This must have been messed up while merging, the intention was
clearly to unlock there.
Change-Id: Icf525a51d4899dc718710ec56a4d3fd2150501cd
Signed-off-by: Lucas Stach <dev@lynxeye.de>
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
Signed-off-by: Hiroshi DOYU <hdoyu@nvidia.com>
Reviewed-on: http://git-master/r/96139
Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
Print an attached device name correctly.
Change-Id: I8352bd81916936aa2276a51c0161f0c2be709760
Reviewed-on: http://git-master/r/96138
Pass the correct gart device pointer.
Change-Id: Ia54c3df7ce013855bf8843161f5ee0816482bda6
Reviewed-on: http://git-master/r/90064
Reviewed-by: Vandana Salve <vsalve@nvidia.com>
Tested-by: Vandana Salve <vsalve@nvidia.com>
Reviewed-by: Hiroshi Doyu <hdoyu@nvidia.com>
The mainline IOMMU API v3.3-rc1 has been changed so that bytes are
used in mapping size instead of page order and page-by-page iteration
is taken care of by iommu core.
The rest are mostly for maintainability:
$ git co iommu/next drivers/iommu/tegra-gart.c
Change-Id: Id88ae8d23d11f4e003d11ec1e4223a72215ad142
Reviewed-on: http://git-master/r/78138
$ git co iommu/next drivers/iommu/tegra-smmu.c
Change-Id: Ib4fdee4a637b3065a1eab6c56923b05f46b3b582
Reviewed-on: http://git-master/r/78137
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
android-tegra-nv-3.1
Change-Id: I9001bb291779f107bbcb593d48f9f0f734074d0e
CONFIG_TEGRA_IOMMU_GART has to be selected explicitly because there's
2 IOMMU framewrok existing in Tegra, CONFIG_TEGRA_IOVMM_{GART,SMMU}
and CONFIG_TEGRA_IOMMU_{GART,SMMU}.
Change-Id: I6f1a0ad8e321c5ad5378baa6bc4a9bcecad9d4d2
Reviewed-on: http://git-master/r/77513
Tegra 20 IOMMU H/W, GART (Graphics Address Relocation Table). This
patch implements struct iommu_ops for GART for the upper IOMMU API.
This H/W module supports only single virtual address space(domain),
and manages a single level 1-to-1 mapping H/W translation page table.
Change-Id: I2f550bf0e14d9f994abdde79b835ddfe815faa5a
Reviewed-on: http://git-master/r/75945
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
To protect the command buffer from hanging when a device
does not respond to an IOTLB invalidation, set a timeout of
1s for outstanding IOTLB invalidations.
The IOMMUv2 driver added a few statistic counter which are
interesting in the iommu=pt mode too. So initialize the
statistic counter for that mode too.
The caches are already flushed in enable_iommus(), so this
flush is not necessary.
In i915 driver, we do not enable either rc6 or semaphores on SNB when dmar
is enabled. The new 'intel_iommu_enabled' variable signals when the
iommu code is in operation.
Cc: Ted Phelps <phelps@gnusto.com>
Cc: Peter <pab1612@gmail.com>
Cc: Lukas Hejtmanek <xhejtman@fi.muni.cz>
Cc: Andrew Lutomirski <luto@mit.edu>
CC: Daniel Vetter <daniel.vetter@ffwll.ch>
Cc: Eugeni Dodonov <eugeni.dodonov@intel.com>
Signed-off-by: Keith Packard <keithp@keithp.com>
Since it is not guaranteed that an iommu driver initializes in its
domain_init() function, it must be initialized with NULL to prevent
calling a function in an arbitrary location when iommu fault occurred.
Signed-off-by: KyongHo Cho <pullip.cho@samsung.com>
This call-back is invoked when the task that is bound to a
pasid is about to exit. The driver can use it to shutdown
all context related to that context in a safe way.
This function can be used to find out which features
necessary for IOMMUv2 usage are available on a given device.
The symbolic register names for PCI and PASID changed in
PCI code. This patch adapts the AMD IOMMU driver to these
changes.
This callback can be used to change the PRI response code
sent to a device when a PPR fault fails.
Since pages are not pinned anymore we need notifications
when the VMM changes the page-tables. Use mmu_notifiers for
that.
Also use the task_exit notifier from the profiling subsystem
to shutdown all contexts related to this task.
Register the notifier for PPR faults and handle them as
necessary.
This patch adds routines to bind a specific process
address-space to a given PASID.
This patch adds the amd_iommu_init_device() and
amd_iommu_free_device() functions which make a device and
the IOMMU ready for IOMMUv2 usage.
Add a Kconfig option for the optional driver. Since it is
optional it can be compiled as a module and will only be
loaded when required by another driver.
Add some interesting statistic counters for events when
IOMMUv2 is active.
Add infrastructure for errata-handling and handle two known
erratas in the IOMMUv2 code.
The AMD IOMMUv2 driver needs to get the IOMMUv2 domain
associated with a particular device. This patch adds a
function to get this information.
To send completions for PPR requests this patch adds a
function which can be used by the IOMMUv2 driver.
This patch adds functions necessary to set and clear the
GCR3 values associated with a particular PASID in an IOMMUv2
domain.
The functions added with this patch allow to manage the
IOMMU and the device TLBs for all devices in an IOMMUv2
domain.
This patch adds support for protection domains that
implement two-level paging for devices.
This function can be used to switch a domain into
paging-mode 0. In this mode all devices can access physical
system memory directly without any remapping.
drivers/iommu/amd_iommu.c
Change-Id: Iea5e664f34bb8fe8e2bb87bdc1cb44ca170a876f
Add a notifer at which a module can attach to get informed
about incoming PPR faults.
