path: root/drivers/isdn
2014-04-14isdnloop: several buffer overflowsDan Carpenter
[ Upstream commit 7563487cbf865284dcd35e9ef5a95380da046737 ] There are three buffer overflows addressed in this patch. 1) In isdnloop_fake_err() we add an 'E' to a 60 character string and then copy it into a 60 character buffer. I have made the destination buffer 64 characters and I'm changed the sprintf() to a snprintf(). 2) In isdnloop_parse_cmd(), p points to a 6 characters into a 60 character buffer so we have 54 characters. The ->eazlist[] is 11 characters long. I have modified the code to return if the source buffer is too long. 3) In isdnloop_command() the cbuf[] array was 60 characters long but the max length of the string then can be up to 79 characters. I made the cbuf array 80 characters long and changed the sprintf() to snprintf(). I also removed the temporary "dial" buffer and changed it to use "p" directly. Unfortunately, we pass the "cbuf" string from isdnloop_command() to isdnloop_writecmd() which truncates anything over 60 characters to make it fit in card->omsg[]. (It can accept values up to 255 characters so long as there is a '\n' character every 60 characters). For now I have just fixed the memory corruption bug and left the other problems in this driver alone. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-14isdnloop: Validate NUL-terminated strings from user.YOSHIFUJI Hideaki
[ Upstream commit 77bc6bed7121936bb2e019a8c336075f4c8eef62 ] Return -EINVAL unless all of user-given strings are correctly NUL-terminated. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-18isdn/capi: Make Middleware depend on CAPI2.0Paul Bolle
The Kconfig symbol ISDN_CAPI_MIDDLEWARE is only used in capi.c. Setting it without setting ISDN_CAPI_CAPI20 is therefor useless. Make it depend on ISDN_CAPI_CAPI20 and put its entry after ISDN_CAPI_CAPI20's entry. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-06isdn/hisax: hex vs decimal typo in prfeatureind()Dan Carpenter
This is a static checker fix, but judging from the context then I think hexidecimal 0x80 is intended here instead of decimal 80. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: 1) BPF debugger and asm tool by Daniel Borkmann. 2) Speed up create/bind in AF_PACKET, also from Daniel Borkmann. 3) Correct reciprocal_divide and update users, from Hannes Frederic Sowa and Daniel Borkmann. 4) Currently we only have a "set" operation for the hw timestamp socket ioctl, add a "get" operation to match. From Ben Hutchings. 5) Add better trace events for debugging driver datapath problems, also from Ben Hutchings. 6) Implement auto corking in TCP, from Eric Dumazet. Basically, if we have a small send and a previous packet is already in the qdisc or device queue, defer until TX completion or we get more data. 7) Allow userspace to manage ipv6 temporary addresses, from Jiri Pirko. 8) Add a qdisc bypass option for AF_PACKET sockets, from Daniel Borkmann. 9) Share IP header compression code between Bluetooth and IEEE802154 layers, from Jukka Rissanen. 10) Fix ipv6 router reachability probing, from Jiri Benc. 11) Allow packets to be captured on macvtap devices, from Vlad Yasevich. 12) Support tunneling in GRO layer, from Jerry Chu. 13) Allow bonding to be configured fully using netlink, from Scott Feldman. 14) Allow AF_PACKET users to obtain the VLAN TPID, just like they can already get the TCI. From Atzm Watanabe. 15) New "Heavy Hitter" qdisc, from Terry Lam. 16) Significantly improve the IPSEC support in pktgen, from Fan Du. 17) Allow ipv4 tunnels to cache routes, just like sockets. From Tom Herbert. 18) Add Proportional Integral Enhanced packet scheduler, from Vijay Subramanian. 19) Allow openvswitch to mmap'd netlink, from Thomas Graf. 20) Key TCP metrics blobs also by source address, not just destination address. From Christoph Paasch. 21) Support 10G in generic phylib. From Andy Fleming. 22) Try to short-circuit GRO flow compares using device provided RX hash, if provided. From Tom Herbert. The wireless and netfilter folks have been busy little bees too. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (2064 commits) net/cxgb4: Fix referencing freed adapter ipv6: reallocate addrconf router for ipv6 address when lo device up fib_frontend: fix possible NULL pointer dereference rtnetlink: remove IFLA_BOND_SLAVE definition rtnetlink: remove check for fill_slave_info in rtnl_have_link_slave_info qlcnic: update version to 5.3.55 qlcnic: Enhance logic to calculate msix vectors. qlcnic: Refactor interrupt coalescing code for all adapters. qlcnic: Update poll controller code path qlcnic: Interrupt code cleanup qlcnic: Enhance Tx timeout debugging. qlcnic: Use bool for rx_mac_learn. bonding: fix u64 division rtnetlink: add missing IFLA_BOND_AD_INFO_UNSPEC sfc: Use the correct maximum TX DMA ring size for SFC9100 Add Shradha Shah as the sfc driver maintainer. net/vxlan: Share RX skb de-marking and checksum checks with ovs tulip: cleanup by using ARRAY_SIZE() ip_tunnel: clear IPCB in ip_tunnel_xmit() in case dst_link_failure() is called net/cxgb4: Don't retrieve stats during recovery ...
