The delayed work function int_in_work() may call usb_reset_device()
and thus, indirectly, the driver's pre_reset method. Trying to
cancel the work synchronously in that situation would deadlock.
Fix by avoiding cancel_work_sync() in the pre_reset method.
If the reset was NOT initiated by int_in_work() this might cause
int_in_work() to run after the post_reset method, with urb_int_in
already resubmitted, so handle that case gracefully.
Signed-off-by: Tilman Schmidt <tilman@imap.cc>
Pull networking changes from David Miller:
1) GRE now works over ipv6, from Dmitry Kozlov.
2) Make SCTP more network namespace aware, from Eric Biederman.
3) TEAM driver now works with non-ethernet devices, from Jiri Pirko.
4) Make openvswitch network namespace aware, from Pravin B Shelar.
5) IPV6 NAT implementation, from Patrick McHardy.
6) Server side support for TCP Fast Open, from Jerry Chu and others.
7) Packet BPF filter supports MOD and XOR, from Eric Dumazet and Daniel
Borkmann.
8) Increate the loopback default MTU to 64K, from Eric Dumazet.
9) Use a per-task rather than per-socket page fragment allocator for
outgoing networking traffic. This benefits processes that have very
many mostly idle sockets, which is quite common.
From Eric Dumazet.
10) Use up to 32K for page fragment allocations, with fallbacks to
smaller sizes when higher order page allocations fail. Benefits are
a) less segments for driver to process b) less calls to page
allocator c) less waste of space.
From Eric Dumazet.
11) Allow GRO to be used on GRE tunnels, from Eric Dumazet.
12) VXLAN device driver, one way to handle VLAN issues such as the
limitation of 4096 VLAN IDs yet still have some level of isolation.
From Stephen Hemminger.
13) As usual there is a large boatload of driver changes, with the scale
perhaps tilted towards the wireless side this time around.
Fix up various fairly trivial conflicts, mostly caused by the user
namespace changes.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1012 commits)
hyperv: Add buffer for extended info after the RNDIS response message.
hyperv: Report actual status in receive completion packet
hyperv: Remove extra allocated space for recv_pkt_list elements
hyperv: Fix page buffer handling in rndis_filter_send_request()
hyperv: Fix the missing return value in rndis_filter_set_packet_filter()
hyperv: Fix the max_xfer_size in RNDIS initialization
vxlan: put UDP socket in correct namespace
vxlan: Depend on CONFIG_INET
sfc: Fix the reported priorities of different filter types
sfc: Remove EFX_FILTER_FLAG_RX_OVERRIDE_IP
sfc: Fix loopback self-test with separate_tx_channels=1
sfc: Fix MCDI structure field lookup
sfc: Add parentheses around use of bitfield macro arguments
sfc: Fix null function pointer in efx_sriov_channel_type
vxlan: virtual extensible lan
igmp: export symbol ip_mc_leave_group
netlink: add attributes to fdb interface
tg3: unconditionally select HWMON support when tg3 is enabled.
Revert "net: ti cpsw ethernet: allow reading phy interface mode from DT"
gre: fix sparse warning
Remove useless kfree() and clean up code related to the removal.
The semantic patch that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
@r exists@
position p1,p2;
expression x;
if (x@p1 == NULL) { ... kfree@p2(x); ... return ...; }
@unchanged exists@
position r.p1,r.p2;
expression e <= r.x,x,e1;
iterator I;
statement S;
if (x@p1 == NULL) { ... when != I(x,...) S
when != e = e1
when != e += e1
when != e -= e1
when != ++e
when != --e
when != e++
when != e--
when != &e
@ok depends on unchanged exists@
position any r.p1;
position r.p2;
expression x;
... when != true x@p1 == NULL
kfree@p2(x);
@depends on !ok && unchanged@
position r.p2;
expression x;
*kfree@p2(x);
// </smpl>
Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com>
Acked-by: Tilman Schmidt <tilman@imap.cc>
Currently we have no way to assign tty->port while performing tty
installation. There are two ways to provide the link tty_struct =>
tty_port. Either by calling tty_port_install from tty->ops->install or
tty_port_register_device called instead of tty_register_device when
the device is being set up after connected.