If the device starts to use IOMMUv2 features the dma handles
need to stay valid. The only sane way to do this is to use a
identity mapping for the device and not translate it by the
iommu. This is implemented with this patch. Since this lifts
the device-isolation there is also a new kernel parameter
which allows to disable that feature.
In mixed IOMMU setups this flag inidicates whether an IOMMU
supports the v2 features or not. This patch also adds a
global flag together with a function to query that flag from
other code. The flag shows if at least one IOMMUv2 is in the
system.
This feature needs to be enabled before IOMMUv2 DTEs can be
set up.
Allocate and enable a log buffer for peripheral page faults
when the IOMMU supports this feature.
Read the number of PASIDs supported by each IOMMU in the
system and take the smallest number as the maximum value
supported by the IOMMU driver.
Convert the contents of 'struct dev_table_entry' to u64 to
allow updating the DTE wit 64bit writes as required by the
spec.
An omap_iommu_iova_to_phys failure usually means that iova wasn't mapped.
When that happens, it's helpful to know the value of iova, so add it
to the error message.
Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com>
Fix:
Section mismatch in reference from the function
ir_dev_scope_init() to the function
.init.text:dmar_dev_scope_init() The function
ir_dev_scope_init() references the function __init dmar_dev_scope_init().
Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Cc: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: Youquan Song <youquan.song@intel.com>
Cc: Ohad Ben-Cohen <ohad@wizery.com>
Link: http://lkml.kernel.org/r/20111026161507.GB10103@swordfish
dmar_parse_rmrr_atsr_dev() calls rmrr_parse_dev() and
atsr_parse_dev() which are both marked as __init.
dmar_parse_rmrr_atsr_dev() to the function
.init.text:dmar_parse_dev_scope() The function
dmar_parse_rmrr_atsr_dev() references the function __init
dmar_parse_dev_scope().
Cc: iommu@lists.linux-foundation.org
Cc: Joerg Roedel <joerg.roedel@amd.com>
Link: http://lkml.kernel.org/r/20111026154539.GA10103@swordfish
Eliminate the public omap_find_iommu_device() method, and don't
expect clients to provide the omap_iommu handle anymore.
Instead, OMAP's iommu driver now utilizes dev_archdata's private iommu
extension to be able to access the required iommu information.
This way OMAP IOMMU users are now able to use the generic IOMMU API without
having to call any omap-specific binding method.
Update omap3isp appropriately.
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Cc: Hiroshi Doyu <hdoyu@nvidia.com>
drivers/media/video/omap3isp/ispccdc.c
Change-Id: Ia9b3421662fab7bb4bee298693ed6da716599ee5
The option iommu=group_mf indicates the that the iommu driver should
expose all functions of a multi-function PCI device as the same
iommu_device_group. This is useful for disallowing individual functions
being exposed as independent devices to userspace as there are often
hidden dependencies. Virtual functions are not affected by this option.
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
Just use the amd_iommu_alias_table directly.
Change-Id: I3aaeb78a1359e1ad8f4a37ba07fb1d404daa8d83
We generally have BDF granularity for devices, so we just need
to make sure devices aren't hidden behind PCIe-to-PCI bridges.
We can then make up a group number that's simply the concatenated
seg|bus|dev|fn so we don't have to track them (not that users
should depend on that).
Acked-By: David Woodhouse <David.Woodhouse@intel.com>
drivers/iommu/intel-iommu.c
Change-Id: Ifc8108a42383f317c2db42003eb96713a98a6899
An IOMMU group is a set of devices for which the IOMMU cannot
distinguish transactions. For PCI devices, a group often occurs
when a PCI bridge is involved. Transactions from any device
behind the bridge appear to be sourced from the bridge itself.
We leave it to the IOMMU driver to define the grouping restraints
for their platform.
Using this new interface, the group for a device can be retrieved
using the iommu_device_group() callback. Users will compare the
value returned against the value returned for other devices to
determine whether they are part of the same group. Devices with
no group are not translated by the IOMMU. There should be no
expectations about the group numbers as they may be arbitrarily
assigned by the IOMMU driver and may not be persistent across boots.
We also provide a sysfs interface to the group numbers here so
that userspace can understand IOMMU dependencies between devices
for managing safe, userspace drivers.
[Some code changes by Joerg Roedel <joerg.roedel@amd.com>]
include/linux/iommu.h
Change-Id: I524607da569e42730bdc706759c49c4e0783555c
Now that all IOMMU drivers are exporting their supported pgsizes,
we can remove the default pgsize settings in register_iommu().
Let the IOMMU core know we support arbitrary page sizes (as long as
they're an order of 4KiB).
This way the IOMMU core will retain the existing behavior we're used to;
it will let us map regions that:
- their size is an order of 4KiB
- they are naturally aligned
Note: Intel IOMMU hardware doesn't support arbitrary page sizes,
but the driver does (it splits arbitrary-sized mappings into
the pages supported by the hardware).
To make everything simpler for now, though, this patch effectively tells
the IOMMU core to keep giving this driver the same memory regions it did
before, so nothing is changed as far as it's concerned.
At this point, the page sizes announced remain static within the IOMMU
core. To correctly utilize the pgsize-splitting of the IOMMU core by
this driver, it seems that some core changes should still be done,
because Intel's IOMMU page size capabilities seem to have the potential
to be different between different DMA remapping devices.
Cc: Joerg Roedel <Joerg.Roedel@amd.com>
Let the IOMMU core know we support 4KiB, 64KiB, 1MiB and 16MiB page sizes.
This way the IOMMU core can split any arbitrary-sized physically
contiguous regions (that it needs to map) as needed.
Acked-by: David Brown <davidb@codeaurora.org>
Cc: Stepan Moskovchenko <stepanm@codeaurora.org>
Cc: Hiroshi DOYU <hdoyu@nvidia.com>
