This is the 4.19.59 stable release
commit 6d4d367d0e9ffab4d64a3436256a6a052dc1195d upstream.
The MIPS GIC contains a block of registers used to map local interrupts
to a particular CPU interrupt pin. Since these registers are found at a
consecutive range of addresses we access them using an index, via the
(read|write)_gic_v[lo]_map accessor functions. We currently use values
from enum mips_gic_local_interrupt as those indices.
Unfortunately whilst enum mips_gic_local_interrupt provides the correct
offsets for bits in the pending & mask registers, the ordering of the
map registers is subtly different... Compared with the ordering of
pending & mask bits, the map registers move the FDC from the end of the
list to index 3 after the timer interrupt. As a result the performance
counter & software interrupts are therefore at indices 4-6 rather than
indices 3-5.
Notably this causes problems with performance counter interrupts being
incorrectly mapped on some systems, and presumably will also cause
problems for FDC interrupts.
Introduce a function to map from enum mips_gic_local_interrupt to the
index of the corresponding map register, and use it to ensure we access
the map registers for the correct interrupts.
Signed-off-by: Paul Burton <paul.burton@mips.com>
Fixes: a0dc5cb5e31b ("irqchip: mips-gic: Simplify gic_local_irq_domain_map()")
Fixes: da61fcf9d62a ("irqchip: mips-gic: Use irq_cpu_online to (un)mask all-VP(E) IRQs")
Reported-and-tested-by: Archer Yan <ayan@wavecomp.com>
Cc: Jason Cooper <jason@lakedaemon.net>
Cc: stable@vger.kernel.org # v4.14+
This is the 4.19.50 stable release
This is the 4.19.47 stable release
drivers/char/random.c
kernel/irq_work.c
Issues with kernel/irq/manage.c
A use after free bug was fixed in stable. But it requires a backport of changes
from rt-devel. The bug still exists in this tree for PREEMPT_RT, but will be
fixed when backporting the rt-devel patches.
This reverts commit ca8648816e3dcc8dadba0e79a034f61c85eb206d which is
commit a1e8783db8e0d58891681bc1e6d9ada66eae8e20 upstream.
Petr writes:
Karl has reported to me today, that he's experiencing weird
reboot hang on his devices with 4.9.180 kernel and that he has
bisected it down to my backported patch.
I would like to kindly ask you for removal of this patch. This
patch should be reverted from all stable kernels up to 5.1,
because perf counters were not broken on those kernels, and this
patch won't work on the ath79 legacy IRQ code anyway, it needs
new irqchip driver which was enabled on ath79 with commit
51fa4f8912c0 ("MIPS: ath79: drop legacy IRQ code").
Reported-by: Petr Štetiar <ynezz@true.cz>
Cc: Kevin 'ldir' Darbyshire-Bryant <ldir@darbyshire-bryant.me.uk>
Cc: John Crispin <john@phrozen.org>
Cc: Marc Zyngier <marc.zyngier@arm.com>
Cc: Paul Burton <paul.burton@mips.com>
Cc: linux-mips@vger.kernel.org
Cc: James Hogan <jhogan@kernel.org>
Cc: Sasha Levin <sashal@kernel.org>
[ Upstream commit a1e8783db8e0d58891681bc1e6d9ada66eae8e20 ]
Currently it's not possible to use perf on ath79 due to genirq flags
mismatch happening on static virtual IRQ 13 which is used for
performance counters hardware IRQ 5.
