path: root/drivers/isdn/hardware/eicon/divasproc.c
2013-04-09procfs: new helper - PDE_DATA(inode)Al Viro
The only part of proc_dir_entry the code outside of fs/proc really cares about is PDE(inode)->data. Provide a helper for that; static inline for now, eventually will be moved to fs/proc, along with the knowledge of struct proc_dir_entry layout. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-02-22new helper: file_inode(file)Al Viro
2012-02-21isdn: whitespace coding style cleanupJoe Perches
isdn source code uses a not-current coding style. Update the coding style used on a per-line basis so that git diff -w shows only elided blank lines at EOF. Done with emacs and some scripts and some typing. Built x86 allyesconfig. No detected change in objdump -d or size. Signed-off-by: Joe Perches <joe@perches.com>
2010-01-14proc_fops: convert drivers/isdn/ to seq_fileAlexey Dobriyan
Convert code away from ->read_proc/->write_proc interfaces. Switch to proc_create()/proc_create_data() which make addition of proc entries reliable wrt NULL ->proc_fops, NULL ->data and so on. Problem with ->read_proc et al is described here commit 786d7e1612f0b0adb6046f19b906609e4fe8b1ba "Fix rmmod/read/write races in /proc entries" [akpm@linux-foundation.org: CONFIG_PROC_FS=n build fix] Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: Karsten Keil <keil@b1-systems.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-10isdn divas: fix proc creationAlexey Dobriyan
1. creating proc entry and not saving pointer to PDE and checking it is not going to work. 2. if proc entry wasn't created, no reason to remove it on error path. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-29isdn: use non-racy method for proc entries creationDenis V. Lunev
Use proc_create()/proc_create_data() to make sure that ->proc_fops and ->data be setup before gluing PDE to main tree. Add correct ->owner to proc_fops to fix reading/module unloading race. Signed-off-by: Denis V. Lunev <den@openvz.org> Acked-by: Karsten Keil <kkeil@suse.de> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] mark struct file_operations const 3Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2005-09-29[PATCH] proc_mkdir() should be used to create procfs directoriesAl Viro
A bunch of create_proc_dir_entry() calls creating directories had crept in since the last sweep; converted to proc_mkdir(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
