drivers/net/wireless/iwlwifi/iwl-agn-rxon.c
drivers/net/wireless/rtlwifi/pci.c
net/netfilter/ipvs/ip_vs_core.c
We leak the memory allocated to 'phi' when the variable goes out of scope
in hfcsusb_ph_info().
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
* remove interrupt.g inclusion from netdevice.h -- not needed
* fixup fallout, add interrupt.h and hardirq.h back where needed.
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6
* 'trivial' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6:
gfs2: Drop __TIME__ usage
isdn/diva: Drop __TIME__ usage
atm: Drop __TIME__ usage
dlm: Drop __TIME__ usage
wan/pc300: Drop __TIME__ usage
parport: Drop __TIME__ usage
hdlcdrv: Drop __TIME__ usage
baycom: Drop __TIME__ usage
pmcraid: Drop __DATE__ usage
edac: Drop __DATE__ usage
rio: Drop __DATE__ usage
scsi/wd33c93: Drop __TIME__ usage
scsi/in2000: Drop __TIME__ usage
aacraid: Drop __TIME__ usage
media/cx231xx: Drop __TIME__ usage
media/radio-maxiradio: Drop __TIME__ usage
nozomi: Drop __TIME__ usage
cyclades: Drop __TIME__ usage
The kernel already prints its build timestamp during boot, no need to
repeat it in random drivers and produce different object files each
time.
Cc: Armin Schindler <mac@melware.de>
Cc: netdev@vger.kernel.org
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (89 commits)
bonding: documentation and code cleanup for resend_igmp
bonding: prevent deadlock on slave store with alb mode (v3)
net: hold rtnl again in dump callbacks
Add Fujitsu 1000base-SX PCI ID to tg3
bnx2x: protect sequence increment with mutex
sch_sfq: fix peek() implementation
isdn: netjet - blacklist Digium TDM400P
via-velocity: don't annotate MAC registers as packed
xen: netfront: hold RTNL when updating features.
sctp: fix memory leak of the ASCONF queue when free asoc
net: make dev_disable_lro use physical device if passed a vlan dev (v2)
net: move is_vlan_dev into public header file (v2)
bug.h: Fix build with CONFIG_PRINTK disabled.
wireless: fix fatal kernel-doc error + warning in mac80211.h
wireless: fix cfg80211.h new kernel-doc warnings
iwlagn: dbg_fixed_rate only used when CONFIG_MAC80211_DEBUGFS enabled
dst: catch uninitialized metrics
be2net: hash key for rss-config cmd not set
bridge: initialize fake_rtable metrics
net: fix __dst_destroy_metrics_generic()
Fix up trivial conflicts in drivers/staging/brcm80211/brcmfmac/wl_cfg80211.c
[2nd try ... 1st attempt didn't make it to netdev mailing list]
A quick google search reveals that people with this card are blacklisting it
in the initramfs and in the module blacklist based on a statement that it
is unsupported. Since the older Digium is also unsupported I'm pretty
confident that this newer card is also not supported.
lspci -xxx -vv shows
04:07.0 Communication controller: Tiger Jet Network Inc. Tiger3XX Modem/ISDN interface
Subsystem: Device b100:0003
P.
----8<----
The Asterisk Voice Card, DIGIUM TDM400P is unsupported by the netjet driver.
Blacklist it like the Digium X100P/X101P card.
Signed-off-by: Prarit Bhargava <prarit@redhat.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6:
pcmcia: Make struct pcmcia_device_id const, sound drivers edition
staging: pcmcia: Convert pcmcia_device_id declarations to const
pcmcia: Make declaration and uses of struct pcmcia_device_id const
pcmcia/sa1100: put sa11x0_pcmcia_hw_init[] to .devinit.data
Saves about 50KB of data.
Old/new size of all objects:
563015 80096 130684 773795 bcea3 (TOTALS)
610916 32256 130632 773804 bceac (TOTALS)
Acked-by: Kurt Van Dijck <kurt.van.dijck@eia.be> (for drivers/net/can/softing/softing_cs.c)
Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
The variable 'buf' is set but unused in
ctrl_complete(). Just kill it off.
Similarly for the variable 'err' in setup_hfcsusb().
The variable 'total' is set but unused in
hfcpci_empty_bfifo(). Just kill it off.
Similarly for the variable 'val' in ph_state_nt().
The variable 'best_id' is set but unused in
diva_mnt_add_xdi_adapter(). Just kill it off.