On TP-Link Archer C7v5:
CPU0
2: 0 MIPS 2 ath9k
4: 318 MIPS 4 19000000.eth
7: 55034 MIPS 7 timer
8: 1236 MISC 3 ttyS0
12: 0 INTC 1 ehci_hcd:usb1
13: 0 gpio-ath79 2 keys
14: 0 gpio-ath79 5 keys
15: 31 AR724X PCI 1 ath10k_pci
$ perf top
genirq: Flags mismatch irq 13. 00014c83 (mips_perf_pmu) vs. 00002003 (keys)
On TP-Link Archer C7v4:
CPU0
4: 0 MIPS 4 19000000.eth
5: 7135 MIPS 5 1a000000.eth
7: 98379 MIPS 7 timer
8: 30 MISC 3 ttyS0
12: 90028 INTC 0 ath9k
13: 5520 INTC 1 ehci_hcd:usb1
14: 4623 INTC 2 ehci_hcd:usb2
15: 32844 AR724X PCI 1 ath10k_pci
16: 0 gpio-ath79 16 keys
23: 0 gpio-ath79 23 keys
$ perf top
genirq: Flags mismatch irq 13. 00014c80 (mips_perf_pmu) vs. 00000080 (ehci_hcd:usb1)
This problem is happening, because currently statically assigned virtual
IRQ 13 for performance counters is not claimed during the initialization
of MIPS PMU during the bootup, so the IRQ subsystem doesn't know, that
this interrupt isn't available for further use.
So this patch fixes the issue by simply booking hardware IRQ 5 for MIPS PMU.
Tested-by: Kevin 'ldir' Darbyshire-Bryant <ldir@darbyshire-bryant.me.uk>
Signed-off-by: Petr Štetiar <ynezz@true.cz>
Acked-by: John Crispin <john@phrozen.org>
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
This is the 4.19.37 stable release
include/linux/sched/mm.h
kernel/sched/fair.c
[ Upstream commit fca269f201a8d9985c0a31fb60b15d4eb57cef80 ]
mbigen_write_msg clears eventid bits of a mbigen register
when free a interrupt, because msi_domain_deactivate memset
struct msg to zero. Then multiple mbigen pins with zero eventid
will report the same interrupt number.
The eventid clear call trace:
free_irq
__free_irq
irq_shutdown
irq_domain_deactivate_irq
__irq_domain_deactivate_irq
platform_msi_write_msg
mbigen_write_msg
Signed-off-by: Jianguo Chen <chenjianguo3@huawei.com>
[maz: massaged subject]
[ Upstream commit 0dda09666f50eae9c5b794dd89b1fd8a8d89d714 ]
Falling and rising configuration and status registers are not banked.
As they are shared with M4 co-processor, they should not be cleared
at probe time, else M4 co-processor configuration will be lost.
Fixes: f9fc1745501e ("irqchip/stm32: Add host and driver data structures")
Signed-off-by: Loic Pallardy <loic.pallardy@st.com>
Signed-off-by: Fabien Dessenne <fabien.dessenne@st.com>
This is the 4.19.31 stable release
mm/swap.c
commit 89dc891792c2e046b030f87600109c22209da32e upstream.
The lpi_range_list is supposed to be sorted in ascending order of
->base_id (at least if the range merging is to work), but the current
comparison function returns a positive value if rb->base_id >
ra->base_id, which means that list_sort() will put A after B in that
case - and vice versa, of course.
Fixes: 880cb3cddd16 (irqchip/gic-v3-its: Refactor LPI allocator)
Cc: stable@vger.kernel.org (v4.19+)
Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
This is the 4.19.29 stable release
drivers/irqchip/irq-gic-v3-its.c
commit 33517881ede742107f416533b8c3e4abc56763da upstream.
Using the irq_gc_lock/irq_gc_unlock functions in the suspend and
resume functions creates the opportunity for a deadlock during
suspend, resume, and shutdown. Using the irq_gc_lock_irqsave/
irq_gc_unlock_irqrestore variants prevents this possible deadlock.
Fixes: 7f646e92766e2 ("irqchip: brcmstb-l2: Add Broadcom Set Top Box Level-2 interrupt controller")
Signed-off-by: Doug Berger <opendmb@gmail.com>
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
[maz: tidied up $SUBJECT]
commit 8d565748b6035eeda18895c213396a4c9fac6a4c upstream.
In current logic, its_parse_indirect_baser() will be invoked twice
when allocating Device tables. Add a *break* to omit the unnecessary
and annoying (might be ...) invoking.
