path: root/drivers/isdn/capi/kcapi.c
2010-12-24isdn/capi: make kcapi use a separate workqueueTejun Heo
flush_scheduled_work() is deprecated and will be removed. Because kcapi uses fire-and-forget type works, it's impossible to flush each work explicitly. Create and use a dedicated workqueue instead. Please note that with recent workqueue changes, each workqueue doesn't reserve a lot of resources and using it as a flush domain is fine. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Jan Kiszka <jan.kiszka@web.de>
2010-10-21CAPI: Silence lockdep warning on get_capi_appl_by_nr usageJan Kiszka
As long as we hold capi_controller_lock, we can safely access capi_applications without RCU protection as no one can modify the application list underneath us. Introduce an RCU-free __get_capi_appl_by_nr for this purpose. This silences lockdep warnings on suspicious rcu_dereference usage. Signed-off-by: Jan Kiszka <jan.kiszka@web.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-03isdn/kcapi: return -EFAULT on copy_from_user errorsDan Carpenter
copy_from_user() returns the number of bytes remaining but we should return -EFAULT here. The error code gets returned to the user. Both old_capi_manufacturer() and capi20_manufacturer() had other places that already returned -EFAULT so this won't break anything. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-23isdn/capi: make reset_ctr op truly optionalTilman Schmidt
The CAPI controller operation reset_ctr is marked as optional, and not all drivers do implement it. Add a check to the kernel CAPI whether it exists before trying to call it. Signed-off-by: Tilman Schmidt <tilman@imap.cc> Acked-by: Karsten Keil <isdn@linux-pingi.de> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-16CAPI: Drop special controller lookup from capi20_put_messageJan Kiszka
This strange special rule to fall back to controller 1 cannot be derived from the CAPI specs and looks a lot like it was once dedicated to some out-of-tree driver, probably AVM's broken fcdsl2 (FRITZ!Card DSL v2.0). I found no in-tree user that needs this check, and I'm now taking care of the fcdsl2. So drop these bits from our stack. Signed-off-by: Jan Kiszka <jan.kiszka@web.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-16CAPI: Rework application lockingJan Kiszka
Drop the application rw-lock in favour of RCU. This synchronizes capi20_release against capi_ctr_handle_message which may dereference an application from (soft-)IRQ context. Any other access to the application list is now protected by the capi_controller_lock as well. This also allows to safely inspect applications for /proc dumping by holding capi_controller_lock. At this chance, drop some useless release_in_progress checks where we obtained the application pointer from the list (which becomes NULL on release_in_progress). Signed-off-by: Jan Kiszka <jan.kiszka@web.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-16CAPI: Rework locking of controller data structuresJan Kiszka
This patch applies the mutex so far only protecting the controller list to (almost) all accesses of controller data structures. It also reworks waiting on state changes in old_capi_manufacturer so that it no longer poll and holds a module reference to the controller owner while waiting (the latter was partly done already). Modification and checking of the blocked state remains racy by design, the caller is responsible for dealing with this. Signed-off-by: Jan Kiszka <jan.kiszka@web.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-16CAPI: Rework controller state notifierJan Kiszka
Another step towards proper locking: Rework the callback provided to capidrv for controller state changes. This is so far attached to an application, which would require us to hold the corresponding lock across notification calls. But there is no direct relation between a controller up/down event and an application, so let's decouple them and provide a notifier call chain for those events instead. This notifier chain is first of all used internally. Here we request the highest priority to unsure that housekeeping work is done before any other notifications. The chain is exported via [un]register_capictr_notifier to our only user, capidrv, to replace the racy and unfixable capi20_set_callback. Signed-off-by: Jan Kiszka <jan.kiszka@web.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-16CAPI: Rework capi_ctr_ready/downJan Kiszka