In this patch we modify most of the drivers to do the latter. When the
drivers use tty_register_device and we have tty_port already, we
switch to tty_port_register_device. So we have the tty_struct =>
tty_port link for free for those.
Acked-by: Alan Cox <alan@linux.intel.com>
This handles the merge issue in:
arch/um/drivers/line.c
arch/um/drivers/line.h
And resolves the duplicate patches that were in both trees do to the
tty-next branch not getting merged into 3.6-rc1.
Building Gigaset's CAPI support without Gigaset's debugging enabled
triggers this GCC warning:
'format_ie' defined but not used [-Wunused-function]
Silence this warning by wrapping format_ie() in an "#ifdef
CONFIG_GIGASET_DEBUG" and "#endif" pair.
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
This will let us sort out a whole pile of tty related races. The
alternative would be to keep points and refcount the termios objects.
However
1. They are tiny anyway
2. Many devices don't use the stored copies
3. We can remove a pty special case
Signed-off-by: Alan Cox <alan@linux.intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB 3.5-rc1 changes from Greg Kroah-Hartman:
"Here is the big USB 3.5-rc1 pull request for the 3.5-rc1 merge window.
It's touches a lot of different parts of the kernel, all USB drivers,
due to some API cleanups (getting rid of the ancient err() macro) and
some changes that are needed for USB 3.0 power management updates.
There are also lots of new drivers, pimarily gadget, but others as
well. We deleted a staging driver, which was nice, and finally
dropped the obsolete usbfs code, which will make Al happy to never
have to touch that again.
There were some build errors in the tree that linux-next found a few
days ago, but those were fixed by the most recent changes (all were
due to us not building with CONFIG_PM disabled.)
Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>"
* tag 'usb-3.5-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (477 commits)
xhci: Fix DIV_ROUND_UP compile error.
xhci: Fix compile with CONFIG_USB_SUSPEND=n
USB: Fix core compile with CONFIG_USB_SUSPEND=n
brcm80211: Fix compile error for .disable_hub_initiated_lpm.
Revert "USB: EHCI: work around bug in the Philips ISP1562 controller"
MAINTAINERS: Add myself as maintainer to the USB PHY Layer
USB: EHCI: fix command register configuration lost problem
USB: Remove races in devio.c
USB: ehci-platform: remove update_device
USB: Disable hub-initiated LPM for comms devices.
xhci: Add Intel U1/U2 timeout policy.
xhci: Add infrastructure for host-specific LPM policies.
USB: Add macros for interrupt endpoint types.
xhci: Reserve one command for USB3 LPM disable.
xhci: Some Evaluate Context commands must succeed.
USB: Disable USB 3.0 LPM in critical sections.
USB: Add support to enable/disable USB3 link states.
USB: Allow drivers to disable hub-initiated LPM.
USB: Calculate USB 3.0 exit latencies for LPM.
USB: Refactor code to set LPM support flag.
arch/arm/mach-exynos/mach-nuri.c
arch/arm/mach-exynos/mach-universal_c210.c
drivers/net/wireless/ath/ath6kl/usb.c
Hub-initiated LPM is not good for USB communications devices. Comms
devices should be able to tell when their link can go into a lower power
state, because they know when an incoming transmission is finished.
Ideally, these devices would slam their links into a lower power state,
using the device-initiated LPM, after finishing the last packet of their
data transfer.
If we enable the idle timeouts for the parent hubs to enable
hub-initiated LPM, we will get a lot of useless LPM packets on the bus
as the devices reject LPM transitions when they're in the middle of
receiving data. Worse, some devices might blindly accept the
hub-initiated LPM and power down their radios while they're in the
middle of receiving a transmission.
The Intel Windows folks are disabling hub-initiated LPM for all USB
communications devices under a xHCI USB 3.0 host. In order to keep
the Linux behavior as close as possible to Windows, we need to do the
same in Linux.
Set the disable_hub_initiated_lpm flag for for all USB communications
drivers. I know there aren't currently any USB 3.0 devices that
implement these class specifications, but we should be ready if they do.
Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
Cc: Marcel Holtmann <marcel@holtmann.org>
Cc: Gustavo Padovan <gustavo@padovan.org>
Cc: Johan Hedberg <johan.hedberg@gmail.com>
Cc: Hansjoerg Lipp <hjlipp@web.de>
Cc: Tilman Schmidt <tilman@imap.cc>
Cc: Karsten Keil <isdn@linux-pingi.de>
Cc: Peter Korsgaard <jacmet@sunsite.dk>
Cc: Jan Dumon <j.dumon@option.com>
Cc: Petko Manolov <petkan@users.sourceforge.net>
Cc: Steve Glendinning <steve.glendinning@smsc.com>
Cc: "John W. Linville" <linville@tuxdriver.com>
Cc: Kalle Valo <kvalo@qca.qualcomm.com>
Cc: "Luis R. Rodriguez" <mcgrof@qca.qualcomm.com>
Cc: Jouni Malinen <jouni@qca.qualcomm.com>
Cc: Vasanthakumar Thiagarajan <vthiagar@qca.qualcomm.com>
Cc: Senthil Balasubramanian <senthilb@qca.qualcomm.com>
Cc: Christian Lamparter <chunkeey@googlemail.com>
Cc: Brett Rudley <brudley@broadcom.com>
Cc: Roland Vossen <rvossen@broadcom.com>
Cc: Arend van Spriel <arend@broadcom.com>
Cc: "Franky (Zhenhui) Lin" <frankyl@broadcom.com>
Cc: Kan Yan <kanyan@broadcom.com>
Cc: Dan Williams <dcbw@redhat.com>
Cc: Jussi Kivilinna <jussi.kivilinna@mbnet.fi>
Cc: Ivo van Doorn <IvDoorn@gmail.com>
Cc: Gertjan van Wingerde <gwingerde@gmail.com>
Cc: Helmut Schaa <helmut.schaa@googlemail.com>
Cc: Herton Ronaldo Krzesinski <herton@canonical.com>
Cc: Hin-Tak Leung <htl10@users.sourceforge.net>
Cc: Larry Finger <Larry.Finger@lwfinger.net>
Cc: Chaoming Li <chaoming_li@realsil.com.cn>
Cc: Daniel Drake <dsd@gentoo.org>
Cc: Ulrich Kunitz <kune@deine-taler.de>
Various functions in the Gigaset driver were using different
conventions for the meaning of their int return values.
Align them to the usual negative error numbers convention.
Inspired-by: Julia Lawall <julia.lawall@lip6.fr>
Functions clear_at_state and free_strings did the same thing;
drop one of them, keeping the more descriptive name.
Drop a redundant call.
Rename function dealloc_at_states to dealloc_temp_at_states
to clarify its purpose.
Fix up some of the readibility deterioration caused by the recent
whitespace coding style cleanup.
An out-of-place "OK" response to the "AT+GMR" (get firmware version)
command turns out to be, more often than not, a delayed response to
a previous command rather than an actual error, so continue waiting
for the version number in that case.
CC: stable <stable@kernel.org>
If DISCONNECT_B3_IND was synthesized because of a DISCONNECT_REQ
with existing logical connections, the connection state wasn't
updated accordingly. Also the emitted DISCONNECT_B3_IND message
wasn't included in the debug log as requested.
This patch fixes both of these issues.
Introduce a global ratelimit for CAPI message dumps to protect
against possible log flood.
Drop the ratelimit for ignored messages which is now covered by the
global one.
The "TTY buffer in tty_port" patchset introduced an opencoded
debug message in the Gigaset tty device if_close() function.
Change it to use the gig_dbg() macro like everywhere else in
the driver.
Cc: Jiri Slaby <jslaby@suse.cz>
Pull networking merge from David Miller:
"1) Move ixgbe driver over to purely page based buffering on receive.
From Alexander Duyck.
2) Add receive packet steering support to e1000e, from Bruce Allan.
3) Convert TCP MD5 support over to RCU, from Eric Dumazet.
4) Reduce cpu usage in handling out-of-order TCP packets on modern
systems, also from Eric Dumazet.
5) Support the IP{,V6}_UNICAST_IF socket options, making the wine
folks happy, from Erich Hoover.
6) Support VLAN trunking from guests in hyperv driver, from Haiyang
Zhang.
7) Support byte-queue-limtis in r8169, from Igor Maravic.