2014-01-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree updates from Jiri Kosina: "Usual rocket science stuff from trivial.git" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) neighbour.h: fix comment sched: Fix warning on make htmldocs caused by wait.h slab: struct kmem_cache is protected by slab_mutex doc: Fix typo in USB Gadget Documentation of/Kconfig: Spelling s/one/once/ mkregtable: Fix sscanf handling lp5523, lp8501: comment improvements thermal: rcar: comment spelling treewide: fix comments and printk msgs IXP4xx: remove '1 &&' from a condition check in ixp4xx_restart() Documentation: update /proc/uptime field description Documentation: Fix size parameter for snprintf arm: fix comment header and macro name asm-generic: uaccess: Spelling s/a ny/any/ mtd: onenand: fix comment header doc: driver-model/platform.txt: fix a typo drivers: fix typo in DEVTMPFS_MOUNT Kconfig help text doc: Fix typo (acces_process_vm -> access_process_vm) treewide: Fix typos in printk drivers/gpu/drm/qxl/Kconfig: reformat the help text ...
2014-01-18net: add build-time checks for msg->msg_name sizeSteffen Hurrle
This is a follow-up patch to f3d3342602f8bc ("net: rework recvmsg handler msg_name and msg_namelen logic"). DECLARE_SOCKADDR validates that the structure we use for writing the name information to is not larger than the buffer which is reserved for msg->msg_name (which is 128 bytes). Also use DECLARE_SOCKADDR consistently in sendmsg code paths. Signed-off-by: Steffen Hurrle <steffen@hurrle.net> Suggested-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-06Merge branch 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/qlogic/qlcnic/qlcnic_sriov_pf.c net/ipv6/ip6_tunnel.c net/ipv6/ip6_vti.c ipv6 tunnel statistic bug fixes conflicting with consolidation into generic sw per-cpu net stats. qlogic conflict between queue counting bug fix and the addition of multiple MAC address support. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-06isdn: Drop big endian cpp checks from telespci and hfc_pci driversGuenter Roeck
With arm:allmodconfig, building the Teles PCI driver fails with telespci.c:294:2: error: #error "not running on big endian machines now" Similar, building the driver for HFC PCI-Bus cards fails with hfc_pci.c:1647:2: error: #error "not running on big endian machines now" Remove the big endian cpp check from both drivers to fix the build errors. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-26isdn: slight optimization of addr comparedingtianhong
Use possibly more efficient ether_addr_equal instead of memcmp. Cc: Karsten Keil <isdn@linux-pingi.de> Cc: netdev@vger.kernel.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Yang Yingliang <yangyingliang@huawei.com> Signed-off-by: Ding Tianhong <dingtianhong@huawei.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-19treewide: Fix typos in printkMasanari Iida
Correct spelling typo in various part of kernel Signed-off-by: Masanari Iida <standby24x7@gmail.com> Acked-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-12-19Merge branch 'master' into for-nextJiri Kosina
Sync with Linus' tree to be able to apply fixes on top of newer things in tree (efi-stub). Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-12-18isdn: use strlcpy() instead strcpy()Dan Carpenter
I don't think the in-kernel drivers ever hit this strcpy() so this doesn't change how the code works. But strlcpy() is safer. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-02treewide: Fix typo in KconfigMasanari Iida
Correct spelling typo in Kconfig. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Acked-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-11-20net: rework recvmsg handler msg_name and msg_namelen logicHannes Frederic Sowa
This patch now always passes msg->msg_namelen as 0. recvmsg handlers must set msg_namelen to the proper size <= sizeof(struct sockaddr_storage) to return msg_name to the user. This prevents numerous uninitialized memory leaks we had in the recvmsg handlers and makes it harder for new code to accidentally leak uninitialized memory. Optimize for the case recvfrom is called with NULL as address. We don't need to copy the address at all, so set it to NULL before invoking the recvmsg handler. We can do so, because all the recvmsg handlers must cope with the case a plain read() is called on them. read() also sets msg_name to NULL. Also document these changes in include/linux/net.h as suggested by David Miller. Changes since RFC: Set msg->msg_name = NULL if user specified a NULL in msg_name but had a non-null msg_namelen in verify_iovec/verify_compat_iovec. This doesn't affect sendto as it would bail out earlier while trying to copy-in the address. It also more naturally reflects the logic by the callers of verify_iovec. With this change in place I could remove " if (!uaddr || msg_sys->msg_namelen == 0) msg->msg_name = NULL ". This change does not alter the user visible error logic as we ignore msg_namelen as long as msg_name is NULL. Also remove two unnecessary curly brackets in ___sys_recvmsg and change comments to netdev style. Cc: David Miller <davem@davemloft.net> Suggested-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-14isdnloop: use strlcpy() instead of strcpy()Dan Carpenter