Similarly for the variable 'CIP' in connect_req(), 'Number' in
sig_ind(), 'Info' in dtmf_confirmation() mixer_command()
fax_connect_ack_command() fax_edata_ack_command()
rtp_connect_b3_res_command() and rtp_connect_b3_res_command(), and 'a'
in mixer_indication_coefs_set(),
The below patch changes a typo "pice" to "piece"
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits)
Documentation/trace/events.txt: Remove obsolete sched_signal_send.
writeback: fix global_dirty_limits comment runtime -> real-time
ppc: fix comment typo singal -> signal
drivers: fix comment typo diable -> disable.
m68k: fix comment typo diable -> disable.
wireless: comment typo fix diable -> disable.
media: comment typo fix diable -> disable.
remove doc for obsolete dynamic-printk kernel-parameter
remove extraneous 'is' from Documentation/iostats.txt
Fix spelling milisec -> ms in snd_ps3 module parameter description
Fix spelling mistakes in comments
Revert conflicting V4L changes
i7core_edac: fix typos in comments
mm/rmap.c: fix comment
sound, ca0106: Fix assignment to 'channel'.
hrtimer: fix a typo in comment
init/Kconfig: fix typo
anon_inodes: fix wrong function name in comment
fix comment typos concerning "consistent"
poll: fix a typo in comment
Fix up trivial conflicts in:
- drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c)
- fs/ext4/ext4.h
Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
"gadget", "through", "command", "maintain", "maintain", "controller", "address",
"between", "initiali[zs]e", "instead", "function", "select", "already",
"equal", "access", "management", "hierarchy", "registration", "interest",
"relative", "memory", "offset", "already",
Delete successive assignments to the same location. In the first case, the
hscx array has two elements, so change the assignment to initialize the
second one. In the second case, the two assignments are simply identical.
Furthermore, neither is necessary, because the effect of the assignment is
only visible in the next line, in the assignment in the if test. The patch
inlines the right hand side value in the latter assignment and pulls that
assignment out of the if test.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
expression i;
*i = ...;
i = ...;
// </smpl>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1699 commits)
bnx2/bnx2x: Unsupported Ethtool operations should return -EINVAL.
vlan: Calling vlan_hwaccel_do_receive() is always valid.
tproxy: use the interface primary IP address as a default value for --on-ip
tproxy: added IPv6 support to the socket match
cxgb3: function namespace cleanup
tproxy: added IPv6 support to the TPROXY target
tproxy: added IPv6 socket lookup function to nf_tproxy_core
be2net: Changes to use only priority codes allowed by f/w
tproxy: allow non-local binds of IPv6 sockets if IP_TRANSPARENT is enabled
tproxy: added tproxy sockopt interface in the IPV6 layer
tproxy: added udp6_lib_lookup function
tproxy: added const specifiers to udp lookup functions
tproxy: split off ipv6 defragmentation to a separate module
l2tp: small cleanup
nf_nat: restrict ICMP translation for embedded header
can: mcp251x: fix generation of error frames
can: mcp251x: fix endless loop in interrupt handler if CANINTF_MERRF is set
can-raw: add msg_flags to distinguish local traffic
9p: client code cleanup
rds: make local functions/variables static
Fix up conflicts in net/core/dev.c, drivers/net/pcmcia/smc91c92_cs.c and
drivers/net/wireless/ath/ath9k/debug.c as per David
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq:
workqueue: remove in_workqueue_context()
workqueue: Clarify that schedule_on_each_cpu is synchronous
memory_hotplug: drop spurious calls to flush_scheduled_work()
shpchp: update workqueue usage
pciehp: update workqueue usage
isdn/eicon: don't call flush_scheduled_work() from diva_os_remove_soft_isr()
workqueue: add and use WQ_MEM_RECLAIM flag
workqueue: fix HIGHPRI handling in keep_working()
workqueue: add queue_work and activate_work trace points
workqueue: prepare for more tracepoints
workqueue: implement flush[_delayed]_work_sync()
workqueue: factor out start_flush_work()
workqueue: cleanup flush/cancel functions
workqueue: implement alloc_ordered_workqueue()
Fix up trivial conflict in fs/gfs2/main.c as per Tejun
diva doesn't use workqueue and there is no reason to flush the system
workqueue from diva_os_remove_soft_isr(). Remove it.
This is to prepare for the deprecation and removal of
flush_scheduled_work().