Fixes: 32bd44dc19de ("irqchip/gic-v3-its: Fix the incorrect parsing of VCPU table size")
Signed-off-by: Zenghui Yu <yuzenghui@huawei.com>
[ Upstream commit 2380a22b60ce6f995eac806e69c66e397b59d045 ]
Resetting bit 4 disables the interrupt delivery to the "secure
processor" core. This breaks the keyboard on a OLPC XO 1.75 laptop,
where the firmware running on the "secure processor" bit-bangs the
PS/2 protocol over the GPIO lines.
It is not clear what the rest of the bits are and Marvell was unhelpful
when asked for documentation. Aside from the SP bit, there are probably
priority bits.
Leaving the unknown bits as the firmware set them up seems to be a wiser
course of action compared to just turning them off.
Signed-off-by: Lubomir Rintel <lkundrak@v3.sk>
Acked-by: Pavel Machek <pavel@ucw.cz>
[maz: fixed-up subject and commit message]
[ Upstream commit 45725e0fc3e7fe52fedb94f59806ec50e9618682 ]
In the unlikely event that we cannot find any available LPI in the
system, we should gracefully return an error instead of carrying
on with no LPI allocated at all.
Fixes: 38dd7c494cf6 ("irqchip/gic-v3-its: Drop chunk allocation compatibility")
[ Upstream commit 6479450f72c1391c03f08affe0d0110f41ae7ca0 ]
1. In current implementation, every VLPI will temporarily be mapped to
the first CPU in system (normally CPU0) and then moved to the real
scheduled CPU later.
2. So there is a time window and a VLPI may be sent to CPU0 instead of
the real scheduled vCPU, in a multi-CPU virtual machine.
3. However, CPU0 may have not been scheduled as a virtual CPU after
system boots up, so the value of its GICR_VPROPBASER is unknown at
that moment.
4. If the INTID of VLPI is larger than 2^(GICR_VPROPBASER.IDbits+1),
while IDbits is also in unknown state, GIC will behave as if the VLPI
is out of range and simply drop it, which results in interrupt missing
in Guest.
As no code will clear GICR_VPROPBASER at runtime, we can safely
initialize the IDbits field at boot time for each CPU to get rid of
this issue.
We also clear Valid bit of GICR_VPENDBASER in case any ancient
programming gets left in and causes memory corrupting. A new function
its_clear_vpend_valid() is added to reuse the code in
its_vpe_deschedule().
Fixes: e643d8034036 ("irqchip/gic-v3-its: Add VPE scheduling")
Signed-off-by: Heyi Guo <guoheyi@huawei.com>
Signed-off-by: Heyi Guo <heyi.guo@linaro.org>
[ Upstream commit c530bb8a726a37811e9fb5d68cd6b5408173b545 ]
The mbi_lock mutex is left uninitialized, so let's use DEFINE_MUTEX
to initialize it statically.
Fixes: 505287525c24d ("irqchip/gic-v3: Add support for Message Based Interrupts as an MSI controller")
Signed-off-by: Yang Yingliang <yangyingliang@huawei.com>
This is the 4.19.23 stable release
commit 9791ec7df0e7b4d80706ccea8f24b6542f6059e9 upstream.
On systems or VMs where multiple devices share a single DevID
(because they sit behind a PCI bridge, or because the HW is
broken in funky ways), we reuse the save its_device structure
in order to reflect this.
It turns out that there is a distinct lack of locking when looking
up the its_device, and two device being probed concurrently can result
in double allocations. That's obviously not nice.
A solution for this is to have a per-ITS mutex that serializes device
allocation.
A similar issue exists on the freeing side, which can run concurrently
with the allocation. On top of now taking the appropriate lock, we
also make sure that a shared device is never freed, as we have no way
to currently track the life cycle of such object.
Reported-by: Zheng Xiang <zhengxiang9@huawei.com>
Tested-by: Zheng Xiang <zhengxiang9@huawei.com>
commit 8208d1708b88b412ca97f50a6d951242c88cbbac upstream.