These strings come from a copy_from_user() and there is no way to be sure they are NUL terminated. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-07isdn: icn: NULL dereference printing error messageDan Carpenter
"card2" is NULL here so I have changed it to use "id2" instead of "card2->interface.id". Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-10-17isdn: remove deprecated IRQF_DISABLEDMichael Opdenacker
This patch proposes to remove the use of the IRQF_DISABLED flag It's a NOOP since 2.6.35 and it will be removed one day. Signed-off-by: Michael Opdenacker <michael.opdenacker@free-electrons.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-10-02isdn: eicon: free pointer after using it in log msg in ↵Jesper Juhl
divas_um_idi_delete_entity() Not really a problem, but nice IMHO; the Coverity static analyzer complains that we use the pointer 'e' after it has been freed, so move the freeing below the final use, even if that use is just using the value of the pointer and not actually dereferencing it. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-15isdn: hfcpci_softirq: get func return to suppress compiler warningAntonio Alecrim Jr
Signed-off-by: Antonio Alecrim Jr <antonio.alecrim@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-13isdn: clean up debug format string usageKees Cook
Avoid unneeded local string buffers for constructing debug output. Also cleans up debug calls that contain a single parameter so that they cannot be accidentally parsed as format strings. Signed-off-by: Kees Cook <keescook@chromium.org> Cc: Karsten Keil <isdn@linux-pingi.de> Cc: David Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking changes from David Miller: "Noteworthy changes this time around: 1) Multicast rejoin support for team driver, from Jiri Pirko. 2) Centralize and simplify TCP RTT measurement handling in order to reduce the impact of bad RTO seeding from SYN/ACKs. Also, when both timestamps and local RTT measurements are available prefer the later because there are broken middleware devices which scramble the timestamp. From Yuchung Cheng. 3) Add TCP_NOTSENT_LOWAT socket option to limit the amount of kernel memory consumed to queue up unsend user data. From Eric Dumazet. 4) Add a "physical port ID" abstraction for network devices, from Jiri Pirko. 5) Add a "suppress" operation to influence fib_rules lookups, from Stefan Tomanek. 6) Add a networking development FAQ, from Paul Gortmaker. 7) Extend the information provided by tcp_probe and add ipv6 support, from Daniel Borkmann. 8) Use RCU locking more extensively in openvswitch data paths, from Pravin B Shelar. 9) Add SCTP support to openvswitch, from Joe Stringer. 10) Add EF10 chip support to SFC driver, from Ben Hutchings. 11) Add new SYNPROXY netfilter target, from Patrick McHardy. 12) Compute a rate approximation for sending in TCP sockets, and use this to more intelligently coalesce TSO frames. Furthermore, add a new packet scheduler which takes advantage of this estimate when available. From Eric Dumazet. 13) Allow AF_PACKET fanouts with random selection, from Daniel Borkmann. 14) Add ipv6 support to vxlan driver, from Cong Wang" Resolved conflicts as per discussion. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1218 commits) openvswitch: Fix alignment of struct sw_flow_key. netfilter: Fix build errors with xt_socket.c tcp: Add missing braces to do_tcp_setsockopt caif: Add missing braces to multiline if in cfctrl_linkup_request bnx2x: Add missing braces in bnx2x:bnx2x_link_initialize vxlan: Fix kernel panic on device delete. net: mvneta: implement ->ndo_do_ioctl() to support PHY ioctls net: mvneta: properly disable HW PHY polling and ensure adjust_link() works icplus: Use netif_running to determine device state ethernet/arc/arc_emac: Fix huge delays in large file copies tuntap: orphan frags before trying to set tx timestamp tuntap: purge socket error queue on detach qlcnic: use standard NAPI weights ipv6:introduce function to find route for redirect bnx2x: VF RSS support - VF side bnx2x: VF RSS support - PF side vxlan: Notify drivers for listening UDP port changes net: usbnet: update addr_assign_type if appropriate driver/net: enic: update enic maintainers and driver driver/net: enic: Exposing symbols for Cisco's low latency driver ...