8) Outline code intended for IP_RECVTOS in IP_PKTOPTIONS existed but
was never properly implemented, Jiri Benc fixed that.
9) 64-bit statistics support in r8169 and 8139too, from Junchang Wang.
10) Support kernel side dump filtering by ctmark in netfilter
ctnetlink, from Pablo Neira Ayuso.
11) Support byte-queue-limits in gianfar driver, from Paul Gortmaker.
12) Add new peek socket options to assist with socket migration, from
Pavel Emelyanov.
13) Add sch_plug packet scheduler whose queue is controlled by
userland daemons using explicit freeze and release commands. From
Shriram Rajagopalan.
14) Fix FCOE checksum offload handling on transmit, from Yi Zou."
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1846 commits)
Fix pppol2tp getsockname()
Remove printk from rds_sendmsg
ipv6: fix incorrent ipv6 ipsec packet fragment
cpsw: Hook up default ndo_change_mtu.
net: qmi_wwan: fix build error due to cdc-wdm dependecy
netdev: driver: ethernet: Add TI CPSW driver
netdev: driver: ethernet: add cpsw address lookup engine support
phy: add am79c874 PHY support
mlx4_core: fix race on comm channel
bonding: send igmp report for its master
fs_enet: Add MPC5125 FEC support and PHY interface selection
net: bpf_jit: fix BPF_S_LDX_B_MSH compilation
net: update the usage of CHECKSUM_UNNECESSARY
fcoe: use CHECKSUM_UNNECESSARY instead of CHECKSUM_PARTIAL on tx
net: do not do gso for CHECKSUM_UNNECESSARY in netif_needs_gso
ixgbe: Fix issues with SR-IOV loopback when flow control is disabled
net/hyperv: Fix the code handling tx busy
ixgbe: fix namespace issues when FCoE/DCB is not enabled
rtlwifi: Remove unused ETH_ADDR_LEN defines
igbvf: Use ETH_ALEN
Fix up fairly trivial conflicts in drivers/isdn/gigaset/interface.c and
drivers/net/usb/{Kconfig,qmi_wwan.c} as per David.
Let us port the code to use tty_port. We now use open_count and tty
from there. This allows us also to use tty_port_tty_set with tty
refcounting instead of hand-written locking and logic.
Note that tty and open_count are no longer protected by cs->lock. It is
protected by tty_port->lock. But since all the places where they were
used are now switched to the helpers, we are fine.
Cc: <gigaset307x-common@lists.sourceforge.net>
Close the window in open where driver_data is reset to NULL on each
open. It could cause other processes to get invalid retval from the
tty->ops operations because of the checks all over the code.
With this change we may do other cleanups. Now, the only valid check
for tty->driver_data != NULL is in close. This can happen only if open
fails at gigaset_get_cs_by_tty or try_module_get. The rest of checks
in various tty->ops->* are invalid as driver_data cannot be NULL
there. The same holds for cs->open_count. So remove them.
Cc: gigaset307x-common@lists.sourceforge.net
Checking if tty->index is in bounds is not needed. The tty has the
index set in the initial open. This is done in get_tty_driver. And it
can be only in interval <0,driver->num).
So remove the tests which check exactly this interval. Some are
left untouched as they check against the current backing device count.
(Leaving apart that the check is racy in most of the cases.)
All num, magic and owner are set by alloc_tty_driver. No need to
re-set them on each allocation site.
pti driver sets something different to what it passes to
alloc_tty_driver. It is not a bug, since we don't use the lines
parameter in any way. Anyway this is fixed, and now we do the right
thing.
Commas are not generally used at locations where
statement termination semicolons are used.
Realign each field set at appropriate indentation.
isdn source code uses a not-current coding style.
Update the coding style used on a per-line basis
so that git diff -w shows only elided blank lines
at EOF.
Done with emacs and some scripts and some typing.
Built x86 allyesconfig.
No detected change in objdump -d or size.
Move the "ISDN4Linux interface" message from device registration,
where it is emitted for each device, to driver registration, where
it is emitted only once, for consistency with the CAPI variant.
In preparation of the module.h usage cleanup, call out the header
that we need to get EXPORT_SYMBOL variants and THIS_MODULE into scope.