Acked-by: Armin Schindler <armin@melware.de>
In diva_mnt_add_xdi_adapter() we do this:
strcpy (clients[id].drvName, tmp);
strcpy (clients[id].Dbg.drvName, tmp);
The "clients[id].drvName" is a 128 character buffer and
"clients[id].Dbg.drvName" was originally a 16 character buffer but I've
changed it to 128 as well. We don't actually use 128 characters but we
do use more than 16.
I've also changed the size of "tmp" to 128 characters instead of 256.
What's worse than no comment? A wrong comment.
Several PCMCIA device drivers contained the same comments, which
were based on how the PCMCIA subsystem worked in the old days of 2.4.,
and which were originally part of a "dummy_cs" driver. These comments
no longer matched at all what is happening now, and therefore should
be removed.
Tested-by: Wolfram Sang <w.sang@pengutronix.de>
When CONF_AUTO_SET_IO or CONF_AUTO_SET_IOMEM are set, the corresponding
fields in struct pcmcia_device *p_dev->resource[0,1,2] are set
accordinly. Drivers wishing to override certain settings may do so in
the callback function, but they no longer need to parse the CIS entries
stored in cistpl_cftable_entry_t themselves.
CC: netdev@vger.kernel.org
CC: linux-wireless@vger.kernel.org
CC: linux-ide@vger.kernel.org
CC: linux-usb@vger.kernel.org
CC: laforge@gnumonks.org
CC: linux-mtd@lists.infradead.org
CC: linux-bluetooth@vger.kernel.org
CC: alsa-devel@alsa-project.org
CC: linux-serial@vger.kernel.org
CC: Jiri Kosina <jkosina@suse.cz>
CC: linux-scsi@vger.kernel.org
Introduce an autoconfiguration feature to set certain values in
pcmcia_loop_config(), instead of copying the same code over and over
in each PCMCIA driver. At first, introduce the following options:
CONF_AUTO_CHECK_VCC check or matching Vcc entry
CONF_AUTO_SET_VPP set Vpp
CONF_AUTO_AUDIO enable the speaker line
Acked-by: Gustavo F. Padovan <padovan@profusion.mobi> (for drivers/bluetooth)
pcmcia_enable_device() now replaces pcmcia_request_configuration().
Instead of config_req_t, all necessary flags are either passed as
a parameter to pcmcia_enable_device(), or (in rare circumstances)
set in struct pcmcia_device -> flags.
With the last remaining user of include/pcmcia/cs.h gone, remove
all references.
Several drivers prefer to explicitly set config_{base,index,regs},
formerly known as ConfigBase, ConfigIndex and Present. Instead of
passing these values inside config_req_t, store it in struct
pcmcia_device.
IntType was only set to INT_MEMORY (driver pcmciamtd) or INT_MEMORY_AND_IO
(all other drivers). As this flags seems to relate to ioport access, make
it conditional to the driver having requested IO port access. There are two
drivers which do not request IO ports, but did set INT_MEMORY_AND_IO:
ray_cs and b43. For those, we consistently only set INT_MEMORY in future.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (27 commits)
netfilter: fix CONFIG_COMPAT support
isdn/avm: fix build when PCMCIA is not enabled
header: fix broken headers for user space
e1000e: don't check for alternate MAC addr on parts that don't support it
e1000e: disable ASPM L1 on 82573
ll_temac: Fix poll implementation
netxen: fix a race in netxen_nic_get_stats()
qlnic: fix a race in qlcnic_get_stats()
irda: fix a race in irlan_eth_xmit()
net: sh_eth: remove unused variable
netxen: update version 4.0.74
netxen: fix inconsistent lock state
vlan: Match underlying dev carrier on vlan add
ibmveth: Fix opps during MTU change on an active device
ehea: Fix synchronization between HW and SW send queue
bnx2x: Update bnx2x version to 1.52.53-4
bnx2x: Fix PHY locking problem
rds: fix a leak of kernel memory
netlink: fix compat recvmsg
netfilter: fix userspace header warning
include/linux/if_pppox.h
Fix conflict between Changli's __packed header file fixes and
the new PPTP driver.
Why wouldn't kconfig symbol ISDN_DRV_AVMB1_B1PCMCIA also depend on
PCMCIA?
Fix build for PCMCIA not enabled:
ERROR: "b1_free_card" [drivers/isdn/hardware/avm/b1pcmcia.ko] undefined!
ERROR: "b1ctl_proc_fops" [drivers/isdn/hardware/avm/b1pcmcia.ko] undefined!