2013-09-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/stmicro/stmmac/stmmac_platform.c net/bridge/br_multicast.c net/ipv6/sit.c The conflicts were minor: 1) sit.c changes overlap with change to ip_tunnel_xmit() signature. 2) br_multicast.c had an overlap between computing max_delay using msecs_to_jiffies and turning MLDV2_MRC() into an inline function with a name using lowercase instead of uppercase letters. 3) stmmac had two overlapping changes, one which conditionally allocated and hooked up a dma_cfg based upon the presence of the pbl OF property, and another one handling store-and-forward DMA made. The latter of which should not go into the new of_find_property() basic block. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-03Merge tag 'driver-core-3.12-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core patches from Greg KH: "Here's the big driver core pull request for 3.12-rc1. Lots of tiny changes here fixing up the way sysfs attributes are created, to try to make drivers simpler, and fix a whole class race conditions with creations of device attributes after the device was announced to userspace. All the various pieces are acked by the different subsystem maintainers" * tag 'driver-core-3.12-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (119 commits) firmware loader: fix pending_fw_head list corruption drivers/base/memory.c: introduce help macro to_memory_block dynamic debug: line queries failing due to uninitialized local variable sysfs: sysfs_create_groups returns a value. debugfs: provide debugfs_create_x64() when disabled rbd: convert bus code to use bus_groups firmware: dcdbas: use binary attribute groups sysfs: add sysfs_create/remove_groups for when SYSFS is not enabled driver core: add #include <linux/sysfs.h> to core files. HID: convert bus code to use dev_groups Input: serio: convert bus code to use drv_groups Input: gameport: convert bus code to use drv_groups driver core: firmware: use __ATTR_RW() driver core: core: use DEVICE_ATTR_RO driver core: bus: use DRIVER_ATTR_WO() driver core: create write-only attribute macros for devices and drivers sysfs: create __ATTR_WO() driver-core: platform: convert bus code to use dev_groups workqueue: convert bus code to use dev_groups MEI: convert bus code to use dev_groups ...
2013-08-30mISDN: return -EINVAL on error in dsp_control_req()Dan Carpenter
If skb->len is too short then we should return an error. Otherwise we read beyond the end of skb->data for several bytes. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-07-26ISDN: convert class code to use dev_groupsGreg Kroah-Hartman
The dev_attrs field of struct class is going away soon, dev_groups should be used instead. This converts the mISDN class code to use the correct field. Acked-by: Karsten Keil <isdn@linux-pingi.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-19mISDN: replace sum of bitmasks with OR operation.Alexandru Juncu
Suggested by coccinelle and manually verified. Signed-off-by: Alexandru Juncu <alexj@rosedu.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-07-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "This is a re-do of the net-next pull request for the current merge window. The only difference from the one I made the other day is that this has Eliezer's interface renames and the timeout handling changes made based upon your feedback, as well as a few bug fixes that have trickeled in. Highlights: 1) Low latency device polling, eliminating the cost of interrupt handling and context switches. Allows direct polling of a network device from socket operations, such as recvmsg() and poll(). Currently ixgbe, mlx4, and bnx2x support this feature. Full high level description, performance numbers, and design in commit 0a4db187a999 ("Merge branch 'll_poll'") From Eliezer Tamir. 2) With the routing cache removed, ip_check_mc_rcu() gets exercised more than ever before in the case where we have lots of multicast addresses. Use a hash table instead of a simple linked list, from Eric Dumazet. 3) Add driver for Atheros CQA98xx 802.11ac wireless devices, from Bartosz Markowski, Janusz Dziedzic, Kalle Valo, Marek Kwaczynski, Marek Puzyniak, Michal Kazior, and Sujith Manoharan. 4) Support reporting the TUN device persist flag to userspace, from Pavel Emelyanov. 5) Allow controlling network device VF link state using netlink, from Rony Efraim. 6) Support GRE tunneling in openvswitch, from Pravin B Shelar. 7) Adjust SOCK_MIN_RCVBUF and SOCK_MIN_SNDBUF for modern times, from Daniel Borkmann and Eric Dumazet. 8) Allow controlling of TCP quickack behavior on a per-route basis, from Cong Wang. 9) Several bug fixes and improvements to vxlan from Stephen Hemminger, Pravin B Shelar, and Mike Rapoport. In particular, support receiving on multiple UDP ports. 10) Major cleanups, particular in the area of debugging and cookie lifetime handline, to the SCTP protocol code. From Daniel Borkmann. 11) Allow packets to cross network namespaces when traversing tunnel devices. From Nicolas Dichtel. 12) Allow monitoring netlink traffic via AF_PACKET sockets, in a manner akin to how we monitor real network traffic via ptype_all. From Daniel Borkmann. 13) Several bug fixes and improvements for the new alx device driver, from Johannes Berg. 14) Fix scalability issues in the netem packet scheduler's time queue, by using an rbtree. From Eric Dumazet. 