So that we don't get build failures once the implicit module.h
presence is terminated.
This allows us to move duplicated code in <asm/atomic.h>
(atomic_inc_not_zero() for now) to <linux/atomic.h>
Signed-off-by: Arun Sharma <asharma@fb.com>
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
if_open() calls try_module_get(), and after an attempt to lock a mutex
the if_open() function may return -ERESTARTSYS without
putting the module. Then, when if_open() is executed again,
try_module_get() is called making the reference counter of THIS_MODULE
greater than one at successful exit from if_open(). The if_close()
function puts the module only once, and as a result it can't be
unloaded.
This patch adds module_put call before the return from if_open().
Found by Linux Driver Verification project (linuxtesting.org).
Signed-off-by: Pavel Shved <shved@ispras.ru>
Signed-off-by: David S. Miller <davem@conan.davemloft.net>
This reverts commit b1c43f82c5aa265442f82dba31ce985ebb7aa71c.
It was broken in so many ways, and results in random odd pty issues.
It re-introduced the buggy schedule_work() in flush_to_ldisc() that can
cause endless work-loops (see commit a5660b41af6a: "tty: fix endless
work loop when the buffer fills up").
It also used an "unsigned int" return value fo the ->receive_buf()
function, but then made multiple functions return a negative error code,
and didn't actually check for the error in the caller.
And it didn't actually work at all. BenH bisected down odd tty behavior
to it:
"It looks like the patch is causing some major malfunctions of the X
server for me, possibly related to PTYs. For example, cat'ing a
large file in a gnome terminal hangs the kernel for -minutes- in a
loop of what looks like flush_to_ldisc/workqueue code, (some ftrace
data in the quoted bits further down).
Some more data: It -looks- like what happens is that the
flush_to_ldisc work queue entry constantly re-queues itself (because
the PTY is full ?) and the workqueue thread will basically loop
forver calling it without ever scheduling, thus starving the consumer
process that could have emptied the PTY."
which is pretty much exactly the problem we fixed in a5660b41af6a.
Milton Miller pointed out the 'unsigned int' issue.
Reported-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Reported-by: Milton Miller <miltonm@bga.com>
Cc: Stefan Bigler <stefan.bigler@keymile.com>
Cc: Toby Gray <toby.gray@realvnc.com>
Cc: Felipe Balbi <balbi@ti.com>
Cc: Greg Kroah-Hartman <gregkh@suse.de>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6
* 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (48 commits)
serial: 8250_pci: add support for Cronyx Omega PCI multiserial board.
tty/serial: Fix break handling for PORT_TEGRA
tty/serial: Add explicit PORT_TEGRA type
n_tracerouter and n_tracesink ldisc additions.
Intel PTI implementaiton of MIPI 1149.7.
Kernel documentation for the PTI feature.
export kernel call get_task_comm().
tty: Remove to support serial for S5P6442
pch_phub: Support new device ML7223
8250_pci: Add support for the Digi/IBM PCIe 2-port Adapter
ASoC: Update cx20442 for TTY API change
pch_uart: Support new device ML7223 IOH
parport: Use request_muxed_region for IT87 probe and lock
tty/serial: add support for Xilinx PS UART
n_gsm: Use print_hex_dump_bytes
drivers/tty/moxa.c: Put correct tty value
TTY: tty_io, annotate locking functions
TTY: serial_core, remove superfluous set_task_state
TTY: serial_core, remove invalid test
Char: moxa, fix locking in moxa_write
Fix up trivial conflicts in drivers/bluetooth/hci_ldisc.c and
drivers/tty/serial/Makefile.
I did the hci_ldisc thing as an evil merge, cleaning things up.
it makes it simpler to keep track of the amount of
bytes received and simplifies how flush_to_ldisc counts
the remaining bytes. It also fixes a bug of lost bytes
on n_tty when flushing too many bytes via the USB
serial gadget driver.
Tested-by: Stefan Bigler <stefan.bigler@keymile.com>
Tested-by: Toby Gray <toby.gray@realvnc.com>
Signed-off-by: Felipe Balbi <balbi@ti.com>
The variable 'offset' is set but unused in
write_iso_tasklet(). Just kill it off.
