x58)
[<c0531cc8>] (sysfs_add_link_to_group) from [<c07ef75c>] (iommu_device_link+0x50/0xb4)
[<c07ef75c>] (iommu_device_link) from [<c07f2288>] (msm_iommu_add_device+0xa0/0xcc)
[<c07f2288>] (msm_iommu_add_device) from [<c07ec6d0>] (add_iommu_group+0x3c/0x64)
[<c07ec6d0>] (add_iommu_group) from [<c07f9d40>] (bus_for_each_dev+0x84/0xc4)
[<c07f9d40>] (bus_for_each_dev) from [<c07ec7c8>] (bus_set_iommu+0xd0/0x10c)
[<c07ec7c8>] (bus_set_iommu) from [<c07f1a68>] (msm_iommu_probe+0x5b8/0x66c)
[<c07f1a68>] (msm_iommu_probe) from [<c07feaa8>] (platform_drv_probe+0x60/0xbc)
[<c07feaa8>] (platform_drv_probe) from [<c07fc1fc>] (driver_probe_device+0x30c/0x4cc)
[<c07fc1fc>] (driver_probe_device) from [<c07fc59c>] (__device_attach_driver+0xac/0x14c)
[<c07fc59c>] (__device_attach_driver) from [<c07f9e14>] (bus_for_each_drv+0x68/0xc8)
[<c07f9e14>] (bus_for_each_drv) from [<c07fbd3c>] (__device_attach+0xe4/0x178)
[<c07fbd3c>] (__device_attach) from [<c07fc698>] (device_initial_probe+0x1c/0x20)
[<c07fc698>] (device_initial_probe) from [<c07faee8>] (bus_probe_device+0x98/0xa0)
[<c07faee8>] (bus_probe_device) from [<c07fb4f4>] (deferred_probe_work_func+0x74/0x198)
[<c07fb4f4>] (deferred_probe_work_func) from [<c0348eb4>] (process_one_work+0x2c4/0x8fc)
[<c0348eb4>] (process_one_work) from [<c03497b0>] (worker_thread+0x2c4/0x5cc)
[<c03497b0>] (worker_thread) from [<c0350d10>] (kthread+0x180/0x188)
[<c0350d10>] (kthread) from [<c03010b4>] (ret_from_fork+0x14/0x20)
Fixes: 42df43b36163 ("iommu/msm: Make use of iommu_device_register interface")
Signed-off-by: Niklas Cassel <niklas.cassel@linaro.org>
Reviewed-by: Vivek Gautam <vivek.gautam@codeaurora.org>
[ Upstream commit 3c120143f584360a13614787e23ae2cdcb5e5ccd ]
Although the mapping has already been removed in the page table, it maybe
still exist in TLB. Suppose the freed IOVAs is reused by others before the
flush operation completed, the new user can not correctly access to its
meomory.
Signed-off-by: Zhen Lei <thunder.leizhen@huawei.com>
Fixes: b1516a14657a ('iommu/amd: Implement flush queue')
[ Upstream commit 29859aeb8a6ea17ba207933a81b6b77b4d4df81a ]
When run on a 64-bit system in selftest, the v7s driver may obtain page
table with physical addresses larger than 32-bit. Level-2 tables are 1KB
and are are allocated with slab, which doesn't accept the GFP_DMA32
flag. Currently map() truncates the address written in the PTE, causing
iova_to_phys() or unmap() to access invalid memory. Kasan reports it as
a use-after-free. To avoid any nasty surprise, test if the physical
address fits in a PTE before returning a new table. 32-bit systems,
which are the main users of this page table format, shouldn't see any
difference.
Signed-off-by: Jean-Philippe Brucker <jean-philippe.brucker@arm.com>
[ Upstream commit 0d535967ac658966c6ade8f82b5799092f7d5441 ]
When PRI queue occurs overflow, driver should update the OVACKFLG to
the PRIQ consumer register, otherwise subsequent PRI requests will not
be processed.