The way we allocate events works fine in most cases, except
when multiple PCI devices share an ITS-visible DevID, and that
one of them is trying to use MultiMSI allocation.
In that case, our allocation is not guaranteed to be zero-based
anymore, and we have to make sure we allocate it on a boundary
that is compatible with the PCI Multi-MSI constraints.
Fix this by allocating the full region upfront instead of iterating
over the number of MSIs. MSI-X are always allocated one by one,
so this shouldn't change anything on that front.
Fixes: b48ac83d6bbc2 ("irqchip: GICv3: ITS: MSI support")
Reported-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Tested-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
This is the 4.19.5 stable release
[ Upstream commit 7bae48b22c8d38c5cd50f52b6e15d134e2bb3935 ]
The PDC irqchp can convert a falling edge or level low interrupt to a
rising edge or level high interrupt at the GIC. We just need to setup
the GIC correctly. Set up the interrupt type for the IRQ_TYPE_EDGE_BOTH
as IRQ_TYPE_EDGE_RISING at the GIC.
Fixes: f55c73aef890 ("irqchip/pdc: Add PDC interrupt controller for QCOM SoCs")
Reported-by: Evan Green <evgreen@chromium.org>
Reviewed-by: Evan Green <evgreen@chromium.org>
Signed-off-by: Lina Iyer <ilina@codeaurora.org>
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Commit fe8e93504ce8 ("irqchip/gic-v3-its: Use full range of LPIs"), removes
the cap for lpi_id_bits, which causes the following warning to trigger on a
QDF2400 server:
WARNING: CPU: 0 PID: 0 at mm/page_alloc.c:4066 __alloc_pages_nodemask
Call trace:
__alloc_pages_nodemask+0x2d8/0x1188
alloc_pages_current+0x8c/0xd8
its_allocate_prop_table+0x5c/0xb8
its_init+0x220/0x3c0
gic_init_bases+0x250/0x380
gic_acpi_init+0x16c/0x2a4
In its_alloc_lpi_tables(), lpi_id_bits is 24 in QDF2400. The allocation in
allocate_prop_table() tries therefore to allocate 16M (order 12 if
pagesize=4k), which triggers the warning.
As said by MarcL
Capping lpi_id_bits at 16 (which is what we had before) is plenty,
will save a some memory, and gives some margin before we need to push
it up again.
Bring the upper limit of lpi_id_bits back to prevent
Fixes: fe8e93504ce8 ("irqchip/gic-v3-its: Use full range of LPIs")
Suggested-by: Marc Zyngier <marc.zyngier@arm.com>
Signed-off-by: Jia He <jia.he@hxt-semitech.com>
Tested-by: Olof Johansson <olof@lixom.net>
Link: https://lkml.kernel.org/r/1535432006-2304-1-git-send-email-jia.he@hxt-semitech.com
Pull irq update from Thomas Gleixner:
"A small set of updats/fixes for the irq subsystem:
- Allow GICv3 interrupts to be configured as wake-up sources to
enable wakeup from suspend
- Make the error handling of the STM32 irqchip init function work
- A set of small cleanups and improvements"
* 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
irqchip/gic-v3: Allow interrupt to be configured as wake-up sources
irqchip/tango: Set irq handler and data in one go
dt-bindings: irqchip: renesas-irqc: Document r8a774a1 support
irqchip/s3c24xx: Remove unneeded comparison of unsigned long to 0
irqchip/stm32: Fix init error handling
irqchip/bcm7038-l1: Hide cpu offline callback when building for !SMP
git://git.kernel.org/pub/scm/linux/kernel/git/maz/arm-platforms into irq/urgent
Pull irqchip updates for 4.19, take #2 from Marc Zyngier:
- bcm7038: compilation fix for !SMP
- stm32: fix teardown on probe error
- s3c24xx: fix compilation warning
- renesas-irqc: r8a774a1 support
- tango: chained irq setup simplification
- gic-v3: allow wake-up sources
Pull Xtensa updates from Max Filippov:
- switch xtensa arch to the generic noncoherent direct mapping
operations
- add support for DMA_ATTR_NO_KERNEL_MAPPING attribute
- clean up users of platform/hardware.h in generic Xtensa code
- fix assembly cache maintenance code for long cache lines
- rework noMMU cache attributes initialization
- add big-endian HiFi2 test_kc705_be CPU variant
* tag 'xtensa-20180820' of git://github.com/jcmvbkbc/linux-xtensa:
xtensa: add test_kc705_be variant
xtensa: clean up boot-elf/bootstrap.S
xtensa: make bootparam parsing optional
xtensa: drop variant IRQ support
xtensa: drop unneeded platform/hardware.h headers
xtensa: move PLATFORM_NR_IRQS to Kconfig
xtensa: rework {CONFIG,PLATFORM}_DEFAULT_MEM_START
xtensa: drop unused {CONFIG,PLATFORM}_DEFAULT_MEM_SIZE
xtensa: rework noMMU cache attributes initialization
xtensa: increase ranges in ___invalidate_{i,d}cache_all
xtensa: limit offsets in __loop_cache_{all,page}
xtensa: platform-specific handling of coherent memory
xtensa: support DMA_ATTR_NO_KERNEL_MAPPING attribute
xtensa: use generic dma_noncoherent_ops
Pull arch/h8300 updates from Yoshinori Sato.
* tag 'for-4.19' of git://git.sourceforge.jp/gitroot/uclinux-h8/linux:
h8300: fix IRQ no
arch/h8300: add a defconfig target
arch/h8300: eliminate kgbd.c warning
arch/h8300: eliminate ptrace.h warnings
h8300:let the checker know that size_t is ulong
h8300: Don't include linux/kernel.h in asm/atomic.h
h8300: remove unnecessary of_platform_populate call
h8300: Correct signature of test_bit()
h8300: irqchip: fix warning
h8300: switch to NO_BOOTMEM
h8300: gcc-8.1 fix
h8300: Add missing output register.
Var "addr" type incorrect.
It have interrupt controler register address.
Type of void __iomem is correct.
Signed-off-by: Yoshinori Sato <ysato@users.sourceforge.jp>
If an xtensa core provides an additional IRQ controller it should be
treated as a separate piece of hardware and be driven by an irqchip
driver.
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
Although GICv3 doesn't directly offers support for wake-up interrupts
and relies on external HW for this, it shouldn't prevent the driver
for such HW from doing it work.
Let's set the required flags on the irq_chip structures.
Reported-by: Lina Iyer <ilina@codeaurora.org>
Tested-by: Lina Iyer <ilina@codeaurora.org>
Reviewed-by: Sudeep Holla <sudeep.holla@arm.com>
Replace the two separate calls for setting the irq handler and data with
a single irq_set_chained_handler_and_data() call.
Signed-off-by: Martin Kaiser <martin@kaiser.cx>
git://git.kernel.org/pub/scm/linux/kernel/git/palmer/riscv-linux
Pull RISC-V updates from Palmer Dabbelt:
"This contains some major improvements to the RISC-V port, including
the necessary interrupt controller and timer support to actually make
it to userspace. Support for three devices has been added:
- the ISA-mandated timers on RISC-V systems.
- the ISA-mandated first-level interrupt controller on RISC-V
systems, which is handled as part of our core arch code because
it's very small and tightly tied to the ISA.
- SiFive's platform-level interrupt controller, which talks to the
actual devices.
In addition to these new devices, there are a handful of cleanups all
over the RISC-V tree:
- build fixes for various configurations:
* A fix to the vDSO build's makefile so it respects CFLAGS.
* The addition of __lshrti3, a libgcc derived function necessary
for some 32-bit configurations.
* !SMP && PERF_EVENTS
- Cleanups to the arch code to remove the remnants of old versions of
the drivers that were just properly submitted.