15) Several bug fixes in TCP loss recovery handling, from Yuchung Cheng. 16) Add support for GSO segmentation of MPLS packets, from Simon Horman. 17) Make network notifiers have a real data type for the opaque pointer that's passed into them. Use this to properly handle network device flag changes in arp_netdev_event(). From Jiri Pirko and Timo Teräs. 18) Convert several drivers over to module_pci_driver(), from Peter Huewe. 19) tcp_fixup_rcvbuf() can loop 500 times over loopback, just use a O(1) calculation instead. From Eric Dumazet. 20) Support setting of explicit tunnel peer addresses in ipv6, just like ipv4. From Nicolas Dichtel. 21) Protect x86 BPF JIT against spraying attacks, from Eric Dumazet. 22) Prevent a single high rate flow from overruning an individual cpu during RX packet processing via selective flow shedding. From Willem de Bruijn. 23) Don't use spinlocks in TCP md5 signing fast paths, from Eric Dumazet. 24) Don't just drop GSO packets which are above the TBF scheduler's burst limit, chop them up so they are in-bounds instead. Also from Eric Dumazet. 25) VLAN offloads are missed when configured on top of a bridge, fix from Vlad Yasevich. 26) Support IPV6 in ping sockets. From Lorenzo Colitti. 27) Receive flow steering targets should be updated at poll() time too, from David Majnemer. 28) Fix several corner case regressions in PMTU/redirect handling due to the routing cache removal, from Timo Teräs. 29) We have to be mindful of ipv4 mapped ipv6 sockets in upd_v6_push_pending_frames(). From Hannes Frederic Sowa. 30) Fix L2TP sequence number handling bugs, from James Chapman." * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1214 commits) drivers/net: caif: fix wrong rtnl_is_locked() usage drivers/net: enic: release rtnl_lock on error-path vhost-net: fix use-after-free in vhost_net_flush net: mv643xx_eth: do not use port number as platform device id net: sctp: confirm route during forward progress virtio_net: fix race in RX VQ processing virtio: support unlocked queue poll net/cadence/macb: fix bug/typo in extracting gem_irq_read_clear bit Documentation: Fix references to defunct linux-net@vger.kernel.org net/fs: change busy poll time accounting net: rename low latency sockets functions to busy poll bridge: fix some kernel warning in multicast timer sfc: Fix memory leak when discarding scattered packets sit: fix tunnel update via netlink dt:net:stmmac: Add dt specific phy reset callback support. dt:net:stmmac: Add support to dwmac version 3.610 and 3.710 dt:net:stmmac: Allocate platform data only if its NULL. net:stmmac: fix memleak in the open method ipv6: rt6_check_neigh should successfully verify neigh if no NUD information are available net: ipv6: fix wrong ping_v6_sendmsg return value ...
2013-07-03drivers: avoid format string in dev_set_nameKees Cook
Calling dev_set_name with a single paramter causes it to be handled as a format string. Many callers are passing potentially dynamic string content, so use "%s" in those cases to avoid any potential accidents, including wrappers like device_create*() and bdi_register(). Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-28isdn: Correct comparison of skb->tail and skb-transport_headerSimon Horman
This corrects an regression introduced by "net: Use 16bits for *_headers fields of struct skbuff" when NET_SKBUFF_DATA_USES_OFFSET is not set. In that case skb->tail will be a pointer whereas skb->transport_header will be an offset from head. This is corrected by using wrappers that ensure that the comparison is always between pointers. Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-20isdn/kcapi: fix a small underflowDan Carpenter
In get_capi_ctr_by_nr() and get_capi_appl_by_nr() the parameter comes from skb->data. The current code can underflow to one space before the start of the array. The sanity check isn't needed in __get_capi_appl_by_nr() but I changed it to match the others. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull VFS updates from Al Viro, Misc cleanups all over the place, mainly wrt /proc interfaces (switch create_proc_entry to proc_create(), get rid of the deprecated create_proc_read_entry() in favor of using proc_create_data() and seq_file etc). 7kloc removed. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (204 commits) don't bother with deferred freeing of fdtables proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h proc: Make the PROC_I() and PDE() macros internal to procfs proc: Supply a function to remove a proc entry by PDE take cgroup_open() and cpuset_open() to fs/proc/base.c ppc: Clean up scanlog ppc: Clean up rtas_flash driver somewhat hostap: proc: Use remove_proc_subtree() drm: proc: Use remove_proc_subtree() drm: proc: Use minor->index to label things, not PDE->name drm: Constify drm_proc_list[] zoran: Don't print proc_dir_entry data in debug reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show() proc: Supply an accessor for getting the data from a PDE's parent airo: Use remove_proc_subtree() rtl8192u: Don't need to save device proc dir PDE rtl8187se: Use a dir under /proc/net/r8180/ proc: Add proc_mkdir_data() proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h} proc: Move PDE_NET() to fs/proc/proc_net.c ...