ERROR: "b1_reset_ctr" [drivers/isdn/hardware/avm/b1pcmcia.ko] undefined!
ERROR: "b1_load_firmware" [drivers/isdn/hardware/avm/b1pcmcia.ko] undefined!
ERROR: "b1_send_message" [drivers/isdn/hardware/avm/b1pcmcia.ko] undefined!
ERROR: "b1_release_appl" [drivers/isdn/hardware/avm/b1pcmcia.ko] undefined!
ERROR: "b1_register_appl" [drivers/isdn/hardware/avm/b1pcmcia.ko] undefined!
ERROR: "b1_getrevision" [drivers/isdn/hardware/avm/b1pcmcia.ko] undefined!
ERROR: "b1_detect" [drivers/isdn/hardware/avm/b1pcmcia.ko] undefined!
ERROR: "b1_interrupt" [drivers/isdn/hardware/avm/b1pcmcia.ko] undefined!
ERROR: "b1_alloc_card" [drivers/isdn/hardware/avm/b1pcmcia.ko] undefined!
Cc: Carsten Paeth <calle@calle.de>
Cc: Karsten Keil <isdn@linux-pingi.de>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (30 commits)
ctcm: rename READ/WRITE defines to avoid redefinitions
claw: rename READ/WRITE defines to avoid redefinitions
phylib: available for any speed ethernet
can: add limit for nframes and clean up signed/unsigned variables
pkt_sched: Check .walk and .leaf class handlers
pkt_sched: Fix sch_sfq vs tc_modify_qdisc oops
caif-spi: Bugfix SPI_DATA_POS settings were inverted.
caif: Bugfix - Increase default headroom size for control channel.
net: make netpoll_rx return bool for !CONFIG_NETPOLL
Bluetooth: Use 3-DH5 payload size for default ERTM max PDU size
Bluetooth: Fix incorrect setting of remote_tx_win for L2CAP ERTM
Bluetooth: Change default L2CAP ERTM retransmit timeout
Bluetooth: Fix endianness issue with L2CAP MPS configuration
net: Use NET_XMIT_SUCCESS where possible.
isdn: mISDN: call pci_disable_device() if pci_probe() failed
isdn: avm: call pci_disable_device() if pci_probe() failed
usbnet: rx_submit() should return an error code.
pkt_sched: Add some basic qdisc class ops verification. Was: [PATCH] sfq: add dummy bind/unbind handles
pkt_sched: sch_sfq: Add dummy unbind_tcf and put handles. Was: [PATCH] sfq: add dummy bind/unbind handles
Driver should call pci_disable_device() if it returns from pci_probe()
with error.
Signed-off-by: Kulikov Vasiliy <segooon@gmail.com>
with error.
with error.
pcmcia: avoid buffer overflow in pcmcia_setup_isa_irq
pcmcia: do not request windows if you don't need to
pcmcia: insert PCMCIA device resources into resource tree
pcmcia: export resource information to sysfs
pcmcia: use struct resource for PCMCIA devices, part 2
pcmcia: remove memreq_t
pcmcia: move local definitions out of include/pcmcia/cs.h
pcmcia: do not use io_req_t when calling pcmcia_request_io()
pcmcia: do not use io_req_t after call to pcmcia_request_io()
pcmcia: clean up cs.h
pcmcia: use pcmica_{read,write}_config_byte
pcmcia: remove cs_types.h
pcmcia: remove unused flag, simplify headers
pcmcia: remove obsolete CS_EVENT_ definitions
pcmcia: split up central event handler
pcmcia: simplify event callback
pcmcia: remove obsolete ioctl
Conflicts in:
- drivers/staging/comedi/drivers/*
- drivers/staging/wlags49_h2/wl_cs.c
due to dev_info_t and whitespace changes
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (48 commits)
Documentation: update broken web addresses.
fix comment typo "choosed" -> "chosen"
hostap:hostap_hw.c Fix typo in comment
Fix spelling contorller -> controller in comments
Kconfig.debug: FAIL_IO_TIMEOUT: typo Faul -> Fault
fs/Kconfig: Fix typo Userpace -> Userspace
Removing dead MACH_U300_BS26
drivers/infiniband: Remove unnecessary casts of private_data
fs/ocfs2: Remove unnecessary casts of private_data
libfc: use ARRAY_SIZE
scsi: bfa: use ARRAY_SIZE
drm: i915: use ARRAY_SIZE
drm: drm_edid: use ARRAY_SIZE
synclink: use ARRAY_SIZE
block: cciss: use ARRAY_SIZE
comment typo fixes: charater => character
fix comment typos concerning "challenge"
arm: plat-spear: fix typo in kerneldoc
reiserfs: typo comment fix
update email address
Instead of io_req_t, drivers are now requested to fill out
struct pcmcia_device *p_dev->resource[0,1] for up to two ioport
ranges. After a call to pcmcia_request_io(), the ports found there
are reserved, after calling pcmcia_request_configuration(), they may
be used.