* Some dead code from the timer driver, most of which wasn't ever
even compiled.
* Cleanups of some interrupt #defines, which are now local to the
interrupt handling code.
- Fixes to ptrace(), which while not being sufficient to fully make
GDB work are at least sufficient to get simple GDB tasks to work.
- Early printk support via RISC-V's architecturally mandated SBI
console device.
- A fix to our early debug trap handler to ensure it's always
aligned.
These patches have all been through a fairly extensive review process,
but as this enables a whole pile of functionality (ie, userspace) I'm
confident we'll need to submit a few more patches. The only concrete
issues I know about are the sys_riscv_flush_icache patches, but as I
managed to screw those up on Friday I figured it'd be best to let them
bake another week.
This tag boots a Fedora root filesystem on QEMU's master branch for
me, and before this morning's rebase (from 4.18-rc8 to 4.18) it booted
on the HiFive Unleashed.
Thanks to Christoph Hellwig and the other guys at WD for getting the
new drivers in shape!"
* tag 'riscv-for-linus-4.19-mw0' of git://git.kernel.org/pub/scm/linux/kernel/git/palmer/riscv-linux:
dt-bindings: interrupt-controller: SiFive Plaform Level Interrupt Controller
dt-bindings: interrupt-controller: RISC-V local interrupt controller
RISC-V: Fix !CONFIG_SMP compilation error
irqchip: add a SiFive PLIC driver
RISC-V: Add the directive for alignment of stvec's value
clocksource: new RISC-V SBI timer driver
RISC-V: implement low-level interrupt handling
RISC-V: add a definition for the SIE SEIE bit
RISC-V: remove INTERRUPT_CAUSE_* defines from asm/irq.h
RISC-V: simplify software interrupt / IPI code
RISC-V: remove timer leftovers
RISC-V: Add early printk support via the SBI console
RISC-V: Don't increment sepc after breakpoint.
RISC-V: implement __lshrti3.
RISC-V: Use KBUILD_CFLAGS instead of KCFLAGS when building the vDSO
Add a driver for the SiFive implementation of the RISC-V Platform Level
Interrupt Controller (PLIC). The PLIC connects global interrupt sources
to the local interrupt controller on each hart.
This driver is based on the driver in the RISC-V tree from Palmer Dabbelt,
but has been almost entirely rewritten since, and includes many fixes
from Atish Patra.
Reviewed-by: Atish Patra <atish.patra@wdc.com>
[Binding update by Palmer]
Signed-off-by: Palmer Dabbelt <palmer@sifive.com>
irq_data->hwirq is unsigned long. This fixes GCC warning:
drivers/irqchip/irq-s3c24xx.c: In function 's3c_irqext0_type':
drivers/irqchip/irq-s3c24xx.c:253:19: warning: comparison of unsigned expression >= 0 is always true [-Wtype-limits]
if ((data->hwirq >= 0) && (data->hwirq <= 3)) {
Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
If there are any errors in stm32_exti_host_init() then it leads to a
NULL dereference in the callers. The function should clean up after
itself.
Reviewed-by: Ludovic Barre <ludovic.barre@st.com>
When compiling bmips with SMP disabled, the build fails with:
drivers/irqchip/irq-bcm7038-l1.o: In function `bcm7038_l1_cpu_offline':
drivers/irqchip/irq-bcm7038-l1.c:242: undefined reference to `irq_set_affinity_locked'
make[5]: *** [vmlinux] Error 1
Fix this by adding and setting bcm7038_l1_cpu_offline only when actually
compiling for SMP. It wouldn't have been used anyway, as it requires
CPU_HOTPLUG, which in turn requires SMP.
Fixes: 34c535793bcb ("irqchip/bcm7038-l1: Implement irq_cpu_offline() callback")
Signed-off-by: Jonas Gorski <jonas.gorski@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/maz/arm-platforms into irq/core
Pull irqchip updates from Marc Zyngier:
- GICv3 ITS LPI allocation revamp
- GICv3 support for hypervisor-enforced LPI range
- GICv3 ITS conversion to raw spinlock
The its_lock lock is held while a new device is added to the list and
during setup while the CPU is booted. Even on -RT the CPU-bootup is
performed with disabled interrupts.