This step prepares the application of proper controller locking: Push all state changing work into the notify handler that are called by capi_ctr_ready and capi_ctr_down, switch detach_capi_ctr to issue a synchronous ctr_down. Also ensure that we do not go through any action if the state did not change. Signed-off-by: Jan Kiszka <jan.kiszka@web.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-16CAPI: Convert capi drivers rwlock into mutexJan Kiszka
Turn the lock protecting registered capi drivers into a mutex and apply it consistently. Signed-off-by: Jan Kiszka <jan.kiszka@web.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-16CAPI: Call a controller 'controller', not 'card'Jan Kiszka
At least for our internal use, fix the misnomers that refer to a CAPI controller as 'card'. No functional changes. Signed-off-by: Jan Kiszka <jan.kiszka@web.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-16CAPI: Reduce chattiness during module loading/removalJan Kiszka
The CVS revisions dumped by all CAPI modules are meaningless today. And that some CAPI module is loaded or removed does not necessarily deserve a message. Just keep the message of the central module, capi.ko, drop the rest. Signed-off-by: Jan Kiszka <jan.kiszka@web.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-14proc_fops: convert drivers/isdn/ to seq_fileAlexey Dobriyan
Convert code away from ->read_proc/->write_proc interfaces. Switch to proc_create()/proc_create_data() which make addition of proc entries reliable wrt NULL ->proc_fops, NULL ->data and so on. Problem with ->read_proc et al is described here commit 786d7e1612f0b0adb6046f19b906609e4fe8b1ba "Fix rmmod/read/write races in /proc entries" [akpm@linux-foundation.org: CONFIG_PROC_FS=n build fix] Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: Karsten Keil <keil@b1-systems.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-11headers: remove sched.h from interrupt.hAlexey Dobriyan
After m68k's task_thread_info() doesn't refer to current, it's possible to remove sched.h from interrupt.h and not break m68k! Many thanks to Heiko Carstens for allowing this. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2009-06-08isdn: rename capi_ctr_reseted() to capi_ctr_down()Tilman Schmidt
Change the name of the Kernel CAPI exported function capi_ctr_reseted() to something representing its purpose better. Impact: renaming, no functional change Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-27Documentation/isdn/INTERFACE.CAPITilman Schmidt
isdn: document Kernel CAPI driver interface Create a file Documentation/isdn/INTERFACE.CAPI describing the interface between the kernel CAPI subsystem and ISDN device drivers, analogous to the existing Documentation/isdn/INTERFACE for the old isdn4linux subsystem. Also add kerneldoc comments to the exported functions in drivers/isdn/capi/kcapi.c. Impact: Documentation Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: Karsten Keil <keil@b1-systems.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-22drivers/isdn/capi/kcapi.c: Adjust error handling code involving capi_ctr_putJulia Lawall
After calling capi_ctr_get, error handling code should call capi_ctr_put. The semantic match that finds this problem is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @r@ expression x,E; statement S; position p1,p2,p3; @@ ( if ((x = capi_ctr_get@p1(...)) == NULL || ...) S | x = capi_ctr_get@p1(...) ... when != x if (x == NULL || ...) S ) <... if@p3 (...) { ... when != capi_ctr_put(x) when != if (x) { ... capi_ctr_put(x); ...} return@p2 ...; } ...> ( return x; | return 0; | x = E | E = x | capi_ctr_put(x) ) @exists@ position r.p1,r.p2,r.p3; expression x; int ret != 0; statement S; @@ * x = capi_ctr_get@p1(...) <... * if@p3 (...) S ...> * return@p2 \(NULL\|ret\); // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-28isdn: rename CONFIG_AVMB1_COMPAT to not look like a Kconfig variableRobert P. J. Day
Since CONFIG_AVMB1_COMPAT is not a Kconfig variable, move it out of the Kconfig namespace. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Acked-by: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28isdn: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28capi: fix sparse warnings using integer as NULL pointerHarvey Harrison