Signed-off-by: Miao Zhong <zhongmiao@hisilicon.com>
[ Upstream commit 46583e8c48c5a094ba28060615b3a7c8c576690f ]
When attaching a device to an IOMMU group with
CONFIG_DEBUG_ATOMIC_SLEEP=y:
BUG: sleeping function called from invalid context at mm/slab.h:421
in_atomic(): 1, irqs_disabled(): 128, pid: 61, name: kworker/1:1
Call trace:
arm_lpae_alloc_pgtable+0x114/0x184
arm_64_lpae_alloc_pgtable_s1+0x2c/0x128
arm_32_lpae_alloc_pgtable_s1+0x40/0x6c
alloc_io_pgtable_ops+0x60/0x88
ipmmu_attach_device+0x140/0x334
ipmmu_attach_device() takes a spinlock, while arm_lpae_alloc_pgtable()
allocates memory using GFP_KERNEL. Originally, the ipmmu-vmsa driver
had its own custom page table allocation implementation using
GFP_ATOMIC, hence the spinlock was fine.
Fix this by replacing the spinlock by a mutex, like the arm-smmu driver
does.
Fixes: f20ed39f53145e45 ("iommu/ipmmu-vmsa: Use the ARM LPAE page table allocator")
Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
[ Upstream commit 04c532a1cdc7e423656c07937aa4b5c1c2b064f9 ]
The base address used for DMA operations on the second-level table
did incorrectly include the offset for the table entry. The offset
was then added again which lead to incorrect behavior.
Operations on the L1 table are not affected.
The calculation of the base address is changed to point to the
beginning of the L2 table.
Fixes: bfee0cf0ee1d ("iommu/omap: Use DMA-API for performing cache flushes")
Acked-by: Suman Anna <s-anna@ti.com>
Signed-off-by: Ralf Goebel <ralf.goebel@imago-technologies.com>
commit 1c48db44924298ad0cb5a6386b88017539be8822 upstream.
PFSID should be used in the invalidation descriptor for flushing
device IOTLBs on SRIOV VFs.
Signed-off-by: Jacob Pan <jacob.jun.pan@linux.intel.com>
Cc: "Ashok Raj" <ashok.raj@intel.com>
Cc: "Lu Baolu" <baolu.lu@linux.intel.com>
commit 0f725561e168485eff7277d683405c05b192f537 upstream.
When SRIOV VF device IOTLB is invalidated, we need to provide
the PF source ID such that IOMMU hardware can gauge the depth
of invalidation queue which is shared among VFs. This is needed
when device invalidation throttle (DIT) capability is supported.
This patch adds bit definitions for checking and tracking PFSID.
commit d1e20222d5372e951bbb2fd3f6489ec4a6ea9b11 upstream.
Currently we check if the number of context banks is not equal to
num_context_interrupts. However, there are booloaders such as, one
on sdm845 that reserves few context banks and thus kernel views
less than the total available context banks.
So, although the hardware definition in device tree would mention
the correct number of context interrupts, this number can be
greater than the number of context banks visible to smmu in kernel.
We should therefore error out only when the number of context banks
is greater than the available number of context interrupts.
Suggested-by: Tomasz Figa <tfiga@chromium.org>
[will: drop useless printk]
Cc: Jitendra Bhivare <jitendra.bhivare@broadcom.com>
[ Upstream commit 0dfc0c792d691f8056f38b5c30789f504be0e467 ]
It allows to flush more than 4GB of device TLBs. So the mask should be
64bit wide. UBSAN captured this fault as below.