2013-05-01Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "Highlights (1721 non-merge commits, this has to be a record of some sort): 1) Add 'random' mode to team driver, from Jiri Pirko and Eric Dumazet. 2) Make it so that any driver that supports configuration of multiple MAC addresses can provide the forwarding database add and del calls by providing a default implementation and hooking that up if the driver doesn't have an explicit set of handlers. From Vlad Yasevich. 3) Support GSO segmentation over tunnels and other encapsulating devices such as VXLAN, from Pravin B Shelar. 4) Support L2 GRE tunnels in the flow dissector, from Michael Dalton. 5) Implement Tail Loss Probe (TLP) detection in TCP, from Nandita Dukkipati. 6) In the PHY layer, allow supporting wake-on-lan in situations where the PHY registers have to be written for it to be configured. Use it to support wake-on-lan in mv643xx_eth. From Michael Stapelberg. 7) Significantly improve firewire IPV6 support, from YOSHIFUJI Hideaki. 8) Allow multiple packets to be sent in a single transmission using network coding in batman-adv, from Martin Hundebøll. 9) Add support for T5 cxgb4 chips, from Santosh Rastapur. 10) Generalize the VXLAN forwarding tables so that there is more flexibility in configurating various aspects of the endpoints. From David Stevens. 11) Support RSS and TSO in hardware over GRE tunnels in bxn2x driver, from Dmitry Kravkov. 12) Zero copy support in nfnelink_queue, from Eric Dumazet and Pablo Neira Ayuso. 13) Start adding networking selftests. 14) In situations of overload on the same AF_PACKET fanout socket, or per-cpu packet receive queue, minimize drop by distributing the load to other cpus/fanouts. From Willem de Bruijn and Eric Dumazet. 15) Add support for new payload offset BPF instruction, from Daniel Borkmann. 16) Convert several drivers over to mdoule_platform_driver(), from Sachin Kamat. 17) Provide a minimal BPF JIT image disassembler userspace tool, from Daniel Borkmann. 18) Rewrite F-RTO implementation in TCP to match the final specification of it in RFC4138 and RFC5682. From Yuchung Cheng. 19) Provide netlink socket diag of netlink sockets ("Yo dawg, I hear you like netlink, so I implemented netlink dumping of netlink sockets.") From Andrey Vagin. 20) Remove ugly passing of rtnetlink attributes into rtnl_doit functions, from Thomas Graf. 21) Allow userspace to be able to see if a configuration change occurs in the middle of an address or device list dump, from Nicolas Dichtel. 22) Support RFC3168 ECN protection for ipv6 fragments, from Hannes Frederic Sowa. 23) Increase accuracy of packet length used by packet scheduler, from Jason Wang. 24) Beginning set of changes to make ipv4/ipv6 fragment handling more scalable and less susceptible to overload and locking contention, from Jesper Dangaard Brouer. 25) Get rid of using non-type-safe NLMSG_* macros and use nlmsg_*() instead. From Hong Zhiguo. 26) Optimize route usage in IPVS by avoiding reference counting where possible, from Julian Anastasov. 27) Convert IPVS schedulers to RCU, also from Julian Anastasov. 28) Support cpu fanouts in xt_NFQUEUE netfilter target, from Holger Eitzenberger. 29) Network namespace support for nf_log, ebt_log, xt_LOG, ipt_ULOG, nfnetlink_log, and nfnetlink_queue. From Gao feng. 30) Implement RFC3168 ECN protection, from Hannes Frederic Sowa. 31) Support several new r8169 chips, from Hayes Wang. 32) Support tokenized interface identifiers in ipv6, from Daniel Borkmann. 33) Use usbnet_link_change() helper in USB net driver, from Ming Lei. 34) Add 802.1ad vlan offload support, from Patrick McHardy. 35) Support mmap() based netlink communication, also from Patrick McHardy. 36) Support HW timestamping in mlx4 driver, from Amir Vadai. 37) Rationalize AF_PACKET packet timestamping when transmitting, from Willem de Bruijn and Daniel Borkmann. 38) Bring parity to what's provided by /proc/net/packet socket dumping and the info provided by netlink socket dumping of AF_PACKET sockets. From Nicolas Dichtel. 39) Fix peeking beyond zero sized SKBs in AF_UNIX, from Benjamin Poirier" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1722 commits) filter: fix va_list build error af_unix: fix a fatal race with bit fields bnx2x: Prevent memory leak when cnic is absent bnx2x: correct reading of speed capabilities net: sctp: attribute printl with __printf for gcc fmt checks netlink: kconfig: move mmap i/o into netlink kconfig netpoll: convert mutex into a semaphore netlink: Fix skb ref counting. net_sched: act_ipt forward compat with xtables mlx4_en: fix a build error on 32bit arches Revert "bnx2x: allow nvram test to run when device is down" bridge: avoid OOPS if root port not found drivers: net: cpsw: fix kernel warn on cpsw irq enable sh_eth: use random MAC address if no valid one supplied 3c509.c: call SET_NETDEV_DEV for all device types (ISA/ISAPnP/EISA) tg3: fix to append hardware time stamping flags unix/stream: fix peeking with an offset larger than data in queue unix/dgram: fix peeking with an offset larger than data in queue unix/dgram: peek beyond 0-sized skbs openvswitch: Remove unneeded ovs_netdev_get_ifindex() ...