drivers/isdn/capi/kcapi.c:829:30: warning: Using plain integer as NULL pointer drivers/isdn/capi/kcapi.c:838:27: warning: Using plain integer as NULL pointer drivers/isdn/capi/kcapi.c:954:17: warning: Using plain integer as NULL pointer drivers/isdn/capi/kcapi.c:1007:37: warning: Using plain integer as NULL pointer drivers/isdn/capi/kcapi.c:1009:33: warning: Using plain integer as NULL pointer drivers/isdn/capi/capiutil.c:453:24: warning: Using plain integer as NULL pointer drivers/isdn/capi/capilib.c:47:30: warning: Using plain integer as NULL pointer drivers/isdn/capi/capi.c:353:29: warning: Using plain integer as NULL pointer drivers/isdn/capi/capi.c:369:15: warning: Using plain integer as NULL pointer drivers/isdn/capi/capi.c:486:48: warning: Using plain integer as NULL pointer drivers/isdn/capi/capi.c:515:46: warning: Using plain integer as NULL pointer drivers/isdn/capi/capi.c:541:47: warning: Using plain integer as NULL pointer drivers/isdn/capi/capi.c:692:47: warning: Using plain integer as NULL pointer drivers/isdn/capi/capi.c:699:49: warning: Using plain integer as NULL pointer drivers/isdn/capi/capi.c:704:14: warning: Using plain integer as NULL pointer drivers/isdn/capi/capi.c:943:53: warning: Using plain integer as NULL pointer drivers/isdn/capi/capi.c:948:32: warning: Using plain integer as NULL pointer drivers/isdn/capi/capi.c:969:42: warning: Using plain integer as NULL pointer drivers/isdn/capi/capi.c:989:48: warning: Using plain integer as NULL pointer drivers/isdn/capi/capi.c:1026:69: warning: Using plain integer as NULL pointer drivers/isdn/capi/capi.c:1028:19: warning: Using plain integer as NULL pointer drivers/isdn/capi/capi.c:1061:20: warning: Using plain integer as NULL pointer drivers/isdn/capi/capi.c:1529:37: warning: Using plain integer as NULL pointer drivers/isdn/capi/capi.c:1531:33: warning: Using plain integer as NULL pointer drivers/isdn/capi/capidrv.c:338:15: warning: Using plain integer as NULL pointer drivers/isdn/capi/capidrv.c:758:32: warning: Using plain integer as NULL pointer drivers/isdn/capi/capidrv.c:880:40: warning: Using plain integer as NULL pointer drivers/isdn/capi/capidrv.c:407:15: warning: Using plain integer as NULL pointer drivers/isdn/capi/capidrv.c:429:49: warning: Using plain integer as NULL pointer drivers/isdn/capi/capidrv.c:407:15: warning: Using plain integer as NULL pointer drivers/isdn/capi/capidrv.c:444:49: warning: Using plain integer as NULL pointer drivers/isdn/capi/capidrv.c:429:49: warning: Using plain integer as NULL pointer drivers/isdn/capi/capidrv.c:429:49: warning: Using plain integer as NULL pointer drivers/isdn/capi/capidrv.c:429:49: warning: Using plain integer as NULL pointer drivers/isdn/capi/capidrv.c:429:49: warning: Using plain integer as NULL pointer drivers/isdn/capi/capidrv.c:429:49: warning: Using plain integer as NULL pointer drivers/isdn/capi/capidrv.c:1664:61: warning: Using plain integer as NULL pointer drivers/isdn/capi/capidrv.c:1969:37: warning: Using plain integer as NULL pointer drivers/isdn/capi/capidrv.c:2294:37: warning: Using plain integer as NULL pointer drivers/isdn/capi/capidrv.c:2297:33: warning: Using plain integer as NULL pointer drivers/isdn/capi/capidrv.c:2338:37: warning: Using plain integer as NULL pointer drivers/isdn/capi/capidrv.c:2341:33: warning: Using plain integer as NULL pointer drivers/isdn/capi/capifs.c:192:37: warning: Using plain integer as NULL pointer drivers/isdn/capi/capifs.c:194:33: warning: Using plain integer as NULL pointer Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Karsten Keil <kkeil@suse.de> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16isdn: guard against a potential NULL pointer dereference in ↵Jesper Juhl
old_capi_manufacturer() In drivers/isdn/capi/kcapi.c::old_capi_manufacturer(), if the call to get_capi_ctr_by_nr(ldef.contr); in line 823 returns NULL, then we'll be dereferencing a NULL pointer in the very next line. (Found by Coverity checker as bug #402) Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Acked-by: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17Use mutex instead of semaphore in CAPI 2.0 driverMatthias Kaehlcke
The CAPI 2.0 driver uses a semaphore as mutex. Use the mutex API instead of the (binary) semaphore. Signed-off-by: Matthias Kaehlcke <matthias.kaehlcke@gmail.com> Acked-by: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-01[PATCH] Fix buffer overflow and races in capi debug functionsKarsten Keil
The CAPI trace debug functions were using a fixed size buffer, which can be overflowed if wrong formatted CAPI messages were sent to the kernel capi layer. The code was also not protected against multiple callers. This fix bug 8028. Additionally the patch make the CAPI trace functions optional. Signed-off-by: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-11-22WorkStruct: make allyesconfigDavid Howells
Fix up for make allyesconfig. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-03-23[PATCH] sem2mutex: kcapi.cArjan van de Ven
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