Make its_lock a raw_spin_lock_t.
Now that every user of MULTI_IRQ_HANDLER has been convereted over to use
GENERIC_IRQ_MULTI_HANDLER remove the references to MULTI_IRQ_HANDLER.
Cc: linux@armlinux.org.uk
Cc: catalin.marinas@arm.com
Cc: jonas@southpole.se
Cc: stefan.kristiansson@saunalahti.fi
Cc: shorne@gmail.com
Cc: jason@lakedaemon.net
Cc: marc.zyngier@arm.com
Cc: nicolas.pitre@linaro.org
Cc: vladimir.murzin@arm.com
Cc: keescook@chromium.org
Cc: jinb.park7@gmail.com
Cc: yamada.masahiro@socionext.com
Cc: alexandre.belloni@bootlin.com
Cc: pombredanne@nexb.com
Cc: Greg KH <gregkh@linuxfoundation.org>
Cc: kstewart@linuxfoundation.org
Cc: jhogan@kernel.org
Cc: mark.rutland@arm.com
Cc: ard.biesheuvel@linaro.org
Cc: james.morse@arm.com
Cc: openrisc@lists.librecores.org
Link: https://lkml.kernel.org/r/20180622170126.6308-6-palmer@sifive.com
GENERIC_IRQ_MULTI_HANDLER is incompatible with MULTI_IRQ_HANDLER because
they define the same symbols. Multiple generic irqchip drivers select
MULTI_IRQ_HANDLER, which is now defined on all architectures that
provide set_handle_irq().
To solve this select GENERIC_IRQ_MULTI_HANDLER for all drivers that used to
select MULTI_IRQ_HANDLER, but only when MULTI_IRQ_HANDLER doesn't exist.
After that every architecture can be converted over from MULTI_IRQ_HANDLER
to GENERIC_IRQ_MULTI_HANDLER before removing the extra MULTI_IRQ_HANDLER
scaffolding.
Cc: Shea Levy <shea@shealevy.com>
Link: https://lkml.kernel.org/r/20180622170126.6308-2-palmer@sifive.com
Allocating a minimum of 32 LPIs per PCI device, let's reduce it to
be just 1, as most devices do not need that many interrupts.
We still have to special-case DevID 0, as there is plenty of broken
HW around where the PCI RID is not presented as a DevID to the ITS,
and all the devices are presented as DevID 0. In this case, we keep
the 32 minimal allocation.
The interrupt controller of the JZ4725B works the same way as the other
JZ SoCs from Ingenic; so we just add a new compatible string.
Signed-off-by: Paul Cercueil <paul@crapouillou.net>
This patch fixes a datasheet issue, in the draft version the "exti0"
was not connected whereas is it.
Signed-off-by: Ludovic Barre <ludovic.barre@st.com>
A recent extension to the GIC architecture allows a hypervisor to
arbitrarily reduce the number of LPIs available to a guest, no
matter what the GIC says about the valid range of IntIDs.
Let's factor in this information when computing the number of
available LPIs
Instead of exposing the GIC distributor IntID field in the rdist
structure that is passed to the ITS, let's replace it with a
copy of the whole GICD_TYPER register. We are going to need
some of this information at a later time.
No functionnal change.
The chunk allocation system is now officially dead, so let's
remove it.
At the moment, the core ITS driver imposes the allocation to be
in chunks of 32. As we want to relax this on a per bus basis, let's
move the the the allocation constraints to each bus.
As we used to represent the LPI range using a bitmap, we were reducing
the number of LPIs to at most 64k in order to preserve memory.
With our new allocator, there is no such need, as dealing with 2^16
or 2^32 LPIs takes the same amount of memory.
So let's use the number of IntID bits reported by the GIC instead of
an arbitrary limit.