2013-04-30Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree updates from Jiri Kosina: "Usual stuff, mostly comment fixes, typo fixes, printk fixes and small code cleanups" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (45 commits) mm: Convert print_symbol to %pSR gfs2: Convert print_symbol to %pSR m32r: Convert print_symbol to %pSR iostats.txt: add easy-to-find description for field 6 x86 cmpxchg.h: fix wrong comment treewide: Fix typo in printk and comments doc: devicetree: Fix various typos docbook: fix 8250 naming in device-drivers pata_pdc2027x: Fix compiler warning treewide: Fix typo in printks mei: Fix comments in drivers/misc/mei treewide: Fix typos in kernel messages pm44xx: Fix comment for "CONFIG_CPU_IDLE" doc: Fix typo "CONFIG_CGROUP_CGROUP_MEMCG_SWAP" mmzone: correct "pags" to "pages" in comment. kernel-parameters: remove outdated 'noresidual' parameter Remove spurious _H suffixes from ifdef comments sound: Remove stray pluses from Kconfig file radio-shark: Fix printk "CONFIG_LED_CLASS" doc: put proper reference to CONFIG_MODULE_SIG_ENFORCE ...
2013-04-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/broadcom/bnx2x/bnx2x_main.c drivers/net/ethernet/emulex/benet/be.h include/net/tcp.h net/mac802154/mac802154.h Most conflicts were minor overlapping stuff. The be2net driver brought in some fixes that added __vlan_put_tag calls, which in net-next take an additional argument. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-29mISDN: grabbing/dropping reference to THIS_MODULE in open/release is racyAl Viro
... when you have no ->owner set. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-04-29mISDN: fix mISDN_read()/mISDN_read() raceAl Viro
2013-04-29mISDN: fix misdn_add_timer()/misdn_del_timer() raceAl Viro
do add_timer() *before* unlocking dev->lock, or unpleasant things can happen if misdn_del_timer() on another CPU finds the sucker, calls del_timer_sync() (which does nothing, since we hadn't started the timer yet) and frees it, just as we get around to add_timer()... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-04-29mISDN: fix races between misdn_del_timer() and timer callbackAl Viro
mark the victim with negative ->id if misdn_del_timer() finds it on the list, have timer callback *not* move ones so marked to dev->expired Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-04-29mISDN: fix the races with timers going off just as they are deletedAl Viro
timer callback in timerdev.c both accesses struct mISDNtimer it's called for *and* moves it to dev->expired. We need del_timer_sync(), or we risk kfree() freeing it right under dev_expire_timer() *and* dev->expired getting corrupted. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-04-29Merge tag 'tty-3.10-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull tty/serial driver update from Greg Kroah-Hartman: "Here's the big tty/serial driver merge request for 3.10-rc1 Once again, Jiri has a number of TTY driver fixes and cleanups, and Peter Hurley came through with a bunch of ldisc fixes that resolve a number of reported issues. There are some other serial driver cleanups as well. All of these have been in the linux-next tree for a while" * tag 'tty-3.10-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (117 commits) tty/serial/sirf: fix MODULE_DEVICE_TABLE serial: mxs: drop superfluous {get|put}_device serial: mxs: fix buffer overflow ARM: PL011: add support for extended FIFO-size of PL011-r1p5 serial_core.c: add put_device() after device_find_child() tty: Fix unsafe bit ops in tty_throttle_safe/unthrottle_safe serial: sccnxp: Replace pdata.init/exit with regulator API serial: sccnxp: Do not override device name TTY: pty, fix compilation warning TTY: rocket, fix compilation warning TTY: ircomm: fix DTR being raised on hang up TTY: synclinkmp: fix DTR being raised on hang up TTY: synclink_gt: fix DTR being raised on hang up TTY: synclink: fix DTR being raised on hang up serial: 8250_dw: Fix the stub for dw8250_probe_acpi() serial: 8250_dw: Convert to devm_ioremap() serial: 8250_dw: Set port capabilities based on CPR register serial: 8250_dw: Let ACPI code extract the DMA client info serial: 8250_dw: Support clk framework also with ACPI serial: 8250_dw: Enable runtime PM ...