Only oddities here are a couple of drivers that bogusly called the ldisc
helpers instead of returning -ENOIOCTLCMD. Fix the bug and the rest goes
away.
Doing tiocmget was such fun we should do tiocmset as well for the same
reasons
We don't actually need this and it causes problems for internal use of
this functionality. Currently there is a single use of the FILE * pointer.
That is the serial core which uses it to check tty_hung_up_p. However if
that is true then IO_ERROR is also already set so the check may be removed.
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits)
Documentation/trace/events.txt: Remove obsolete sched_signal_send.
writeback: fix global_dirty_limits comment runtime -> real-time
ppc: fix comment typo singal -> signal
drivers: fix comment typo diable -> disable.
m68k: fix comment typo diable -> disable.
wireless: comment typo fix diable -> disable.
media: comment typo fix diable -> disable.
remove doc for obsolete dynamic-printk kernel-parameter
remove extraneous 'is' from Documentation/iostats.txt
Fix spelling milisec -> ms in snd_ps3 module parameter description
Fix spelling mistakes in comments
Revert conflicting V4L changes
i7core_edac: fix typos in comments
mm/rmap.c: fix comment
sound, ca0106: Fix assignment to 'channel'.
hrtimer: fix a typo in comment
init/Kconfig: fix typo
anon_inodes: fix wrong function name in comment
fix comment typos concerning "consistent"
poll: fix a typo in comment
Fix up trivial conflicts in:
- drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c)
- fs/ext4/ext4.h
Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
In drivers/isdn/gigaset/capi.c::do_disconnect_req() we will leak the
memory allocated (with kmalloc) to 'b3cmsg' if the call to alloc_skb()
fails.
b3cmsg = kmalloc(sizeof(*b3cmsg), GFP_KERNEL);
allocation here ------^
if (!b3cmsg) {
dev_err(cs->dev, "%s: out of memory\n", __func__);
send_conf(iif, ap, skb, CAPI_MSGOSRESOURCEERR);
return;
capi_cmsg_header(b3cmsg, ap->id, CAPI_DISCONNECT_B3, CAPI_IND,
ap->nextMessageNumber++,
cmsg->adr.adrPLCI | (1 << 16));
b3cmsg->Reason_B3 = CapiProtocolErrorLayer1;
b3skb = alloc_skb(CAPI_DISCONNECT_B3_IND_BASELEN, GFP_KERNEL);
if (b3skb == NULL) {
return;
leak here ------^
This leak is easily fixed by just kfree()'ing the memory allocated to
'b3cmsg' right before we return. The following patch does that.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
"gadget", "through", "command", "maintain", "maintain", "controller", "address",
"between", "initiali[zs]e", "instead", "function", "select", "already",
"equal", "access", "management", "hierarchy", "registration", "interest",
"relative", "memory", "offset", "already",
Rephrase some USB error messages to make them clearer and more consistent.
Downgrade some warning messages that may occur during normal operation to
debug messages.
Rework the handling of USB errors in interrupt input reads
to clear halts correctly, delay URB resubmission after errors,
limit retries, and improve error recovery.
Recover from a lost HD_RECEIVEATDATA_ACK message by sending a
zero-length HD_READ_ATMESSAGE command when ev_layer sends "+++".
In error_reset(), if sending HD_RESET_INTERRUPT_PIPE to the device
fails, try performing an USB reset.
Also correct an error in the leading comment.
Use setup_timer() and mod_timer() instead of direct assignment to
timer structure members, simplify the argument of one timer routine,
and make extra sure all timers are stopped during suspend.
Remove the debug flag DEBUG_DRIVER and associated code.
It doesn't serve any useful purpose anymore.
In transparent data reception, avoid a NULL pointer dereference
in case an skbuff cannot be allocated, remove an inappropriate
call to the HDLC flush routine, and correct the accounting of
received bytes for continued buffers.
Rework the handling of USB errors in AT response reads
to fix a possible infinite retry loop and a memory leak,
and silence a few overly verbose kernel messages.
Unlock cs->lock before calling error_hangup() which is marked
"cs->lock must not be held".
I moved the kfree(cb) below the dereferences.
We should unlock here. This is the only place where we return from the
function with the lock held. The caller isn't expecting it.