CC: Michael Buesch <mb@bu3sch.de>
Acked-by: Marcel Holtmann <marcel@holtmann.org> (for drivers/bluetooth/)
After pcmcia_request_io(), do not make use of the values stored in
io_req_t, but instead use those found in struct pcmcia_device->resource[].
Remove cs_types.h which is no longer needed: Most definitions aren't
used at all, a few can be made away with, and two remaining definitions
(typedefs, unfortunatley) may be moved to more specific places.
This patch converts pci_table entries, where .subvendor=PCI_ANY_ID and
.subdevice=PCI_ANY_ID, .class=0 and .class_mask=0, to use the
PCI_VDEVICE macro, and thus improves readability.
Signed-off-by: Peter Huewe <peterhuewe@gmx.de>
is used)
is used)
All these files use the big kernel lock in a trivial
way to serialize their private file operations,
typically resulting from an earlier semi-automatic
pushdown from VFS.
None of these drivers appears to want to lock against
other code, and they all use the BKL as the top-level
lock in their file operations, meaning that there
is no lock-order inversion problem.
Consequently, we can remove the BKL completely,
replacing it with a per-file mutex in every case.
Using a scripted approach means we can avoid
typos.
file=$1
name=$2
if grep -q lock_kernel ${file} ; then
if grep -q 'include.*linux.mutex.h' ${file} ; then
sed -i '/include.*<linux\/smp_lock.h>/d' ${file}
else
sed -i 's/include.*<linux\/smp_lock.h>.*$/include <linux\/mutex.h>/g' ${file}
fi
sed -i ${file} \
-e "/^#include.*linux.mutex.h/,$ {
1,/^\(static\|int\|long\)/ {
/^\(static\|int\|long\)/istatic DEFINE_MUTEX(${name}_mutex);
-e "s/\(un\)*lock_kernel\>[ ]*()/mutex_\1lock(\&${name}_mutex)/g" \
-e '/[ ]*cycle_kernel_lock();/d'
else
sed -i -e '/include.*\<smp_lock.h\>/d' ${file} \
-e '/cycle_kernel_lock()/d'
fi
The function inittiger is only called from nj_init_card, where a lock is held.
The semantic patch that makes this change is as follows:
// <smpl>
@gfp exists@
identifier fn;
position p;
fn(...) {
... when != spin_unlock_irqrestore
when any
GFP_KERNEL@p
... when any
@locked@
identifier gfp.fn;
spin_lock_irqsave(...)
fn(...)
@depends on locked@
position gfp.p;
- GFP_KERNEL@p
+ GFP_ATOMIC
// </smpl>
Add a spin_unlock missing on the error path. The return value of write_reg
seems to be completely ignored, so it seems that the lock should be
released in every case.
The semantic match that finds this problem is as follows:
// <smpl>
expression E1;
* spin_lock(E1,...);
<+... when != E1
if (...) {
... when != E1
* return ...;
* spin_unlock(E1,...);
// </smpl>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (44 commits)
vlynq: make whole Kconfig-menu dependant on architecture
add descriptive comment for TIF_MEMDIE task flag declaration.
EEPROM: max6875: Header file cleanup
EEPROM: 93cx6: Header file cleanup
EEPROM: Header file cleanup
agp: use NULL instead of 0 when pointer is needed
rtc-v3020: make bitfield unsigned
PCI: make bitfield unsigned
jbd2: use NULL instead of 0 when pointer is needed
cciss: fix shadows sparse warning
doc: inode uses a mutex instead of a semaphore.
uml: i386: Avoid redefinition of NR_syscalls
fix "seperate" typos in comments
cocbalt_lcdfb: correct sections
doc: Change urls for sparse
Powerpc: wii: Fix typo in comment
i2o: cleanup some exit paths
Documentation/: it's -> its where appropriate
UML: Fix compiler warning due to missing task_struct declaration
UML: add kernel.h include to signal.c