2013-04-25isdn/sc: Fix incorrect module_param_array typesGeert Uytterhoeven
drivers/isdn/sc/init.c: In function ‘__check_irq’: drivers/isdn/sc/init.c:36: warning: return from incompatible pointer type drivers/isdn/sc/init.c: In function ‘__check_ram’: drivers/isdn/sc/init.c:37: warning: return from incompatible pointer type Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-25isdn: mISDN: set ->family in ->getname()Dan Carpenter
The "maddr->family" variable was not set but instead it leaked stack information to userspace. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-09procfs: new helper - PDE_DATA(inode)Al Viro
The only part of proc_dir_entry the code outside of fs/proc really cares about is PDE(inode)->data. Provide a helper for that; static inline for now, eventually will be moved to fs/proc, along with the knowledge of struct proc_dir_entry layout. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-04-09hysdn: stash pointer to card into proc_dir_entry->dataAl Viro
no need to search later - we know the card when we are creating procfs entries Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-04-02ISDN:divert: beautify code: useless 'break', 'return (0)', additional comments.Chen Gang
delete useless 'break' after 'return'. let 'return 0' instead of 'return (0)' also give a comment for 'break' to let readers notice it. Signed-off-by: Chen Gang <gang.chen@asianux.com> Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-01Merge 3.9-rc5 into tty-nextGreg Kroah-Hartman
We need the fixes here as well. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-28net: add ETH_P_802_3_MINSimon Horman
Add a new constant ETH_P_802_3_MIN, the minimum ethernet type for an 802.3 frame. Frames with a lower value in the ethernet type field are Ethernet II. Also update all the users of this value that David Miller and I could find to use the new constant. Also correct a bug in util.c. The comparison with ETH_P_802_3_MIN should be >= not >. As suggested by Jesse Gross. Compile tested only. Cc: David Miller <davem@davemloft.net> Cc: Jesse Gross <jesse@nicira.com> Cc: Karsten Keil <isdn@linux-pingi.de> Cc: John W. Linville <linville@tuxdriver.com> Cc: Johannes Berg <johannes@sipsolutions.net> Cc: Bart De Schuymer <bart.de.schuymer@pandora.be> Cc: Stephen Hemminger <stephen@networkplumber.org> Cc: Patrick McHardy <kaber@trash.net> Cc: Marcel Holtmann <marcel@holtmann.org> Cc: Gustavo Padovan <gustavo@padovan.org> Cc: Johan Hedberg <johan.hedberg@gmail.com> Cc: linux-bluetooth@vger.kernel.org Cc: netfilter-devel@vger.kernel.org Cc: bridge@lists.linux-foundation.org Cc: linux-wireless@vger.kernel.org Cc: linux1394-devel@lists.sourceforge.net Cc: linux-media@vger.kernel.org Cc: netdev@vger.kernel.org Cc: dev@openvswitch.org Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Acked-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-26Merge tag 'arizona-extcon-asoc' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/misc into char-misc-next Mark writes: ASoC/extcon: arizona: Fix interaction between HPDET and headphone outputs This patch series covers both ASoC and extcon subsystems and fixes an interaction between the HPDET function and the headphone outputs - we really shouldn't run HPDET while the headphone is active. The first patch is a refactoring to make the extcon side easier.
2013-03-21Merge 3.9-rc3 into tty-nextGreg Kroah-Hartman