[ 3.760024] ================================================================================
[ 3.768440] UBSAN: Undefined behaviour in drivers/iommu/dmar.c:1348:3
[ 3.774864] shift exponent 64 is too large for 32-bit type 'int'
[ 3.780853] CPU: 2 PID: 0 Comm: swapper/2 Tainted: G U 4.17.0-rc1+ #89
[ 3.788661] Hardware name: Dell Inc. OptiPlex 7040/0Y7WYT, BIOS 1.2.8 01/26/2016
[ 3.796034] Call Trace:
[ 3.798472] <IRQ>
[ 3.800479] dump_stack+0x90/0xfb
[ 3.803787] ubsan_epilogue+0x9/0x40
[ 3.807353] __ubsan_handle_shift_out_of_bounds+0x10e/0x170
[ 3.812916] ? qi_flush_dev_iotlb+0x124/0x180
[ 3.817261] qi_flush_dev_iotlb+0x124/0x180
[ 3.821437] iommu_flush_dev_iotlb+0x94/0xf0
[ 3.825698] iommu_flush_iova+0x10b/0x1c0
[ 3.829699] ? fq_ring_free+0x1d0/0x1d0
[ 3.833527] iova_domain_flush+0x25/0x40
[ 3.837448] fq_flush_timeout+0x55/0x160
[ 3.841368] ? fq_ring_free+0x1d0/0x1d0
[ 3.845200] ? fq_ring_free+0x1d0/0x1d0
[ 3.849034] call_timer_fn+0xbe/0x310
[ 3.852696] ? fq_ring_free+0x1d0/0x1d0
[ 3.856530] run_timer_softirq+0x223/0x6e0
[ 3.860625] ? sched_clock+0x5/0x10
[ 3.864108] ? sched_clock+0x5/0x10
[ 3.867594] __do_softirq+0x1b5/0x6f5
[ 3.871250] irq_exit+0xd4/0x130
[ 3.874470] smp_apic_timer_interrupt+0xb8/0x2f0
[ 3.879075] apic_timer_interrupt+0xf/0x20
[ 3.883159] </IRQ>
[ 3.885255] RIP: 0010:poll_idle+0x60/0xe7
[ 3.889252] RSP: 0018:ffffb1b201943e30 EFLAGS: 00000246 ORIG_RAX: ffffffffffffff13
[ 3.896802] RAX: 0000000080200000 RBX: 000000000000008e RCX: 000000000000001f
[ 3.903918] RDX: 0000000000000000 RSI: 000000002819aa06 RDI: 0000000000000000
[ 3.911031] RBP: ffff9e93c6b33280 R08: 00000010f717d567 R09: 000000000010d205
[ 3.918146] R10: ffffb1b201943df8 R11: 0000000000000001 R12: 00000000e01b169d
[ 3.925260] R13: 0000000000000000 R14: ffffffffb12aa400 R15: 0000000000000000
[ 3.932382] cpuidle_enter_state+0xb4/0x470
[ 3.936558] do_idle+0x222/0x310
[ 3.939779] cpu_startup_entry+0x78/0x90
[ 3.943693] start_secondary+0x205/0x2e0
[ 3.947607] secondary_startup_64+0xa5/0xb0
[ 3.951783] ================================================================================
Signed-off-by: Changbin Du <changbin.du@intel.com>
[ Upstream commit 70ca608b2ec6dafa6bb1c2b0691852fc78f8f717 ]
In MediaTek's IOMMU design, When a iommu translation fault occurs
(HW can NOT translate the destination address to a valid physical
address), the IOMMU HW output the dirty data into a special memory
to avoid corrupting the main memory, this is called "protect memory".
the register(0x114) for protect memory is a little different between
mt8173 and mt2712.
In the mt8173, bit[30:6] in the register represents [31:7] of the
physical address. In the 4GB mode, the register bit[31] should be 1.
While in the mt2712, the bits don't shift. bit[31:7] in the register
represents [31:7] in the physical address, and bit[1:0] in the
register represents bit[33:32] of the physical address if it has.
Fixes: e6dec9230862 ("iommu/mediatek: Add mt2712 IOMMU support")
Reported-by: Honghui Zhang <honghui.zhang@mediatek.com>
Signed-off-by: Yong Wu <yong.wu@mediatek.com>
[ Upstream commit 39ffe39545cd5cb5b8cee9f0469165cf24dc62c2 ]
find_dev_data() does not check whether the return value alloc_dev_data()
is NULL. This was okay once because the pointer was returned once as-is.
Since commit df3f7a6e8e85 ("iommu/amd: Use is_attach_deferred
call-back") the pointer may be used within find_dev_data() so a NULL
check is required.
Cc: Baoquan He <bhe@redhat.com>
Fixes: df3f7a6e8e85 ("iommu/amd: Use is_attach_deferred call-back")
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
